View Full Version : Forced Induction
- Hondata on a PDA
- ????Hard decision to make about my LS/vtec turbo. ----HELP-----
- anyone here running big horsepower with tial 38mm ??
- bowtie S/C Zcar
- precision SC63 compressor map
- CRX's with Hasport billets, and victorX manifold...(Question for ya)...
- Turbo is EXTREMELY close to the block. *pics*
- Quick measurement needed!...Length of VictorX manifold...
- Gm map sensor wiring??? Already searched..
- new motor for turbo??
- Air to Water intercoolers, would putting some type of refrigerant chill it better than water?
- I made the right choice huh?
- anybody know if ssautochromes tial style wastegate is good, decent, worth it?
- Test fitted my intercooler and have some questions with plenty pics!
- Trying to diagnose my turbo civic's overheating issue...
- BOV sound clips
- is there a good equal length b series turbo manifold out there that wont change my turbo location ?
- any high comp. boosters?
- Inline Pro and WasteGates?
- revhard Intake Manifold??
- oil feed line what size
- anyone using precision gt35e?
- how do external wastegates work ( search used, bashers go elsewhere)
- fields controller run 450's ??
- Plugs are white now!!
- DECISION TIME! I need YOUR help!
- TBO350
- Which Turbocharger
- Wiring a Wideband by itself
- Bypass alarm ignition for turbo timer how?????
- How much longer is the engine suppose to smoke after changing the head gasket?
- how much can i boost
- Who can get Haltech e6x?!??!
- greddy turbo, questions??
- Accordingly Done's 3" exhaust for 90-93 tegs
- Using a WG instead of a BOV.
- HEAD PORTING QUESTION
- which clutch ?
- Are the Precision injectors a direct fit...
- h23 direct port system
- Any one know where to get a 3 inch down pipe for an h22?
- spoolinPerformance GSR's
- P28 ECU Pinouts NEEDED OR EMANAGE WIRING DIAGRAM
- FPR
- greddy turbo timer installation in 4th gen civic?
- just got my GE h22 int. manifold! need help with picking T.B
- Question. Can you buy just the Pipes and fittings from a Drag Kit?
- What size turbo comes on EG sohc Greddy Turbo kit ?
- Looking for Greddy 3in. exhaust
- no weld oil drain line kit
- Something really wrong with my TURBO!!!! HELP!!!!!
- Are all T-70's the same?
- Using a VTEC ECU on a non-VTEC engine... problem?
- Fastest spooling turbo for low boost (6-8) for a D series that will last to a stock redline??
- need to match a turbo to my motor help please
- can i stick this on a Dseries??
- Converting HX O2 Sensor To WideBand ?
- Will Hondata idle 8 injectors?
- endyn breather kit
- Anybody have a Hondata b18b basemap?
- Honda Bearing color to thickness chart for everyone who loves using OEM bearings
- EVOVIII boosting low from the factory?
- Need pics of where to put AVCR Boost Controller in 00 Si.....
- HELPP PLEASEE!!!! H22 Turbo
- Intercooler fitment question
- fuel setup for d16 & nitrous
- How does my clutch/flywheel look?
- I just installed my turbo and I have questions about normal EGT temps and Oil Pressure.
- plumback valve?
- What is wrong with this oil return line?
- ebay turbo kit...bs?
- Intercooler question size and exposed area
- TURBO XS single vs dual boost controllers
- Exhaust ?
- A/F Gauge Choices
- Any issues w/ daily driving 1011cc's injectors?
- What size injectors should I get for LS Turbo
- Has RevHard stopped making the Iron/Tubular manifold? (Heard Rumor)...
- Gear dependent boost settings?
- 2 different boost guages give me 2 different readings
- vacuum box
- help me find a hondata tuner to tune a ls-vtec turbo and direct port nitrous!!!
- Best cams for turbo set-up
- wastegate plumbing question
- cold start injector setup
- The search for 600HP
- will it hold
- AZ peeps, I need some charge piping.
- Help....strange problem.
- searched: where to i tap the oil pan
- InnovateMotorsports Wideband and Standalone for Datalogging?
- Supercharged LS/VTEC - Anyone Done it?
- Inline Pro Kit vs. Full-Race Turbo Kit
- wastegate and boost controller help
- Your alls info on Vacuum Boxes...
- who got turbo goodies for christmas?
- Need help tapping manifold for EGT
- BOV question...
- switching from turbo to supercharger?
- maximum boost with 10,2:1 CR stock B16A Engine
- High Boost B16...how important are head studs?
- jrsc snout leak
- causes of overboosting???
- remove the resitor box or not that is the question.
- Electric intercooler?!?!?!?!
- ____________PICS of 94-97 INTEGRA INTERCOOLER PIPING. ABS Equipped...
- about header for jrsc
- turbo smoking?
- Does MSD make the DIS-2 HO anymore?
- TURBO PROBLEM :(
- Ideal headwork for a built turbo setup?Oversized valves?Valvetrain?Cams?
- Fuel Rail Qs
- Where can i find a honda manual for....
- Need your opinion......
- dsm injectors on a honda?
