View Full Version : Forced Induction
- another noob ?
- help plz im noob to FI
- ELECTRICAL problem.... and tach tooo HELP>> PLEASE
- Stock or Crower turbo cams on a Turbo D16y8. Anyone got crower or zex cams?
- looking for rediculous e30 bmw video
- What guages do you daily driven built motor guys use?
- going to get boosted need your opinion on this kit
- Oil pressure help
- Removed Evap Cannister, what to do with fuel vapor line?
- b18c turbo block
- WASTEGATE HELP!
- Long road trip with junkyard turbokits...
- HELP: Compressor map for SC61???
- What Turbo is this? **Help**
- Rod selection Help!!!!!!!!!!!!!!!!
- 81 mm VS 81.5 mm pistons.
- Dumptube hits radiator, custom radiator solution?
- steam/smoke coming out of valve cover breather?
- .::need to get new plug wires??::.
- traction bars with drag kit
- surge limit
- can my car handle boost right now?
- h22 turbo simple question
- Hard work finally pays off! reliable street tune thanks to Gruvytune...
- Got a question reguarding what turbo for my application...
- safe oil pressure?
- vacuum/boost gauge prob
- What and how should I check a used turbo to make sure it's in good shape?
- Fuel Pressure question.
- Boost problem
- durrr, which 5 bolt flange?
- Mr. Freeze Methanol/Washer Fluid Injection
- turbo installed, car wont start
- No Boost?
- Bov Doesnt make sound
- Video!! My Sohc non Vtec runs low 12's
- Forgot...does a O-ring go here...help asap
- What are peoples experiences with Clutch Master
- size intercooler piping
- Does anyone have extra arp headstuds washers laying around?
- 15psi on a stock dohc zc
- waste gate issue
- peekboost turbo kit
- Identifying a bad ecu.... fuel related
- 245/45/16 on a 16x7.5" wheels? I Need Traction For The Street
- 95 coupe b16
- Rebuilding Greddy 18g Turbo... questions, comments.. help
- Running lean
- crower 402-t cams need to be advanced or retarded or stock setting??
- Gauges - where did you get yours from?
- Anyone running the subaru Injectors (880)?
- obd0 case the same as obd2
- broke my first set of ringlands
- 2002 Civic Si Turbo Help!
- T4 60-1 too much for my GSR?
- Motor Break In Write Up
- turbo smoke problems lil blue
- Wastegate Open in Vaccum
- ZEX Nitrous kit user's please help me out.
- Holy Christ I'm Tired of the Supercharger/Turbo Debate....Settled inside!!!! Turbo owns!!!
- K04 oil lines?
- drag gen 3. stock b16 intake to a victor x. what diffeences will i run into?
- Need urgent help, AEM FPR parts
- Burning Oil
- best way to install
- Best pistons and rods for my LS-T
- turbo b16 exhaust question
- Will I be able to keep my A/C B18B turbo?
- New Motor/ New Turbocharger Break In
- How long will my turbo motor run?
- prob with h22 on boost!
- Turbo acting weird
- 3" Vibrant Muffler Pics....
- Greddy Turbo Timer Question
- Need help on turbo housing size
- e-cutout tunning question....
- rom editor for the old hondata
- Idle questions with Hondata...
- QUICK HELP NEEDED WITH EMANAGE
- .::MSD 6AL install??::.
- Slicks question (please don't move)
- H22 turbo bucking problem
- Beating an Srt-4
- How many of you have broken-in your newly built engine on the DYNO???
- **Burnout Video**JRSC Ls/Vtec EF hatch
- Strange Mis-fire, need help please
- slim fan for smic?
- vitara piston question and plasti-guage?
- D series turbo manifold
- quick question... what rpm will this turbo spool
- GT35R Qestion....
- Head Gasket
- 94 integra turbo track times
- What are the benefits from these parts?
- Moroso oil pan
- BOOST LEVEL OR POWER??
- installed 550's, now running way to lean??.....
- 600+++ HP STREET CARS....HOW MANY ARE THERE......
- Need to get JDM H22A replacement pistons, piston rings, gaskets, and rod berrings
- Close to hitting 11's..My track times with the Vitara setup
- I made a Boost spike/creep controller from a rad cap...
- Turbo stopped boosting at track
- normal oil pressure?
- 420whp posible on pump gas?
- 1997 Honda Civic DX with Greddy Turbo kit, going hondata/ neptune, what ecu do i need?
- LOOK ...OPINIONS NEEDED
- Few Questions before i buy parts
- supercharged gsr?
- poisonts
- 2.0l w GT30R Dyno Results
- b16 and nitrous??
- What turbo is this?
- Block Assembly - *blurps* when rotating by hand..... BAD???
- installed ZEX kit today with no instructions....have some questions.
- Best OBD1 Chassis to Supercharge? B16/B18c
- Might be getting a turbo, need some help
- to turbo or not to turbo?
- space between turbo and manifold?
- S/C ITR headers: endyn vs. toda
- Synapse missing link
- Turbo DC2 EXHAUST?
- 9.7:1 cr turbo, dail driven? got lazy with the search!
- nitrous question
- Stainless braded line has leak, How do I fix this?
