View Full Version : Forced Induction
- LS Turbo
- who has built there own turbo manifold???
- ebay intercooler, Good or Bad?
- Right forum? Front mount and a B swapped EF
- i need 2 get a gasket for my turbo manifold the main one the one that go's to the head
- does anyone know where i could get some oem main and rod bearings for cheap
- Manley H beam Pics with Eagle
- d16z6-condition for turbo?
- T3 turbo suggestions
- what turbo manifold can i use
- Tach is going crazy at higher rpm's and car starts to miss...
- Ring Gap Questions
- WRX turbo? what size flange?
- Need help deciding:Nitrous set up or homemade turbo set up??
- dsm 20g on ls/vtec or b18??
- fuel psi drops to 0psi as soon as i shut off the car
- Golden Eagle Block Guard
- Help w/ manifold fitment on Integra GSR
- residue in my turbo possible motor is burning oil???
- Experience with 20g turbo??
- Searched: Jackson Racing Map Controller Help Needed
- looking to purchase an oil cooler?
- turboing a d16 non vtec??
- turbo b18b with a/c possible?
- what head to use? b16 gsr type r
- Turbo Help
- Just wondering, does a 1000hp Honda 4 cylinder exist on this planet?
- Is twin turbo set up possible for a 1999 civic B16a2?
- b18b pcv system?! **Fast help so i can cancel order asap if needed** THX!
- co2/o2 intercooler spray (SEARCHED)
- HELP HELP....Searched Already Please read .....Nippon Racing , Vitara pistons
- NITROUS
- oem spec bearings not working w/ eagle rods
- 406whp/281wht Stock Sleeve Turbo D16z6 Video/Dyno Sheet
- anyone have problems with their eagle crank like this
- what clutch
- d-series-
- New CRX turbo build
- COOLANT for Turbo - Single Looped Line? One Source OK?
- D16 Turbo for everyday driver ?
- over heating at WOT???
- Help!!! Need help re: turbo
- What is the diffrence between the H cover and the S cover on a gt40, pics would be great
- GREDDY E01 - control valve
- for you guys that know turbos...please read its a lil long
- anyone running a full race intake manifold on thier b16?
- dseries turbo guys
- LS question
- E85 - would methanol/H2O injection be useable?
- van line sizes
- boosting problem...
- vavle train
- ZEX "brain" question!!!!!!!!! need to know
- Looking for unique BOV (cat)
- Whats a must for a B20B turbo setup?
- Turbo help....
- Approx what should total timing on my H22 be at 15 psi?
- Electronic boost controller comparison question
- t25 turbo
- all injectors firing at once
- D16Y7 motor + D15b2 Tranny + turbo
- cp piston chip near intake valve relief
- whats the advantage of using an external vs internal wastegate
- hit a dip and a lot of white smoke came out of my exhaust
- i hate to ask this!!!!
- Wanting input... trying to intercool a JRSC on a K20a3
- will this crankcase breather set up work?(pic inside)
- thermostat?
- wich best Turbo Manifold for b20vtec gt35r 600hp?
- built for boost help?
- New to FI
- DC2 Radiator
- Hondata or Crome?
- Oil pressure w/ rod knock
- anyone ever used probe forged pistons??
- Thoughts on results from an sc6152e on an lsvtec
- buddy club spec V cams and turbo
- F22a1 Boosted
- d16z6 at 15 psi!!! stock head and block!!! wtf
- Stock b18c5 how much boost?
- intercooler flow ?
- which ecu to tune gsr jrsc p06 with chrome or p72 with s100
- Comp. Clutch Stage 5?
- Oil too cold?
- Anyone know where to find the plate to place aftermarket map sensor in stock location...
- Anyone use the HONDA Evolution Motor Sports 6puck sprung clutch yet
- My AIR-Endyne Intake Manifold Review
- Custom B16 ef turbo setups. Lookin for ideas.
- earl inline fuel filter for FI
- BOV gasket ?
- power FC and P/H injectors problem
- what would cause this problem with my motor???
- Best clutch for 500-600whp
- building a ls turbo question
- idle problem with chipped ecu??
- Do I need to get a MSD 6AL box
- new chipped ecu problem
- Changed mind on what type of t3/to4e turbo.
- B16 100 shot w/ Hondata?
- I hate FedEX!!!!!!!
- 3" exhaust
- Turbo Sizing for the average noob!
- How to mount intercooler on EK?
- vtec controler & turbo
- B16a Set-up. Realistic goal?
- Sparks Racing Turbo Manifold?
- Question about Nitrous Systems! Help would be greatly appreciated!
- 1480bhp@ 20 psi and still going
- got ls v dyno low numbers
- GT4094r
- oilpump modifications ??
- CARB STIKERS FOR TURBO KIT
- Average tune..
- t25 vs t3/t4
- fuel pressure regulator for a FI
- resistor question
- Transmission question LS/GSR hybrid setup for high HP setup
- OT: best/cheapest place to buy obx lsd
- look!!!
- turbo question
- 1/4" to 1/8" adapter for oil feed, what material?
- dmh cutout-what length wire harness is needed?
- Worth getting oversized valves
- Found a little something today, let me know if I should worry or not.
- what's the difference between aluminum, mild steel, etc.
- When does the fuel tank shrinks
- Something to think about....
- ????wtf with the hood spacers???
- builder called it quits. shop shutdown.
- Best Turbo Kit for My B16 Ef Civic?
