View Full Version : Forced Induction
- fouled plugs and now running rich ?
- Injectors question
- Crank Won't Turn over when bolts are torqued...
- different 5 bolt flanges?
- most accurate oil pressure guage?
- 00 gsr w/ATI procharger..im new
- 600 + 2000 integra gsr build
- FULL RACE T4 bottom mount Twin Scroll
- main guages
- Identifying turbos
- Yard turbo build
- GT4082 turbo
- What type of turbo do I have?
- Whats the best HEADGASKET? POLL
- Vacum From Valve Cover
- INLINEPRO MANIFOLD??
- EMS and wideband, quick question...
- H22 sleeving
- godspeed turbo kits any good?????
- 600+/- INJECTORS F22
- Can you identify this Turbo?
- Oil Gauge, Accurate One!
- turbonetics exhaust housing.
- spoolin performance 450cc
- Small boost leaks at compressor housing?
- this turbo worth it?
- A few questions before i start building.
- HF manifold + external wastegate???
- What size turbo?
- wideband cluster mod
- calling all Greddy 15g turbo kit owners
- Turbo Manifold
- my turbo sohc vitara setup with timeslip!
- Race weekend on a German track - video
- Help with timing maps on LS/VTEC turbo setup.
- Need help Identifying turbo
- will 5th gen intergooler piping work on a 6th gen
- HELP!! compressor o-ring
- symptoms of sleeves sinking?
- Thinking about building a fully built TURBO GSR
- boost limitation
- Dohc ZC....JAckson D16 super charger???
- k20a2 turbo buildup with pics and comparison to another k20 turbo setup!!
- Best tranny for 600WHP
- Best Turbo kit for 99 gsr???
- Buying "Built" Motor : How to tell?!?
- Need opinions on dropping all my B stuff and goin K
- will it fit!?!
- Stupid turbo car
- My boost keeps going up and up!
- Rough Idle
- b16a turbo with itr cams??
- Bronze ek hatch with turbocharged k series swap at sema 2008
- question on piping
- Stock z6 setup - advice?
- need help about dsm 550cc inectors
- well seems like everyone around me it doing it soo..
- piping diagram for 96 civic.
- who is the nitrious king????? i need help
- Dump tube on race day question?
- Don't start?
- Oil return issue with pics... Need advice
- Merger Collector??
- hp guestimate on 2.0l gsr at 20 psi?
- dual tial 44mm wg's not opening HELP!
- Hot Air Blows Cold After Boosting? Why?
- How to run coolant lines to a GT-series turbo???
- help finding flanges and stuff for GT15
- high hp, and cooling
- gsr w/ eagle stroker and deck plate question. *searched*
- Running used pistons and rods in a LS (or LS/VTEC) build
- Building for turbo
- Not plug breather chamber hose to intake manifold?
- GT BALL BEARING TURBOS!!!!!!!
- Tires for DD Turbo???
- missing link
- Off Topic- Anyone going to Import Face-off in Montegomery,AL this SUNDAY?
- EG ebay boost
- Fastest time on drag radials.
- How much power with off the shelf Wiseco's?
- Looking for forged pistons for B18C1
- wiseco pistons
- Who has done DARTON SLEEVES?
- B16a or B18c?
- backdoor coolers. show me ur front bumpers!
- electronic boost controller help
- What cams are best for lots of boost?
- Hondata S300 for Turbo JDM B18B or???
- boost shopping...?
- H22 mapped p28 running a turbo ls?
- 627hp stock sleeves mase tuned!!!
- b18b1 or b18a1
- stock internals ok for turbo???
- vacuum source for tial wastegate?
- new gasket?
- Should this be this dirty?
- b16a2 head???
- Mahle Pistons help plz
- does any 1 know how to test it??
- how to test a turbo?
- Greddy intercooler piping
- COIL ON PLUG!!!! PLUGS & MISFIRE/IGNITION ISSUE
- just got a turbo and i need help.
- Leaking Tial Wastegate question
- pulled ls'vtec turbo setup outta EJ8, put into DC2 and now stumped
- SLT manifolds .. anyone having problems with em? business wise?
- whats should i do next on ls vtec 35r???
- Type R intake or Venom
- OBD0 B16 turbo question
- need help on turbo d16z6
- wastegate vavuum hoses
- S/C D15B info
- Forward facing turbo setups. Please post pictures..
- built b20v turbo vs b20 turbo...opinions needed
- Headgasket? Whats the best?
- I need help turbo db8 bogging and cant rev pass 3500!!!!! WTF
- What is this stuff worth???
- Large amount of condensation and carbon coming out of the exhaust, bad?
- pros and cons of 8.9:1 ratio
- FBM S2000 Dual Walbro Setup!
- High Compression Turbo
- fuel pump ?
- Leaning out. help
- Boost spike problems
- What wastegate spring is this?
- 4" turbo back exhaust on 96 cx (lots of pics)
- intercooler and piping
- Do i need a retune after changing turbo? AFR looks identical
- piston ring seating
- fastest spooling turbo for 500whp??
