View Full Version : Forced Induction
- 2.5 Bar Mounting
- Code 1 with PLX wideband
- Questions on JRSC Race Kit on EP3.
- boosted n2o d16z6
- About my intercooler
- Has anyone ever dealt with Turbocalculator.com?
- LS/VTEC 550HP
- engine management question
- Precision 440 Identification help?
- Questions on Boost Creep
- 3" IP aluminum where to find in s/florida
- Any warranty on engine rebuild + aftermarket parts?
- 9.01 built engine, weird comp test results?
- Turbocharged H22 Civic - some issues..
- is my wheel okay?
- oil and watter colling turbo
- Mounting FMIC...no brackets?
- leaning out in higher rpm's no matter how much fuel i add??
- Florida Tuning Trip / Vacation Nov. 4 - ???
- Bought a turbo kit got a couple questions
- Signs a turbo needs a rebuild?
- ***PLEASE LOOK*** LS motor cutting out at 6500 rpm...!!!!
- Fluctuating idle - Uberdata problem, IACV problem, or vacuum leak?
- Oil weight question?
- D16 (y8) Clutch Recomendation
- Do I need a fuel pump?
- dished valves
- NEED PART # FOR GM BOOST Solenoid
- Just wondering, anyone from New England on here going to New England Dragway on the 22nd?
- Blitz DSBC Electronic Boost Controller Question...
- t3/60-1 vrs t3/t67
- Whats needed for a basemap
- Ok this is going to be a real stupid question. re: headgasket
- Turbo, blocking access to slave cylinder on 95 Integra
- Stock B16 boosted again...
- Average egt's at idle
- turbos and valvetrain
- Where to get t3 oil feed flange with 1/8" NPT threads?
- help me pick injectors
- Who tunes DFI gen 7 in south florida??
- turbo integra problems- wont rev pas 2k
- Calling those with DSM turbo setups on b18b's
- Jackson racing S/C for k20
- top mount
- Greddy oil catch can install question
- Want to go faster
- 2000 Integra Turbo, downpipe and Charge pipe w/air conditioning Picture request
- Any Vortech Sponsors here?
- Boosting my LS
- More Hondata Customer Service problems
- some help with my turbo 00 integra ls
- off season rebuild T4
- Uberdata users - how the heck do you tune past 7940 RPMs?
- Rocket's "CLUTCH 101" Tech Article Rehosted
- Any turbo DA's w/ A/C???
- Spraying nitrous through shifts with WOT activation on an auto tranny?
- who has experiance installing arp headstuds without removing the head? jdm d15b
- what valves in a turbo car?
- Sleeved Block
- Turbo B16 problems, whats your guess?
- Laskey Racing?
- b16 turbo kit?
- what size fuel line do i need?
- Nitrous Help Needed ...
- Is the TurboXS Boost Controller.....
- oil in compressor
- Will turbo XS RFL work at 7 psi?
- Fidanza flywheel making me lose rev?
- Tunner whinter park FL
- Timing too advanced?
- New to boost, have a few questions for HMT kit.
- What did they use to tune????
- Any one running a t3/60-1 turbo?
- I need help replacing piston rings on stock B20 pistons: w/turbo
- Displaying wideband on narrowband gauge
- B18a/b crank pulley
- High Imp. Injectors
- Holset/BW guys
- Looking for a Cheap Garrett GT28 disco patato
- tial wastegate pros/cons
- What engine management to use?
- boost b16 or gsr?
- 38mm tial wastgate. I need help with the vacume ports.
- original bore on brand new darton sleeves
- where 2 buy t4 to t3 adaper?
- resistor box / dsm 450cc
- AEM wideband compatible with emanage ultimate?
- Integra Apexi Turbo Kit?
- Intake air reverts back to compressor turbine. Pls help
- What are my turbo options?
- Installing ARP Studs: Motor Oil or Moly?
- avid motor mounts?
- some wierd stuff after new fuel filter intall.
- turbo car in the NE ?
- another greddy kit question... for 01 gsr.... help!
- Front mount and the rain
- ic piping: need a quick answer
- i need advice about modifing my fuel system
- 15g turbo on d16z6 dyno
- can you guys help me
- gt40r compressor size.....
- pin outs plezzzzz
- is this a good deal?
- What clutch/Flywheel for my goals.....
- OT : Protege Mazdaspeed fuel management ??
- Manley Rods
- chip ecu and gm3bar map sensor
- dsm Bov questions
- Greddy E-manage ULTIMATE
- dropped wastegate stud on Inline pro manifold
- which turbo to choose?
- Pics of b16 ACL RACE rodbearings.. Anyone?
- grs hesitate during start up???
- Lovefab vs. Bmc-race
- Oil Return line that goes on the drain plug, by Greddy
- Need Engine Rebuild - which Turbo to choose?
- Twin Superchargers!
- NEW Dyno 2.0 Liter ITR motor. Tuners and etc..post your thoughts.
- have a look see!
- are the zeitronix boost sensor just like a 3bar map sensor?
- Lightweight Crankshaft in Turbo motor.
- 1000cc and bigger
- looking for turbo h22 guys whats your comp.
- t3/t04b hp limits
- In depth problem, Solid CEL, Car wont start, Uberdata/450cc/OBD1-b18b1
- Help me read my plugs
- Getting Turbos Balanced
- HELP new to FORCE INDUCTION!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!
