View Full Version : Forced Induction
- one of my good moment of the summer
- whats the difference between a Ls Block and Gsr block...
- Best fuel managment ?
- best cam gears???
- Which Turbine wheel on Ford Turbo?
- How do I know if it has gone bad?
- 8psi D-series Hondata folks S.O.S.
- rebuild the drag turbo or buy a t3/t04E??
- "any muffler shop can do it"
- Finally Got a charge pipe =)
- just resurfaced my head...
- Can you braze the return line?
- GSR secondary runners
- ls/vtecs, and what do they offer turbo wise?....
- Where to get fuel line..SS braided..
- Manual Boost Controller or Electronic Boost Controller?
- Identify this ecu
- Whats everyones fastest times on those sohc greddy kits?
- is exhaust wrap really worth it?
- how would i temp. hook up my fmu to an aeromotoive fpr..
- Looking For Pics of the Spring Loaded FMU by vortech
- DIY Wideband Soldering Help
- JE vs. Arias
- looking for oil feed flange posted not to long ago
- dyno dissapointment, sugestions..
- injector seal kit
- questions about MSD FPR w/boost and opinions
- intercooler damage
- Which intank fuel pump to buy (replacement)?
- ? CR Pistons ?
- random ign. probs, back to stock?
- Pics of My DP setup
- turbo d16z6 with very annoying misfire. HELP!!!!!
- JAYDEEM BOV anybody?
- HKS SSQV questions.
- How much whp should this setup make?
- Goodbye Turbo :'(
- post pics of your fuel systems!!!!
- Got an offer today, do you think its worth it??
- how big of a shot to run???
- blockguard???
- Blockguard??
- Tunning turbo kit with pyrometer
- going FI, will i need a new clutch?
- Final Verdict? '95 GSR with Greddy Kit Impossible?
- Piston Question: PLEASE HELP
- How did you guys run your wires/hoses/etc. from inside to engine bay?
- Best Intercooler?? for Greddy kit?
- Car Stutters after O2 Sim Install
- Troubleshooting an engine with constant misfires.
- **Finally Philly Dyno Day**
- wastegate flanges...
- oem O2 sensor
- where to buy headgasket for oversized bore?
- ... lsd... street application... 300-350hp
- To VTEC or not to VTEC
- msd btm that comes with cortech???
- chipped turbine blade = problem???
- boosting D16Y5?
- wheres the cheapest and best place to rebuild a turbo?
- LS Turbo 60-1/T3 with AC
- anyone have setting for 370 cc vafc hack
- Rev Hard Turbo Kits
- A look inside the greddy blue box... What does this stuff do?
- D16Z6 dyno numbers
- Keep fmu set up or for trade for dsm 440's and SMC??????need some input please....
- Starion/Conquest intercooler pics?
- help identify this turbo
- valve to guide clearance?
- wastegate dilemma
- max bore on stock sleeves
- Does anyone make a turbo that...
- How to make GSR a 2.0L??
- What cc injectors???
- turbo d15
- My Dyno 19psi
- attn: GA members...tuning aem ems
- Turbo manifolds for the rev hard downpipe
- oil sending unit
- What should I be running?
- question about going greddy turbo 18g on gsr...
- Need Help!!!...Please Read
- fmu is it really worth it?
- b18c1 2.0 vs. b20/vtec 2.0
- Got my LS/Vtec Turbo Setup running..
- new best times
- Prelude Traction Bars ?
- where to get a d series STR intake manifold?
- manifold q's
- Turbocharge integra precautions
- Can you turbo a carbureted engine
- RevHard Installation
- Hondata questions... stock p28 or chipped?
- Oil inlet line picture...
- AE Show in Florida
- what piston to wall clearance?
- LS crower cams hp worth it?
- profec b setup?
- turbo for itr?
- QUestion on top end
- Headgasket..?
- 10 psi t3 cfm = 10 psi t4 cfm?
- Boosted R's???
- Stock Ignition Control Module purpose with Standalone?
- Awesome dyno results, t4/60-1, 2.0l block
- OT: Finally Boosted...!!!!!!
- oil feed/ return on turbo
- Intake for Rev Hard
- B16 dyno'd with the afc hack, very good results!!!
- Compression Test
- lil vid: flying by and blowing off into the cam! 56k friendly
- Set ups?!?!............
- new "drop-in" turbo-kit
- B18C5 bottom end build up
- greddy blue box
- big 16g
- t3/60-1 specs HP potential
- Injector Questions???
- Need Intercooler piping
- What kind of power to EXPECT with 8lbs and type r motor?
- boost controller gains
- Biggest?
- SMC and GM 3 Bar?
- How vital is o2 sensor placement on a downpipe?
- my homemade manifold completed
- Is Nitrous legal in...
- I almost killed someone tonight...
- stock head gasket at 10psi.. ok???
