View Full Version : Forced Induction
- dsm injector and resistor box wiring?
- Alright guys I searched and am still a bit confused Resistor Box Install!
- MSD and Hondata problems???
- too small of a turbine wheel
- Skunk Stage 1 cams with JRSC, too big?
- A few q's for u greddy owners
- question about a garret t3 with 42 turbine and 48 exhaust
- headgasket?
- Turbo Integras w/ large intercoolers, how to mount bumper lights?
- Turbo + V-afc + chipped ecu?
- Throwing Cel 3 - MAP sensor with Uberdata????
- turboXS RFL bov...past 25psi?
- What does this Cel Mean? #67
- Head gasket for B18C5 / JRSC
- What size bolt/stud is used to bolt up downpipe to garrett t3/t4????
- My old dyno chart. And questions too!
- ZC DOCH motor
- What a perfect A/F ratio for an turbo set up ???
- fast\speedpro
- Jackson Racing parts list
- jg manifold install help
- installed new injectors and now car smokes....
- Changed injectors now problems?
- high hp hondas.... high hp trannies?
- jrsc for h22
- Is your turbo watercooled ?
- those using water injection w/ the jrsc, who sprays before the blower???
- what do i need to make a custom turbo kit
- tial problems, (posting for a buddy)
- will a frountmount work with cai
- Will a EBC solve this problem?
- hytech vs. Full race
- Opinions/Exprience wanted on setup H-T#s Vs. Real World #s...
- Help guys...all of a sudden i'm running LEAN!!
- Turbo for f22 or h23 series motor for sale
- drag turbo kit
- Will I be okay running a DSM fuel pump???
- $2000 for a hondata s200b greddy injectors and dynotuning good price???????
- What JE FI piston is this? 81md4?
- 550+ Fuel System
- type of line and an size for oil return/feed line
- Oil pan compatiblities
- Possible to change a dry kit to a wet kit?
- how does inline pro get this to work?
- max CR on this engine to run low boost?
- just making sure the newbies know not to deal with the DropShop
- rebuilding turbo
- need help with my BOV and Boost gague
- what size turbo for my h22
- quick question about my turbo....
- Skunk2 or JG for GSR. Couldnt find shit in search.
- boosted CR-V
- intercooler/radiator efficiency setup for DAILY DRIVEN VECHICLE
- price of dsm injectors and 3 bar sensor i paid, good or bad?
- max fuel pressure with vortech fmu,310s, & 255lph in-tank..
- How much power can 310s support?
- Reliability of JRSC, 10psi, stock internals D16
- How do you install the HKS Turbo Timer???
- valve cover vent with turbo ???'s
- *Any difference between d16a6 tubro and DOHC ZC turbo???
- better engine to turbo B or H
- camp 1320 manifolds?
- Urgent, can someone check their helms for me?
- Anywhere else i can get a exedy organic racing clutch cheap for d16?
- Were to tap 02 sensor on downpipe?
- greddy turbo Si problems with install.
- RX7 BOV
- turbo "kit" on my b18c1 hatch
- Summer oil - 10-40 or 20-50?
- Q about turbo and intake
- Turbo seals / oil line press (h22)
- n20 qestions
- ANY IDEAS ON A CRAZY NITROUS CAMS?
- Pressure problems with MR2 turbo, please help
- twin charge setups
- Greddy SOHC turbo its a 15g what upgrades can i do with out changing the turbine housing??
- not too happy with dyno 220 hp B18C1 turbo
- So when boosted wit AEM EMS....need gm 3 bar map and Aem selenoid?
- any one ever heard of a "vegas" manifold?
- A Couple Pics Of My Install....
- Some would say, this is bad for your turbo
- Head bolts or studs?
- turbo getting to much oil
- I want to buy, sell, or trade this turbo housing.
- are there any turbochargers that don't need oil to cool?
- installing turbo....fuel management questions
- rebuilding turbo for the sake of learning. need turbo experts advice
- favorite bov?? sound?
- Can someone point me to a solution
- got the turbo on...
- whats a charge pipe?
- B18b engine into 6th gen Civic worth it?????
- ls/vtec turbo
- hondata hates my car WTF ????
- Car bogs under nitrous. Need help quick.
- Just bought a TD04 Turbo for a great deal. Help me get started on my y7 please
- Fully built LS motor for street/track, turbo recommendations?
- best turbo to run on d 16
- Stand Alone Anti Lag prgramming question-
- CRX turbo install
- h-t thoughts on these pistons
- I was wondering how big of a turbo to get, help me out here im new
- is this the GM 3 bar map sensor i need?
- High Flow Cat recommendations
- code 16... fuel injector...please help
- Philly dyno day results
- Question about FMU that comes with drag kit.
- Combustion chamber analysis after teardown
- Holding boost w/ Greddy Turbo
- Garage Door + Turbo Timer = BAD......
- apex i turbo
- pics of low budget junk yard setup on d16 *update*
- Pics of my Car!!
- Long distance driving with turbo.
- Vortech super chargers for 99-00 Si?
- dsm injectors on a civic si tunning question
- Some questions!!!! NOS... and does it belong in this forum>?
- Low Boost
- Turbo suggestion, daily driven B16.
