View Full Version : Forced Induction
- how much hp can i get out of a stock b18c1 turbo in a crx
- Dyno of SRT4 t3/t4e
- C16 really needed? Will 110 be enuff?
- used garret t3 turbo
- **** Integra Type R Dyno Numbers ***
- Intercooler piping size
- What do you think of this ebay intercooler. CHEAP!
- header fitment questions
- injector size help?
- This outta create a little controversy......
- SMC 500 Issues
- resistor box help, checking continuity?
- Valve job....more information needed please...
- boosting nonvtec?
- Lightest turbo rods?
- t3 50 trim on a d15b vtec
- Critique my welds...
- Possible Boost leak ?
- Talk to me about Fuel trims...
- Retard my timing with MSD BTM or leave it to stock specs?
- Earls return line fittings- How to connect (Searched)
- WTB: Dsm 450,resistor box,intercooler piping,fuel pump......
- Part # for Greddy 18G Oil return spout ::need badly!::
- open headers on jrsc
- does anyone have problems with the greddy type s or r
- WHICH FAN TO USE ON A TURBO CIVIC
- Some sohc swap pics =P
- Greddy studs
- Spun Rod Bearing???????
- No Power in fist gear until 3,500 RPM
- aem ecu advice!
- Check out my Soon-2-be Homemade Setup
- Input needed for my future plans... engine builders please look.
- Help identify these fuel injectors? *pic*
- some hks manifold and t25/t28 questions
- some Boost Suspension Q's???
- EVO 8 Mitsu Turbo on my 95 teg gsr b18c1??? what can I expect??
- Eagle Rods??
- How far will 240cc Stock injectors get me?
- any one use these traction bars on a boosted integra?
- Custom build block for boost..250whp??
- Is this oil coming from my Turbo Inlet?
- Eagle Lightweight Rods??
- what cams to get for my car
- Poll: How many are turboed with or without shocks?
- my new turbo parts! (lotsa pics)
- Radiator Fans for Turbo Integras with A/C
- changing to new manifold and 3 in exhaust, do i need to get retuned after wards?
- Quick ? about H23 sleeves
- downpipe 3" flange... question?
- Intercooler and BOV
- who would tune my h22-T in indiana???? anyone?
- gsr manifold question?????
- Any 350+ whp SOHC's?
- question for boosted h22 ludes
- What kind of oil to break in a brand new motor?
- Quick question on rod length
- H22 STR 70 MM Throttle Body pics
- Is anyone running the AEM C2DI??
- MF2 With MSD6A Ignition? Will it fry the MF2?
- funny question about a BOV blow off valve
- blue box and prelude obd 2 injectors?
- will effectiveness of intercooler suffer if i paint it?
- What is the DATA LINK wire for on obd1
- l be pumping way too much yet another fmu, vafc, injectors, pump question.
- Another VS topic....
- skyline turbo
- New member on the board. Have a new turbo setup coming.........
- overspooling...
- Where does oil go? Deep thought by Jack Handy
- Compression too low what head gasket to help raise it?
- Just curious as to times I can expect....
- Post Pics of Inline Mani and EGT Probe
- Just finished my DIY obd0 to 0bd1 link wire
- Losing coolant?????!?!!!!
- Critique my dyno chart. GSR t3/t4 need advice!!
- ANyone have any experience with weapon r fpr?
- questions about Jasma certified Turbo mufflers
- whipits nos kit? haha
- GE oil feed kit (ls/vtec kit) questions?
- Oil Pressure Sender - Turbo Oil Feed
- how far can i go with 450cc injectors??
- sc34 and lsvtec?
- high compression + nitrous + OEM pistons..
- intercooler size
- Reading sensors?
- Question on hooking up the boost gauge.
- ERL SUPERDECK
- Looking for an MF2 Unit Cheap!
- 14b or t25? sohc zc in crx si
- how to prevent boost creep on t25?
- what are CP pistons?
- Copper Head Gasket and boost
- Jotech in Dallas
- wideband o2 sensor smog legal????
- Leave the head stock? Help please!
- 2 bar map sensor good for 14.7psi tune?
- FJO wide band
- My dyno from Nov. '03
- Turbo Mani for d16a6
- 10:1 c/r too high?
- Precision sc61 with t04s cover
- Does Turbo Pass Emissions??
- turbo ls
- sorry dsm injector question. searched.
- endyne supercharger on a lsvtec
- This is really funny! You have to look! More FMIC issues
- stock gsr bore?
- turn up the boost....
- Ran the car FINALLY! Not 10's YET but close! Vid inside!
- Check out this setup
- B20 and LS timing belt cover - same thing?
- anyone ever uses this walmart gas welder?
- Can you guys tell what BOV this is? --Video--
- EMANAGE PASSWORD?????
- Misc questions ...
- Air/Fuel ratio
- ordering bends piping
- Nitrous Refills : good price in San Jose??
