GSC T1 VTEC RPM
I never narc'd on nobody!
Re: GSC T1 VTEC RPM
This. If you really want to know where to set your cross, though, set it to 1000 RPM (basically always on), do a pull on the dyno, then set it to 10000 (basically always off) and do a pull. Where the HP lines cross between the two graphs, that's where you want to set your VTEC engagement.
Re: GSC T1 VTEC RPM
Re: GSC T1 VTEC RPM
In a pinch, the "Virtual Dyno" software can help with things like what you're looking to do. Don't put any faith in the numbers it spits out, but it does give you a curve to work with.
Re: GSC T1 VTEC RPM
For mine I just turned off vtec did a pass and made it come on where the torque started leveling off. My initial guess of 4500 was spot on.
Re: GSC T1 VTEC RPM
i will give virtual dyno a test :D thanks, hopefully it can open logs from VEMS with out to much hassle :D
gutted
30
01-27-2004 08:17 AM
