View Full Version : Forced Induction
- GSC T1 VTEC RPM
- Recommended Intake manifold for my setup? B-series
- Feed and return line sizing
- Turbo LS floods on startup.
- z10 sleeves
- from turbo to n/a
- Turbo on a freshly rebuilt D16z6.
- Turbo b16
- AMS FMIC ???
- Todallybuilt's B20/VTEC Build
- 3" High Flow Cat Question - 96-00 Coupe
- Stock block f20b dyno results
- Question about Water Meth Injection
- Controlling boost issues
- what is the purpose of this tank?
- e85 fuel pump question
- Tap for oil catch can feed
- Lookin for suggestions for my b20 build.
- Need suggestion on which valve locks to buy
- Exhaust Manifold Design
- Turbo, oil and coolant sources
- Help with SAFC hack for boost.
- B16a turbo questions
- 1000 miles in, have a look at these pistons please
- First turbo build
- No power when cold
- Question about Type R Valve Springs and Retainers
- Turbo Suggestions
- Low(ish) cost d16z6 turbo build
- Nippon cast K20 PRC pistons... How far would you push them?
- EKCivic14's "Budget" DA9 Turbo Integra Progress Build
- New member
- b20 vtec turbo charger + Supercharger
- Treadstone Intercooler
- coolant over flow reservoir
- 1991 Hatch D16Z6 Turbo - Precision 5431E
- new b20b turbo, questions on exhaust and boost control.
- LSV
- B16 turbo blowing head gasket. Good Advice would be appreciated
- T28 cast manifold?
- b16a2 turbo have 2 hoses need info on them
- ECU Help!!!!!
- Single cam vtec, boosted?
- Ls/v cutting out at 7800rpm. Please help!
- rebuilt turbo parts
- Drag Ef rebuild
- cheap ass turbo exhaust where to buy?
- What is the best to use for turbo? K24 or k20?
- B18B1 new turbo running rich
- wastegate vs bov
- I need help with piston ring gap
- Build almost done, B18B1, HX40.........E85?
- Pushing the RDX platform further (DYNO and TIMESLIPS)
- How many of you are running a boosted honda with or without LSD
- Stock internal b18c5 turbo options
- 600+ whp trans choices...
- johnie1199's "800whp or bust" ACHIEVED!! - lsvtec progress build
- b20 turbo build in progress, need advice
- Question on Holset HX35 w/ BEP housing
- Has anyone used JE Pro Seal headgasket for their turbo build?
- Valve springs issue
- Any one have any experience with STC "Hunter" turbo.
- PSI for 350hp
- What HP can I expect with a Z6 and 7psi from a TD04Hl 13G
- Turbonetics t3/t4
- Where did you buy your oil feed and return lines
- Turbo's Center Section/Seal Question
- Which engine to use in my 98 ek for turbo build
- Please help me learn more about this unit
- Oil restrictors: Fittings or Flange style? Multiple turbos destroyed
- Engine Coolant Temperature and IAT
- Want to Know your hp b20turbo
- would you install a Block Guard on a B20 turbo
- What are you guys seeing for oil pressure? Not liking mine.
- 2016 mods and plans
- B16 ringland failure?
- JDM D15b VTEC.
- Garrett Turbo Help
- EG Civic Bezel Gauge Pods???
- Twin Screw Supercharger Compatibility?
- sp methonal pump help
- bad battery can cause performance issues
- crx w/b18b1 turbo?
- MHI standard rotation turbine wheel with right hand threads?!?
- My Turbo EG Hatch
- Rebirth of Greddy CARB stickers anyone???
- b16a turbo over heating when A/C is on-*Solved* Replace Radiator!
- Big turbo B16 timimg advices
- Biggest Turbo for AC/PS setup
- Is 220,XXX too high of mileage to start modifying?
- Reasonable turbo upgrade for daily driver?
- Remove copper o-ring ok???
- Reliable 350hp Daily Driver
- Best forged pistons for a cold weather turbo K24A1?
- 500whp and a street tune?
- Let's talk boost + IAT sensor
- Del sol si b18 block b20 head swap with GSP t35 turbo EMUSA manifold
- Dyno graph breaking up at high RPM
- I need help. Civic not making [enough] boost.
- A/F ratio questions
- Built Integra Gsr Turbo smoking and afr problem
- water cooled turbo: return line?
- What causes boost threshold???
- B20z2 to supercharge or to turbo?
- Your opinion on turbo setup
- Won't boost past 1psi
- Need help! NEED TURBO BASEMAP Z6 HONDATA S300
- STC surfer vs predator turbo review
- Bought a turbo kit, damaged intercooler
- Oil Restrictor for Borg warner journal bearing
- Turbo prep
- BWR downpipes?
- GSR Trans wheel spin
- Intercooler piping + battery in bumper
- Built B18B head on stock b18b block
- K24a3 head or k24a2 head or k20a2 head fro turbo application ?
- knock sensor question! help!
- What to do before I turbo my civic?