- NEw #'s Stock LS turbo @ 12psi
- turbo oil feed line size
- turbine wheel and shaft swap
- would 3500 be enough to build a h22a4 to handle 400whp?
- Took my BOV apart, is this broken? *pics*
- Stock fuel pump capabilities? 11psi okay???
- DRAG TURBO KIT
- turbo probe MAP
- To the Sponsors: Would it be possible?
- is this detonation?
- plz help valve adjustment specs
- Forced indution for ATR
- Best Turbo kits
- what else do i need for hondata?
- side exit dump tube thru front bumper
- F22 Turbo Setup??
- safest oversize pistons for...
- Setting timing on a new motor, any tips?
- JG Manifold on a B16A2, some install questions
- SC61 / Drag
- Well I'll be damned; look at this nifty little thing...
- AVC-R Wiring
- problem with check light
- Can't get oil return fittings to cooperate?! help!
- EMANGE USERS-Ignition Harness Question
- Let's see your dumptube pictures
- finished turbo project tonight.. and NO Boost..
- A lot of blow by, headgasket bad?
- Dump tube?'s
- can anyone tell me if tickets are on sale yet?
- what turbo manifolds to use with 94 si(no a/c or PS)with b18a1 t3/4 turbo,and teg full radiator?
- oil catch can
- what do you need to do to use HF mani for turbo
- is there something missing from this 1000cc injector?
- Which clutch?
- Water injection
- question regarding /internal external wastegate
- Just getting Boosted
- What hp can I expect
- Best Aftermarket Oil Pan for Turbo Applications
- To Preludes tuned with Hondata
- b18b or b18c?
- Greddy Turbo Kit Dynoed
- Greddy turbo question???
- I SOHC turbo problem
- RHb5 Question
- Bogging?
- Need Quick help with a turbo sizing issue.
- TT d16z6
- what type of oil should i use in my turbo?
- Thicker headgasket on my D series?
- t3/60-1 question
- Spool and Lag
- How does a turbo work???
- sleeve the y7 block or z6?
- buid-up and tunnig question
- smoke...need help please
- best turbo for a single cam
- OT: Sorry Guys, but good explanation
- Any of u with vacuum manifolds
- Help with Pcv routing, oil in turbo... hard to explain
- Intercoolers
- fuel pressure regulator for boost
- **MY SET UP WHAT HP/QUARTER MILE TIMES TO EXPECT**
- ARP 2000 rod bolts yay or nay
- SC34 Turbo Clearance
- GOOD hondata tuners in so. cal??
- Just spoke to s00pid on aim about Hondata and aem
- What parts to replace for high milage turbo engine
- ANY Emanage users with OBD1 HELP!!!!!
- gm 3bar map sensor (whats the part number)
- 9.5:1 or 10:1 for now more than 15-16 lbs.??
- crvtec turbo new to this
- Exhaust Flow Question.
- LUCAS injectors
- cheat the hack!
- Intercooler Piping
- what injector size?
- Wich is the best turbo-manifold for a B16A2??
- maximum egt temp
- Need tunning help Bad...
- turbo specs for integra Ls?
- What tranny for a LS/VTEC turbo???????
- JRSC + DTR header?
- Cali peeps!!! Coming back through!!!
- Why do you need to gap spark plugs?
- good motor building place?
- SPA egt gauge hitting 1650 at wot!!!!
- benson for me?
- Are the b-series cyclinders lined with anything?
- ? about converting a mani w/t3 flange to t4
- boost problem
- Spark advance
- Quick t-25 question
- Buddys crx turbo Info/Dyno VIDS (56K go to Tbell)
- which cometic headgasket???
- found a used turbo for sale, 90 000 miles!! :o is it even worth it?
- Plans for 2004...
- looking for a throttle body for a h22 turbo
- Look what Santa brought me....
- HONDATA.... advantages over emanage?
- Clearance probs with oilpressure sending unti after Endyne catch can install . Help
- Help with custom filter...fitment question
- greddy profec b spec ll
- Pics of the Peon
- Paid $12 for purge kit, EVERYTHING included?
- GSR with 3MM Head Gasket Questions
- need help with turbo mani
- Octane and Air Fuel Ratio
- lots of oil missing...
- Aluminized steel Q.
- 200-250 whp on a d16z6 sohc turbo?
- BOV facing downwards???
- NEED HELP, Oil feed fitting broke off block!
- Oil Fittings
- Oil pressure gauge hitting 100psi
- video/sound clips
- Best place to buy an O2 wideband sensor?
- does the piping AFTER the intercooler have to a metal type?
- how bad is this "hairline crack"
- ?Garrett T3/T4E 57 trim turbo specs? (inducer & exducer measurements)
- 9:1 CR or 10:1 CR for turbo?
- AEM EMS versus FUM/inline pump setup (dyno plots inside)
- Can Hondata control something like an electric water pump?
- Long time stability
- Hondata question?
- Boost vs NJ emm
- Is 9.5:1 C/r too high?
- Hondata tuning issues...
- timing controll
- dyno and tuning shops in atlanta