- From 4 bolt to 5 bolt housing? How do I make sure I get the right housing for my turbo?
- which intake manifold..
- Vavle Adjustment
- bearing clearance plz help
- A small turbo boosting into a larger turbo... Is this desinted for failure
- What would cause this...?
- HOw much power can i get out of a garrett GT4094r with .95 ar housing
- Fastest spoolin turbo that can make 700WHP...Turbo Talk!
- Who drives their turbo LS b18b daily?
- those witha ramhorn mani and 1 38mm wastegate how is the creep
- POST PICS: AFI B series topmount kit
- Brand new turbo, oil leaking from the bolt that you loosen to clock hot side (pic)
- blown turbo after 4k miles
- b18b1 turbo help.
- fmic ?
- Building a Engine...HELP!
- Should i upgrade my wrist pins?
- code 3 and running badly on turbo b18b integra
- Lets talk Meth Kits
- First time with turbo! Dyno vid
- deciding on a fuel pump out of what i have
- Turbo pistons
- All stock f22b2 turbo?
- Anyone tried .0047" piston-wall clearance with CP pistons?
- maximum bore size k20 stock sleevs?
- H22 Arp Head studs. How tight in the block?
- Tial 44mm Wastegate Issue
- Would a bolt on turbo blow my d16z6 engine????
- highest hp on pump gas
- New Tial Q surging a little.
- wtb greddy carb badges turbo & intercooler
- ?walbro dual fuel pump?
- rebuilt ebay heads?
- best oil line input to turbo
- cylinder 3 took a poop
- GE sleeve Question
- how much power could this make?
- Injectors not opening?
- OBX Adel Wiggins, Hydraflow clamp assembly clones.
- Stock H22A Turbo - My cylinder compression test results ok?
- Skat Rods any good?
- Eagle crank question??
- Whats the most power on Crome Pro?
- what turbo to buy
- TURBO??
- which injectors for a low boosted 90 dohc zc on a slight budget ????????
- Mod exhaust ticket.....
- Broken sleeve # 3 B18 ls/vtec turbo
- COP what fits on a B-Series engine
- Built motor H23A1 question about misc part.
- 94 accord ex turbo w/o intercooler
- Need guidance for my first F/I engine build.
- in this pic does the turbo on the right have ETT
- Skunk2 Megapower 70mm on Turbo B-Series EK
- holley throttle body
- Very weird TPS issue/CEL, no start, bad ECU?
- oil every where!!!!!!!!
- What is the difference between the S300 and S400 series turbos by BW?
- Advice on compression ratio.
- hate my car!! help please
- anyone have a picture of a broken\bent eagle rod?
- Which company for engine build.....
- k-series spool
- Heli Coil block for head studs?
- obd2 dead end
- exhaust smell in m car
- dsm injectors....
- Fastest e-cutout? Can't find a faster QTP or DMH...
- "Stock" oil catch can
- BW ETT s362 guys share your dynos and setups
- made good numbers on a stock sleeve 35r today
- differences between log manifolds
- jdmb16 turbo
- HELP! Building a Fuel System for 600+ WHP
- What are the negatives of running BOTH the stock water pump and a electric pump?
- Question about removing purge canister
- New turbo setup. Help.
- car sputters while cruising
- Is this filter big enough for my turbo? pic and dimensions inside
- what turbo???
- Oil Feed line for turbo?? Help
- Boost Cut???? WTF
- E85 or not???? cant make up mind
- automatic k20 drag car??
- disadvantages of running bearing tolerences a little on the loose side?
- Questions bout supercharging my rex
- valve cover leaking, help a d-series out :)
- havnt gotten to tune an H22 in a while...
- overboosting with tial 44mm need help!!
- vacume lines for a D16y8?
- oil dipstick question
- new to turbos. what parts??
- help on turbo for 400hp
- high piched scraping sound, help me out
- My cars smoking alittle....but i need a car for school.....!
- motor build
- Bullseye Power T3/T04E vs. T3 Super 60
- D16Z6 turbo questions
- F22 turbo cam
- Internal vs External
- generally what does a good b series head flow stock? and with a godd head job?
- <<<<<<yeappp a noob here (which turbo question)>>>>>>>>>
- Help me build my motor....
- What power should i be expecting??
- Any one from CT ever have to go to DMV for exhaust ticket ? What to expect
- car drives really weird now after turbo is installed.
- BOV/ ByPass Valve/ Diverter Valve WTF???
- Whats with the smoke?
- You're first experience, any regrets?
- FI + Buddy Club Cams
- f22a crank, h22 block
- d16z6 turbo
- looking for 350-400whp suggestion...cheap project..
- belt from alt. to jackson racing supercharger on ls/vtec
- which turbo for this set up
- Anyone made a SS InlinePRO 4 bolt Passenger's Side Down Pipe?
- whats the best bang for the buck turbo kit
- Need a custom manifold. anyone know?
- Proper IC piping size ???
