View Full Version : Forced Induction
- Need rasister pack part number
- Here's what I'm talking about, Secrets part 2
- head gasket to lower compression.....
- Missing link 88-91 Civic/CRX, 88-93 Integra/Accord, 88-96 Prelude for sale
- ATTN: SoCal Canyon Runners
- WTB b18 or b20 block?? I'll buy the whole motor also but its gotta be cheap.
- EGT gauge needed???
- wide band o2 kit
- Newbie to the TURBO scene
- Do Turbonetics turbos have the option of watercooled centers?
- Greddy BOOST Controller for sale!
- zc/d series manifold
- Toying with the idea....
- 404 WHP 1.8T GTI anyone???
- Bi-turbo vs TT
- Transmission Probs
- B16a turbo stumbles and Hiccups at constant throtte got worse...
- Most compatible turbo timer with security systems?
- Which cams for turbo?
- Going to the highest bidder...
- Need Help with installation of S-AFC!!!! help please, installing now!!!!!
- Need a P28 ecu
- who built the first aftermarket turboed Honda?
- T3 vs T3/T4 with same compressor size
- Drag Gen 4
- How much does sleeving usually run?
- oil return line
- what kinda internals for 93 vx 1.5???
- I need to know
- shotpeening rods
- ... resistor box (not crx)... can i use it?
- ... resistor box wiring (red wire)
- Started the install today
- efi pms vs. afc hack
- any experience with trans am turbos
- ??? *** Why does B16a1 have 2 O2 Sensors? *** ???
- second time at drag strip with my turbo :)
- Valve Guides: Ferrea or Portflow?
- How important is it to have a filter connected to your turbine?
- Finally fixed oil leak!!
- fuel with boost questoin
- need help fast... where does this little do-hickey go?!
- Max rev manifold + tial wastegate
- guys with the VAFC hack? just a simple question
- my painted I/C piping and Blow off Valve
- Impartial review of the SMC
- Which way is OUTLET and INLET on my bosch inline fuel pump?
- New best times-finally went 11's
- New Oil Feed Line?
- First time driving my boosted hatch!!!!
- Engine coolant is bubbling on turbo integra...
- Ya think I've ported this enough?
- Custom Turbo for H23a?
- Anyone know coil charge time for a honda stock coil?
- +SRP pistons
- d16z6 junkyard turbo setup?
- Street driven Fuel cell people + people who have modded the stock tank.....
- Anybody want to explain this ahha
- turbo oil line question
- Anyone Know how to hookup a Motec M4 on a Saab?
- Oil return flange question
- intercooler or not?
- 3 bar map sensor problems
- OT: Any good sites for Celica Turbocharging Info?
- Checking for DETONATION while tuning?
- Built B18 non vtec... What turbo/manifold should i use?
- Can someone please HELP me read this picture!!!BTM diagram..
- Cylinder head build up
- SRR SOHC Flywheel
- Honda/Acura Oem part numbers
- Turbo and A/R trim help needed
- Im on a mission. NEED #5 MAIN CAP
- what car have t3/t4 turbos in it?
- Female BSPT adaptor?
- Upgrading fuel system on Integra, please help!
- will these pistons work?
- What number are the factory spark plugs?
- Stock plug numbers
- oil pressure sensor question.....did search
- ... anyone seen this before? (data systems concealed vtec controller )
- Intercooler for SOHC Greddy Turbo??
- what happened to the importparts drag turbo kit thread?
- will this work?
- OT: posting for a friends who got his turboed eg jacked
- quick question on a 1988 thunderbird turbo
- AVC-R Crapping on me !!!!!!
- ls turbo or all motor ls/vtec
- turbo ls or all motor hybrid
- h22 or turbo?
- OMG!! I hate my turbo!! I hate FI!! I'm so frustrated!
- F/S Brand New Turbo Manifold for B-Series Motor
- Check out my new wing............
- rockingham nc 12/13 battle of the imports
- Did a compression test, what do you think?
- customizing a downpipe? good idea??
- Greddy Turbo Kit question
- ... resistor box... where is it???
- Valve springs
- Revhard turbo kits
- turbocharged b18c1 with stock internals question
- water cooled turbo ????
- Fitting Size on Greddy Turbo Kit
- drag turbo kit for sale with tial wg
- d16 VTEC turbo, advice needed!
- need help with race fuel
- where to buy iron ductile sleeves?
- OT: He's here
- Idle speed dropping????
- B18A/B18B
- By the book......
- Passed NV somg
- Pros on the Greddy Oil Catch can
- f350diesel turbo cooler good?
- One more time! How do you calculate airflow so you can read a compressor map
- fuel pressure gauge bolt
- Does this sound like a deal
- ... vafc hack... low boost (5-7psi)... stock timing?
- FMU question
- To end the Rumor Mill, MaxRev is NOT going out of business...
- ... hondata tuners in colorado
- best place to install/tune turbo itr in ny/nj?
- cheapturbo.com GROUP BUY T3/TO4E T3/60-1 and straight 60-1'S
- RE: 1 BARGSR - No bearings
- need setting,please help
- h22 or turbo
- will i notice a hp difference from a drag to inline pro?
