View Full Version : Forced Induction
- Masterpower Turbos.
- precision turbo goes bad. precision says oil contamination?
- Injector clip only grounding once car is hot? wtf?
- Air to water or Air to air? what you think?
- OBD0 b16 turbo fuel problem
- Turbo Manifold Advice
- what kind of head gasket youre are running for hi hp set up
- Spark Plug (Pic)
- nitrous express kit 20200 150 shot jets.
- Searched...hondata & wideband
- Braided line coolant systems
- SEARCHED! Need these questions answered!
- ••••>best way to gain 30-40whp from my supercharged setup - COME SUPERCHARGER PEOPLE
- What do you run in your setup?
- need a datasheet for honda map snes.
- Universal turbo....
- BOV air leak?
- AEM Fuel rail question
- fuel cut vs ignition cut for rev limit
- ls vtec turbo, vtec not engaging, oil line question
- Which tranny is better LS,GSR,ITR,or b16 (ls-vtec)
- S300 help
- RC310cc injector question
- Any Log manifold/t3/t4 turbo guys in the 400+HP range??
- gearbox selection
- 98-01 US dc2 front end + fact fogs + FMIC
- Injectors.
- is any one put down over 450 whp on a stock BLOCK GSR?
- Any one daily drive a dart block? (On boost)
- need turbo suggestions
- mis shifted now running pig rich??
- HELP ! car idles fine at cold but when it warms up , it keeps shutting off
- How long can you boost on the freeway?
- help with fuel pressure regulator
- Overheating problems
- Intercooler Question
- "Super 60" for stock LS....300whp?
- dual wastegate spring size question
- 14b Not Building Full Boost
- O-Ringing the Block: Copper vs Stainless Steel
- 650cc injectors good for what bhp max??
- Aem fuel rail Different part number B18 and B16 why?
- 09 Fit (GE) supercharger kits?
- Rough vtec crossover
- Wastegate problem?
- low fuel pressure, bouncing fuel pressure
- D Series Boosting; Why so common?
- searched but still not sure on MBC
- My new manifold uses a Tial 46mm flange but I have a 38mm
- How much oil?
- type r cam install question for b16a turbo engine .
- JRSC header question
- new build, before starting
- HELP!!! RESISTOR BOX HELL!!!
- BW S259 or S362 for my setup
- Q's on building a head for boost
- Where to find a m10 x 1.25 banjo bolt for oil feed, locally?
- nos set up?
- Resistor box required? 1000cc low resistance injectors
- 60-1 Power
- Buy a Skunk2 Manifold or not for setup???
- vtec noise when running low compression
- Precision turbo oil feed question?
- thoughts on this engine setup
- Help Misfire...
- act clutch AR1-HDR4 4 puck on k20 turbo
- Eagle H Beam Rods vs. stock pistons
- bad sputtering/cutout when idle and driving
- what should i gap my plugs to?
- Is hot weather bad for turbo.
- Turbo question...with pics
- Breaking up in boost
- blowing injector seals
- built motors - out of round - taper
- Where can i get 2 CP pistons or does anyone want to split?
- what power to expect ?
- whats your gas mileage on E85?
- will ceramic coating increase my spool?
- Turbo for a 350whp d16?
- What Happens If...???
- H22A Turbo, What Clutch?
- oil feed size on turbo itself
- turbosmart mbc - stuck
- wrapping the manifold and downpipe a good idea???????
- s2000 240hp with turbo need help
- Fuel system with Turbo build stock FPR + cam gears
- should I be able to spin crank by hand?
- Missing Pistons wtf!?
- just got some of the parts for my tubo kit in.. have a question
- Okay to use 2in IC piping?
- vacuum lines
- Im not soo new, but new to boost
- B16a vs B18c Dilemma
- HX manifold the same as HF?
- boost control?
- help!!!! d16y8 turbo
- b16zvsh22vsb18bvsb18cvsLSvtec how do they rank for boost build?
- Sohc turbo build almost done but....
- optimal motor for FI? as far a bseries builds and tranny combination?
- NEED HELP PROBLEMS!!!!!!!!!!!
- Optimal Air/Fuel ratio?
- full boost only in 4th and 5th
- boosted b18b build
- Identify Turbonetics. HELP!?
- Greddy Type RS BOV screw threading?
- What Vac Lines For B18B-T
- Can 450hp to 500hp run 10's?
- Gsr turbo low boost problem.
- Clutch options for 600+whp street car
- EGT gauge stopped working
- Is A T62-1 too much for a stock gsr motor?
- What sleeves are these?
- Anyone running a .96 A/R T4 on a street car?
- Clutch suggestion's for 300whp JRSC B series daily driver.
- 2" turbo back large enough for 200hp?
- Adjust the angle of the turbo inlets?! NoOb..
- What head to use.
- just bought a boosted eg hatch need some tech help
- help!! passing inspection with turbo-built cars??
- garrett turbo Q on exhaust housing.
