View Full Version : Forced Induction
- Greddy Sohc Turbo on D16Z6, Should replace parts?
- Apexi TT after feelings
- i was bored so i modified my kami header
- will these pipes fit ??
- a couple of eagle rod failures...
- b16 stock sleeves
- garret 4bolt dp flange and oil return flange
- technical turbo question...
- LF: a large T3 turbo. (to new to post in classifieds)
- should there be a gasket between manifold and turbo ?
- Dump tubes and stinky exhaust fumes?
- DUAL POINT turbo'ed 1.5 questions
- Modify combustion chamber- To do...or not to do.
- instialling starion FMIC
- anyone running over 400HP with a log style manifold?
- BOOSTED, and running OK..(pics and movie)
- jsut bought NOS install help?
- Someone was looking for a titanium muffler with a scorched tip...found it for you
- ls motors are the best
- T3/T4 or T-25 turbo?
- Need help with Turbo kit Installation!!!
- I cant freaking get the bolt off of my fuel filter!
- how do you hook up a manual boost controller?
- anyone else running an E6K?
- TURBO EXPERTS please help me out with decision!!!!!
- Aem Ems Users: Maybe I'm an Idiot or something, but I just can't get my Ems to Connect
- Where can i find 3" stainless steel pipe?
- Just came back from racing.....(boost problems)
- Centerforce dual friction - how long will it last?
- Eagle Rods rod bolt torque???
- Jason Hunt won IRDC quicass at maple this weekend
- Quaife LSD or ?????
- JRSC: fuel and misc questions
- Suggestions wanted on how to improve setup
- 3k what should i get???????
- help with head gasket and boosting on drag gen 3 kit for b16
- ? for all the SOHC Greddy users.....
- Golden eagle or Darton sleeves ????????
- Mandrel Bent piping
- Which path is safer for 12 psi?
- D16 piston available with 21mm pin?
- bov swap
- Got back from the dyno, satisfied, but not happy.
- I have a choice.... LS or B16 transmission???
- How much HP can I expect to get out of a Drag or Rev-Hard kit?
- I'm having V-TEC problems, PLEASE HELP!
- Attn: Hondata Dealers/Tuners..Possible GroupBuy??
- Anyone using AME (Art Morrison) rollcage in a 96-00 civic coupe?
- Made my Horsepower Goal Dyno Chart inside........
- Price check
- What's the best stuff to use to get the paint off a valve cover?
- look at my dancing valves
- Drag manifold after 10000 miles
- Quick JRSC question
- Where to buy turbos?
- Need help!!!!!PLEASE!!!!!I need turbo!!!
- how too tell what fuel injectors are needed??
- Turbo Kit WARRRR!!!
- what turbo do i have???
- Trying to locate a certain Supra Turbo video clip!
- How will this turbo do on a B16?
- fawked up noise...b18b1
- please reply turbo ??
- Honda gear box's when Boosted are they weak??
- What's the torque specification on a b-series valve cover?
- how to properly mount the oil pan?
- Anyone ever turbo a BMW 325?
- Share your knowledge/Experience with Majestic Turbo
- DSM 450cc's in a pre obd integra?
- help on vacuum diagram ASAP
- Help with HKS SSQ BOV?
- o2 sensor for DIY wideband
- Need a better help explaining "tuning" w/turbo.
- Need help with my Turbo Kit...PLEASE!!!
- Turbo differences
- Gas Smell
- What rings should I go with for my JE pistons?
- Starion FMIC
- V-afc hack!!!
- A little more setup advice...
- should i upgrade my injectors?
- Greddy Turbo Kit w/ ZC/D16A6 Motor
- those of you with the C&R
- New Project: H22A Turbo People, Read...
- Top port on Tial wastegate used with a manual boost controller???
- code 67 (catalyst below threshold effiency)
- Need some gen turbo help...
- Need help!!!! Oil pools on my pistons!!!!!
- another weird idle/rpm fluctuation...
- My car idles crappy with my 450's and hack. Please help
- finaly, VS Racing tubular manifold PICTURES
- what turbo can should i go with??
- My baseline dyno graph...view it! =)
- where can i get a 3in down pipe
- Best Place to get Hondata IM Gasket?
- EGT and Wideband tap ?
- Help...I have oil leaking somewhere from the top of my turbo
- need some help w/Identifieing a IHI turbo?
- ... machined gsr head or b16 head?
- JRSC websites and prices...
- 500 Plus HP on 93 pump gas with dyno chart, any thoughts?
- Just installed DSM 450's w/S-AFC @ -37% and there's a clicking....need help
- torque
- How bad is having ext WG on 2 cyls of manifold only?
- t3 vs t4
- Boost controller question??
- Things for sale (mods please don't move!)
- Please help with turbo timer install questions...
- quick headgasket and ARP head stud question!!!!
- Can anyone give me a tips on how to make my car pass emissions, My #'s where way high.
- What happen if the BOV is leaking?
- what is your oil temp?
- impressions of the VS racing tubular manifold
- What turbo for ZC on stock block?
- Water cooled turbos?
- clutch question
- anyone know what chrysler lebaron turbo injectors flow?
- charactoristics of this size turbo?what kind of power band?
- anyone get rebuild kits for t3/t4?
- I have a serious question
- Because of some earth shattering crappy times at the track, i'll be visiting the dyno...
- Bah, I seemed to have taken some rice crispies to the track with me last night...
- Eclipse turbo injectors 450cc???