- LS Turbo owners, how much $$ have you spent?
- Hondata Problem
- TD04 on B16A: Which tranny to use?
- Got 2 GSR race motors for sale
- Apex'i digital AVC-R FS!
- Oversize OEM pistons and CR?
- For anybody who runs DSS axels here..
- Pic of new install
- Ok, over blue box and AFC circuit, Do I need a Inline pump with the FMU set-up?
- 1barGSR..
- AFC blue wire mod... readings????
- Throttle position sensor....adjusting
- F/S Drag 3 turbo setup with extras hondata 3b
- Greddy LS Turbo and Blue Box
- Which Intercooler? Drag or Greddy Type24
- Tranny Question B16 vs LS for my setup
- vacuum source....where exactly?
- Anybody use the Apexi AVC-D Boost controller? *thinking about getting one*
- opinions on this turbo mani
- Help with t-bolt-clamps of Drag 3 kit
- Hey I just wanted to get everyone's opinion on a new shop location. It will be on westhiemer behind
- Do you have a turbo GSR???
- Which turbo timer should I buy???
- OT:people in the gulf area...
- Blitz Turbo timer wiring question?
- Couple of questions
- newbie question
- Turbo question
- a little video of me
- Possible oil feed from B16a head?
- Really good stuff on EBAY for sale, awesome chassis,great block,amazing head
- how much Hp with -6 hoses for fuel?
- Deltagate + EBC.. hook up?
- HACK GB????????
- what size hose for clamp style oil return bung on oil pan
- check valves ???
- Starion IC guys, post pics of your piping...
- Miniature check valve: Crap?
- what kind of number SHOULD I be making?
- Re-did compression test...
- Biggest turbo that'd fit a D series...
- 5/8 = what AN size?
- Need some advice about piping/SMIC issue
- My 2000 si/ex turbo is for sale, all offers welcome!!
- dohc greddy turbo kit???
- experience with turboxs boost controller
- Starting to get frustrated (long)
- Check out this hardbody
- turbo install/tune in new engalnd area?
- Maybe u guys can help....
- 8psi on stock ITR motor???
- D Series Guys -- MaxRev D Series Kit Released --
- Hondata question
- hondata question?
- question about sleeves
- Any companies make N2o kits for Lightnings?
- T3/T4 in an ITR
- limits of a GE non o ringed block?
- Cams for Nitrous..
- Pls help: Apexi S-AFC wiring
- Welding
- Will 550cc Injectors idle like stock off of an EMS?
- Where can I get a threaded T3 inlet flange? Need one soon.
- Which is better 2.5in DP or 3in DP and 2.5 Exhaust or 3in?
- Lookie what the UPS man brought me....
- ? about AFC hack settings..
- Need Help setting up Apexi turbo Timer....
- WTT: TO4E-54 .82 AR stg 3 wheel and/or 28x7.5x3.5 IC for LAPTOP COMPUTER
- WTF, JE says to put the ring gap on the thrust side of piston?
- ... fuse for diy wideband kits
- 2mm head gasket.
- mounted egt probe on turbo car?
- mounting oil temp sender
- intake manifold for 8 injectors?
- Spark plugs
- T3 turbo ??
- question about a race turbo vs. turbo: greddy vs. drag
- 40 trim T3 on B18B suc?
- Who STOCKS OEM Honda Parts?!
- Need Help
- DSM 450cc injectors on a GSR
- is 9psi pushing it for a tuned stock jdmb18c1?
- ... diy wideband datalogging with a palm
- Anybody know a place where i can get a 9 lb Tial 35mm wastegate spring?
- JRSC for sale-CHEAP
- Who makes a 3inch thottlebody?
- vafc install?
- zc zdyne tune
- gsr turbo or b20/vtec turbo?
- who's runnin stock injectors, fmu, inline, and AFC?
- questions on going boost
- AFC Settings?
- Montreal's civic :P
- Leaning out w/ AFC hack!
- Running 2 resonators on an exhaust system?????
- 2.5" vs 2.75" vs 3.0" Exhaust/DP sizing...
- Just looking into the future.. but need help with this..
- Manifold flange
- OT: but whats the weight of a honda crank
- highest HP from turbo b16 with stock sleeves?
- B16a or b20b for turbo
- Parts For Sale
- Best Head Gasket? Need input!!!!
- AEM EMS for sale...sorry mods
- N20+SC
- turning to the dark side!
- now what supercharger?
- Adjustment for Blitz dual drive BOV?
- Wierd vaccum after BOV install?
- hondata?
- need serious help.. DRAGIII vs. REVHARD2
- Can a low CR headgasket be re-used ?
- Race or Street Turbo..LS
- Diagram or MBC
- Some pics of Bart
- Need quick help/advice about HKS type-0 Turbo timer...
- boost gauges in PSI
- Check this out, QUAD turbo...
- I think I found the reason for my low compression #'s....
- Picking out a transmission ( the ye ole LS vs GSR Tranny debate )
- Who has a greddy turbo timer?
- CHEAPTURBO.COM groupbuy to start soon.
- How to tell if my turbo has blown seals?
- double checking this piece for the wastegate
