View Full Version : Forced Induction
- JG turbo kit????
- b16b
- what kind of valves to use
- Turbo Type
- What kind of sleeves are these?
- cel code 41 ho2 heater? can somebody explain this one??
- how much is labor work for resleeving?
- ::turbo piping:: NEED HELP
- Anyone running Meng style manifold not getting boost creep?
- choice of turbos
- is my turbo shot??
- drag 3 kit and h22 help
- Where to buy a built engine??
- Need Serious Help in So. Cali!!!
- Turbo'ed in Tucson
- Car won't accelerate....HELP!!!
- gm part # for jrsc oil?
- Accel DFI Gen 7 Sequentail ECU
- What kind of Standalone?
- ES Oval 2.5" W/Turbo
- Need sites where I can get a pipe set and hoses, thanks!
- What do you do to keep your turbine housing free of rust?
- help!!!! broken banjo bolt
- PIC request: good oil TEE fitting setup on back of block
- ... break-in vs tuning dilemma...
- Seperate oil system for turbo???
- 60-1/t3
- ... how to identify prelude injectors from civic/integra injectors...?
- Drag Turbo kit wastegate question
- Tell me why THIS looks so different?...RE: oil catch can
- Okay new 255 walbro pump still working out the bugs
- Vac leak from injector seals?
- Turbos direct phone number, anyone have their number?
- Can I go dyno with only 500 miles on rebuilt engine?
- Prelude Injectors and Fmu
- On/Off Vacuum Leak
- okay Is this a good start till im really ready
- custom turbo...why replace the whole manifold?
- Considering NAWWWZZZZ...
- WTB Downpipe
- safe to run oil feed line capped off before i out turbo on??
- It is lobster season and I want to tow a boat? NEED HELP
- :: azenis in the rain/wet ::
- any you figure this out??
- Stock FPR???
- Unorthodox Pullys
- turbine housing trims? stage or numbers?
- can a D mani fit a B series motor?
- NX NterCooler
- can i run a N/A cam on a turbo'd car?
- Discussion question: does NOS blow up motors.
- Sohc...5-7 psi... FMU Setup or AFC Setup ?
- 90 Degree fitting for oil drain line off the turbo?...yay/nay?
- Centrifigal superchargers and boost control?
- Removing Drag 3 kit for smog
- Tial wastegate spring question...
- anyone using a stock crx radiator with a revhard manifold w/t3/t4oe
- Valve Cover Leak!
- toggle switch for obd0-obd1 question???
- exhaust size for jrsc on gsr
- MBC and internal wastegate actuator questions
- obd0 to obd1 conversion ARGGGGGG!@!
- Drag III ...Greddy!
- Has anybody used the piping from a front mount intake?
- Need help finding out size piston rings
- figured out what is keeping me from getting oil sending unit off pic inside
- do I need a BTM with this fuel set up?
- ??? b16 and d16 rod bearings the same ???
- GSR: TURBO OR SUPERCHARGER
- Greddy Turbo Kits
- got a ? about what i might have done to my engine
- e-cutout vs. hallman
- VAFC problem
- i did a comp test on my turbo LS hatch
- :: thermostat mod ::
- Intercooler piping??? 2.5 or 3 inch!!!
- How do you remove the internal wasgate on a T3?
- Benifits of cam adj. cam gears with boost?
- TINY KKK K03 on D16Z6??
- Jim Fab vs. LSD
- Check if this turbo is any GOOD
- List all makers of turbo kits for honda/acuras
- Intake Air Temp Sensor
- Hondata problems, need help
- Greddy Turbo Kit
- The AFC Hack ?
- total boost controller
- 35mm and 38mm tial
- Where to put O2 bungs on a B16 downpipe
- BEST turbo for 300-320 whp @ 15-18 psi
- 35 mm tial????
- having second thoughts...
- FS: flexpipe for exhaust, downpipe
- anyone seen K&Ns "wide band O2"
- Will a stock clutch wear out on a turbo car?
- New turbo break in???
- Turbo motor is almost done! will it be safe to break in at very low boost?
- Worried
- Help! Overheating a bit running the afc hack!
- wastegate for 500 whp??? tial 38?
- Help on new setup
- ... garrett turbo users, where to tap for boost source for wastegate...
- where do i find weld els and tight radius 90 degree exhaust bends?
- ebay turbo
- What core size are you guys using?
- Turbo and Nos?
- How can I make my own shift light
- Gearing for Turbo
- For those that considered getting an SRT-4...
- ATTN Drag manifold users. Dip stick clearance.
- Help, I need Apexi AVC-D Boost Controller instructions!!!!!
- boost?
- 2.5 downpipe vs 2.5 flaring to 3" Need help!
- boosting safe
- Jackson Supercharger on stock CRV B20Z, Anyone?
- E-85 with a turbo
- Good AEM Tuners in Southeast...
- Turbo manifold fabricators/ I need help
- Where are turbo kit installation instructions? help!
- need to install vacuum lines on turbo.
- Which Precision Turbo for my setup?
- Garret 15g Turbo ?
- Who to cool down your JRSC????? cooling system?
- DRAG kit and smog test
- Top Fuel style Intercooler mounting question.
- where do you hook your WG to?
- HELP!! me with my oil return flange on my TURBO SIDE!!!!!! not oil pan
- Ready to install soon, any tips? Greddy Turbo
- turbonetics Stage III vs. Stage V turbine - what the heck does that mean.
