Synchromesh....will it help kill the grind in 3rd?
I have a 92 VX hatch with 134k on the body, not sure when the clutch was done last (if ever) but it still feels like it has a good amount of life. It grinds when shifting from 2nd to 3rd at around 5-6k RPM. It only started doing this a few weeks ago. It's a slight grind, nothing terrible. It won't grind at a lower RPM. I've heard this has a lot to do with clutch wear and synchros. I've also read quite a bit about Synchromesh MT oil and synchro grinding dissapearing. Have you guys had any experience with Syncromesh and has it been positive?
http://www.stealth316.com/2-pe...h.htm
Thanks...
**edit**
What brand are you using?
Modified by axiomjunglist at 9:40 PM 7/24/2006
Thanks...
**edit**
Re: Synchromesh....will it help kill the grind in 3rd? (xtrec02)
Worked for me, it was grinding so bad I used to skip third gear completely and feather it into fourth. When we put it in we were told it usually takes a couple of days to lube up everything. Havn't had a grind since putting it in. Its worth the $45.
Re: Synchromesh....will it help kill the grind in 3rd? (STN_DX)
i have the same problem man. it grinds from second to third when vtec is engaged in second. i just changed my tranny fluid with honda mtf. i'll try that gm synchromesh fluid next time.
Re: Synchromesh....will it help kill the grind in 3rd? (babyboy9o7)
hrm, I never knew that this was a commen problem, i thought my clutch was that bad. no other gears grind its just when i shift 3rd when vtec is engaged, that i grind.
I will have to also try this
Re: Synchromesh....will it help kill the grind in 3rd? (axiomjunglist)
23623-P21-315 #007 SLEEVE SET, SYNCHRONIZER (3-4) $162.83
this is the replacement part you need. totally kill the grind, dont bandaid it.
Re: Synchromesh....will it help kill the grind in 3rd? (Marcpb443)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH »</TD></TR><TR><TD CLASS="quote">23623-P21-315 #007 SLEEVE SET, SYNCHRONIZER (3-4) $162.83
this is the replacement part you need. totally kill the grind, dont bandaid it. </TD></TR></TABLE>
Most people dont need to change the syncros, if u try syncromesh and the grind goes away your good, but if theres not improvement then yeah, time to change the syncro's
Re: Synchromesh....will it help kill the grind in 3rd? (SohcPower)
its not just the syncro that needs replacing albert, its the syncro spring, hub and collar also!!!
Re: Synchromesh....will it help kill the grind in 3rd? (SkRiBLaH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH »</TD></TR><TR><TD CLASS="quote">its not just the syncro that needs replacing albert, its the syncro spring, hub and collar also!!!</TD></TR></TABLE>
wtf are u talking about? read wat i posted.
that gives me a good idea of what I need to do. I wanted to hear some success stories before I bought some and put it in. Are you guys using the Pennzoil or some other brand? Curious...
Re: Synchromesh....will it help kill the grind in 3rd? (kucherenko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kucherenko »</TD></TR><TR><TD CLASS="quote">Synchoromesh covers up the grinds really well. </TD></TR></TABLE>
like this dude said, it covers it up well, like a bandaid. Thats like a dog taking a **** and putting newspapers on it, it doesnt fix anything, just masks it.
I just hope you don't sell your car saying that the tranny has no grinds, thats all.
phoenixR
12-26-2002 06:02 AM