- Help me chose a Kit for my GSR
- FJO/Hondata lamda datalogging problems...
- my car is running pretty rough on the AFC hack
- cranking engine by hand
- The life of a puck style clutch how long???
- My first time at the track...just got back!!
- Anyone Know a cheap dyno in San Antonio/Austin Area?
- Nitrous Trouble, Need help ASAP
- drag 3 question??
- Pullin off turbo.....NEED SOME HELP!
- best place to buy turbos?
- Not getting any spark?
- D16 trim and A/R
- New here: need turbo advise..
- Valve Seals(URGENT)
- new turbo setup for GSR motor
- newb needs help with turbo question.
- Attention Engine Builders/Professional Shop owners, need a favor!!
- ... help!!!... blown head gasket!!!...
- ?can i still go FI if i have piston slap?
- Boost Spike! Please help me!
- Spark Plug ?
- going to tap the intake manifold
- My fuel problem is still not solved...yet!
- Max-Rev Clearance Sale!!!
- ATTN: New must have product of the year...
- Custom SS b-series turbo manifold for sale
- Quick ? - Problems with continually running the fan?
- VAC lines for a civic
- Dont need this.....
- jrsc ?
- Ever install a N2O gauge on A-pillar?
- Thicker than stock Main Bearings?
- AFC hack + map
- TurboXS manual boost controller! I need help, going to the track in 45 min!!
- Question? JSpec Head.......
- Is anyone a criminal lawyer??
- What compression level for 6lbs-7lbs?
- Fuel pressure regulator????????
- take a look at this turbo and tell if it a t3/t4???
- Pic's Of my car...I am finally posting pictures of my Setup
- Question with S-AFC and boost controller
- my 1/8 mile track visit. deja-vu
- FS:Brand New Drag III LS kit
- Emmisions and the EMS
- What to do.. what to do... Help!
- FS Blitz Dual SBC SpecR boost controller
- FS: Drag Inline Pump, 12:1 FMU
- DRAG Turbo Kit Sale!!!! $2779 Shipped
- Dumb question from newbe. About blow off Valve
- This is very important. Please help!
- B16a1 Turbo Setup in a91 CRX
- Exhaust Fitment Question
- SMC faq
- full-race needs a logo, let me know which ones you guys like!
- DSM Injector Question
- intercooler fitment
- Tube/Fin V.S Bar/Plate intercooler design?
- how to setup afc hack for 4th gen hatch with b16 and dsm turbo????
- I need QUAIFE now!
- turbo rebuild kits
- problems with b18c turbo
- S-AFC hack on pre-obd
- Long - Big problem with Turbo GSR in Civic
- Affect of boost on nitrous
- Anyone try 3bar GM map sensor with Hondata?
- Went to the track, almost blew up the ZC, real fun...
- Crank up the timing, crank up the boost...
- Anyone here have a boosted b16 running more than 7 lbs. on stock internals? Post your setup here...
- Normal clutch noises?
- Fuel pressure problem
- Is there an increase in HP if I use 310cc instead of stock injectors??
- how do you adjust boost on turbo kits ( greedy t3 )
- Skyline turbo, what do you know about them
- questions for guys with built motors...and transmissions with lsd
- woo hoo my car started and idled thanks to falcongsr
- Please help, or i'm gonna go nuts!!
- Any good shops in the North East for turbo hondas?
- d16 turbo people
- alright, this is a unigue wideband O2 question......
- Hard starting..FJO reading 15/16 with car off....
- 250whp JRSC'd @ 6psi
- Question about IAT sensor
- Plz help me pick my turbo specs
- Maxrev downpipe & Revhard manifold compatibility?
- a/f and boost guage install?
- Defi Link Guage Series? Good or Not?
- T4 turbo Questions
- is the BLITZ S-SBC a good boost controler?
- Cant Adjust Boost
- mystery noise, need help.....
- h22a 2.0mm cometic gasket for sale
- water injection and Rust
- Anyone in here try an Inline Pro manifold with a T3 60-1?
- Kumho Ecsta V700 - Competition Tires
- Notced a trend poping up about N2O spraying on intercoolers what are the benifits????
- N2O Problem
- question about autometer boost gauge
- What size turbo is this?
- Want to know what type of turbo to put in your car?
- Finally got my dyno scanned. anyone want to see it?
- any one with a safc in an 95 integra ls please help
- what TURBO is this?
- please Help with wastegate on drag gen3??
- How much lag with a T4 60-1?
- Hot Rod Racers...
- jackson superchargers
- alarm with a turbo timer?
- What kinda of damage?
- O2 sensor question
- Is vac necessary on a boost gague??
- ... 1/4 tank of gas... wierd hum from engine bay...???
- Check out the welds on the JimFab prototype 92-up Civic bars
- 5-wire wideband sensor
- Greddy Turbo Kit + B16 + JDM P73=?
- Turbo, Turbo, Turbo, EXPERTS wanted!
- T-25 Turbo on B18C1?
- Ahhh Horsecrap it was only a dream... Turbo Dream!
- Drag Install..
- Problem with B16A Turbo and o2 Sensors
- rev limiter/high speeds + boost?
- Intercooler Efficiency.. What to look for?
- Installing a RevHard turbo kit in my R on the 17th...
- fuel controller
- civic turbo mani
- Where to buy.....8 gauge 90 degree elbows for custom manifold....
- For sale: Parted out turbo kit, guages, injectors, suspension
