View Full Version : Forced Induction
- Tilton twin disc clutch ??'s
- torn between 81mm bore and 84mm bore - please help
- Arias Pistons
- Internal or External wastegate
- calling all ls/vtec and b20vtec turbo
- T4 with .60 AR compressor / .84 AR Exhaust
- Lancer EVO 8 Intercooler on a Integra? Has it been done?
- greddy turbo timer question
- Drag B-Series Turbo manifold
- Spraying nitrous
- turbo mani - help
- t25 or t3?
- anyone use the "neukin " manifold
- What are your thoughts on jet coating a tubular manifold?
- S-AFC Safe for my Goals?
- can I build my own turbo manifold from my factory header like the CRX HF style??
- What is the A/R of a late 80's early 90's chrysler 2.2 SOHC turbo??
- Need help trying to rebuild my APEXI turbo
- Exhaust piping question regarding a 2.5"->3" flare
- GSR charge pipe w/ Skunk 2 Manifold
- Website?
- SRS light and AFC Hack
- DH Racing PnP Head: Ya or NaY (Not 56K Friendly)
- WTB: T3/T4 and other turbo parts!
- H22 turbo Manifolds
- can you use a fmu with a vafc
- Quick question about rom emulator
- FI related: Matt Scraton street car dyno results
- tial 38mm wastegate ring
- turbo questions
- 85mm x 86mm b16a; powerful and reliable?
- B16 turbo vs. Ls turbo which pulls harder
- 2g housing on a 1g 14b Turbo ?
- does anyone use apexi power fc with their charger??
- The ultimate test for stock rods and a t3 turbo!
- white smoke after rebuild and turbo install. d16z6
- Important information about K series sleeves
- e cutout+cold weather=bad?
- SS Auto Chrome Turbo Kits....
- Map sensor quick question
- Whats the most reliable hp i can expect from 1.8 liter
- ITR tranny and OEM LSD how much whp before BOOM??
- Any onehave any experinece about the nippon sleeves sell in ebay?
- ATT :ARTURBO
- Oil in Spark plug
- Boosted JDM H22a blown head gasket?????
- motor rebuilt. Break in period?
- Wanna Be Safe
- Innovative LM-1 Wideband with Hondata
- b16 pan on b20?
- Need help w/ oil feed line
- question about VAFC HACK
- Ls Tranny or GSR Tranny?????
- Hondata work on PR3 ECU???
- Please help get DIY dumpe tube
- custom flanges?
- show me your ls/vtec turbo oil setup
- anyone useing scat rods
- Precision SC34...What would you pay?
- oil restrictor 0.1" too big?
- turbo traveling
- Mase pisses in pants
- high comp. vs. low comp.
- how many are still using stock fuel rails?
- Whats the biggest hp i can expect on a 18 liter
- Tial bov
- turbo size question
- v band clamp on down pipe
- oil leak at downpipe
- boost with a ls/vtec???
- anybody turbo subarus?
- trying to understand real-time dataloggin
- Where to get a cheapo MBC?
- To move to 3" exhaust or not to...that is the question.
- OBDII fuel management
- Install Phase One: Project 2.0L GSR *Pic City*
- Head build now oil loss? exp ppl help plz
- Anyone have anything good to say about SSAUTOCHROME?
- Does anyone know who makes CUSTOM intercooler end tanks?
- Boost problem
- Lower alt. bracket with JRSC kit?
- has anyone experienced boost gauges being incorrect????
- D17a Fuel Management
- Blitz DD bov question
- Need Advice on Setup?
- Pix of my new turbo set up D-series
- Need help TUrboing D16z6???
- SRP-Pistons good or bad for turbo b16a?
- Smoke out of intercooler
- Atmel 29c256 Discontinued...
- Initial thoughts on my new boosted honda, and a few questions...
- Exhaust Gaskets
- Callin AFC Hack gurus - This one is a mystery.....
- Help with tuning 18psi on C-16
- Need Greddy Blue Box Diagram for 92-95 Civic...Searched
- TURBO NOT CLOCKING!
- Need Help Finding someone on honda tech ASAP.
- Does anyone know the weight of a Drag Turbo Kit? I need to Know for shipping
- Camshaft for LS-Turbo..worth it????
- anyone recomend or have suggestions on this cheap turbo kit?
- Need Build Advice, 1.6L stock sleeve vs 1.8L aftermarket sleeve
- VW Noob...
- 93 Integra RS, what to do with $2000 extra to engine?????
- Anyone know how to replace seals on a turbo...
- Woking on some intercooler plumbing... (what you guys think, gunning for 500wheel)
- where to find brackets that hold turbine to housing?
- EGT install. please help. four wires, where do they go?
- Help- Oil inlet fitting on Precision/GT 3071 Turbo
- just put turbo on and have no idea whats wrong
- uberdata whores who know what they are doing please help me!!!!
- should i get my new block's deck resurfaced?
- OT: History Channel RIGHT NOW: "The History of Turbochargers"
- High Compression or Low Comopression You make the Choice
- Should I do more head work?
- Plans for boost - which head is better for...
- Defi Gauges...
- Upgrade coils, electrical?
- Couple questions before install *searched*
- anybody using the kms valvetrain parts?
- anybody heard of tilton clutch ??
- turbo carb engine
- Couple of questions about oil lines & Wiring an o2 sensor to the greddy gauge
- boosted f22a4 i need your help!!
