View Full Version : Forced Induction
- What pistons?!
- GT35R on a Subaru STi... .63AR or .82AR? Oh the choices
- Turbo Sizing question...
- Turbonetics Raptor BOV, how does it sound?
- ECU question
- Oil out the dipstick...
- 300M coils
- Best Turbo for 300WHP???
- H series injector management ?
- JRSC idle vacuum??????? is this right????
- Painting intercooler?? help
- best sounding bov
- turbo or supercharge?
- help on supercharger
- SSAutoChrome Ball Bearing Turbos, any real life experience?
- Deciding on a FMIC
- best sounding bov
- Turbo experts: Compressor Maps
- driving without ic pipes
- Wastegate, fuel
- mufler for 3 inch exhaust
- low comp pistons with no tune?
- b16 bottom with other misc....
- Losing boost. TD04 14g on D16Z6
- Weird ECU code, help please...
- T-25 help! Overboosting!
- Turbonetics Turbo kit for Preludes.. anyone have one?
- is air reasearch the same as ssautochrome?
- Found a turbo kit on ebay
- Turbo tuning?
- Small chunk missing from block, is it still okay??
- Perrin MBC
- PCV and Vacuum question???? please help
- what's up with the torque curve on this dyno?
- WTF!!! Turbo oil inlet seeing too much pressure????
- turbo parts questions help plz
- anyone ever broken/fried a moates usb burn1 unit??
- CRV crank pulley on a vortech..how much more boost?
- are you supercharged?
- compression
- oil in charge pipes?
- WB o2 sensor or stock on boosted F22b1 on Crome???
- What else do I need?
- Garrett GT4082R and GT4067R - from Garrett?
- injector wiring question..... electricians please :)
- TOTAL TIMING ON A P75 ECU ???
- Dimentions for T4 flange with T3/T4 holes..
- WALBRO Fuel Pump PROBLEMS????
- Low Boost Dyno Graph
- A/f gauge with CROME
- need your opinion
- 60-1
- T3/T4E VS T3/T04E. GT28R for H22? A/R?
- turbo b20 question something wierd is happening
- Borg Warner and Porsche develop NEW Variable Vane Turbo!
- motor build (what to use)
- g16 pistons from vitara
- what size turbo?
- Ben Strader, still doing EFI "school"????
- dyno numbers of my jdm gsr b18c and greddy kit
- why do i need banjo fitting for small16g?
- CALLING ALL TUNERS!!!- Blundar, Jeff evans, Stoopid, Mase ECT.. where did you learn to tune
- Garrett GT4082R/GT4088R/GT4067R specs ?
- DYNO'd my H22 DC2 Turbo.... Results inside.
- Stock B16 tuned via Crome, results + question for Crome users..
- Largest FMIC on DC2?
- which turbo do you guys suggest???
- Oil Problem, Help
- tuning a turbo
- boosting 11:1
- Wat size intercooler for 350 WHP???
- SRP or JE pistons????
- need opinions on my b16b
- Need help finding information on turbo.
- Help...cel, searched but unclear results.
- flowmaster muffler + turbo..results?
- i need a website that sells
- Confused about the Garrett GT30R turbo/turbos!
- weird exhaust leak
- B16 stroker T4/GT40 681 HP 465 TQ
- new turbo kit
- Just thought i'd share
- b16 with GE 3 main girdle?
- Boostfed Racing/RLZ Engineering GT4088R powered LS/VTEC Dyno #s
- Quick price question
- All Rings End Gap, please, need help. No reply from the manufacture :(
- Tuner Toys? how to get ahold of them.
- ANYONE RUNNING SINGLE CAM SUPERCHARGED?
- coolant issues and coolant hose issues
- Turbo or NOT!?
- wastegate line size ???? can you go to big ????
- T25/B16 Turbo setup...what will happen?
- MR2 camp vs. Honda-Tech
- Intercooler piping.....how big????
- Most Effective Boost Applications for Hondas?
- Post your SC61 D16 dyno
- Opinions on BOV?
- 10 psi to 8 psi need to be tuned again?
- bar to psi conversion and map sensor reference points
- vafc
- Idle Issues
- mahle gold series
- where to get -8an Banjo fitting for STR/BDL fuel rail???
- .63/.60 T4 on a B16A2
- i have a problem with clevite beraing please help maybe i do something wrong
- what is min octane in turbo gsr
- b16 84mm bore and 89mm crank and gt28rs worried about turbo surging
- high power on open deck
- 8 out of 10 head bolts are stripped......what to do?
- will hondata reset?
- where can i buy a new T3 ?
- Cooling Question... Is [I]too[/I] cool, bad?
- map bypass
- Who tunes solely off of EGT and A/F ? like no dyno...
- Technically, what's wrong?
- What brand of Headgasket for boosted GSR
- .48 a/r 50 trim Garrett T3/T04E
- HybridKOOP - The rebirth... underway!
- Would like to see high hp cars ET's
- ??? can i start my turbo gsr without a downpipe???
- fuel pump ?
- turbo problem
- my ls/vtec turbo runs cold, real cold. i dont get it...
- running larger studs for the head?
