View Full Version : Forced Induction
- Water/Methanol Injection
- EG B16A2 Turbo build help
- How to turbo a D15B
- fitting on turbonetics turbo
- Max power on oem D16 pistons + ceramic coating
- GT3071R 0.63A/R
- Curious about spool time
- Need some advice for building a d15b7 for boost*
- Car doesnt maintain idle on cold start (d16z6 turbo)
- b series pistons
- Turbo d16 Overboost problems
- Please Help B16 Turbo Motor Noise
- Boosted LS Reliability.
- nos on itb's?
- Airesearch turbo
- Wiseco k20 piston in sleeved H22
- Do i need a retune after changing boost pressure?
- 98 Civic LX D16Y7 Turbo Help
- Air research m10 turbo how to bolt?
- Looking to Upgrade my civic hatch
- password jdm top end gasket kit
- TURBO recommendation??
- Turbo sizing clarification
- Question about upgrading turbo components?
- where can you buy a black oil feed line?!
- 3" or 4" uppipe/downpipe
- Turbo B16 civic
- supercharging b series vtec
- ITR cams, cam gears? Gsr head question
- Where to buy used Holset Housings
- Few Questions Regarding Boosting A EJ Civic
- New here, need direction
- do i need a block girdle??
- Exhaust Wrap question
- Evans waterless coolant
- Turbo Supercharger or All Motor
- Integra turbo stock engine
- issues with f22a1 I need to resolve before turbo stuff
- B16 turbo stock sleeves
- Turbo F22 going lean after hard pulls. Other symptoms as well..
- What brand
- Do I need an adjustable FPR?
- turbo crx, smoke issue??
- B16 turbo burnt valves!
- Wiseco wrist pin
- Super Charger on a civic?
- obd1 injector clips to obd2 injectors?
- help....all BOV's sound the same.
- Help-Built LS/VTEC Turbo
- Boostlsveg's 92 cx street/strip build thread
- B16 main girdle necessary??
- 93 octane
- My Turbo List , give me ur advices
- ask compresion
- Downpipe Reduce
- b18c1 turbo
- Competiton Clutch stage 4/5 Reviews?
- To those who have A2W intercoolers with heat exhangers
- help?? sohc turbo p08
- BFG G Force TA VERSION 2. Anyone try them yet?
- Turbo D16Z6 del Sol Build
- Highest HP Turbo Non-Vtec Setup?
- D15b7 Boosted Stock internals
- combustion chamber pics was this motor burning coolant?
- B18C Turbo Questions
- Grams 1150cc injectors... Anyone put them to work?!
- h22 coil pack
- Oil question
- MAP no CEL issue
- turbo half radiator fan speed
- Sleeved B16, 81mm Pistons Low comp, thoughts?
- My first build....
- turbo downpipe question
- Forged Crank and future build
- 700+whp E85 fueling question
- Built for boost: Verifification/Comments on build.
- Ls Turbo Help
- jdm b18cr
- my d16z6 build plan
- Quick question
- Need help from experts, oil fees line queation
- Maybe/Kinda/sorta starting turbo build.
- I need help building a turbo system in my 90 Civic EF help????
- Timing belt jumping off of car *help*
- Speedmaster Connecting Rods
- 85 octane regular unleaded + 100 Shot
- Do i need a FPR
- Godspeed GT3582 Success :)
- What turbo should i go with?
- Nice b.o.v for high boost on a dsm 1g flange
- Better spark/ignition options
- Help me make some decisions
- Working hard or hardly working??? (show me those projects nearing completion)
- How's my soon-to-be turbo setup?
- Built d16 with a bb 5858 made only 280whp @ 22psi..some woes...
- IAT sensor options
- B18B1 (GSR) Crank, Rods & Piston - Direct Swap Into B16B ?
- H22 Turbo to sleeve or not to sleeve
- TT, DE, CIRCUIT Track temps
- is there any truth to this? 68mpg avg/228hp/12psi
- JRSC for K series
- 2015 CTR Petition for USA
- Greddy 18G TD05H Gaskets
- Chicken build
- NEXT 1CAMBEAST
- daily use boosted for d-series
- flat valves
- Let's try again
- b16 tb intercooler coupler
- FIC 900 Woes...
- Favorite turbo accessory
- Boosting mY 2007 civic ex 4dr??
- New noob... Preparing for h22 turbo build
- Cali LHT+JRSC Build
- Update on my sweet pea
- PTE 5858SP Exhaust housing
- Rebuild or new motor for boost - B18B
- Questions regarding Greddy turbo
- What my compression with these pistons? Turbo s2000
- Intercooler size
- h22 with mahle 9:1, what should compression be?
- chokes when press the gas
- y7 turbo.swap to z6 head or keep y7
- Maybe a dumb question... Nitrous question
- Too TwinDisc Or Not
- B-Series Stage 2 Oil Pump
- Are these pistons appropriate for my setup?
- turbo identification
- Please Help turbo Starvation.
