CEL code reading problems
Old Oct 29, 2021 | 06:03 PM
tico:)'s Avatar
Default CEL code reading problems
so... i have a 96 coupe with a d16z6 swapped into it, vtec and obd1 converted, and when it rains, some sensor gets wet and shorts and it throws a code and the CEL turns on and makes the car run pretty rough (idling at around 1700, won't go past 4000rpms) but still drives fine i guess but when it's warm and dry there's no CEL and the car absolutely shreds just like normal. point of the story is i need to figure out what sensor is getting wet and shorting and so i need to read the code to find out, so i connect the two holes of the blue connector with the paper clip to read the code if you guys know what i'm talking about and... the CEL doesn't flash any codes and just stays solid???? the paper clip is all the way in and i know it is making a connection because when i have the paper clip in the connector, the SRS light flashes when normally it just stays on solid (because i don't have a bag in the steering wheel) so i have no idea what's going on has anyone every experienced this?
Old Oct 30, 2021 | 09:47 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: CEL code reading problems
CEL on solid with jumper installed is when it doesn't have a code and is in service mode for setting ignition timing etc.
Have you tried to jumper it when CEL comes on without shutting the car off? If the 7.5A backup fuse is blown it will not store codes as it resets itself as soon as the car is shut off.
Old Oct 31, 2021 | 01:04 AM
tico:)'s Avatar
connecting the jumper while the car is already on yields the same result. do you know how i could fix this??? it makes the car run soooo bad and slow
Old Oct 31, 2021 | 07:10 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I would start hunting around for water when it happens if you cannot get a code.
Old Nov 1, 2021 | 09:01 AM
tico:)'s Avatar
well actually something strange happened today. just had two days of dry weather and the code never went away, and it rained last night and i get in the car this morning and the code was actually gone and it was running just fine so i guess the rain isn't what is causing it. i don’t know
Old Nov 1, 2021 | 04:08 PM
tico:)'s Avatar
i have found that there is some water next to the fuse box and harnesses next to the clutch pedal but none of the fuses are wet or anything so i don’t know if that would be causing it
Old Nov 1, 2021 | 08:52 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I would crack open the ECU. I suspect the capacitors may have popped or are going to.
You could also have some grounding problems. If I recall there is some grounds in the area you mentioned water. You could also have a bad seem seal under the fender in the pillar area as per a TSB Honda put out about it.
Old Nov 2, 2021 | 06:24 AM
tico:)'s Avatar
i have checked the ecu before, as for the grounds, i think i recall one of them being rusty down near the clutch pedal and fuses, how would i go about fixing that and making it a good ground again?
Old Nov 2, 2021 | 08:23 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
sand paper works wonders on rusted metal to make it shiny again
89luderSi
Oct 25, 2011 10:54 AM
1251_ks
Honda Civic (2001 - 2005)
Oct 7, 2010 03:39 AM
karrar55
Aug 29, 2009 04:52 AM
emanLS
Oct 20, 2003 01:15 PM