- boosted b16b
- b16a2 turbo setup need help
- peakboost vs. fullrace
- The Laser came with saturated injectors?
- wastegate spring question
- need Oil lines for an IHI RB5
- Anyone USING the synchronic FPR?
- ZDYNE GOLD SECU OR NO ZDYNE GOLD SECU that is the question?!?!?! or hondata
- oppinions on what direction i should choose
- revhard turbo kits????
- Air conditioning in my 91 LS vtec turbo teg
- best route for me?
- moroso oil return fitting
- Mahle Pistons(where to buy)
- Anti Lag System AKA Misfiring System.
- how much hp can i get from topmount manifold?
- turbo valve train h22
- Tial 40mm w/g w/ inline pro manifold..ELBOW?
- I'm Proud to present my new manifold the "B-series Ultimate"...(not 56K freindly)
- ls crank into GSR
- i have a stock d16z6 with d16y7 tranny and want to spray.
- New FP "GT3582HTA" ?
- Help identify the specs on this turbo
- tell me what u guys think sorry for bad picture.. cell phone pic
- Anyone running a Greddy Profec B spec II boost cont??
- How hard to reach 12's?
- Limp Mode! Cluless...searched...still lost
- Where to get catchcan with -AN fittings on it?
- --------- Greddy Bolt-On Kit, d15b SOHC VTEC ---------
- problems trying to find ignition harness to install turbo timer. help!!!!
- Longetivity of the GT30R BB turbo?
- turbosmart ultragate 38mm wastegate
- d15b8 needs a turbo ... help (topic needs disscussion)
- 600+ WHP Build: From N/A To the Darkside..
- JRSC - What sized Fuel Pump?
- whats can i put on first b4 turbo
- profec B
- Daily Driver Turbo-d D series?
- has anyone used a gt3076R .82ar hotside on a d-series
- Honda ATV Turbo...can it be submerged?
- not going into gear
- Nos set up help
- turbo gurus i need help gsr turbo
- Can I get to 300 whp
- Golden eagle sleeeves handle hp even if bored to 84mm?
- What should be replaced when adding turbo?
- anyone that can tune or knows about zdyne please help.
- Edelbrock "Performer X" Turbo Kit
- Custom Turbo Setups
- shaving head and compression increase?
- Wiseco Piston Choices
- Custom Methanol/Intercooler project for my JRSC R (pics)
- which tranny should i get for my budget build....? B16
- how many go into 5th?(1/4 mile)
- New build questions and suggestions
- sohc mini me
- Password Help!
- what companies make a No. 2 rods? IE eagle is No. 3
- T3/T04E 60 trim .63 a/r vs. 60 trim .82 a/r on a B16?
- who has had boost creep problems with their full race top mount.
- Ways to make my b16 with less power be faster then my friend(s) LS- Vtec's.
- Wastegate Hitting turbo- Any suggestions?
- supertech dvs,titanium retainers,valves & bronze valve guide for high boost application?
- stock ignition
- SRP pistons for D16z6 on boost...
- Any amount of boost?
- help please!!
- Garrett 50 trim, .42/.48 A/R. ---> Good for 300 hp and 7500 rpm?
- tuning question
- will this fit
- i want to get a new turbo and i was wondering which is better precision or garret
- Are VITARA PISTON good for boosting a single cam...
- garret t3/t4 50 trim
- Is it normal to see small droplets of oil from turbo compressor outlet while reving
- What Turbo Setup should I go with? And should I mod more?
- Precision Turbo?
- T3 Setup on stock H22A
- The Weld EL cracked, NOT the Weld.
- Is it alright to add vents on the back of the valvecover?
- Ls Vtec hp on race gas
- turbo oil leak?
- Built Ls/Vtec with Tube Style Mani & 60 Trim Questions.
- Bulls Eye Power S Series Turbo Givewaway! - FREE TURBO
- oil catch tank (filter/no filter)
- wisch turbo for my setup
- Has Block been line honed/bored?
- Camp1320.com TOMahawk Turbos.??
- late night sex..
- Mfactory Oil Cooler
- turbo controller or no turbo controller???
- Waste(gate)d Egos...
- i NEED gsr cams!!!!
- s300 and plx...datalogging problem
- dart block turbo
- top mount question
- turbo question
- post pics of your CCA intercooler in del sol or EG....
- turbo b16 , sputters at 6-7k rpms and looses power???
- Precision turbo compressor maps? My ebay sc60 is a sc44
- NEED ADVICE ON EMISSIONS ---WILL IT PASS? JRSC in NC
- when adding vent to VC will oil spew out ?
- question bout my turbo
- Can anyone post Technical Pics of JRSC
- b20/b16 gt35r (victorx vs Full-race manifold) 600hp?
- Nitrous Backfire?
- ls vtec supercharger need help
- Portflow inners with stock b16 valve springs w/gsr cams to 9000rpm?
- 3" downpipe to a 2.25" stock exhaust pipe? disadvantages?
- Bullseye Power Chris Rado edition S200 makes 588.3hp@22 psi on bone stock tC engine
- Tune a t25 boosted d16a6
- Twin Scroll Turbo? What are they? And a couple general turbo questions
- what size oil lines
- how long do walbro's last??
- how do u clean the peakboost turbo manifold
- neptune boost cut?
- Hall effect setup, ideas, help
- >>>>>Will 8psi be fine on a bone stock d15b7<<<<<
- is this a real garrett 60-1? please show me yours to verify!
- Supercharging a LS
