View Full Version : Forced Induction
- My motor ate an alternator belt!
- My 2.0L, topmount GT35R, Crower 404, non-VTEC B18B build. Tons of pics!
- Englishtown 5/7/06
- meutek cast manifold. new company in the world of boost?
- What vacuum hoses are you using?
- Spoolin Performance d-series ramhorn pix
- New S2k Stock Engine record - by JG-Fab.com
- How is everyone running their power wire to external pump?
- short exhaust
- Will I Make 300+ Whp
- Target Lambda when spraying Nitrous?
- CIVIC SHOOT FOR 350
- Manifold/Retain A/C?
- Estimated spool time?
- where to buy turbo mani merge, and donuts
- few pics of my 99 turbo si.
- Shimming your OBX LSD?? Who did it? Did you have too?
- map sensor code after run to full boost; using MSD 3 bar sensor
- OVERHEATING on free way
- acg fuse help plzzzzzzzzzz
- exhausts exhausts exhausts
- hi maybe boost leak?
- cast manifolds
- chipped ECU problem
- ordered a p06 ecu, got a p75
- oil cooler success!
- RETURN FUEL SYSEM
- edelbrock turbo
- Anyone use the ATP Turbo VES assembly?
- D16Z6 bottom end build. Where to get any better price?
- Vortech Exhuast size and bore size
- Is It Safe To Run Turbo Pistons N/A To Break In???
- GT3082R (aka 3040R) TURBO..Has anybody tried one?
- t3/t4 p trim questions..
- 96-98 Civics...Lets see your front mounts!!!
- 2.5 flange > 2.35inlet ?
- dyno'd car today, have issues need help with.
- Does anyone know when the JRC site is gonna be back up???
- sleeve size
- cant seem to find a decently priced scatter shield SEARCHED A LOT!!!
- Should this be connected?
- Turbo guys, what brake setup are you running.
- jdm d15b rocker arm assy and cams on y8 head question
- has anyone used a gt4276
- Turbo Oil Line setup questions.
- Randomly Has no Power
- Do I need an Adjustable Fuel Pressure Regulator?
- 99si turbo, best street legal way to get 260+ on stock motor
- sc50 turbo on LS vtec?
- Painting intercooler?
- What do you all think about this kit?
- Does your large turbo spool in 1st gear?
- what size injectors?
- exhaust blows smoke
- probe srs pistons?
- Installing injectors before turbo
- Turbo LS/Vtec
- b20-vtec with 50 shot
- Is this turbo too small for B-series?
- Need oil Feed line San jose Area Help!! cant find and local store!!
- Turbo kit?!
- WTB: T25 turbo. Good or bad
- Going for turbo to N/A
- 14b flange same as 16g?
- Tuning on boost?!
- GM 3bar map?
- PT67DBB on a B16?
- bov flanges
- Q about afr's (TUNING WITH SAFC)
- zeitronic and uberdata
- where to find locally a 1/8npt plug san jose area
- Blitz SSBC boost controler install.
- meutek manifolds
- is this a sc61?
- T3 60 Trim with .82 a/r
- using an 11 x 11 rad (2.5" thick), help with cooling?
- Is this too small to run real low 12's to hight 11's in Integra
- Drop In Boost on RSX -S with K pro.
- .82 exhaust housing helpful?
- Quaife install question
- ** name that TURBO **
- SEARCHED, but couldn't find my answer oil pressure related
- When assembling a turbo do you....(Help)
- Radiator / Cooling fans - Best 10" fan?
- Question regarding GT35R...
- @ what WHP do U need MSD?
- my basic stock b18c set up
- People using gt28rs, gt2871r....t25 housing
- BOV location??
- those using GE oil sandwich, need fitting sizes for large port
- Wideband/narrow band question
- I GET MY BUILT B18C BACK TODAY......BRAKE IN PROSSES???
- Anyone got a helms for bseries? need some tq numbers pleeeaassee
- is it to spray simple green on your fmic?
- JRSC issues
- REv hard intake manifolds.
- NEW SETUP PICS!! 92 VX Hatch-T
- h22 turbo basemap?
- surging idle.
- whats the difference stage1,2,3 turbine wheel
- where to hook air/fuel wire?
- what oil pump should i use
- Need Installation Manual for Greddy 15g kit
- BOOST PROBLEMS??
- EMS Solution for D16V Engine?
- What reliability parts are recomended for 300whp?
- Opinions on JB Welding oil fitting to oil pan.
- Air filter NOISE?
- what would this vacuum port BEST be used for?
- 5-cap block girdle
- few questions before tuning for the first time.
- restrictor with 3an feed?
- runnin lean and rough during idle sometimes, lean idle on the tune or fuel pump no gettin enough pow
- 500 WHP club! w00t!
- Tuners/Tuning
- the right way to do your oil feed line!!
- whats the problem?
- anybody try this intercooler piping?
- Nitrous solinoid leaking please help
- got a queztion
- Question
- Coupler help
- VERY WIERD: coolant coming out of my BOV/charge pipes?
- Crankcase pressure = ruined turbo?
- would cams be worth my time?
- has anyone built a b16 with ls crank
- Anyone use this map sensor? (ebay)...says it's the same as AEM
- edelbrock intake manifold
- need some numbers
- JRSC 10LBS of BOOST?
