OBD scanner low voltage.
Recently picked up a EJ, took it to get smogged, smog guy hooked his scanner up but kept getting "low voltage" error.
I took the car home and looked under steering column, to find out somebody tried to install aftermarket alarm system, what would be the best place for me to start for correcting the smog issue?
Thanks for any help.
Re: OBD scanner low voltage.
What year Civic?
its a 96..
update: i took the car after driving for 45 mins and now its able to be read, but now i have a oxygen sensor monitor and Catalyst Monitor failure..
thanks for the responses
Maybe check your Alternator then battery then power wires and grounds. If you drove around and it was able to read, the battery had to be low on power or the alternator is getting tired of recharging the battery.
I just recently bought a brand new alternator and battery, maybe a month ago, but ill go over the wiring.. thank you
Does the scanner work when plugged into other cars? If so, measure the voltage on the power pin of the OBD2 connector. Also measure continuity to body ground on the ground pin. I think there are only three pins in the connector.
caliprelude3087
01-22-2006 12:08 PM
