View Full Version : Forced Induction
- questions about nitrous bottle
- Greddy Universal intercooler piping kit ?
- Vortech supercharger times
- GSR Pistons in B16 motor???
- Preparing for more nitrous.. What to do..
- Camp 1320 Reliable?
- B18B 350+ what engine management?
- RS or Benson sleeves?
- bent wrist pins?
- Will my planned setup be smog legal?
- just came back from the strip
- Fuel problems?
- Compressor size
- e-cutout
- new power adder ehhh... hmmm
- Hondata: low speed fuel tables! 880CC injectors
- GE sleeves and HG Q?
- Can someone verify part number for Eagle Rods?
- b20 turbo fuel pump
- Manley Valves from Full-Race
- Does anybody have direct experience, Spec vs. ACT?
- Oil pressure question. b16 turbo.
- Question about Hondata?
- ecu swap?
- Turbo car jerkyness
- need help bad car doing strange things
- oil sandwich adapter for turbo feed line
- Piston Bottle Opener Interest?
- Where to get my turboed CRX worked on in NoVa?
- (GM) Supercharger Oil
- Simple math. Boost + AWD = ?
- losing power at Boost
- I think my friends turbo is F**ked
- nitrous timing?????
- Oil Restrictors are ready and Contact Info
- What type of core is this?
- E-cutout seals well???
- who here has installed JRSC ? got some questions
- post your dfi setups
- Anybody using the ATI damper
- can you modify your stock dizzy cap for use of an external coil?
- How Do I Hook Up A Resistor Box?
- Garrett T28 questions
- CTR N1 Crank Pulley + Turbo?
- Can't figure out problem with v-afc and turbo
- Is Nitrous Timing retards nescessary
- squeak when accleration...........
- why is my d16z6 turbo slow
- stock exhuast with turbo?
- After rebuild?
- my car was stolen today
- Stock sleeve capability
- best model CRX for b18c swap???
- Teflon tape for oil feed lines
- help - precision turbo size for stock gsr
- Piece together a nice LS turbo kit for cheap?
- Price on GT35R and SC61??
- some kind of knock...what is it
- ahhhhhhh guy's help me out again please
- WRX Td04 vs DSM 14b
- What is this on this turbos oil feed line?
- Max Rev?
- h22 bore
- JRSC? Whats required to......
- n1 for catback?
- Drag 3 turbo w/ jim fab bars (fitment questions)
- what the heck is going on???
- AEM Wideband & AEM Wideband Display - Info from SEMA
- i gotta have the first full-race kit in beantown!
- 450's + Vafc + Missing link = OK?
- Spool Time?
- full race mani is it worth it?
- Integra Gsr greddy turbo kit on Civic Si
- Fastest stock motor street integra?
- quiet bov?
- 10.5:1 ok for low boost?
- suggested ways to save money...
- another hondata question
- Help, vac. question???
- parts suggestions?
- quest for 500whp b16a
- boost contoller
- Problems with cold start. EMS possibly?
- edelbrock turbo
- y 6psi of boost. Do you think a cam will help much?cams with turbo
- MOtec advanced tuning and logging
- Any Reviews Of the Greddy Power Extreme II?
- where to buy flex pipe?
- Noob ? abt turbos
- S200bd trade for ems??
- smoking
- Anyone know what wideband o2 will plug into Motec harness
- Turbo choices, need help T3 60-1 or SC61, what is the difference?
- Stock S/C pulley "upgrades" for D-series?
- turbo cams and fuel pump
- wrong forum: window weld motor mounts
- Bearings: what color?
- What application do I order for with this setup?
- Greddy Profec B Spec II warranty? HELP....
- 500whp + which Clutch?
- ls vtec or upgraded head
- H22A Turbo Manifold - Need a 'tight' one...
- what would be a good setup for my build
- Does this Downpipe flange allow you to use the internalWG?
- pics of after market fuel pressure regulator on DA
- difference between saturated and peak & hold injectors
- Tial 35mm wastegate w/12 psi spring but I only want 6-8 PSI right now
- what trim t25 turbo for a d series?
- Manual Boost controller
- 550 injectors
- HELP! turbo spikes.. now motor wont start
- V-AFC Hack w/out fuel pump
- why can't i blow off in nuetral?
- What gap on NGK bkr7e?
- Need help with setting with safc on sohc..
- Love Fab on a B16 CRX
- Bay Area Guys check this out!!!!
- Cam suggestions for N2o+H22 setup?
- blow off valve
- Help with HKS type-1 tt...
- New to Board...about to get a Kit
- what Guages do you run?
- Turbo Comparison
- Need turbo rebuild..... QUICK!!!
- Craaazy spiking!
- view/comment on my timing tables
- 84mm golden eagle sleeved bore. can i overbore if i have too???
- precision turbo?
- How does a v6 turbo work?
- WTB: 99-00 Civic Si B16 Turbo kit
- Electronic RPM matching?