- Is 15psi to much on stock block?
- what will cause bogging after boost ?
- cometic head gaskets...
- IT STARTED!!! First build - *VIDEO* Wont Idle, Sounds Rough. Diagnose me
- d16z6 with a t-28 but starving for more power
- LS with TD05H-18G questions...cant search.
- Copper plugs with CBR COP setup?
- Anyone ever buy anything from turboimport.com?
- can any muffler shop do a full 3" exhaust?
- 14b and 16g question
- Need Help!! Turbo kit components
- S200 to S300?
- Another One Fab Complaint! Business 2 Business
- Greddy E.O. badges?
- Tuning Preparations
- Am I in Limp Mode?
- B18B Turbo Question's
- Cleaning/Degreasing a boosted engine bay!
- turbocharged B16 work fine with MSD SCI?
- edelbrock turbo kit problem
- Number 3 cylinder is gone..
- internal wastgate boost adj. question ?????
- B20 VTEC
- loop strap mounting bracket things, where to get?
- NOOB b18b nitrous question nitrous gurus plz chime in
- Difference in power capabilities of walbro 255 and 255hp?
- turbo and motor question
- pte gt35-61s for h22?
- turbo lag or something else?
- Ideas To Check For Tuning Problem. Urgent Help Required.
- every turbo kit on ebay....
- A1000 fuel pump
- Hear me out...
- t360-1 turbo,40mm wastegate,11psi spring,spiking to 15psi on gauge,No boost controller,Why?
- GSR and b16 vtec solenoids the same?
- Downpipe Issues ...
- re did my PVC set up
- Step Decking and O-ringing....boost motor...
- How long until rings fully seat on built motor?
- Check engine light on after greddy turbo??
- Cam choice
- Vortech supercharger....
- (searched) boost street/strip
- compression test right?
- Good Injectors for Stock Motor 250-400 whp
- need tuning in miami ASAP!!!!!!!help!!!!!!
- Walbro 255 Pump-25 psi
- arrghhhh i cant decide what turbo to buy and i need one sooon!
- What kinda fitting for DRAG oil return line?
- WHAT I DO
- is it worth the price?
- hey lads i drive a 97 ek9 type r (want boost)
- MSD Ignition Install
- Fuel pump and injector question
- Typical Output from Edlebrock Manifold?
- Precision Injectors- Not accurate?
- Something really weird has happened! (please help).
- Gasket Maker or Bare Metal ? ...
- WTF! Fuel Saving Pill ?
- What type?
- b18b turbo sutup....help needed ASAP!
- Picked up some BFG's for the coupe...tech question though.
- To Do or Not To Do (Turbo Type-R)
- quick wastegate question
- Very random, dumb question - 3 inch IC piping + EG foglights = possible?
- Turbo Theory..............
- Order or putting on a turbo?
- Precision Turbo Announces . . .
- car revs fast and hard to 7000rpm then it struggles the rest of the way
- rc 1000cc injectors to much for my set up
- Turbo Timer on Compustar alarm, can't get it to turn on why?
- Boosting only 1.5lbs and nothing more. WTF?
- rod stretch gauge really necessary?
- LS turbo hesitating... why?
- Turbo LS uberdata issues
- Fuel Pressure Goes Crazy...
- anyone use this ebay BOV??
- Question aobut nos dry kit
- Vortech Owners Unite----List your set up
- datalogging with plx wideband, is this how you hook it up?
- d16z6 arp torque specs and extension on torque wrench
- Please explain bearings and dialing them in correctly to me
- B16 turbo build help
- Teeing off @ FPR
- S/C rsx throwing lean code at idle need help
- i dont think my bov's working
- hp limitations on 440cc injectors?
- difference on intercooler ??
- oil burning question
- b20 turbo
- Low compression k20a3 question.
- vtec is not working , please help :(
- Greddy Type 31 and 24 HP rating?
- Fluidampr install/removal with tool!
- finally some pump gas numbers
- HELP:ANYONE KNOW WHERE I CAN GO TO REBUILD A TURBO?!---SOCAL---
- turbo to manifold bolts
- stock lsd transmissions any good ???
- Vortech pulley upgrades......2000 Civic Si
- has anybody ever rain a jrsc on a d15b7?
- Good place to order BKR 7E-11s from?
- Plastigauge results-- advice please.
- 2000 b16 turbo?
- NSR manifold
- How much whp is this intercooler good for.
- will a 30x6x3 fit my 95 civic bumper?
- Anyone had this problem? Block and Crank issues
- precision 1000cc injectors, and stock injector seals?
- People who have owned TURBO AND ALL MOTOR cars, please come in.....
- Where to buy a wideband sensor...vwdealer not working?
- What Trans is best for my setup ????
- Getting Back Into the Scene....maybe
- Aftermarket Fuel Rail/filter . ? Needed for my setup?
- My car pops/misfires/shutters after 10psi, any suggestions.
- SAFC2 help please??
- SAFC2 Settings??
- coolant & bb turbo?
- gasket between turbo and manifold?
- ring gap (yes, once again)!
- Who the heck is MPRD? and where are their manifolds?