- Calling all Holset HX52 users
- opinions on throttle body
- stock b18c1 turbo
- nitrous b20vtec sleeves or no sleeves? opinions on my setup please
- can a F23A4 motor hold up to boost
- Camshaft upgrade and turbo selection
- Cylinder one plug black
- questions about turbo on b23 motor ulev
- 250 Hp d16y8 turbo.
- High comp pistons
- 90 Waggon turbo what injectors do I use
- In Need Of some Input From the Turbo Experts
- hx35 turbo
- B18C breaking up on all motor after using nitrous!?
- B18CR TURBO
- Waste gate surging under boost?
- Boosting B18B1??
- 400whp B16A Part List
- Anyone used a Turbonetics 5454 billet?
- boost by gear
- Need Help On My Build???
- Anyone looking for new cp pistons
- srt-4 turbo on my gsr
- D15B7 Turbo
- Jackson Racing Supercharger Help
- weird boost spike issue
- Hone and Re-Ring Sleeved Block?
- Greddy turbo OBD1 question.....
- Intercooler core
- Laskey Racing Benson Sleeved Block?
- Discontinued skunk2 turbo cams
- Help needed with b16 full build
- unopened gsr 411whp/262wtq
- Where to buy NordLock washers
- Dyno Test: Rocket E85 vs. 93 octane. OEM H22 Turbo
- Large turbo b16 what power will I make
- Supercharging my 2013 GE8 Fit Sport 5AT
- borg fittings
- searching for turbo kit
- Want to boost the B16. OPINIONS?
- ls vtec turbo won't rev choking and sputter
- My Integra LS with Greddy 18g on the Dyno *Video*
- k20 turbo coolant lines setup
- Wierd boost problem, any ideas???
- turbo build b16a
- Attarixep EP3 build for big boost
- how to upgrade my turbine housing from a .48 to a .63
- B16 boost safe power /psi
- b18b turbo cams
- thoughts from experienced only - turbo setup
- cracked B16A2 / advice for a better engine
- B16A with GT35
- D16Y8 Build - New Rods/Pistons - Crankshaft Balance?
- Clutch suggestions needed
- real full race manifold?
- Skunk2 throttle question
- Precision 6765 vband outlet question.
- both coolant hoses blew off on the dyno
- Ctr cams or skunk 2 pro series stage1 cams
- B20B catch can to atmosphere hose routing HELP
- D16Y8 Turbo Build Ethanol - Pistons/CR Options
- sleeving a block
- BOV Sizing
- Nitrous timing retardation required?
- E85 vs pump gas quick question
- is this a good build
- Air Filter Flow Theory Idea
- Half radiator vs full size radiator
- good turbo kit for first car??
- Oil cooler line size
- Turbo build 97 teg circuit racing
- Borg Warner EFR Series - worth the hype? Lets have a discussion
- lst? ls-t? boooost?;
- switching from 9.1 to 10.1 compression
- pro 3s and nos
- Future turbo but need clutch now. Advice?
- Help with spark plug reading. Ls/vtec turbo
- K series coil pack boost limitations on b series
- Ac/Ps compatible turbo kit?
- tuning opinion...? supercharger
- Great white paper on Mixed Flow Turbine wheels
- Can I add an audio capacitor to my cooling fans? Spal extreme fans stall my can when
- D2B turbo build
- Best camshafts for stock b16 turbo, e85
- Throttle leak Fixable?
- BUYERS BEWARE OF ILLICIT FORGED WHEELS!!!
- TWO WAYS TO BOOST LOW (8psi or less)??
- Honda Del Sol B16A3 with a t3 t4 turbo
- D16Y8 Head D15B7 Block?
- NY tuning shops ANYONE?
- civic 96 pump assy. an fitting.
- name this turbo
- Project almost complete but gota problem..
- B20 Vtec Turbo
- 200 hp boosted ls reliability?
- Integra turbo cooling help!
- B20V high compression turbo? ya? no?
- skunk2 ultra VS Edelbrock Performer X
- GSR Edelbrock Performer X on a B16 head
- Opinions On Turbo Choice?
- built ls compression numbers okay?
- low ohm injectors and no resistor box?
- Top mount or Ramhorn
- Turbo 3.5L J-series V6 High CR Build
- Adding Turbo Kit To 94 Honda Civic EX Vtec(D-Series)
- Things NO ONE told me about installing Turbos
- Borg Warner s366
- five-0 880cc bosch injectors.
- b18a1 build help
- Favorite blow off valve
- Anyone going to PRI this week?
- To rebuild or NOT to rebuild?
- *****Greddy 18G No downpipe safe?*****
- Another turbo advise question
- f22a4 turbo help basemap
- changing turbos ditching cheapo ebay turbo for a garett t3
- boosted f22b2 question
- precision 6262 compressor wheel bend??
- Turbo seals shot?
- Problem with a Drag 3 Turbo Kit on my 00 Civic Si
- Wideband s300 problem.. help please!