- Turbo Street Car...Traction
- ,maximum rpm with stock b16?
- SEMA my fav. pic's (56k Beware!!!!)
- Looking for EGT probe for Blitz gauge
- Intercooler Performances (which is better bar/plate or tube/fin)
- How to determine turbo size
- what happens when you drill a hole in your FPR?
- ssautochrome?!?!?! good or bad or what opinions?!?!?
- HELP!!! CEL 23
- Question about the bolts on a turbine housing...!!!
- turbos with nitrous
- Turbo vs Supercharger
- help with custom turbo set up
- Roll Call. Just want to see how many of the FI guys are pusing 500+hp
- how much boost /?
- Harness for stock injectors?
- problem leaning out when I hit 1psi
- Injector Size
- i got some crazy oil pressure, needs info
- Got my car retuned..
- Daily driven AEM EMS powered supra runs 10's.
- greddy fmu install techniques?
- d16z6 or d16y8
- garet t3 super 60
- E-manage ignition harness need help
- the most streetable hp
- Drag Gen4 Prelude/Hondata Pics and Dyno
- 1998 Honda Civic EX Turbo General Question
- $1600 and dont know what to do!!!
- Sticky Idea
- ClutchNet disc with ACT pressure plate
- help with boost leak
- How to install Greddy relief valve?
- How much power can RC 310 injectors hold?
- Starting to research for b18c or c5 turbo build, need some help and advice...
- b18azdyne??
- SMC guru's...i need your help
- 300 whp, what injectors should I use?
- How good are these compression numbers?
- Want to get my d16 to around 250 whp
- UGHH, I cant make up my mind!
- exospeedAMcrx, Please PM or email me
- type r or gsr head?
- Building my D16a6 need advice! Fuel, Internals, Valve Train, Complete Rebuild!
- will this clear a/c? SOHC
- Which Standalone units to go with
- Right placement for the oil return and feed lines
- do i buy aem ems or hondata
- Stock exhaust on Turbo app...
- Turbo exhaust....
- SFP Manifold and HKS Wastegate
- which ecu for h22 turbo
- Spark plug gap & Emissions
- Blow Off Valve Location
- Problems after turbo on LS
- Wastegate Actuator Rod Adjustment
- Radiator for Sidewinder mani?
- b18a block how much psi can it handle
- where to fill up nitrous bottle in orange county CA?
- Switching Hondata for AEM EMS? Should I?
- Just installed turbo.... ok to drive w/ stock ecu to get to dyno????
- Anyone done a 4" dp on SC61?
- OEM rings with JE overbore pistons?
- SC61 really worth it?
- Are these pistons/rods badly damaged? *PIC*
- d16y8 turbo
- 7-8 psi on a t25 . . . . ignition?
- Turbo on an f23
- Where in So Cal can I smog my car? u know what I mean
- New project need advice before starting.
- Pics of my car and turbo setup
- Another turbo clocking question (i searched even the archives)
- quick question on boost gauges
- techedge datalogging and datalogging software ???'s
- pics of piping on a del sol
- How do i clean my rubber clamps that i got with my used greddy kit?
- Where are you guys getting your manifolds at?
- where can i buy T3 compressor inlet?
- picked up a crank, journal scored?
- Before and After
- T66 Garrett turbo
- jrsc and crv crank question
- 2" -> 2.5" bad idea?
- Misfiring, fuel or spark? video inside
- new some help with calculations.....
- Which darton sleeves???
- Rdiator fluid problem with FI!!!!!HELP!!!!
- Praise for CP pistons!!
- What cams to run in an LS/Vtec
- Help me with my little situation
- am i getting scammed? help me out
- upgraded intank require fpr?
- will my valve cover withstand high boost?
- What do you guys think about the b18e1 block???
- ever notice ??
- Exhaust Cutouts worth it?
- Why do you need a 3 bar MAP sensor with hondata???
- Blitz Downpipe - Nut Size question..?
- Tunning your car for 20psi for track and running 10psi for street?
- did I just get shafted?
- How do you launch on Azenis at the track?
- size of turbo needed for h22a4 in 95 civic Si hb
- What size vacume hose!?
- what size exhaust for turbocharged d16y8
- Logging data from my AEM - Estimates on what I would run ??
- Vafc = spun rod bearing... hmmm
- When someone says "x-degrees at Total Advance"
- How hot can forged pistons get?
- JRSC reliability
- how to build boost on idle?
- AFC wiring from obd2 to obd1, HELP PleZ
- Fuel to Boost ratio??
- SOHC Twin Disk
- Identify this wastegate?
- Turbo Wheels interchangable?
- Wastegate Elbow and Dumptube, Tial 38mm
- Precision SC61 vs. XS Engineering T3/60-1 *Lots of Pics.. 56k Welcome*
- Us turbo guys (darkside) rule.... AREA UNDER CURVE RULES!!
- apex N1 exhaust on turbo gsr
