View Full Version : Forced Induction
- DRAG Turbo Manifold Issues
- SRP pistons??
- which turbo should i get for my 00 gsr
- compression and boost
- DUMBEST @#@% to happen
- Koni yellows w/ lowering springs..for $200
- I just dropped a turbo in and I'm drinkin gas like a V8! Is that normal?!?!?
- what is the best nitrous oxide setup?
- What cams and cam gears should i get with my turbo?
- Turbo Uninstall for emmissions
- weird gurgling noise from intake?
- How much boost non-intercooled?
- GReddy EGT probe help
- Drag 3 GS-R & Fluidyne Radiator?
- Sheetmetal Intake Manifolds and Tubular Exhaust Manifolds (Kooks, Etc.)
- HKS "horns"
- How much does a t3/4 turbo with a deltagate WG weights ????
- Are Japanese “30,000 mile” Engines Street legal for California emissions?
- Turbos and the Bay Area
- will revhard stage II B series fit ITR?
- block trimming with rev-hard kit....
- what motor combo?
- Will I LOSE power with Kamizazee header with no JRSC?
- what is the the difference between the JR M-45 and M62?
- looking to upgrade the radiator
- Honda Fuel pump pressure and flow test results.
- DRAG GEN III Turbo for honda civic
- AVC-R groupbuy
- Ignition Map
- fuel pressure formula w/ rising rate
- what size of Tial wastegate to go with a Rev-hard or Drag 3 manifold for B18 ???
- Fuel Pumps for Turbo Setup
- Does anyone know the cfm's of the Drag Gen II kits?
- Anyone ever get really loud belt screeching on their Jackson Racing Supercharger??
- WTF?!?!?!?!Tach died...HELP!!!!!!!!!
- Which connecting rods to get?
- B18b Turbo HP???
- Attn. All GSR Greddy Turbo kit owners.. Need help..
- What about a turbo volvo project??
- whats this whaling, screaming noise i hear around 4k rpm when i hit boost?
- whistling noise?
- pics of blitz dual din pod?
- exhaust for turbo
- Does the water injection help at 6psi
- F-MAX Turbo Kit?
- want to run 13's with my 2000 civic si
- overheating problem *dammit*
- Crank (rear main) seal?? how many have.......
- Mugen Radiator Cap?
- 1/4 times !
- turbos..someone help
- does ne one have ne pix of a turbo LS engine in their civic 92-95???
- does ne one wit a turbo honda ls turbo hybrid go up to da races in philly???
- Holley (Walbro) fuel pump question
- What type of %#@!*& Spark plugs to get?!?!?!?!?!
- wheres a good place to get a cluchmasters cluch ?
- Differet Supercharger Kits available for G3 GSR's
- smaller detail greddy turbo questions
- Boost Controller Setting
- Too much boost!
- Best Intake For Turbo
- VOLTAGE READINGS AT WOT on Turbo LS
- does ne one kno ne shops whu do engine and turbo work in south jersey or philly??
- how should i build up my motor?
- calculating compression ratio under boost.
- Interesting thoughts.....
- MASS DYNO DAY???????
- Budget turbo
- How many Turbo Integra Type R's are out there?
- help..turbo install threw engine code
- Times with a Greddy Turbo?
- Stock camshaft or aftermarket???
- Portflow vs. JG vs. ????
- LS TURBO???
- Engine HEAT problem...help
- can a Non-JRSC comptech intake be modded to fit a JRSC??
- Turbo install overview... where to find?
- need help on intercooler piping....
- 9.8:1 and 12 pounds of boost?
- code 3 anybody with 2k steady RPMs
- Why is it doing this?
- insight has wide-band o2 sensor (or similar)?
- Am I going to get a CEL on my ride when the turbo goes in?
- Has anyone heard of a Rayjay turbo?
- mf2 tuning?
- How much boost can a stock honda/acura cpu&MAP sensor read?
- LS VS GSR!!!
- How much whp should a turbocharged gsr make?
- HELP!! My HKS Turbo Timer Problem! My Timer runs but engine shuts off with key, whats up?
- 8psi Blower Pulley + X = 9psi?
- ACT clutch problem? or suspension?
- HKS EVCIV Help!
- B20Vtec Turbo vs. B18C turbo vs. LsVtec Turbo.......ahhh
- Need help picking out exhaust for turbo civic
- Looking to go turbo..Need input!
- Does Apex make a 3 inch exhaust?
- will apexi twin chamber bov universal fit a drag kit?
- What should be considered as a BUILT Motor?
- help! stuttering
- How much have u guys spent on ur setup, so I don't feel too bad
- Need help on these trouble codes please
- anybody running a Hondata computer
- Greddy turbo with BOV and no Intercooler?
- JR Charged B16 Crx.....anybody??
- Atomic and Endyn (yes I know this is getting old)
- Routing boost gauge vacuum line on drivers side
- GSR...Best cars for NOS???
- FI Emission(Smog) test results, if you have them post it here
- Single wire O2 -> 4 wire O2?
- Anyone ever have anything done by bullishracing in NJ?
- Can I keep A/C with a Revhard Turbo Manifold?
- quick question..
- just bought the J&S safeguard piece, what do you guys think of it?
- Websites
- Type R BOV, ANY COMMENTS?
- which blow off valves use the same flange as the drag and fmax kits?
- my car
- What's the website for XS engineering Turbo's?
- Is running a turbo w/factory injectors ok?
- are the autometer a/f gauges accurate or close to accurate at WOT? or even accurate at all?