- WANTING TO GO TURBO WITH MY JDM GSR SWAP
- top mount in a crx?
- would you buy used rods?
- A nstock P28 chip HELP!!
- I need a friggin huge turbo where do i get one?
- p05 ecu question
- Average cost of Neptune/Chrome/Uberdata........
- turbo install, but no boost...HELP
- h23vtec turbo yes or no?
- pics of 5th gen lude turbo setups please
- turbo and mani bolts
- missing link
- 99 si B16A2 with JRSC! 12psi
- greddy kit for gsr
- Any Tuners in South West Florida?
- SC61 to big???
- Si cable tranny vs Dx
- What long 5th gear will fit in y21
- compression test results
- do eagle rods need block notched on D series
- Spark plugs for ZC turbo "D series"
- help with ecu
- FAQ: How To Check ECU Codes w/Code List & ECU Pinouts
- is that D or B manifold ? (revhard)
- LS with a Garrett GT35/40
- Turbo whores... If you've owned more than 3 turbo's let me know what you like!
- front setup question ************
- fmic+fogs
- JRSC bogging problem, HELP PLEASE!!!!
- boost creep help me
- intake for turbo
- Recommend a good electronic boost controller
- surging idle after boosting
- Any one sell a map block off plate?
- ECU/Hondata Question:P72 and manifold swap.
- Problems with my new motor build
- Stroker kits?
- T3/T4 Hybrid 57 trim turbo from Spark Racing......anyone ever bought one from them????
- New One fab top Mount picss
- What to use to cover turbo inlet?
- B18a1 turbo
- need help with AEM 3.5 bar map sensor
- Greddy Oil hose for turbo leaking???
- Bracing tubular ex mani's
- E-Manage tuners in missouri?
- Planning a new setup with some mild power goals
- jg intake manifold (price)
- Who can Fab a GOOD downpipe in Lower NY?
- my set up what do you think
- VARIOUS OIL PICKUPS
- white smoke coming out of valve breather
- high hp stock sleeved guys, block guard or no?
- turbo on stock fuel system?
- Cometic head gaskets (What is the best plac eto puschass
- Will i get Problems with my downpipe when switching from a T3/T04 to a T3 Turbo?
- BOV PROBLEM : sounds like turbo surge???
- turbonetics super h turbo for 300whp b series?
- Ideal Exhaust size for boost, 88 crx
- sohc crower cam tuners post results!!!
- gt28r...three quick questions
- I think I've lost my mind-thinking about swapping LS crank for B16 crank in my 83mm GSR
- Just dandy...
- Oil pressure problem
- cai charge pipe?
- 450 cc and y8 fuel rail fitment issues... help!!
- Injectors. Greddy. 720cc. Need info ->
- Golgen Eagle vacumn manifold.....where to get fittings?
- deltagate spring?
- d15b vtec turbo problem
- Looking to buy a Top mount tubular turbo manifold..who makes the best one?
- Where to Get DP Flange for SC61?
- choosing turbo
- H22 and FI... what to do
- Comparison of Garrett GT4088R , GT4082R and Precision 4067R .
- Turbine not spinning at Idle..
- is this rod useable?
- need some help on buying turbokit
- Anyone using Crower 62404-2 Non-VTEC camshafts
- fresh motor = code 6, 7, and 10
- can i run type r cams
- ATS Close Ratio gearset on a boosted app?
- how much power/boost can a deltagate hold??????????
- TD04 AND T3 FLANGE are the same?
- gt2871r internal wastegate
- e-cutout or switch to 3" exhaust?
- where can i buy PARTS from greddy turbo kit?
- Do the High HP guys Go By Compressor Maps
- lets see your turbo b17/b16 setups
- Need a oil Pan for a D16z6!
- Rod bearing question for turbo setup
- what oil to use
- Dual Intake 255 Walbros
- newly built engine-comp numbers??
- What makes EF IC plumbing different from EM1??
- Might be building a drag car... B series or H for turbo...
- CEL..PLEASE HELP
- big NA cams with turbo , any advantage ??
- d16z6 boost Q.
- Larry of ENDYN... i just would like to share :)
- what to boost?
- My new setup.. Turbo b18c1 eg hatch
- Wich header is best for supercharged engines?
- down pipe
- DOHC ZC - compression for boost
- Finally, My H22 Civic Build/Benson, PeakBoost, AEM, CP= A Good time!!!
- my old eg b16t
- what piston
- boost problems with my rex
- rc fuel injector physical size issue
- boosting a DA??
- clutch for a turbo setup
- new LS turbo build..need help picking a good turbo
- looking to get a boost controller. what is a good one??
- Going turbo, need obd2 engine management
- breaking in a turbo
- vecco turbo kits?
- My Boosted CRX buildup! Lots of pics.
- SOHC winter build up
- weird coolant issue
- "Bolt Stretch Gauge" Best Investment Ever!!
- I just need some opinion to know if im right... GT2871R + B18C5 + 8psi = ?
- EXTERNAL WASTEGATE PROBLEMS
- Old Greddy turbo timer music....
- f/s sleeved LS-VTEC (fresh never cranked) getting out of the scene
- Limit Straps?
