ecu looking for a pressure switch, and my solenoid is missing it.
1 Post
the gsr is a jdm and the solenoid only has one plug the vtec one...the ecu is looking for the pressure switch...is this preventing vtec from kicking in?
also when i check A4 pin witha voltmeter it is constantly powered? is this correct?
will vtec kick with out the pressure switch?
Modified by Dead CIVIC at 1:10 PM 7/13/2008
Seagull Management
Re: ecu looking for a pressure switch, and my solenoid is missing it. (Dead CIVIC)
if the ecu is looking for the vtec pressure switch and you don't have one get another vtec solinoid that does, some JDM B series vtec engines do not have a vtec pressure switch and the corresponding ECU doesn't look for it.
1 Post
Re: ecu looking for a pressure switch, and my solenoid is missing it. (94EG8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 »</TD></TR><TR><TD CLASS="quote">if the ecu is looking for the vtec pressure switch and you don't have one get another vtec solinoid that does, some JDM B series vtec engines do not have a vtec pressure switch and the corresponding ECU doesn't look for it.</TD></TR></TABLE>
yeah i'm trying to find one, and im curious to know it the vtec should still be engaging?
1 Post
Re: (94EG8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 »</TD></TR><TR><TD CLASS="quote">should be throwing a CEL and not engaging, someone correct me if i am wrong</TD></TR></TABLE>
yeah it is throwinng a CEL and not engaing. so then i need the solenid that comes with it.
1 Post
Re: (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">if you are running a us ecu then yes you need the us vtec solenolid that has the solenoid wire and the vtec pressure switch</TD></TR></TABLE>
cool tanks for that... do i need to buy the ex harness or will running the wires work.?
Re: (Dead CIVIC)
if you have a vtec harness already then the plug should be there, but if not just go to the junkyard and cut off a plug and wire it straight to the ecu
Takumi Fujiwara
07-23-2006 09:18 PM