- How to install autometer electrical fuel pressure gauge?
- H22A Turbo or B16 Turbo
- turbo on crack?
- TURBO
- will 95 ls injectors work on a stock 95 gsr motor?
- need help check engine on greddy turbo kit
- Dealings with Luangamat@aol.com
- Quick question......
- does anyone have vortec's website address?
- MarkC I need your help with tubo rebuild...
- greddy (95 gsr) blue box and injectors w/ 95 ls computer?
- I Have a question for u turbo guys?
- loosening and tightening HKS SS BOV!
- ENDYN
- Help!!!! Is FMAX Turbo worth it and for this price????
- Built 94 LS with 12psi, are 370cc injectors too much????
- Code 92
- Custom Ram Air
- request! search didnt do it!
- We're giving away RC Engineering 310's!!!!
- whats a good fuel setup???
- t28 turbo?
- Greddy T. Timer ???
- Hel pme out here...which one and why?
- Where do I buy sleeves?
- Overboosting ...
- Upgrading Injectors
- Buiding a 12sec.daily driven 90civ hb
- GSR w/ Drag III kit with a Skunk 2 Intake manifold ????
- VTEC on turbo
- fuel pressure gauge sits at 40 psi with engine off....is this normal?
- can someone explain to me the dif between ball bearing turbo and a standard turbo..
- I am new!!:) help me with my turbo setup
- God help me.....turbo here I come
- I don't understand my JR BTC unit... Please help!
- why isn't it good to mix cold air intake with a compressor device?
- NEED HELP, VACCUM ISSUES?
- Which Copper Plugs ??
- Injectors+stock ECU
- Could it be my DELTAGATE that is enabling me to get my AVC-R working?
- does ne one know of a good turbo LS setup in a honda coupe(92')
- 2 questions.......should be simple
- Ran the Civic hybrid/turbo last night...
- AVC-R Q. The injector signal (purple wire) connects to ??
- i/c piping
- ATTN: G2 Integra Turbos
- should turbo be cleaned?
- My Drag 3 Turbo Pix...
- O2 sensor observation.
- How to check for Brake booster leaks?
- Detonation Woes...help!
- 1995 Civic Si knock sensor
- need help with an LS turbo question!!!!
- overheating problems?!?!
- ZEX AND ENGINE PROBLEMS?
- hpc coating for forged piston?
- Anyone use juice and turbo together?
- compressor surge-what to connect blow-off hose to?
- Are FMU's necessary if you have big injectors, fuel pump, and a AFC?
- whos going to NJ for SummerSlam
- Turbo install...car shutting off
- where can I find a Tomei a/f/meter?
- has anyone boosted on a crv motor here
- NE1 have a hook up on STR stuff?
- Straight forward question about ...
- Built GSR motor + SpeedPro = ?
- kamikazi header question??
- What Turbo is Bigger
- Old Style B18A1 power struggle
- the best fuel setup to go???
- can a turbo's specs be changed ?
- Anyone runnin the SKUNK intake Manifold? . . on their turbo LS?
- Anyone ever blow a fully built honda motor.
- LS/ITR Edyn JRSC numbers?
- Heat Shield
- What you guys think about the new RSX type S
- reliability of f-max kit
- Turbo advice and opinions
- Vinyl Paint?
- need help with wiring greddy turbo timer with alpine alarm
- How much lbs of TQ can a bottem end hold?
- 550cc injectors
- difference between M&H and mickeys....
- Nothing like a hybrid/turbo!!!
- Boost
- Please help the new guy out with turbo questions!
- I have a Turbo LS thinkin bout Vtec head or NOS? whats better?
- Should I use the FMU or the 2 extra injectors
- Apex'i 3" Universal Filter
- CRV crank pulley for JRSC users?
- When to change plugs?
- Car runs HOT after COLDER plugs???!
- Drag Gen 3 for Prelude
- Cutting a hole through my frame
- Here's why you shouldn't buy a used turbo...
- how do correctly reboot a 2000 honda civic si ecu?
- just got my manifold.....
- For those that asked for a Thermal 3" exhaust group buy!!!
- How do i adjust my GReddy Tpye S BOV?
- Rocky
- Apex Turbo kit for Integra
- What is a good oil temp for highway driving with a turbo?
- WHITE SMOKE!!!!
- My dyno numbers....
- Endyn modified JRSC dyno plots?
- any one utilizing the VENOM nos KIT fully programmable one
- Turbo rebuild advice
- Turbo Gurus lend me an ear!!!!!
- vtec to non vtec, what internals will crossover??
- The Reason I Love Boost
- Greddy Kit
- Hey, Please post Dyno charts and Track slips for Turboed integras.
- Turbo Cams for all out drag racing
- can i get some turbo help ?
- Running a Bosch fuel pump intank?
- DRAG manifold cracking - how to prevent it?
- need help with check engine light on turbo 2000 honda civic si
- 3" Downpipe?
- HOW MANY OF YOU GO 12's in a boosted LS WITH FULL INTERIOR?
- what is the best set up for a B18c Crx?
- Gotta get a new radiator...
- Greddy Type S BOV question
- why greddy kit for 99si have alot of cell problem ?
- My last 3 weeks...
- Vortech or Turbo?
- Anyone have Dynoplots of JRSC on B18B motor
- Anyone have a Dyno plot of B18B with JRSC
- greddy turbo vs jackson supercharger?????
- Turbo question.....
- 90 civic EF with a 92 civic radiator? Possible?
