Keyless entry
Get your remote, hold the valet button between FM/CD buttonsfor 5 seconds. you should hear the locks unlock. Then while holding the valet button within 10sec hit one of the transmitter buttons and they will activate. After they have been programed turn the ign switch off and hit one of the buttons 6 times to make them start to work.
you might find a transmitter on ebay or will need to go to the dealer.
Re: (150sol)
You have to retain the factory stereo for the OEM system to work. If you have an aftermarket radio, chances are they didn't install it properly. Your keyless wont work and your dome light wont come on when a door is opened. The proper way is to take apart the factory radio so that it fits behind the new radio. Then install a Y adapter harness so that both stereo's are powered up. Metra and other companies make these stereo Y adapter harnesses.
Quite frankly the factory keyless module sucks and should be replaced with an alarm that has a keyless option. Then you can dump the factory stereo. When you install an aftermarket stereo, two wires in the stereo harness need to be cut and wired together. Any competent install shop should know how to do this.
This info applies only to 96-98 Civics with factory keyless.
Does it matter what remote I get? Is there a certain model that I need? Also, I found a post on this last night and is there a module that I need that hooks to the radio?
re2417
16
06-07-2012 04:43 PM
jshooter
33
09-23-2009 07:05 PM
viciousclipse
06-22-2009 04:12 AM
Si_GReddy
Audio / Security / Video
09-05-2003 07:10 AM
