View Full Version : Forced Induction
- Quick question on where BOV and wastegate are connected to on GSR
- Getting a drag turbo for my gsr
- obd1 injector plugs?
- where to order b18b sleeves??
- Rec. spring rates for a 425whp street/strip Integra.
- Planning on turboing d16z6-d15b2 mini me
- Question about CAI on supercharger?
- zfyne connector
- what do they do to tune your turbo?
- I think my clutch fork is broken (help)
- home made turbo kit
- downpipe problem
- Questions About Street Tuning.
- NEED SOME HELP.....CIVIC TYPE R CRANK PULLEY, GOOD OR BAD??..........
- xs-power.com turbo?
- junk turbo
- ss autochrome manifold and t3t4 turbo
- I overgapped my piston rings by a little should I get new ones ?
- Nitrous was causing car to break up at higher RPM's, ran perfect before..why not now?
- How much Hp can 310cc handle???
- Does anyone have the english instructions for the HKS Turbo Timer type-0?
- Tial Wastegate Vaccum Fitting Thread
- all stock ls turbo tegs need your help
- Lost the Link to an Oil Feed Fitting for Block
- Where to find ZIF socket located in Canada??
- boost gauge?
- Why the D-Series Head Lifting lately? D-Series Timing Maps.....
- Techedge wideband: 7057 and 6066 sensors...
- 94-01 Integra LS Intercooler Piping
- DIY WB02 need help for calibration
- vortec FMU question
- What is the Gas Milage for your Daily Driven Boosted Car?
- strongest tranny ??
- With a VAFC, what else is needed to properly run a turboed B18c 8-10psi w/o throwing CEL's
- max boost for a block guard
- greddy blue box
- Fmu with Afc or not
- FS: Turbo Stuff, Prelude Stuff, and some Civic Stuff
- b16 throttle cable...given me a headache
- map
- JRSC in DA
- question about manifold design
- quick question on hooking up a Turboxs mbc
- Drinking and driving dont mix RIP Mike
- New MSD wires for $30 or new OEM wires for $40?
- Help!Smoking bad
- aem fpr diaphram is a p.o.s.
- 400whp: b16a tranny(short) or b18a tranny(long)
- 310cc or 450 cc
- fuel pressure too high
- what kind of boost controller are you running with hondata?????????
- 18g is going crazy
- turbos from trucks
- Preparation for turbo install...do I have everything? Should I add/change anything?
- NGK spark plug wires, need info
- boosted sohc carlisle,pa area
- td04-19t vs t/3,t25
- difference b/t 2.5 and 2.75 inch charge piping
- QUICK! where should i...?
- boosting a stock Jdm B18C(Si-G)
- A/F Gauge Not reading Right????
- Custom gearing???
- Smoke coming out the valve cover/ exhaust! HELP!
- Build my ls or gsr motor for boost?
- 99 Si turbo question
- LoveFab Problem... This was my last resort.
- anybody have a 46mm tial low pressure wastegate?
- FRAM oil filters....my experience
- Problems with turboed Jdm H22
- Fresh turbo now having problems. Please help
- whos makin decent power using afc tuning?
- Some pictures of TiAL's 44mm V-band Wastegate
- ls/vtec timing covers
- b20b help me wit my set up
- For those of you that have had your motors tuned at Balanced Performance
- precision frequencies
- Owners Manual / Instructions for a Profec B
- What Size Tap (Zex Intake tap lost) HELP
- Anyone having probs with there catch cans spewing out under load?
- how often do you tune?
- where to mount my EGT probe?
- leaning out as soon as full boost comes in
- Finally joining the bandwagon . . . . getting a new turbo
- difference btw H-series and B-series downpipe
- Machine shop close to northern FL needed!!!
- t3 on a b18??????
- Intresting problem
- Turbo oil feed line ?
- need help building gsr.
- Freshly boosted JDM B16: power falls off when vtec engages.
- Questions on how accurate WG springs really are?
- stock bore stock stroke STOCK SLEEVE b16, whose made the most power?
- Where to buy gaskets?
- 1.8l d16z6 motor build up
- how hot does the ic piping anc charge pipes get during boost?
- Sometimes i lose fuel pressure?
- Possible to bolt an IHI turbo to a Greddy manifold?
- SOHC larger downpipe good or bad???
- Turbo Teg died at the light NEEP HELP!!
- turbo? for b16
- How old is too old?
- **which fmu?
- Jimbo has a plan,,, to make the vortech S/c create full boost at 4000RPM's & till redline
- turbo ?
- Turbo Sohc
- Time for 10lb. CRV pulley, I'm ready!
- looks like I got no oil...
- Log style manifold who......
- ignition cut at WOT
- Competition Clutch
- ITR muffler too restrictive for boosted cars?
- Stock Map voltage to PSI
- please i need some help about s/c
- where do i attach the vacuum off of the turbonetics deltagate wastegate
- Why is it that more turbo manifolds crack ten NA cars with headers...
- How do you replace the bulb in a gauge?
- 14b on a cx manifold??
- Cide 73, Random misfired???
- whats the key to run nitrous safely?
- the anticipation...
- Need some Feedback on the GT3037 for a built B18C1 application
- running colder plugs, BKR7E vs. BR7ES
- TurboXS dual stage boost control
- emange/obd11
- boosted only 5 lbs on hondata.....think wastegate is messed up???
