View Full Version : Forced Induction
- Damaged my intercooler!
- HF Manifold VS. Turbo Manifold OPINIONS!!
- Turbo Miata help
- what year of MITSU are these compressors from?
- What size/thread bolts do I need for my turbo??
- Heads up on new pistons just released from Venom
- Too much for zex kit??
- dohc zc or d16z6
- TI MAIN CAPS
- msd injectors?
- Any dynos of a B16 with an SC61 ??
- How much boost on pump gas?
- 3 radiator fans on the radiator.
- Supercharger on ITR motor...Times and horsepower?
- Does oil coolers really help?
- Which clutch to get? b-series
- BLOV placement?
- Saving gas with 1000? Can it be done
- What wastegates is everyone using theses days
- Video from this last weekend... 12.3 pass vs. new viper
- how should i break in my motor with turbo installed?
- Direct Port same as Reg Wet Setup?
- dyno number request, stock internal b16a @ 6 - 8 psi
- Need Help on H22A Turbo Set up
- HELP OVERHEATING!!!!!!
- Ebay intercooler
- where to mount the wide band 02 flange?
- peak and hold resistor box wiring, why can't you...
- Spark Racing 92mm Throttle Body Almost ready for release !!
- sea level...what psi am i at?
- Turbo Differences
- Well shit....99% sure I blew my head gasket...=(
- Best dseries blockguard?
- remember "car stolen in tennessee post"?
- new here!! i would like your opinions..
- ATTN: Fellow boost users...help my troubles
- Redoing my Setup, Need advice
- 96 up FAT Stubby intake manifold worth it?
- Max boost with lsvtec
- Need some tips on turbo/kit options
- shorter injectors than RC?
- DRAG turbo kit for d16y8
- Anyone know of a good turbo rebuild shop?
- Issue with inline fuel pump + fmu.. HELP!
- Compression/Timing question...
- Rc SL4-550 injectors.
- Good turbo for my application?
- Stock A/F for a B18C
- greddy ic for ls
- Is the Greddy turbo kit for the 92-00 Sohc engines any good?
- finally got it running right then....BOOM!!!
- Problem with my nitrous..
- Better reliability?
- asket head gasket
- Can Avc-R help stop boost creep?
- turbo timer ?'s
- Any sugg. on CR?
- What do you guys think of this turbo?
- Max rev manifold Cracked
- quick vafc hack questions
- couple new toys came today>>
- Which turbo charger?
- Nitrous question....
- code 9, obd-2...does anyone know?
- manifold upgrade, what gains?
- problems holding boost
- injector size question
- NEED PICS OF YOUR CAR FOR MY BOOK!
- Injectors and intercooler for sale
- My blow off valve works better now?
- Dyno: 290 whp Stock ls
- FMU???
- what BOV should i run?
- hooking up a MBC?
- ** Question about my Delta Wastegate - Pic inside **
- REALLY!!!! considering boosting my gsr!
- Who makes a good t3/t4 turbo manifold for a ls motor
- way to adjust fuel pressure????
- 5w30 or 10w30?
- dseries turbo post up you dyno #
- Deltagate problem
- Someone Wants to Sleeve a block, who have YOU gone with and YOUR personal experiences..
- Best rings for JE Pistons?
- avc-r vtec?
- Turbo b16 how low can I set VTEC?
- Good Volkswagen forums
- LS rods
- Running stronger pistons/rods on FI motor
- running oil line into car? anyone do this?
- Toulean, Xylean, propane for ocatane boost
- Looking for a few suggestions on bov, wastegate, fmic - help a guy out!
- B16 to b18c1, With a drag Kit, How much fast will I spool. I don't see full boost to 4.5
- compression test results before i buy my turbo....how am i?
- What thickness aluminum for end tanks?
- Tuning timing on dyno... Jump service connector?
- Anyone using aluminized steel for a downpipe?
- Pic request: Your turbo return lines
- Anyone used competition clutch sprung 6 puck carbon kevlar?
- T4 question
- Detonation in 3rd gear @ 5k RPM, blue box @ 7 psi
- Fkuidyne fal and drag3
- Please read my email to my local honda tuner
- 90 degree bend needed for compressor housing, where to get??
- CRX si cam in D15 motor...I need help...
- Question on LUVFAB SST,any use it to replace drag manifold? what else was replaced
- 720cc too much fuel?
- Civic Hatchback w/ LS (b18b nonvtec) motor..turbos?
- blew up with zex
- Anyone here use Turbonetic's?
- Is the Uberchip still around?
- A/C and a T60-1?
- Will the Blue Box help at all if I hook it up without tuning?
- I lost the electrical plug to my boost gauge!!!!!
- 96-99 GReddy Kit on 94 GSR, problems and solutions?
- Intercooler question
- JC whitney 10% off 80- 199.99 15% off 200+ code here !! take al ook if u gotta buy stuff there
- Intercooler and water = bad?
- auto standalone
- TRACTION!!!!
- Oil Return line parts?
- lambdaboy wideband. seen it? used it? worth it?
- 94-95 integra gsr greddy turbo kit
- Edelbrock turbo kit for d16
- dyno of a friends car
- 1st gear is very quick at 7.5 psi. Any is that good?
- Boosting on a 200k old teg what mods...
- Stumbling hard
- anyone use dsm turbo pipes for their turbo apps?