- golden eagle o-ring block?
- GSR Turbo question
- Mini me
- Broke bolt in head.. options?? :thumbdown:
- will this pass emissions??
- greddy blue box
- Tial WG physical size?
- anyone running a 4inch exhaust
- help turbo and ac!
- turbo project
- Max Torque for STOCK Headbolts? EMERGENCY
- throwing codes cant fix.need help
- GSR or LS tranny???
- Spark plug analysis
- oxygen sensor problem help?/
- effects of water/meth on a JRSC + stock ITR motor
- TurboSmart e-boost2?????
- Ninjas check in - 300whp rods for $155 shipped? *LINK*
- what size turbo for b16 1.7
- ts the proper way to place a egt probe?
- Retorquing ARP STUDS- any special instructions?
- 400hp 310tq turbocharged civic quarter mile time
- can't boost beyond 12 lbs.
- SOHC TURBO PLS HELP ASAP
- The monthly h22 MAHLE pistons thread..
- HKS Hi-power vs. Magnaflow oval muffler
- Engine Builders
- plug gap for h22a 8psi?
- exhuast goes pup pup after valve adjustment??
- Motorola 2.5 bar map sensor
- DSM injector problem?
- Question about an oil port on the head..
- piecing small turbo kit on bb6...t28?
- H22 BAR'd Swap: Which turbo kit do I need and is smog/CARB legal?
- sohc ex running 14psi with apexi-afc making 271-300whp???
- Sizing up a used turbo kit
- Greddy15G on a B16 . Questions peeps?
- Crush bent vs Mandrel Bent Charge piping AND 2.5'' vs 3.0'' DP
- ramhorn vs mini me
- Tial WG: 38mm or 44mm
- another turbo d16 build up with vitaras
- boosted b16 with stripped head... gets owned by my OCD engine building.
- GREDDY TT
- How many of you wasted money Building/Planning a turboset??
- AVC-R duty cycle calculation
- Turbo too big?
- Boost junkies....... what is this swap worth????????
- Will this budget scenario work? Greddy 15G (for 92-95 Civic) Turbo on a stock Y5 shortblock with a Z
- help on turbo d
- T4 GT35R vs. T4/T67 GTQ
- Lucas Oil Stabilizer as Assembly Lube
- running more boost.....
- Would anyone happen to know the market share for the major turbo manufactures?
- HELP: does the prcesion sc61 come with a 4 bolt exhaust flange
- OMG what happened to this turbo?
- what do you think of my potential set up??
- traction bars turbo in a 1995 civic with gsr and a/c
- best turbo for d16y8
- C&R radiator w/19-21 psi cap + stock hose clamps = leaks
- Just when you thought they were done....no, no. AGAIN!!!!!
- NW boostheads. i need some advice
- Supercharged b16a ticking at full throttle
- Spool time for upgraded exhaust
- Del Sol or EM1?
- Turbonetics T72 and Racegate with custom cover....
- What Are Some Problems With The Rev Hard Turbo Kits?
- head work (turbo ls)
- Megasquirt
- je piston rings -vs- oem ????
- oil pressure sensor..autometer..?
- Hondata s300 Questions.
- b16 cheap turbo, but safe?
- Greddy kit.
- ls/vtec-Turbo Oil Lines Is this right (pics)
- Anyone with an IHI turbo?
- S2000 setup, 4" downpipe, GT40
- Blew up my motor again...
- OT: If your a mechanical engineer, or have good ideas...check it out....
- who has a skunk2 throttle body?
- Is my head okay?
- What turbo size???
- Wastegate inlet, not a complete seal??(large gap)
- What is the normal temperature for boosted b18c?
- Clutch Install. PP holes dont line up with flywheel pins. WTF do i do
- ***boosted teg?
- Quick question about tuning?
- GT3071R on built DOHC ZC
- whats the thread size of your egt probe?
- Turbo spooling too late?
- stock map sensor , giving wrong readings @ 13-14 psi
- Turbo Help PLEASE
- Clutch doesn’t fit WTF?
- brand new 2.0 gsr has no compression AT ALL!
- Is there something wrong with my motor... possible ringland?
- Oh...$h!t :/
- tunning my prelude on 10psi.......
- Help turbo integra takes 2 times to start
- ls tranny question
- DA w/delsol half rad downpipe probs!
- GT35R v. T3/T67, which better for 400 whp?
- are gsr cams better for a b16 turbo?
- block guard?
- HELP.. CHIPPED ECU + HONDATA S200B HAVING MAJOR ISSUE PLEASE HELP PLEaSE
- EMS or not?
- Resistor Box Question
- Quick Question
- someone to tune uberdata
- //// 450 install on a obd2 motor... Can't find the dead plug. ////
- Lightweight flywheels
- I am having problems setting up my EBC
- can a stock eg return line handle 2 pumps?
- head gasket
- HELP .. Whats Wrong with my Valves? Burnt? 5 Hi Resolution Pics (56K NOT!)
- FAQ: How to Change Headgasket , Water Pump, Timing Belt on B16 ITR GSR... Tons of pix!!
- Next "Stage" for my turbo gsr
- Twin Loop vs. "straight through" exhaust
- plx m-300 display problem
- the effects of a low static cr on emissions
- 1/2 size radiator
- low compression whats wrong with it ?!?! not pistons or rings...
- running lean at idle
- JG Victor X cracked!