- What is this ring for?.. Wastegate
- Where do I tap in for coolant? *pics*
- My d16 turbo, representing the HMT, only.. a little worst
- which injectors do i use?
- cost to resurface a flywheel ??
- want to buy clutch disc only, how much ?????
- T3/T67 Manifold
- Catback Exhaust?
- Who tunes AEM EMS in New England area?
- help rebuilding B18A1 for turbo
- -> Is this a good budget 350-400WHP plan ??
- Looking for someone to install my turbo in SD
- did a compression test and cylinder #1 has no compression the rest have 220
- is this a good clutch for my d16 turbo?
- What Turbo Are You Using?
- ? on installing aftermarket pistons
- who can tune vafc hack in bay area?
- WHat is the diffrence between a T3/60-1 and a T3/T67
- Choose my turbo for me!! T3 60 trim or t3/t04b v trim???
- Headwork?Upgrades?
- Got some Dyno time
- Jrsc on B16..
- Full Race or custom turbo kit?
- quick uberdata question
- dyno results
- anyone using Defi Link Display ???
- looking at switching from all motor to turbo
- spun bearing on b20 (lsvtec)
- Spark Racing New EVO 8 Manifold
- Are these RC 750cc injectors seated the right way??
- Tial Wastegate leaking?
- Need info on turbo kit info for 88-91 civic
- coolant shootin out?
- From a T3 to a T3/T4
- Have a question
- can i reuse presasure plate, and get only new disk ?
- Storing Turbo cars over winter?
- removed my tranny, tell me if my clutch needs replacing...photo
- Is this safe?
- I just don't know what it is about the SOHC.... (new dyno #'s inside)
- changing out manifolds what do i need
- Are these Darton Replacement sleeves?
- how much nitrous can an h22a take?
- I going over the the dark side and i need some help
- Stock sleeve k20, K-pro, 525whp!!
- Who's running a gt40r?
- problems with intstall to today some quest
- ls/vtec turbo
- Tial 44mm wg+Full Race Mani = Boost Spike!!!??
- hp #'s using a t3 60-1?
- More power in B16A2.. Boost!
- advance timing for nos???
- My new SC setup *dyno*
- Issues with Hondata Romulator...
- i went on the dyno today
- Video from Stockholm M3 Turbo, Mk4, STi, CTR
- Read my plugs.
- Turbo Kit For LS/VTEC?
- Another Stock internaled 11 second hatch. (VID)
- Oil line Question T3-->Td04
- Coolant Line Turbo Pics
- Garret Spec Turbo THE HELL WITH TURBO CALCULATOR!
- Just found a nice flaw with the BLOX manifold..
- Cheap clutch for aprox. 200-250 WHP
- 3 bar map sensor
- want to make own ic piping
- I love turbo! :) Ran a 13.4@113mph
- No boost from turbo
- It's beginning to look like XMAS a little...
- Which headgasket for rebuild?
- how repitable are the ARI racing sleeves
- how many of you guys use a Stock exhaust with a E-cut ?
- Something making A Funny Noise
- NO ( PPM) Result.
- Quick question about HONDATA prep.
- Need help w/HKS EVC 4 boost controller, car won't boost past 7PSI.
- B18C1 Full Race Stage III AC kit (pics)
- Cost to prepare honda blocks for big boost
- A good article about spark plug temperature ratings
- Atmel AT29c256 discontinued ?!?!
- Which is better to do FI on F22 or H22??
- Where to hook up my oil temp gauge prod?? b18c semi-built boosted
- Help? o2 wiring diagram for 60mm a/f Greddy gauge
- EDELBROKE INJECTOR& FUEL RAIL
- garrett t15 specifications..
- where to get tuned in NJ/PA/DE
- Turbo suggestsions for h22.....
- Precision ???
- Has anybody heard of this web site?
- Dsm 450's broken tip
- vacuum leak through FMU?
- Your thoughts
- New To Boost
- The best cable tranny for turbo? y1 or ys1
- please turbo guys i need help.....
- Hondata Datalog Question
- Crank questions when building a motor...
- can someone explain
- dumptube size?
- Sleeves...
- I have a T61, use what I have or cut my losses?
- TURBO!!!
- WHAT CAMS ?
- just wanted to say uberdata sucks!!!!!!IMO
- Hondata S200B Rev Setup
- What kind of horsepower should I expect? B18C1 JRSC
- What kind of horsepower should I expect? B18C1 JRSC...
- internals to boost higher?
- will ARI sleeves with nuforms blockguard be sufficient for my set-up
- More Engine Tuning Theory Discussion
- Blew turbo. Put car back to semi stock. Will I be alright running like this?
- ngk bkr5e iridium???
- How many of you run turbo blue?
- are these injector clips broken?
- Okay so to start the process or not?
- T3/T4
- Post your uberdata .bins
- whats the difference between different staged turbine wheels?
- Clearance issues with Inline Pro mani....
- Building a Nitrous Motor
- NEED HELP!!! AEM Guage-Type UEGO wiring to work with Single Channel WB
- Edelbrock Turbo victor x
- ls/vtec vtec not working help
- Rebalance b16 crank
- Good place to buy silicone intercooler connectors and turbo gaskets.
- I suck at Uberdata. D16, 3bar, high z 750cc RCs, anger
- any shops that will install lsd on the east coast?