- thinking of zex 55shot
- b20 boost levels LOOK
- B18B on the funny fog...100 shot on stock bottom end
- my turbo is hitting my block
- correct blockguard install
- radiator for crx with boost?
- times from track 7/25
- Does your exhaust shoot out a lot of carbon?
- oil t fitting question ...where do i get it....help
- drag 3in. downpipe
- Nitrous Install need help with install.
- code 8 problem?
- How much power could one expect to pick up once their a/f ratio is dialed in properly
- HP limits of d16y7 DX block.
- bov question
- exhaust @ idle?
- pros and cons of a homemade turbo setup?
- Help finding downpipe or downpipe flange for t3 4 bolt.
- lookin for Tyrus intercooler?
- New part number for GM 3bar map sensor
- CEL with no code!!!!
- new 1/4 mile times, oh yes
- Will a P06 Ecu work well w/ my LS setup?
- Eagle Rods...will they be safe enough? I wanna hear personal testimonials about em.
- poor mans turbo buildup lots of questions
- Where to get the best head................
- a t3/t04e turbo will fit on a drag mani right?
- Boost Lag w/ SOHC VTEC
- Greddy boost gauge???
- Down time? How long have you guys been down...
- Now making: Custom Downpipes
- if u could start out with any engine for FI what would u use
- Who makes a 3.5" to 2.5" coupling?
- Double checking on "pusher type" fans
- best place to buy new sleeves?
- 2.5" downpipe, is it worth running 3" exhaust?
- newbie turbo question
- turbo to piping coupling t3/60-1
- LS Greddy Turbo Kit???
- not starting...
- diffrence between t4/t3 and t3/t4
- ic piping fitment on b16 with victor x man.....
- So I installed my turbo today :(
- hondata/440cc/stock fuel pump
- Hondata + EVAP
- Edelbrock's turbo for 96-00 D16Y8
- Is honda bond this.....................??????????????
- how much hp/boost can LS rods hold
- anyone had a msd ignition go bad?
- greddy kit on '00 y7 o2 sensor question
- How much pounds or hp can a exedy organic clutch hold?
- How do i use SS braided line on my oil return without the threading thing
- Del Sol, I moved the intercooler errr interheater was it was call.
- twins turbo heat shield
- Bad Bad News....is it fixable!?
- Turbo manifolds for the HKS GT2835
- Vaccum question...will this work?
- do i need gaskets between turbo and mani/DP and turbo??
- Pics of Drag Turbos
- HKS turbo questions
- has anyone installed new edelbrock kit for d16?
- clutch install need help asap!
- settings on Apex Blow off
- Combustion Chamber Detonation and cost to reweld
- which size WG, 35,38,40mm from tial?
- will a t3 turbo manifold mate up to a 2g dsm t25?
- some questions for my setup
- hondata with missing link
- Proper way to install ARP head studs
- Boost on GSR engine question........With stock intake manifold.
- Too much oil in the motor???????????????? help again
- B16 hondata base map
- Reading lower boost than spring settings..
- Vortec Blower on B16???
- 77mm D16 Headgasket Choice
- Dyno results
- Tyfoon BOV!
- Oil leaking from ceneter cartridge. help!
- .48 .60 .82 a/r?
- Ferrea Roller Rocker System
- SOHC REV HARD TURBO KIT
- for you boosted b-series...
- critic my 1/4 time
- ... gsr transmission and 13's... shorter gears... how much shorter?
- AVC-R problem...
- Hows this for forced induction?
- OEM prelude/dsm mufler on D16 greddy kit??
- Turbo newbie, ID this manifold ? t3 or t4 ?
- Sohc, Hack, ditch the 6BTM ?
- Anyone running stock muffler?
- Guttin a cat with OBD2... ???'s
- do i need FMU and injectors?
- Boosted!!!!! vac/boost?
- what turbo should i get
- Ground Zero Motorsports, Duc's car is running!!!!
- Flanges?
- 8 injectors on 4cyl??
- How's the E-Manage?
- Compressed CO2 on the Intercooler
- What turbo should i get for my app.
- JRSC 25 vacum at Idle? is that normal?
- Honda Fit turbo
- fuel
- Which engine is better for boost?
- Anaylze this Dyno Run, Race car ++ PICE LINK INSIDE +++
- california inercoolers and bov emissions question
- Open or closed loop w/zdyne for boost (not wastegate dump)
- Ok, for final TIME, what oil weights to use on TURBO engines.. argh...
- ::FMIC size::
- engine heating up while driving??????
- Help. FPR won't let me adjust past 20 psi.
- Those with F-Max kit, how'd you run the extra fuel line?
- tempest
- What would you do first!
- 1992-1995 Greddy Civic Turbo Kit fits 96-00 ?????
- Attn: Those using Meng Style manifolds...DP questions
- vafc hack question (settings)
- code 20
- in desperate need of manifold for crx w/ AC
- Anyone Heard of RH Engineering cluthes?
- Can I run water lines like this?
- MF2 Wiring, some wires were not used!?
- Is it possible????
- from 10psi to 8psi with JRSC, is it possible
- what is the most accurate for monitoring A/F?
- knocking noise under load...
- problem with no spark on aem ems..please help
- Since turbo install keep blowing fuse
- How to adjust HKS BOV
- gauges
