Hondata require O2 sensor?
Old Aug 18, 2015 | 02:27 PM
2kdrift's Avatar
Default Hondata require O2 sensor?
Im re-doing my engine wiring harness, I have already removed the primary and secondary O2 plugs (HX Model) I have not used an O2 sensor in years ever since I jumped on the chipped p28 bandwagon. When I install my turbo kit I will be running a Hondata ECU will it need any type of O2 input??
Old Aug 18, 2015 | 03:13 PM
boosted94gsr's Avatar
Default Re: Hondata require O2 sensor?
Nope. You can use your wideband as an input if you still want to run closed loop.
Old Aug 18, 2015 | 03:23 PM
2kdrift's Avatar
Thanks I have not decided on the wide band thing yet. Still up in the air on that. Tuner has his own, but I might decide to get one for my own peace of mind.
Old Aug 18, 2015 | 03:28 PM
I wouldn't own a boosted honda without one period.
Old Aug 18, 2015 | 03:29 PM
2kdrift's Avatar
My gauge pod supports 2 gauges, should I ditch my oil pressure or get another pod?
Old Aug 18, 2015 | 03:30 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
How else will your ECU adjust fuel mixture if there is no O2 sensor? srs q
Old Aug 18, 2015 | 03:37 PM
It doesn't need to if tuned properly. It just runs in open loop all the time. Obd1 closed loop is not very good anyway. My afrs are much more stable in open loop.
Old Aug 18, 2015 | 09:26 PM
turbohatch96y7's Avatar
I would do afr gauge boost gauge and oil pressure
Old Aug 18, 2015 | 11:01 PM
2kdrift's Avatar
yea thanks I was kinda leaning towards that. Just didn't want to run a pillar pod. I currently have the dual gauge pod. I guess ill have to add a single pillar pod
Old Aug 19, 2015 | 12:02 AM
wunfstgsr's Avatar
Loved
Community Favorite
I use the Innovate Mtx-l wide band its very accurate i havent had a issue in 2 years of owning it i would reccomend that one.
Old Aug 19, 2015 | 12:12 AM
m4xwellmurd3r's Avatar
Its good when it works. The o2 on mine is failing. I think from the system being on without the car being on (need to add a switch so I can shut it off when I have ign on)
But up till it started acting up it was dead on perfect
Old Aug 19, 2015 | 04:57 AM
Turbo-LS's Avatar
Boost gauge isn't really nessesary. A wideband is a must for boosted application. Even with a great tune air density changes. Temps change through the seasons and corrections will most likely need adjustments. How are you going to even know that without the wideband displaying your a/f ratios. It's 200 bucks for a PLX wideband. Invest it one.
$amGD3
22
Feb 24, 2021 06:12 PM
jeffy
Mar 21, 2008 02:36 PM
DaiJekBok
May 24, 2007 08:51 PM
jadugartir
Dec 13, 2006 10:53 PM
w0ng_sta
Sep 12, 2006 12:05 PM