- what LSD are you D-series guys using?
- sc61 question or problems with new turbo
- ATTN: Honda Tech Vendors, Protect Yourself ... READ
- fuel management options
- 100shot DP on my b18c,, my setup, anywhere for improvement?
- Finally! recent Dyno of my Saturn Ion Turbo!
- What do you guys think of the prices on these manifold?
- please help??
- MBC help, tips, please read, diff question.... really good
- ANOTHER HONDATA QUESTION??
- My new Engine
- Custom Turbo Setup
- where to get heat sheild or wrap or both for turbine housing??
- I Have Decided To Keep My Accel DFI Gen 7 & Not Go With Hondata Thank's To Job Spetter!
- finally boosted after a horrible first attempt
- Piping gaskets help
- oil lite blinking
- Back from the dyno... 400 club :)
- **Help, Noob with Turbo
- i need help quick
- To turbo the SOHC VTEC??????
- What turbo should i use for 15-20 psi on my b16a?
- who to go to for tuning in las vegas?
- Any 450whp to 500whp+ cars out there on STOCK HEAD and valves with upgraded valvespings/ratainers?
- 99-00 civic SI greddy type 31 FMIC ......
- Dyno results (Thanks Lawrence!)
- Any fully built H22 Turbo #'s out there ?
- Ice Box on D-series JRSC Civic
- Can I use my headport as a source for my Oil Pressure Gauge?
- 18g vs 15g
- wide band engine tunning questions?
- PWR in Texas?
- 99-00Si DRAG Gen 3 Manifold fit on LS motors???
- some completed pics (not 56k friendly)
- dont know s about hondas
- Turbosmart wastegate?
- turbo diagram for a first timer
- can it be the gasket??
- exhaust cut out quest..
- A wait worth Waiting(56k beware)
- How to tune Hondata's timing?
- Can't someone burn an Eprom compatible with the VAFC hack?????
- Will this rev-hard manifold work with a precision sc34 w/ no block shaving?
- Looking for opinions/advice on my engine build up
- scarry stuff when driving with a boosted engine and is 1600F high for egt?
- question about turbo parts
- Took it to the track for the first time....Down right Horrible. First time though!
- anyone heard detonation causing rins to loose seat?
- Eclipse Manifold?
- bone stock motors whats the highest boost all you tuners have pushed
- how many of you have upgraded your heads?
- How do you do a leak test on an intercooler?
- Who makes a functional non ricey hood scoop?
- Oil return leak
- turbine housing exchangebale? HELP!
- VALVE springs and retainers
- anyone with only PISTONS?
- Please Help With Burning Settings Into SMC+
- Type R pressureplate and 6 puck disc - will it hold the power?
- is this a good d16 set up? please look!
- I’m trying to figure out what boost I’m running
- FINALLY It's DONE! (LOTS OF PICS) !But haven't started it :(!
- LS VTEC vs. "poor man's type r"
- newest uberdata released
- p30 (10.4:1 CR) pistons and JRSC or turbo.. Too much CR?
- those with nitrous
- Dyno'd: 2liter b16, revhard stage2c
- traction bars and intercooler piping??? help
- PANDA motor ......Anyone in it?
- looking for the right blockguard for d16 using turbopandas set up
- HIGH BOOST JDM B16a converted to no-vtec
- can any one post pics for fal fans in a gsr turbo
- blow turbo?
- I am so getting sick and tired of working on my car
- driveshafts for 450-500whp
- difference between S-AFC and S-AFC II??
- Stock honda ECU timing MAP???
- Precision turbo oil requirments? need good info
- will 440 injectors off of mk3 turbo supra fit d16?
- D16Z6 Dyno results from NOPI Nationals
- Thinking about going turbo....Need some advice
- Internal vs. External Wastegate
- Drag turbo cars running thermostats?
- fixed a/r fuel...still missing like 35whp..(dyno inside)
- intercooler nitrous its
- wastegate, falling off! melted gasket
- need radiator for 1990 civic hatch with b16a and a drag turbo kit
- Boost and Fuel...hack this, FMU that...
- finally boosting!!!!!!!
- problem w/ys1 cable clutch and act xtreme pressure plate!!
- what kind of numbers on your turbo sohc
- Ideal voltage at wot
- what do ya'll idle at normally?
- does the JRSC make power with the jdm itr motor?
- blue gray smoke
- Went 12.1 @ 116 mph this weekend.
- Where to order breather filter from
- 99-00 civic si 1/4 run??
- car bogging when i hit the gas???
- turbo gen2 integra
- wastegate location >>
- LS turbo what to do?`
- what to do
- need help with greddy profec 2 controller
- 200 hp goal, here is my setup. Will this setup take me there?
- VTEC engagement?
- Oil Consumption?
- A smaller diameter tire that should help my quickness correct?
- turbo exhaust
- Turbo exhaust questions
- scared to drive 2 hrs to a track .. what to do?
- Hondata Question
- Help with turbo kit
- WTB 3 in. DP
- uhh my account, didnt know what forum to post it in..
- Kit or piece it together?
- Gasket on comp housing...
- Irratic idle...help..
- 450 cc noob ?
- Everything I need for turbo...
- what is the max hp make a 14b mitsu turbo??? tdo5h
- Ruff idle and white smoke????New head gasket pls help!