- Unofficial Dyno Day Results
- From 2.5 to 3.0 inch DP
- tired of my blitz blow off!
- compression ratio questions
- over boost with greddy kit....Please HELP!!!
- leaking off boost like crazy ? possible wg prob, help
- 3 bar map sensor
- B series and DET dowel conversion!
- going back to thearkside but first one stupid question
- vafc hack + inline fuel pump = overkill?
- Maxrev Vs. InlinePro Manifolds
- What's your.......?
- Ringlands on FI Prelude motors?
- Ennis SUCKS! Got dynoed instead
- Fuel pressure regulator question.
- Homemade turbo manifold pics....
- Prices on Sleeves + Install
- D16y7 Turbo people?
- injector end caps...where to get replacments?
- NEWB turbo question??
- RIP (lower case to make filter happy)
- Pros and Cons of test pipe?
- how much boost?
- 10.6:1 cr and turbo????
- does anyone know the flywheel surface height on an integra?
- Why is my boost gague different from my vafc
- Pics of how you ran the lines for water cooled?
- Hybrid901 & a friend's dyno #'s. . .
- can anyone on here burn ecu chips?
- Whistling coming from blow off valve or turbo??
- Arrrg!! Turbo is leaking oil.
- Which ECU to run?
- Friend put down 330 today
- SMC Plus Dyno numbers?
- New Toys... 56k beware..
- PMS Engine management
- fmu's
- New Dyno #'s
- problem with boost....
- where to get manifold
- ... help me pick a clutch...
- Time Frame for your turbo
- i know the welding topic has been beatn to death....but....
- Turboing a .........
- Is this all worth it?
- Octane rate
- Webers and Boost
- Cam gears even worth it?
- opinions on this exhaust set up for turbo
- what fpr?
- ... camber kit... looking for recommendation... (sorry, kinda OT)...
- Getting so close...I can't wait to get this puppy back on the road...
- can't boost or rev high.... =(
- daily h22 or turbo post
- Turbo on DX motor or EX motor?
- Tial 40mm Wastegate, Will it hold 30psi and 650-700hp???
- stock fuel pump
- B16 garreta turbo on an LS?? does it fit?
- dart block prices, whos the best?
- Timing settings under full boost?
- Block Guard with low boost?
- WG port location revisited...
- ... intake manifold... which one?... stock, victor x, skunk2, others...
- What times do you think I should pull with my setup?
- ring seal in 35 mm tial wastegate
- Pictures
- Step bye step instructions to install turbo
- how mutch nitrous can my engine handle?
- noob question: turbo...
- Airborne express and the UPS man stopped by: Pics
- please check my spark plugs
- Idea! Would save us all alot of time
- carfax needed!
- Drag Gen III's Intercooler Effeciency:
- Ferrea dual valve springs and valves compatible with stock head assembly (B18c)??
- afc hack methods
- I think I'm in limp mode!
- Having two blow off valves?
- Compression Test numbers: Need Opinions
- quick question *d16y7 people*
- 1.8 SOHC turbo???
- B18C owners... what size turbo are you running, and how do you like it?
- What do you think of these manifolds? (links)
- I need a 3" muffler that is QUIET! Help please (did search already)
- Lightweight Battery for Daily Driver
- ... balanced crank... necessary/recommended...???
- dyno result!good or bad?
- Using AEM CAI as upper charge pipe, what to do with holes and sensor + valve cover breather?
- Pic of my new Intercooler!
- dohc zc dsm turbo question
- MOFO'S I just officaly joined the darkside:)
- JDM-auto B16a cams in B18, better???
- anybody running methanol injection on a street setup?
- Engine rebuild/build - Bay area
- anyone running SMC+DSM450's WITHOUT a turbo? I got a question for ya.
- anyone know anything about MENG header manifold?
- maxrev manifold with internal wastegate???
- Question RC Injector
- Water got sucked in the motor
- ... traction bars... jimfab vs z10... and deals...
- Final shots of my manifold
- Greddy kit vs anyother kit....
- How do i remove/install BOV onto flange
- Safe to bore to 83mm w/blockgaurd and boosting?
- ?'s about standalone's
- Converting from obdo-obd1
- What to do?! Block and Piston question
- What timing to run?
- Need ODB1 Distributor - CASH IN HAND!!!!!!!!!!!!!
- How do you know when your fuel pump isnt working properly?
- Question about oil catch cans
- my wastegate flange on manifold looks a little warped, what should i do?
- Hondata S100B VS S200B
- B18B w/ FI - vs - B16a2 w/ FI
- Max boost w/stock internals
- Last question about Greddy Turbo Timer... I swear!
- button or peddle injected?
- Need help from u Turbo guroo's. Please help the rookie.*please*
- Just a helpful link...
- I Need Help People! Give Your Opinion Please...
- Yet another FPR question...
- NE1 know of a good tuner????
