knock sensor question! help!
Old Oct 18, 2015 | 06:28 AM
philcivicjordan's Avatar
Default knock sensor question! help!
Hello,
Currently putting my engine back in after a rebuild. Ready for a turbo to be fitted.
Anyway i some how managed to break the knock sensor, i believe its the knock sensor anyway. Its just under the inlet manifold on the block (b16a2)
Was looking for a replacement but i've heard that on a p28 ecu the knock sensor isn't read. If this is the case i can just use the broken sensor as a plug and continue my build?
Only seen it mentioned on few forums so i dont wanna carry on building if im going to get bitten by it then have to take it all apart again
Old Oct 18, 2015 | 11:34 AM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: knock sensor question! help!
Most OBD1 ECUs won't look for a knock sensor, unless they have a knock board added. That being said, though, your tuner (as well as the health of your motor) will love you for having a functioning knock sensor.
Old Oct 18, 2015 | 11:06 PM
raverx3m's Avatar
p28 is not the right ecu for b16
unless its chipped with crome and has a b16 map on it
you need a p30 ecu if you want to run stock ecu
Old Oct 19, 2015 | 09:27 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
The hold is blind, meaning it doesn't go all the way through into the block. You can just leave the sensor put or remove it, it doesn't make a difference if you are using an ECU / EMS that doesn't need the KS input.
Old Oct 19, 2015 | 11:11 AM
wantboost's Avatar
Who is Mr Robot?
I've never understood NOT running a knock sensor... Like do these people have ultrasonic hearing that can detect knock events?
Old Oct 19, 2015 | 12:30 PM
turbohatch96y7's Avatar
Big ptw gaps dont help ks
1sikhatch
Aug 17, 2010 08:20 AM
95b16civic
Mar 18, 2010 07:02 PM
96 GSR-T
Jun 30, 2006 09:31 PM
b16civicrida
Mar 2, 2006 02:36 PM
untitled
Aug 8, 2003 08:03 PM