- GE oil sandwhich plate
- Best 3" Exhaust for 94 civic coupe.
- Is RevHard still around?????
- Boosted S2K
- Boost gauge
- pr3 ecu with obd1 injectors?
- Turbo-map sensor
- FMU ?
- Keep heat down
- California BOOSTED cars!
- Quicktime Electric cut out PEICE OF CRAP
- Boosted guys...how do you stay out of trouble with the law?
- edelbrock
- Import builders turbo manifolds...They look like OBX and SS Autochromes?? WTF???
- Turbo Help: No Boost From Compressor? WTF!
- building head for boost...Help
- VAFC questions
- GReddy Blue Box with any setup??
- All about Vac & Gauges
- 14b on ZC question
- Greddy 52mm Guage install (water temp, boost)
- rebuild the tranny or get another one?
- hondata tuning at R and D...
- vortech bov problems
- Link request. I've searched. Someone has to have it bookmarked
- Build B16 with ~20psi and 9:1 CR is that possible?
- How mutsh boost ?
- rebuilt motor..ready for start up..few questions
- Clutch pedal stiffer after driving? Brake softer.
- Can u run a hondata chipped ecu with out the s200b box
- Max HP of a b18b
- free mod day 2 intercooler water sprayer
- top end power in JR super
- sohc turbo- advice
- Boost Problem
- boost issue
- Do DSM 450's tick?
- greddy kit
- sohc turbo...safe to run stock dsm boost pressures stock internals?
- Alluminum intercooler piping HELP
- Vortech S-FMU Threads???
- Thought you guys might wanna check out my car!
- GSR-T with skunk2 IM....vtec question
- Boost w/ Factory Cast Pistons
- How high are you reving your BUILT ls/vtec's to?
- D Series build help
- any shop for tuning in nyc
- Anyone using nitrous with boost?
- which injector can you use without resistors.. i want to know.
- ***Anyone that has experience with SR20DET Motors***
- 66-1
- TORQUE spec ringgear to differential bolts what torque
- painting my intercooler
- Has anyone actually used the Vitara pistons/ LS combo in a build yet?
- d16 Turbo for sale
- Turbo Install? DIY or Not??
- Denting Hood with MaxRev Manifold and tial wastegat?
- Is it possible to hit 400whp on a non sleeved ls/vtec?
- Full-Race TURBO Install COMPLETE!!!! but a few little problems...
- wiring diagram for emanage civic 2000 ex d-series
- someone, school me, on turbo sizing !!!!
- Blow-off valve flanges...
- need some quick advice
- oil feed size for t25
- How to tell if injector seals are leaking or not
- oil feed size for t28?
- Any a/c experts on this board?
- 510 cc injector and big fuel pump can handle how many hp and boost
- 2000 civic si help
- Boost Leak
- Who here has tuned an e manage on an obd2 car?
- Block pins?
- ls/vtec swap.......looking to go with nitrous........reliability issues???
- Problem!...No boost!...Help
- need help burning chip with Flash & Burn
- Best Turbo Enginge Management System for PW0 ECU???
- need help deciding which turbo suits me
- How high you rev your LS?
- Injectors vs. boost- picking the right one?
- problems with idle and fuel after install
- Kinda New To BOOST PLEASE HELP with some Questions
- turbo timer, boost controller, and 2 gauges = accessory power????
- anyone running precision 600hp intercooler having slight overheating problem?
- Turbo install finished...Major GHETTO bLiNg!
- Where are these REALLY supposed to connect to? (non fi, but this is really the only place I post)
- Good place to buy turbo parts in So Cal?
- IHI t25 on a D15b
- Bolt holes not lining up on Inlinepro Mani and Tial WG
- moanual boost control installation..well sorta
- Do you still hear vtec on your turbo app?
- Please help me!! Do these plugs look dead? ??!?!?
- automatic transmission with turbo
- sleaves were bored over....how much boost?
- What is the proper way to check spark plugs?
- looking for 4g63 turbo mitsu mighty max vid
- Simple Question regarding hondata... Searched with no luck
- Nitrous Express relay box
- installing set-up, help with software asap
- safc blue wire mod
- VTEC engagement
- HELP !!!!!!!!!!!!!! VORTECH V-2 SQ S-TRIM SUPERCHARGER
- H22a4 Turbo in Ek hatch.. Which Precision turbo is best?
- keep my tdo5 or upgrade to bigger turbo?
- does turbo timer kep engine running or somehow just turbo components??
- Greddy Type S BOV (install ?)
- Need help removing injectors from clips
- Devestated oil pump inside
- Awesome turbo truck !!! vid !!!
- help crx turbo timer wiring!!!!!!!!!!!!!
- fuel pump/injectors
- PWR vs. Fluidyne Radiators which is better
- video of my first drag run
- air fuel ratio pinned to rich dont know why
- boosting w/ ECU chip programmed for NA
- Newbie
- What are the chances billowing white smoke means leaking water jacket on turbo?
- CHANGING HONDATA S200 REV LIMITER
- ls,quaife and valves
- thing just keep getting worse for me..
- basemap 750cc saturated, running 880 p&h, can I start it up w/o problems? Opinions asap
- can someone measure their Drag dumptube?
- One last plea for a lil help.
- looking for turbo recomendations..not honda!
- After a hard run?
- do u only port the exhaust side?