- How do you knoe if your running lean?
- Golden Eagle Block back.....Coolant Conditioner? Other Questions....
- :: stock radiator fan cfm ::
- Turbo Type R in an EG hatch some ?'s
- LS Turbo Kit Question...
- over boosting! just installed my turbo kit!
- need the name of someone who sells custom 3"exhausts!!
- Power FC or Hondata for B16A OBD1??
- REV Hard turbo - kits... ??? -- um?
- keep inline fuel pump or not
- Where should i mount my wastegate?
- Car runs like crap! Cant idle, nitrous sucks....arg!
- 18g...what t-series???
- superchager vs turbo vs nos
- turbo LS VS turbo b16!
- eg hatches with turbo and turbo timer....HELP
- anyone dyno with v-afc hack?
- Pic of Hondata ECU and Interface Box
- Help Quick Question..about boost
- Technical Help!! Wastegate placement abd Boost creep????
- EACV?
- head gasket for boost
- Bolt stuck in turbo!
- Leaded fuel with Tial wastegate?
- Overboostin
- help with my set up for my 96 hatch dx
- help me decide...
- ... radiator fan recommendations...
- ... t3/60-1 downpipe fitment questions...
- New to turbo, need D16z6 suggestions
- Anyone Know Where To Get The VAFC Wiring Harness At?
- at what point should I rethink my fuel delivery system?
- greddy turbo or JRSC for b16???
- Inline fuel pump wiring help...
- inlinepro manifold vs equal lenght manifold ????
- Engine Swap Need Help with Fitting Turbo.....
- volvo intercooler- modding to fit civic/crx
- Put my turbo on... *PICS*
- How do i make a Hondata ECU revert back to STOCK specs.
- Oil Capacity: Add more than stock?
- Latest pic of my setup
- OBX manifold
- turbo b16a...???
- whee to buy hks wastegate springs?
- Greddy Turbo Timer Questions
- ok I'm ready to put my "piece" together.............
- Compression and leakdown results in. . . .talk to me guys
- where the hell can i find a 11/16 tube sleeve and nut???
- downpipe flangs/ plates, where to buy>>
- Need help wiring E-manage for 92-95 greddy turbo * searched already *
- what do you guys think of this manifold/downpipe
- Race Cats, Test Pipes, and Regular Pipe.
- CRX Turbo Radiator, I'm Screwed
- bending and welding own tubing for turbo?
- Has anybody heard any good feedback w/ manifolds sold on ebay?
- How do I adjust the wastegate on my greddy kit?
- Can i run bigger injectors on a fmu?
- Best exhaust turbo civic Hatch
- best spark plugs for JRSC
- Car sat for 3 weeks without oil, put oil in cylinders?
- How do you guys get to the dyno with your setup?
- Best cable vtec tranny for boost?
- nitrous with chipped ecu
- How long is your charge/intercooler piping?
- Anybody running the greddy Profec E0-1?
- Web Cam's experience/opinions...
- Turbo newb.....please explain .50 trim?
- what pistons for my setup?
- Quick synopisis of my turbo install (with question and teaser pics!!)
- how much psi on stock injectors
- What an ignition upgrade gives you on a turbo car?
- map sensor for supercharger
- Look, oil
- What clutch and flywheel to buy if going turbo?
- Any boosted 4th gen preludes??
- can you post your pics of the turbo on a b16 in crx?
- What else do I need?
- Getting rid of check valves, restoring MAP sensor
- toda spec B's with nitrous??
- Zdyne tuners/users whats your timing retard ???
- d16 piston combination
- Power FC
- Running an FMU setup, help with details ?!!
- Boost/Compression
- Check valves?? Turbo Q
- how many people use sandwich plates for oil feed?
- oil in actuator tube?
- hondata tuned boosted cars........what kinda gas mileage you guys get??
- Erl MF2 Extra Injector Controller Opinions Needed
- Greddy E-manage limits
- whats the point of a volt guage?
- how much boost (td05-18g)?
- Need Advice on Project Car
- DSS axles vibrating problems - anyone else?
- fuel setup for 20psi h22a?
- How do you install a BOV?
- Tapping charge pipes for BOV, Wastegate.
- weird sounds comming from belts of my sc or around that area..please help
- How does Cheezefrog get by with running stock exhaust?
- Post pics of Supercharged B series... need some visuals!
- please explain why 400 hp not possible.
- What junkyard turbo for my b18a?
- What should I expect to pay for dyno tunning?
- dsm blue top injectors in d16y8 obd0..
- Best turbo to have for LS/VTEC turbo
- Looking for a good exhaust cut out.
- Anyone know where to get greddy turbo kit gaskets??
- What are the largest injectors you have idled on Hondata?
- My Thermal 3" "warbles" all of a sudden
- have you been satisfied with your turbo
- Do you need msd?
- who's boosted the most on stock h22a sleeves?
- JRSC on 99 Hatch ?'s
- new motor/catchcan/smoke
- do you really need a turbo timer?
- Welders, how much were your gas tanks?
- Problem Overheating, 2 headgaskets wtf??
- Where to mount Gauges
- how would an FPR designed for 240cc handle 290cc?
- Honing: 60deg vs 30deg
- Am I getting raped on this price turbo kit + hondata + tunning?
