View Full Version : Forced Induction
- how about this turbo ona H22?
- d16 turbo
- turbo setup
- Walbro GSS 341
- boost with vtec controller?
- H22 Intake Manifold Question?
- HELP!!! turbo not boosting what is should......
- does my piping route look right? seems kind of low to me.
- hamp oil filters????
- LSD.. How do you know if.......?
- TURBO s2000
- Post up your ef b series turbo pic
- technical comparison of FullRace Topmount vs Lovefab Topmount
- What kind of engine managent system will work fine with OBD0?
- DYNO COMPARISON: GSR cams, skunk2 IM vs ITR cams, JG IM
- Quick Q?? What Water Lines for Ball Bearing Turbos ??
- SPoolinPerformance/RedzonePerformance New facility
- increasing boost
- toda valvetrain too stiff for cams???
- what do you turbo d guys think of them ebay clutchs f1??
- Turbo B16 Potential
- Oil bung steel or alum???
- Which to build?
- saab turbo
- how do you read maps?
- Anyone here have a BB SC61?....
- custom turbo setup
- GSR Cams with LS/Vtec Turbo setup... yay or nay?
- how much did u paid for ur wideband
- ignition
- Datalogging with Crome HELP. Can't get Laptop to conn to ECU.
- Dyno comparision: Gt30r vs Gt35r
- What do you think happend to this Piston? PICS
- Non-honda ? Tc related????
- Compact Boost Gauge options ?
- Z6 Head vs Y8 Head .....Which is better for bOOst?
- fuel management
- 1st time turbo
- which turbo would you use?
- question about chrome?
- glowshift gauges
- Help ....ECU and Emanage stolen..
- Boosted F22 internals + hp
- half radiator?
- question?
- Frequency of Changing springs/retainers
- How to run peak and hold injector with saturated ecu/car?
- t3 super 60 vs t3/t4
- full-race rods
- help please
- catback
- Any reccomendations on what turbos for a G35?
- GT35R pump gas dynos!!
- STR sheetmetal or JG victor X manifold?
- painted intercooler, less efficient??!!!
- oil leaking a bit from feed line only after boost...
- anybody has suggestions about my idea?
- holiday sales
- Riddle me this: Heater stops working when floored
- a good 14b manifold?
- turbo noob questions.
- My Turbo DC2 Update
- Rebuilt t3/t4
- Boost Question?
- top mount with A/C is it possible?
- Stock Sleeves or Darton Sleeves GE Aebs ???
- revving stock GSR flywheel to 9K?
- will the greddy emanage work with my 95 gsr?
- Shopping for GT35R, best deals?
- smokes after idle
- Highest WHP on a JRSC b series
- need help choosing between options for my setup
- Manifold Question
- Track Days + Supercharging questions
- Stock Ignition or Keep MSD
- anyone ever used these axles?
- Turbo Timer + Clifford Alarm?
- ported head question
- Whats the best why to manage a turbo car???
- Aftermarket Axles - List your setup
- my h series set-up? what you guys think I should do?
- whats next after the GT42R? Whats the bext biggest turbo?
- 808 any place tune crome in Hawaii?
- AAAAAAHhhh can some one please educate me really quick this ? is eating me up
- What are the part #'s for the GM Boost solenoid and a 3Bar pigtail?
- boost/vac gauge questions
- Ls/vtec more efficient than a 2jzgte?
- Much Hp will a stock d sleeve handle?
- SVE map hondata s300 questions
- could i possibly be fouling my wideband sensors this fast????
- need a english operation manual for the blitz live unit and racing dc boost gauge
- solution to better 60'
- Look over my new setup/goals and give opinions and advice?
- Bigger injectors with vortech FMU at low boost?
- h22 turbo manifold?
- My Setup
- GSR dizzy
- LS/Vtec Oil pressure??
- apexi turbo timer
- Few pictures
- Attention all H22's with a topmount manifold.
- what oil for a build motor with a good piston to wall clerance
- Rich or lean 42 psi
- Turbo SOHC running choppy at 0psi?
- TIGHT FIT ON EVERYTHING!! What Do I Do? How Did You Do It?
- boosted b16a1 crx vtec
- 950 cc Precision Injectors, cyl #2 blew, could it be the injectors? Should I get new ones? Do I HAVE
- 84mm bore 85mm gasket
- Painting the Bottom End
- FMU and INTAKE pump? Please answr!!! installing now\!
- help me decide which turbo for my D14.
- Here are some pictures of my turbo setup lemme know what u think
- Turbo noob w/ ?'s on b18c turbo kits
- Anyone else shot there dipstick out of there car when they boost?
- spooling a t3 60-1
- Broke my block..what to do now? Rebuild or deal with it?
- Full Race Back Door Intercooler Q?? $$worth it??
- Turbo not spooling, checked piping....
- How to gap plugs
- i got boost!
- Full boost on stock internal b18b1 with Garrett T3/60-1 w/ .48 ar turbine housing
- Stock block b18c1 - upgrade pistons and rods...
- Wanna see some Gen 3 Integras with big front mounts and uncut bumpers !!