- Exhaust question
- Blew up on Christmas!
- wideband tuning
- New buy for me!
- jesus this is big. sp88?
- merry xmas!
- missing link
- stupid question
- Dont flame me for this, it's just never been discussed before
- Headgasket leaking oil...
- Injector Help
- SSAutoChrome manifold questions...
- missing link question
- is there anyway??????
- a where do i get a base map from??
- how do my plugs look to be doin?
- manifold piping ubends
- y1 w/lsd or ys1 gsr for turbo?
- Problem with isolation valve and map sensor...
- 2.5 vs 3 inch exhaust,
- The Audi
- turbo question?
- Vafc hack? somebody explain.
- CP Pistons Compression.
- i searched but didnt find... biggest shot nitrous in 2002 v6 accord
- twin turbo mustang @6psi 600rwhp!!
- Merry Christmas and Happy Boosting Everyone!
- what turbo?
- revhard manifold
- OT: Chevette From Hell
- Engine Swap B16A/B18C
- Cold start and turbo seals.
- EXHAUST
- Will this make a diffrence in turbo ???
- Is it worth the hassle to convert a P06 to a P28?
- redline water wetter?
- oil feed?
- Does full race use stainless head flange for their manifolds?
- fabbing a downpipe. got a few questions...
- mounting turbo backwards on inline pro... who's done it?
- Should I display the A/F ratio If .....
- LHT intercooler any good?
- 3" exhaust and dp
- aftermarket fpr?
- Going 84mm, do I need fuel management if not boosting yet?
- Couple of Newbie nitrous questions....
- Clutchmasters Pricing
- Hondata s200 hard starting and surging
- Turbo ITR throwing missfire code
- Downpipe Manufacturer
- Traction on the dyno with big power?
- Cams for turbo setup on B20/P73. ECU suggestions. Your opinions please
- Turbo B series EG
- Is 4,000 too much for a Turbo Kit?
- JDM integra pic
- i have a missing link???
- interga jdm front pic
- Formula for fuel injector size?
- problems with avcr......
- Need some help guys. Back door intercooler options
- ** Tubular Manifolds W/ Running AC **
- Turbo size
- Drag kit inline pump quick question
- Turbo Guide
- homemade kit intercooler question
- SOHC manifold on b-series
- ATTN. Emanage users!!!
- k-series fuel management
- Anyone got pics of the Inline Pro Fuel Rail?
- Anyone sell an i/c that will fit where my ac condensor once was? (92-95 civic)
- Show me your Setup
- damn it which turbo do i use?
- Wilson Manifolds?
- 440rc and vafc good/bad
- Fuel management for Auto-X / Road racing? Does it matter?
- Tuning with a Gameboy
- JRSC from GSR to ITR atlernator question.
- Odd CEL, Once boosted and with the Hondata, i get a ELD only when...
- high flow cat or test pipe?
- greddy turbo kit
- Does this Filter solution look like itll work??
- MP TURBO MANIFOLD
- Group Buy on USB Batronix Programmer?
- Who uses the Willem burner??? I've got some questions
- Injector question...
- How much boost can a d16 stock piston take?
- Spool times - Exhaust Wheel Size - Intake Wheel Size
- Has anybody used "Crome"??
- up to the emmissionEMS & state inspection?
- Tuning open downpipe.
- H22 Turbo Questions.
- Starion FMIC stock Brackets???
- Tuning Uberdata for B16
- ** Apexi B-Series Turbo Kit Review **
- what is the most power seen from super charged b-series?
- a collection of turbo info ... why don't we have one?
- Anyone know about 2g DSM injectors? Wanna make sure these are 450cc
- Settings for a Turbo project
- Where can I get a new T3 compressor inlet flange that looks like this?
- 2 weeks of boosting @7psi take a look at my plugs
- 2.5" or 3" dp and exhaust?
- lma's...symptoms of them going bad?
- ping
- rx-7 turbo II on a d16z6???
- Please post pics of Direct Port setups....
- Need help with N2O setup
- I am pretty happy with my engine management setup...
- Pics after turbo install on LS.
- defi dog!!
- b18c rebuild belp
- pros and cons to oversived valves
- .63/.60 T3 Turbo Help. Regarding keeping an internal WG
- What's a baffled catch can?
- How can I get 200 hp out of my custom setup. d15b jdm vtec + turbo
- Throwing around this idea for next setup, critiques please
- engine building
- Hondata people please help look at my maps
- Damn when are they gonna release this aem display.
- Can I switch a internal wastegate to external?
- PLEASE IDENTIFY THESE BOVS FS:
- How much power from a turbo b16a......?
- full-race kit question?
- greddy turbo numbers
- Uberdata questions
- I know its been asked but...
- head gasket choices
- how much boost??? 2000 civic si
- Turbo charged engine efficiency vs. NA (engineers, lets chat)
- RevHard Stage II
- www.cheapturbo.com rebuild service
- In search of a street able external fuel pump
- Must I use the "o2 housing" on my DSM T25?
- Hondata quirk.. situation inside.
- popping at idle only changed injectors...a/f is fine, help
