View Full Version : Forced Induction
- JDM Turbo ITR (F-MAX)....project starts tomorrow!!
- anyone ever heard of SX engineering?
- those with Blitz dsbc..
- Anyone have any info on Moroso axles?
- I cant wait....
- How do you bypass the IAC...???
- Good turbo piping?
- just installed drag turbo..and it DOESNT WORK!!!!!!!!!!!!
- Help w/ choosing Turbo.
- Pictures of the damage....
- Question on using torque wrench
- What ever happened to the VAFC Boost MOD update??
- Need some fan flow rate help
- Fuel system?
- If you guys need GM 3-BAR map sensors, get them here cheap:
- only use NGK plugs.
- the TORNADO--the next generation of forced induction!
- pedal feel of clutchnet stage 2
- Bye Bye to turbo integra...Car might be totalled...Call lawyer?
- Charcoal Canister???
- Ryan - 'degradated' just had an accident... so wish him the best
- what do think of my jrsc setup..............
- Greddy Turbo kit BOV?????????
- how to make my downpipe cloosed loop
- What size intercooler does everyone have? ( In and outlet diameter)
- Drag Gen 4 kit............
- need air-temp numbers of turbo dataloggers
- Where can i read step by step instructions on installing a turbo kit?
- How loud will my Drag 3 Integra be with open downpipe?
- Drag II/III owners: what is the Inner Diameter your IC piping?
- lets begin fixing my engine
- cold idle valve - vaccum hose connection (f-max install problem)
- ITR intake manifold question..
- Got a Revhard manifold, want to trade it for Drag
- Better motor for turbo.. B16 or Straight LS
- SOHC intake
- Fuel pump ?s.....greddy blue box?s
- How do you know you've blow yer motor ?
- Help with BOV clearance in hybrid (92 civic with b18c1)
- Newbie needs help with turbo
- DTA standalone....
- 94 LS/turbo
- Revhard vs. Drag Turbo kits ????
- Is the LS tranny only suited to drag racing?
- f-max - does the wastegate need a boost source or vaccum/boost source
- will a exhaust donut seat?
- anyone running octane booster with your pump gas?
- pistions, rods, NO sleeving, anyone out there have this?
- flanges for tial wastegate to make closed loop dp
- will this work for an oil pan fitting ? (pic)
- who here is in the 11 sec club?
- Fuel pump NOS
- Clutchnet customer service...
- f-max installation - part two
- tuning and boost
- si or integra ecu on zc turbo???
- Position of injector bungs in intake for additional injectors???
- OT: Nissan Pulsar GTI-R
- nooooooo, engine fu##ed up!!!!!
- i have a size question about some turbos.
- 490 HP Honda Del Sol
- Jackson supercharger upgrade pulley for Civic si 2000
- GREDDY Blue Box FCU Questions....
- Anyone familiar with Haltech standalones?
- any of you guys selling an hks ssq bov?
- i think my car cut out on me on the freeway tonight...
- Who would buy this for $31 grand?
- 90-93 rs/ls turbos OR supercharger*, whos got em, who likes em
- Mark : Drama continued...
- I'm looking for some help...tuners needed
- nitrous engine wear & tear
- f-max install questions
- running 3" catback on a N/A 95 teg
- B17A or B18C for forced induction???
- Hood Clearance w/ Tial
- best ignition setup for turbo gsr at 12 lbs.
- do turbos smell???(having problems)
- New Tial wastgate for sale, $180 shipped!
- Turbo Stopped Working, wtf is wrong with my car
- pic - I am copying off of Flamenco since I just washed my car and he did not!
- Which Blow off Valve sounds best?
- wtb vortech 12:1 fmu
- pic
- Question onCarsound Cat
- aeromotive/sx FPR install
- Fuel upgrade for f-max kit?
- OT: finally, I'm 21....
- wet vs dry???
- NOS installation for B18C5
- Oil coolers
- this was done. tomorrow is dyno time
- does anybody have any experience with a J+S knock sensor?
- How much psi does your car run?
- !!!!!!!!HEY SUPER IMPORTANT QUESTION! would you consider an SC if it would be affordable??
- (very off topic) Hondas new 1.3L 4 cyl intercooled turbo watercraft
- tilton clutches=big$ Whats the next best for high hp?
- Arp head studs for a B16a
- help with power fc
- Boost levels
- wonder if anyone's up but....i'm finally boosted :D
- which is a more complete turbo kit for 98 civic ex coupe..........
- F-Max Turbo - Opinions and Prices
- Is 80lbs. of pressure for the oil receiving line on a turbo normal?
- Check Engine Light, Fuel related
- exhaust noise
- Chat?
- IF had to get 1 of 3 which would you get? SS Valves, Springs, or Retainers.. On LS,13-16PSI, and sto
- Blow off valve info?
- o2 help
- Any times on a ZC w/ a TD04-14b??????
- Area 51 Dyno Day- So Cal...JAN 20th
- For turbo experts
- Wastegate and Emmissions?
- Pls help me ID this turbo + ic
- External Wastegate Operation... TiAL... some help please
- here's a pic of the Maximum Perfomance Manifold
- Need pics of rollcages in '92-'95 EG hatches. . . .