- Turbo kit
- D series and Build questions
- torn! input!??
- best setup for turbo b16a t3/t4 garrett
- Ceramic coating
- Low HP after boost :(
- Is my Turbo oil drain line causing oil to leak out of Turbo? pics
- WISECO SAYS .0040 IS TO LOOSE, BUT BLOCK IS ALREADY BORED!? HELP!
- 84mm oil pump?
- first turbo build.....what tranny and clutch should i use?
- sc61 vs s372 build
- P28 chipped and going back to stock via dip switches?
- new dyno video
- downpipe question
- d series jrsc
- Z6 pressure max before head lift.
- rubber couplers snapping off and breaking
- problems with turbo oil drain line
- Compression too high??
- do's and don'ts of nitrous. Progressive controlled
- Vitara Pistons
- Wiseco K1 vs Crower rods?
- ls nonv cams
- oil pan question
- 880cc and resistor box question
- to lean???
- cometic head gasket leaking oil..
- Leakdown test result
- wastegate question....
- Ignition break up after 12psi - ?? - >>
- Need the height measurment on the 44mm tial wg
- half size radiator
- Turbo?No?
- Custom Gauge Setup
- bought fjdistributors gasket kit, is the HG worth using?
- TURBO EXHAUST
- Help. Rod bearing issue
- S2000 S362? S256? 58? help!!
- 2000 Prelude JRSC dyno results
- Need turbo info Schwitzer Turbo
- old school guy here Which kits is best now integra gsr b18c1
- turbo d16 help and suggestions.
- Greddy TDO4H-19T
- radiator hose diameter
- Vaccum Diagram Needed for LS-Turbo in EF Civic
- AEM FPR HELP!!!!!
- Compression Ration/piston choice
- Honda FIT turbo size?
- a new start
- WHAT TIRES ARE YOU RUNNING???
- cracked manifold?
- turbo question
- Precision GT37r D-BB coolant and oil question
- How much Boost/HP before It goes bye bye...
- Turbo choice dilemma(last thing needed for finished project)
- what injector duty cycle is ideal?
- wrong distributor??? (check out pic)
- What Plugs to run with Boost levels of 14 PSI+
- what turbo is this?
- 3inches exhoust and 2.5 muffler ?
- Tial/Turbonetics Gaskets
- Troubles when Refueling
- jrsc diy install istructions needed
- F22B DOHC turbo questions...
- HOT TO CLOCK INTERNAL WASTEGATE TURBO ?? HELP !
- d series bearing clearence
- SPoolinPerformance H22a AC Compatible Quick4 Manifold - 3" DP compatible
- newguys build
- Effects of a bad wastegate gasket?
- PSI Builders Turbo 4-Door Dyno session
- Should I get 1 of these? What do you use?
- How much would you sell a darton sleeved block for?
- NEED S/C HELP
- Is running an open turbo bad?
- Soarer Fuel cut problem...
- Anyone oredered from 360infiniteusa?
- running on 3 cylinders!!
- eg b18b1 turbo or no2
- Here's the plan, do I stand a chance?
- what should i turbo b20b or b18b in my hatch
- Filter for turbo
- Tial 33mm Wastegate Gasket
- Almost done long soch turbo build
- new tial wastegate plumbing..
- Turbo suggestions stock b16 street dd??? precision?
- Calling all TWINSCROLL experts.. wastegate question
- can i change cams with no tune??
- Best Turbo Piston size for a good set up
- what compression is to high for boost
- 600+whp on Vitaras, stock sleeved D16!
- turbo question please help !!
- b16 (pr3) pistons on ls rods...
- HELP!!H22 Turbo CRX Overheating
- question on BOVs
- SMOKING NEED HELP ASAP
- info on exospeed racing
- Best Head Gasket for 30psi help!
- Possible b20 knock advice needed
- Couple questions on my GSR Turbo?
- 14b turbo
- turbo size help needed
- Okay, so I think I want boost now... An uncommon question.
- SPAL fan relay wiring question EF
- Turbo K24 EP3 results, long build......done
- D series turbo with A/C setups
- Gsr block Type R piston on boost Question
- breaking in fresh built b18c turbo, what oil to use?
- Divided vs open turbine housing
- help
- What yall think about this simple set up?
- Runing off wastegate
- d15z1 block with jdm d15b vtec head
- s2 tunner 1 and turbo stg 1 markings?
- turbo drain plug to low?
- CXRacing or SPFab 1/2 Size Radiator
- Tire size question
- What turbo to run??..
- rebuilding a t61
- Turbo sizing
- BONE Stock GSR Turbo 494whp E85
- Trying to find a Vitara/Eagle set, any help would be appreciated.
- Does a turbo affect the lifetime of a honda engine??
- B16 Trubo build suggestions
- Name this part
- Single slam turbo cam choice?
- DX Hatchback build review?
- check engine lights
- sohc auto tranny, how much boost
- AEM injector driver install help?