- went turbo.. no vtec.... help
- painting your intercooler
- car wont start, need help please
- ek fmic with fogs
- some blowby on rebuilt turbo??
- Lean a/f in boost, rich a/f in vacume
- qustion about how much power?
- My car has hiccups!
- started my turbo install on my EG hatch today
- Turbo ID
- Question With A Turbo with Internal Wastegate
- Where is matt? The manifold man. (One-FAB)
- Best build for Nitrous.
- any one use the act 6 puck sprung disc
- Is there a difference between Honda OEM Denso O2 sensor vs aftermarket Denso?
- i want to buid a high compression boosted h22
- can i achieve 350 whp with this set-up??
- Turbo Setup
- turbo nitrous set up?
- how do you do boost?
- supposedly faulty tunertoys correctinject injectors???????
- Aem Wideband uego instructions
- Old school supercharged F series
- winter coming in,what oil for turbo?
- LS crank in a B16 block
- blown gsr (turbo) which block to go back with
- Will pay $5 paypal to the first person that can help me in running my vacuum lines and ect ?
- How to set my wastegate to my desired psi?
- what eaqual length manifold for ac???
- Turbo without tune?
- what size rod bearing do i run???
- FMIC ducting?
- Poll:: help me chose my turbo kit...
- questions about finding right crank bearing, and cost to buy parts needed for engine buildups
- Clutch Questions..............Im going to run on stock for a while!!
- S300 with JDM P30
- Quick Q? GT35R or GT3076R???
- Sorry another clutch question
- turbo d questions
- the max hp on dsm 450's?
- 93 integra turbo ac compatible?
- What turbo can serve 130-150cc motor (bikes)
- What is the max. piston velocity?
- what would happen with this on a H22?
- obd1 injector resistor box install?
- ordered from krb and have not heard from them.
- Anyone know how much hp a TDO5H-18G turbo can support?
- adjusting actuator
- Fuel Injector Fitment........DSM 450's
- knocking.... maybe from the head
- Where do you source your WGA's vacuum line from?
- Is there a turbo that can do this?
- Walbro fuel pump?
- wastegate not working? what the?
- garrett t3/t04e 60 trim oil return bolt size???
- internal wastegate
- missing link on crx
- how do i do this?
- Couple of questions regarding 2000 Si Turbo
- GT35R or GT40
- 600whp del sol?
- LS-T ECU and Injector Choices?
- Will this sandwitch adapter work with a oil cooler?
- Apexi WS for my turbo ??
- GT28 on a B18B?
- SOHC TURBO SETUPS
- Best Turbo For LS/Vtec, Forged internals-Stock Sleeves
- Enough WHP to hit 12s in a RSX?
- spark plugs
- Turbo selection on a SOHC?
- Good Choice?
- boost with thicker head gasket.
- all you big hp boys.....
- seized my gt28r; time to upgrade on stock LS
- not f/i related but a great music video ahhaha sorry im bored
- what internals for 15 psi ls motor
- good price??
- The Causes Of Compressor Surge?
- timing retard or race gas for big nitous and boost
- Reusing ARP Headstuds on boosted Motors
- name this wastegate flange!
- y8 on nitrous
- Blowing some blue smoke..?
- TURBO ->->->->-> Chargepipes HOW DO THEY CONNECT!!??
- re-sleeving block + pistons, rods
- oil feed to turbo
- PLS GUYS I NEED YOUR ADVICE!!!!
- GT35R EBAY SPECIAL? WTFBBQ!!! check it out
- What ATTS code did your Prelude SH throw when you had too much whp?
- 97 Honda Accord - F22 - Drag Kit Installation @ AF-P..
- Race pipe after cat?
- boosting issue
- Wideband Sensor placement
- boosted, need clutch
- Precision AS-1019
- Buying Tuning software for my 98 Integra Crome or Hondata?
- 3/8in line = What -AN size????
- H22 owners with 8:5 cr pistons...what turbo you using?
- Injector Help!!!
- lightweight flywheel with boost or no?
- Affordable/reliable fuel management?
- Blitz Dual SBC Boost Controller USERS.....
- Turbo cam advise...
- Anyone have a diagram on how the vaccum lines are ran?
- ls/vtec with dragkit
- What do i do???..............................another tuning question
- weird idle after reving
- brand new turbo blown??WTF
- Any AEM EMS tuners in AZ?
- Daily driven JRSC? How to keep it cool?
- peakboost kit?
- Boost controller Apexi avcr Vs. Turbo Smart dual stage
- New Turbo setups!!
- o2 sim install
- Titanium Retainers: Use them or keep stock?
- oil problems
- oil spraying out of something and my turbo is sucking it in.... how to clean it?
- Emanage Ignition harness install anyone done it (right)?
- dsm injectors
- For those with superchargers.....
- turbo rebuild at blaast performance, anyone can vouch?
- Accord H22a Drag Kit Problems
- 500+++whp Civic VS. THE WORLD & 1000+whp Camaro Compilation ***VIDEO***
- Drag turbo kits?
- Performance lost with catalytic convertor?
