View Full Version : Forced Induction
- cam issue
- Easiest way to switch around BOV :) (for fun)
- 93 gsr turbo q's
- are all integra walbro pumps the same?
- Edelbrock kit for SOHC VTECH
- Anyone running an SX Performance 18203 Fuel Pump?
- High pressure fuel pumps.
- Bucking, now won`t start. Spark and fuel are there. (searched, help please!)
- Pic Request!!! T3/T04E 60 trim
- higher than 9:0:1...more like 10:0:1??
- What ecu to use??
- Deciding on a turbo
- I need help with the Hex plugs on the back of the block, I'M STRESSED OUT!!
- Full-Race front mount
- Foggy boost gauge?
- Peakboost turbo kit... wastegate dump tube hitting frame?
- I need an answer quick!! (Hondata related)
- head studs and gasket
- Hey, yet another help me Id this Snail topic...
- Anyone here try running one of those 60mm wastegates on ebay?
- Excess oil in intercooler piping
- HELP, PLEASE!
- TSX turbo?
- Turbo that will do 400+ whp/ 400ft lbs on a 2.4L with a WIDE torque curve?
- AutoMeter Boost Gauge #6159 Gauge Install Question
- Cam timing with turbo engine
- help with my turbo setup
- "Street Turbocharging" -- new book by Mark Warner
- Ideal fuel pressure?
- QUESTION ON -TD04H-15G turbo
- $4000 to spend on turbo kit...help!
- (SEARCHED)*****B16a2 Vs. Poorman's Type R Boosted?????????*****
- h22 oil pressure, vacuum
- Map sensor
- Stolen Full Race turbo Kit Help!
- need help installing moroso oil pan
- Installing a GM 3 bar map sensor.... wire configuration help...
- Who here has a stock bottom end over 300WHP? How long are they lasting?
- 500 whp set up
- PLEASE HELP! Wacked out oil pressure, 100+ psi?!?!
- i think my turbo is smoking?
- JE forged oversized Turbo Pistons H22-for sale
- knock on startup
- RC 750cc injectors with chrome basemap.... havin idle problems
- Engine Builder:Need help with Arias Pistons 3320202
- Post your ep3 turbo setups here i want to see them!!!!
- Garrett GT3567R Fitment issues
- Thermal exhaust opinion....
- Upgrade to Walbro Pump with Greddy Kit?
- Dropping boost on 7psi spring in a Tial 38mm?
- Fuel injector question. 1000cc dsm injector
- ebay radiator...inlet/outlet sizes
- FLEXLITE oil cooler
- turbocharger guru's please read, hybrid turbo question
- tial 38mm question
- h23 turbo set up?
- GT water cooled turbo problems
- Explain this coolant overflow setup?
- Ebay turbo...
- Intercooler... before and after
- evo intercooler fit into 92 si?
- the most messed up fuel problem
- H22 Stock Tubro?
- IC piping assembly question about couplers
- Using injector duty as HP estimate?
- ~10" bellow too long for dp?
- best cams and springs/retainers to use on a lsvtec 2.0
- Turbo DA Integra pics...
- White Smoke, but not from exhaust...
- eagle rods and ???
- Stuck wastegate?
- Wanna upgrade my 8" JRC IC which one??
- Performer X or Victor X manifold for Turbo B16 setup??
- Boosting 6th Gen. Accord (98-02) F23 motors - GUIDANCE
- how did everyone weld, or bolt on there oil return line fitting?
- How to set up cam gears and timing on LS-T crx
- F23 6th Gen. (98-02) BOOSTED ACCORDS - Your Setups?
- Axle Suggestions...Gator again or DSS?
- oil feed fitting pissing me off
- How much HP will I get with this setup..?
- Turbonetics Deltagate Mark II Wastegate not closing....
- turbo on my d15 civic or b18 non vtec
- testing waters: full-race prostreet non-ac manifold 44mm flanged
- d16 turbo
- B18C1 Turbo setup - FMU - 5psi boost problems
- Need Help with Dumptube! Nova...
- Overheated on highway yesterday... now leaking coolant from HG.
- Tuning a Vortech S/C car? - Generic Questions
- turbine stripped
- Installed catch can- consuming 1/2 qt every hour
- back off the dyno.....bad luck
- Benson Sleeved block leaking water
- B16 Fuel Pressure
- can't clock my turbo to make oil face down! need help!
- what purpose does an fmu serve????
- 1/2 blown Nitrous LS
- Manley Valvetrain
- b18c turbo
- A Couple Of Dilemas Here, Miss Fire??? Burning Oil???
- Boost Gauge HELP. Everyone. Link to Picture.
- how do u hook up a aem wideband o2
- Meutek Manifolds.... Whats yours thoughts about them?
- D series help please. I have only built B's...
- D-series and Vitaras
- Anyone have a calibration for a 99si on 10psi Hondata S300?
- car smokes. is there any way to tell that the turbo is bad
- Oil lines don't fit
- Turbo Lude help
- need filter but no space. now what
- Please help
- downpipe steel braided flex
- bad wastegate or turbo?
- supercharger cam
- Quick question????
- question flange turbo
- t3/t4 turbo selection help needed
- Think anyone would trade a complete d16 turbo swap for a ls motor
- Anyone have this manifold?Is this manifold any good?
- Precision SC6169E comparsion
- 28lbs of torque right
- Who rebuilds IHI's?
- What rubo should I run?
- can someone please help!
- Having the turbo timer...
- coolant temp problem on my b16 turbo help??
- turbo size @ oil feed ?
- What makes FLUIDYNE Radiators better then normal ones?
- Which Aeromotive FPR?