- tial question
- who makes a manifold for a f-series? trying to help out someone...
- Want to know what stock cars have what size injectors?
- Anybody need a set of 750cc's?
- 9000 RPM
- Recomended IC
- Reliability on a road trip
- HF/STD Manifold Adapter Plate to T-3 (homemade Style) Pics.
- wastegate question
- Drag 3 on LS??
- Budget racing.
- How do I know that my catch-can/PCV is doing its "job"
- nos question
- I need your help on a DSM question.
- 6000 miles in two months and still....
- Turbo XS BOV..
- LS final drive in a S4 tranny? (2000 Civic Si)
- intake manifold
- Custom exhaust components...............(READ B*TCH)
- booooost controller
- please post ls turbo, and ls/vtec turbo setups
- Some inspiration? JDM Turbo Civics..
- Juicing and Boosting
- BOV barking at me !
- who builds the best turbo motors.
- running hondata off base maps only!
- is this block clean enough?
- Did i get sent the wrong turbo?
- need some help with an Fmax install...
- power fc map sensor?
- Turbo time wiring with aftermarket alarm.
- in-line pro headgasket question
- Hondata tuning questions....
- Attn: Speed Pro D.F.I tuners
- Torque converter ok for a daily driver?
- 2mm Head Gasket???
- Eagle Rods from Import Parts
- what style flangs on a drag gen 2
- DragII/III turbo specs for gsr
- larger exhaust??
- working on piecing my turbo lude, a little help on fuel?!
- Vapor Lock???
- DRAG Generation Question.
- My saga...
- Honestly the car gets one more chance.... then I sell it!
- are you supposed to resurface the flywheel when you change clutch? y/n.
- D16Z6 at 12 psi... you tell me!
- Rev-Hard turbo for RSX
- blue smoking ???
- what kinda cars can I beat on the street with 350whp?
- Where to find used/rebuilt turbos?
- turbo guys planning on using a FAL fan,i just discovered something that can save u $$ on one
- whats the average 1/4 mile time for a turbo b16a civic coupe??
- Newbie Nitrous Question
- GReddy air/fuel guage
- Best Turbo motor?
- b18b or b16a
- No increase in power after taking off exhaust
- telling turbo sizes
- OT: Is it me???
- Best Pistons for Nitrous?
- What weight flywheel do you use w/ your turbo?
- BOV vacuum
- for those of you that were looking for the t-bolt clamps,here ya go w/ part #'s
- Thinking about going Turbo from all-out N/A
- GReddy CARB sticker
- info on this new Turbo noise
- Crank case ventelation and boosted cars.
- pix of my motor
- Is this too much fuel??
- HOTSHOT Tubular Manifold
- Bad Rings, Bad Valve Seals, where did all my Oil go!!!??? Give me your opinion please..
- Fuel pressure question.Yes did search.
- ZEX kit??
- tapping line for water cooled turbo
- Suddenly I'm running more boost.....what gives?
- Greddy Type S blow off valve problems!
- Raising compression ratio and Turbo??
- Make Nitrous Safer to Use???
- What psi will be safe to run ls auto?
- J&S Ultra Safeguard question?
- what do you guys do about crankcase ventilation?
- Bet you mines bigger than yours
- kooks for 550 brand new?TOO GOOD TO BE TRUE?
- Slick tire sizes
- RPM stuck at 8K! Clutch related?
- Put in thermal today and had muffler guy put in 3" test pipe...question
- Do any of you guys...
- Best BLOCK GUARD out there in the market
- 3" downpipe info (once again)
- help idling problem
- Running open wastegate...
- air filter for turbo
- How to run 12's on a Type R??..NEED HELP
- Best place for feed line?
- Good power source for extra pump?
- What 's the farthest you have driven your turbo Honda or Acura on a road trip
- car idling horribly and dying out.
- how much boost?
- FS: Turbo parts...
- Oil return line setup....
- F-max h22a oil feed
- smoking
- HELP: LS/Drag3 down
- inlinepro?
- I've decided on headwork. Now who do I go to for it?
- somethings wrong with my car! ran open downpipe and.......
- Problem with ANplumbing.com
- nitrous on a turbo LS
- need advice on injectors, feul pump, and spark plugs
- Shifting sends shock throughout whole car
- Rev hard kit is it good???
- PROBLEM ....please help
- T3 / T3/T4 whats good??
- 2002 Civic EX Super charger kit????
- accord turbo manifold??
- Yo guys i need some help on my clutch
- 3" open exhaust opinions on noise
- Who installed DRAG 3 Turbo on their GSR>?????????
- ls/vtec questions? I did a search no luck.
- wire clips with injectors if obd2 to obd1?
- Which one?
- Injector, O rings, please look at picture
- Big problem, one injector is leaking while boosting!
- D16Z6 Vacuum??
- Hondata on a 94 accord vtec ecu!
- Compresser wheel on t04b and t04e.....
- What size injectors for turbo prelude?
- Pics of my turbo kit
- HELP! 370 CC, too rich!
- b18c5 and turbo
- I am soooo tempted!!
- OT: southern snow?