- Is a 11.3 compression ratio too high for turbo?
- anyone running t4/67 on gsr motor?
- gm 3 bar map in stock location
- Revhard IC piping with oem fog lights on an EM1 00 SI
- Hesitation from 10inHG to 0
- Found out how to up boost without a controller...If you have this prob. look!!
- Why not to use a cracked turbo manifold?
- oil return for apexi kit..
- my 380 whp h22 wants more power...how about a T-61
- WTF?? Me vs. 350z story.....(moved from kill stories)
- Here are some pics of my new hybrid d series setup. z6 head/ y8 block
- Devcon Liquid Aluminum and Block posting
- Small Turbosetup without intercooler - is this possible?
- High Horse Power On Pump Gas?
- Master Power turbo gt45 seals!?
- Turbo code / names
- question about emissions(obd II) and chipped ecu
- boosted ppl with c/f hood
- Will oem fogs fit with this precision IC?
- supertech pistons vs forged pistons
- where can i get a oil sandwich adapter?
- just installed greddy turbo last night
- FMU set up with injectors?
- turbo d-series questionaire.
- spoolin performance turbo manifold?
- $400 OBX mani, IS THIS ANYTHING LIKE THE cheaper one?
- intercooler in a D16
- turbo tuning question
- Exedy Hyper Carbon Clutch
- stock boosted d16z6, want a headgasket to lower CR
- engine for a newb
- o2 wideband?
- - Just need a few more parts -
- how would this do on a poor mans type r?
- vid of 500whp accord
- oil leck in the spark plug tube
- Tial 7.25+3.63 spring = 11psi est ?
- sc44 vs. sc61
- open downpipe on a obd2
- Turbo runs great on stock fuel system?
- catch can ques...easy answer, just not for me.
- hks ssqv making fluttering noise
- spark plug question
- Tial BOV or GReddy type RS ?
- turbo sohc 1/4 time
- jrsc ecu with hondata?
- Piston ring question (filing)
- How do you take off the alternator bolt?
- Car acting funny.. Turbo????
- Problems with spooling and full boost
- PROBLEM WITH BOOST!!!!! HELP
- Just finished greddy kit install on GSR. Running RICH.
- 852rwhp s2000 in this months super street
- whats best rods and pistons for 450-550 hp lsvtec boost
- 11secs nitrous 1/4 mile????
- Ayone have Z10 oil pan for turbo setup?
- using exhuast for catch can vacuum.......what tubing???
- Shipping a block.
- help on motor build
- Ebay manifold.....
- getting boost creep running open downpipe (VW)
- Advantages/disadvantages to putting a T3 exhaust housing on a GT2871R?
- blowing oilpan gasket
- OIL FEED
- Another ssautocrap thread
- Fluctuating boost?????
- Nitrous on 9:1?
- what are the specs on this turbo?
- High Comp Ls/Vtec... Turbo possible???
- Oil cooler?
- SSAUTOCHROME TURBO KITS???
- Got my Precision 880"s, what do these numbers mean?
- honestly , if i spend 6000 on a motor and turbo how long will it last? 50kmiles? 300hp
- Doing A Boosted D16 for my EF....
- turbo parts
- JR cahrger in DA integra??
- getting hot, but not overheating?
- Equal length manifold that is compatible with fullsized radiator?
- Whats wrong with my BOV? It wont stay shut
- If a have V-fac should I still chip Ecu
- T4T67 air filter ?
- need some help guys....
- what type of FMU is this?
- turbo oil feed line, what adapter is needed
- mase does it again>528hp@350 torque,stock sleeves!!
- boosting then no power then shut off ????
- Z10 block girdle. need the facts.
- Did a bunch of tests, and still no boost.
- JRSC install with Thermoblock
- how do you set your boost on the turbo?
- help car run like shit sound like lawnmower
- Need some help, little boost and fuel cut off at 6500 (2000 si drag kit)
- eagle rods torque
- Hks ssqv not sounding well
- trap speed with JRSC
- lets see some purge pics
- are hks ssqv adjustable?
- need some relp remounting my N2O
- emanage with built b16a turbo, car won't start, will with just ecu
- 600hp canadian civic
- installing guages
- Testing: Function7 Oil inlet/return flanges
- wastegate gasket
- wow
- Manifold cracked, need to find a new one for HPDE/Time Trials! Helpx0r!
- srp 9:1 gsr pistons in a ls.......... i searched
- Misfire CEL 74 Help!
- Motorolla 2.5 bar map sensor question.
- Running Closed Wastegate
- Place to buy U bends in socal?
- H22 SC61 dyno H22 @ 12psi
- Quick question about venting PCV into atmosphere...
- Greddy 18g flapper que..........
- Greddy Type RS BOV/POV
- greddy 18g ......adjusting the rod ......
- b16a tranny or b18c tranny for Boost?
- Downpipe help!
- turbo problems
- kms blockguard! any opinions?
- OBDI block + OBDII head + uberdata = me ok?
- EGT probe extension wire?????
- Anyone having problems with the Profec-S?
- Help w/ T25 Please. Pics inside.
- Turbo Question??
- getting air to the turbo ef pics lets see them.
