Potential bad ECT Gauge Sending Unit
Old Jun 7, 2021 | 08:19 PM
Pantera96's Avatar
Icon5 Potential bad ECT Gauge Sending Unit
So I own a 1997 EJ8 Civic with a D16Y8 and ever since I bought the car, the gauge temp shows way too low temperatures.
The gauge basically shows three positions: fully cold below cold mark, slightly above cold mark and the maximum value is a bit above 1/4 maybe 3/8.
The car has a new thermostat and coolant. I tested the old thermostat and it worked just fine. The radiator fans are not always on. So then I think my problem cames from the ECT gauge sending unit.
What do you guys think? Could this sensor be sending wrong values to the gauge?
Also I tried connecting an obd2 cheap bluetooth scanner to compare with the ecu temp reading but apparently my car doesn't have an obd2 port. Maybe because it was sold outside the US? (Even though it was made in the US)
Old Jun 12, 2021 | 11:42 AM
Pantera96's Avatar
Default Re: Potential bad ECT Gauge Sending Unit
Bump
Old Jun 13, 2021 | 06:10 PM
tony_2018's Avatar
Fish Twig
I would test it.
Old Jun 14, 2021 | 04:15 AM
Pantera96's Avatar
Update: I changed the sensor and it immediately started working like it should.
An odd detail is that the old sensor had a smaller nut size (1 mm) than the new one. Maybe it was meant for another model and that's why I was getting inaccurate readings?
Anyway, I'm happy I finally solved it :D
Jack Murphy
Aug 8, 2017 05:14 PM
tegmoc90
Mar 29, 2010 06:22 AM
TshingY
Jan 25, 2010 12:59 PM
Fook_me_honda
Jan 22, 2010 05:04 AM
signal9
Sep 4, 2008 09:21 PM