- someone please help me!!!
- emmisions waiver in md
- dowel pin fitment on the ls block? a lil loosee
- need some turbo opinions over here
- the i'm rediculously happy post, please read!!
- How much boost can you run through a d16y7 safely?
- Does anyone here Have a 96-00 Boosted Mini Me?
- should i have my turbo "coolant cooled" or just use oil lines?
- Is there a Diff between JDM ITR & USDM ITR Cams?
- Black stuff in my end tank in my intercooler....
- gsr 85mm rs sleeves good for turbo or what
- Intercooler Question
- best turbo exhaust manifold for 500 or less b series help
- Good Ramhorn Turbo Manifolds
- 11.79 @122 need avise
- lsvtec TURBo feedline question ?
- 450hp stockgsr gt35r and aem ems
- intake/intercooler piping
- Money
- WI seen through "Sight Glass" On Plenum
- Greddy Profec B2: Valve releases vacuum randomly???
- Looking for an F23 or H23 turbo manifold
- Putting my engine together... some help?
- switch configuration
- white mark on top of my spark plug, coolant???
- gearbox upgrade
- Repairing Garrett GT40r Turbo
- gt30 with .60 A/R
- white color inside manifold and turbine
- GUesS How Much HP would I make on the 1st setup vs 2nd setup??
- Made some new IC pipe, wanted to keep it short and simple for effectiveness, I am pleased.
- feedback--> 3" catback "SSAUTOCHROME"
- top mout turbo ?
- Upgrading -manifold and turbo opinions
- my dizzy isnt lined up anymore?? help
- toda Cs on a boosted del sol.
- GT28RS vs. GT2871 - Spoolup on a B16
- OIL LEAKING FROM TURBO ????????
- What's you opinon on these spark plugs??
- Topmount oil return line (pic request)
- d16y8 turbo ideas?
- low oil pressure @ idle?0psi?
- d15 turbo
- JRSC on my integra gsr!!!!!
- stainless lines off back of block for catchcan?
- New dyno numbers for the boosted d17 @ 11psi
- Piston coatings
- d16 + 59300 = love
- Watercooled turbo dilemma.
- miss fire? Not sure why.
- NOOB needs opinion... Turbo LS-Vtech??
- The BEST T3 TurBO hOUSING TURBO??? FOR PEAKBOOST MANIFOLD
- Oil Drain Line, Where to Get One?
- nitrous help!
- What to do? ECU
- Catch can into d16y8 boosted civic
- I am sorry, but I gotta have this shirt!
- What b-series tranny
- What cams + valvetrain do you prefer
- Turbo Timer Install PROBLEM in a DC2
- 0-5 psi oil pressure @ idle, 25-30 WOT... Please help me out im lost, 40k on motor.
- Car Leans Out - Turboedit Cells Are Maxed - What Can I Do?
- Best tuner in TEXAS?????????? your opinion.......
- Quaker State Q Oil, Every tried it?
- Components in a nitrous system (technical)
- high boost hondas, how often you change your sparkplugs????
- How can i tell inside my ecu if i can hook a laptop up for datalogging?
- Good, Cheap Welder in Nova area?
- F23 Turbo 303whp 274 ft/lbs of tq
- Turbine Wheel discussion
- t3/60-1 turbo question
- just a quick YES or NO
- Relocated my powersteering.
- ABS Light with Wheel spin?
- CC Fab: Post only if you are waiting for refund/manifold
- Who can fabricate me a downpipe for this setup, pics inside.
- Anything wrong with this idea?
- Suggestions for companys for flow bench, 3 angle valve job, and valveguides
- The Reliability Thread. Everyone please check in.
- Help please, Delsol with k20 planning to go Turbo. HELP
- How much power can the ITR LSD handle?
- edel. victor x mani.
- Anyone used VP Import fuel/race gas?
- Can i use this to make a downpipe?
- HELP! Camshaft choices for my turbo'd B series Vtec...
- SEARCHED- Turbonetics T04e T3/T4 turbo 60 trim .63 A/R
- supercharger... on gsr
- Has anyone ever had this problem before? (broken bolts in the turbine housing)...
- which to choose...need opinions
- A lot of blowby.. high oil pressure at the turbo??
- few easy questions ...
- cooling question
- turbo oil line plug
- 255 or 255HP for 7 Psi?
- what fmic piping kits do you guys wanna see ?
- DSM Injector Intall Wire color matching?
- breather kit and catch can
- when spraying nitrous the car dies?
- dyno in nyc area
- FINALLY! Dynoed the Integra-T 416whp
- oil feed kit doesnt fit my precision sc34
- Broken Axle?
- Rod Stretch Tool 100% neccesary?
- B16 EF with a FULL radiator??
- b16 100 shot?
- Wiseco Rings for 84mm Endyn 9:1 Pistons?
- E-Manage on my 00 LS
- Some ceramic coated hotness
- does it matter what spring i use in the wastegate with an electronic boost controller?
- Chipping obd1 ecu for boost application any recomendations
- what do i use for piping on a IHI RB5h (probe) turbo?
- Another Lsvtec question pls help me im ready to put my lsvtec turbo setup
- boosting too high
- Got Tuned Today overheating now
- AEM EMS Battery Voltage Compensation Question... 1050 BOX...
- Turbo on D16?????
- What turbo? responsive DD + 300-350 whp ?
- Thermo-stat high horsepower
- Any dyno numbers of open downpipe vs full exhaust?
- Post pics of A/C compatible ramhorn manifolds (B-series)
- WILL OB1 INJECTORS WORK ON OBD0 ENGINE
- Wierd Oil Pressure