- Garrett T25 off of Nissan S13 questions.
- boosting a B Swap
- B18B Turbo Build - Advice Needed
- Closed deck or open deck sleeve
- DAILY DRIVEN Honda turbocharger longevity
- Turbo Suggestions on My Build.
- Anyone Running Skunk2 Ultra Manifold
- Downpipe started smoking
- K24 turbo, k20 6 speed tranny? Or 5 speed Honda stream tranny?
- Harmonic balancer/crank pulley?
- Intake Manifold upgrade
- turbo B18a1 engine build
- Suggestions on sleeves for b18c
- Compression and leak down results
- Kraftwerks Supercharger on B Series
- B18 turbo camshaft help
- Looking to buy a new turbo questions
- K20/24 Build Questions
- Newbie!! 96 civic no boost
- What's weaker - stock pistons or stock conrods in a d15b vtec?
- d16z6 400hp?
- D15b7 Tiny Turbo help
- trying to boost my b18a1 in stock internals
- Garrett GT2871R
- questions on 2000cc ID injectors.
- WARNING about DNA Motoring, call to boycott
- Missfire at vtec crossover point
- T3 T04E Turbo Wheel Size
- wont idle in closed loop
- Wastegate dilemma noob
- b20b non v turbo build to 400whp e85 the needs
- Garrett Super t70 Too big for a built b16a2??
- Help! Did my fuel pump short out?
- 00 civic turbo battery issues
- Biggest size turbo ran on ramhorn w/ AC?!
- Oversquare setup for Turbo
- Filter on turbo?
- Pre turbo water injection. lets talk about it
- dyno results
- D15B7 Jackson Racing Crome Tune - How does it look?
- edelbrock #1500 turbo kit for 00 civic question...
- Your go-to piston?
- EMS on a 1995 NSX
- Which Summit ignition box?
- Lsv turbo
- Turbo exhaust housing is wet
- Looking for new turbo - Built b18b1
- Intercooler Sizing
- d16z6 bearings
- Silver Surfer
- Best cams for k20 ported head turbo, 800+hp range
- Turbo EM1 HELP!
- Honda civic 1.6 2000
- different trims of vortech questions
- No air flow to radiator..... Need help!!!!!
- Engine turbo prep
- B20b Turbo questions
- D16z6 turbo NEW
- ID725 install, B18B, which intake cushions should I use?
- 93 Honda civic ex B18c1 turbo help
- T31 stage 2 stage 3 turbine housings and wheels
- 2014 K24 CVT transmission + forced induction = ?
- Cooling Engine Bay, Road Trip
- Need help with going boost. Ecu and injectors
- Recommend me an ems
- 500whp LS VTEC Running rich randomly. HELP!
- How much hp could this b16 handle?
- 82mm GSR turbo?
- Opinion on Turbo Setup
- Gap between Wastegate and manifold flange
- turbo ID help.
- 91 civic dx gonna do ls vtec turbo swap
- Timing vs iat vs boost
- Lowest whp turbo b16 in the country
- oil sludge? turbo gsr, need some help
- driving to tuner on new injectors????
- Eagle rods - What pistons?
- Jackson Racing Supercharger coolant hose question
- Best fuel pressure for RC750
- B-series build ideas
- Boost controller issue
- Stumbled upon this thing... B series billet cam tower girdle?
- J-series for Gatebil Extreme
- Metal head gasket for d16y8 turboed.
- LsVtec Turbo
- Ls turbo
- beware NoOb Questions!
- over boosting
- More boost on the stock K20A2 engine.... Continued.
- Locked
- No compression.
- Turbo inquiry
- Just cracked a sleeve. Recommendations for sleeving?
- 99 gsr turbo question
- Anything wrong with a high idle?
- Pusher fan help, pic inside - blade and motor direction
- B16 jrsc help
- Project Blue
- JRSC belt wants to slip off of idler pully
- Planning ~1000HP GSR Build
- Eg b16a2 turbo
- Lsvtec turbo running rich
- Draw through converted to blow through
- Deleted
- I dont read forum rules
- GT2860RS with e85
- mac solenoid 12v question
- B and R Fittings
- Freshly Supercharged D15B7 High Idle
- 96 Accord F22B Turbo Forced Induction
- Help turbo
- New ek hatch build needs a motor
- B18b1 turbo smokes
- Neptune+Demon p28 ecu q
- STC Reaper siR em1 build!
- Setup advice, B20V
- Blackworks 4 Port Catch Can Drain? Need Help
- Calling all JDM H23A Turbo owners!
- Turbo LS on the dyno again...B18B1 with SC50
- More Boost on JRSC
- Hondata require O2 sensor?
- Turbo vacuum line diameter
- b20vtec turbo problems with boost in high rpm
- Where can I get a flange or manifold for this turbo?
- Compression Ratio on these pistons
- Valve Seals/Guides 2015
- Question about Turbo charging
- What should compression test numbers be?
- 2.0l 130bhp standard Prelude
- Turbo with high compression?
- What Turbo is this?
