View Full Version : Forced Induction
- Importturbos New turbo manifold!
- s-afc help? Please read...
- Wheres the Knock sensor???
- Snap Ring On BOV
- Prothane or engery sup motor mount?
- cartech fmu
- ok quick question on making jumper harness
- decision time, please help!
- Can anyone send me the Honda PGM-Fi .pdf files that were floating around?
- B16A J1 TRANNY ON TURBO LS
- Question: Experienced (engine)builders please
- Fuel Pressure Question
- Part # for LS rod & main bearings
- tranny problemos on turbo b16a
- The strength of Eagle rods ?
- Cost of a PnP job on an LS head
- addy to the old hostbard force fed tegs board?
- site for that "build your turbo for under 1k"
- Street value of this car and setup
- SoCal Meet, BBQ, and tech lecture by Oscar Jackson April 28th
- t4 too big???
- Turbo goes on tonight!
- Dyno Run
- Blow off hook up
- Help fast
- S-AFC Tuning Questions
- dsm injectors
- Go Turbo LS or Turbo LS/Vtec ? R/S ratio Q?
- slightly OT: Boost Vs Boost
- attn: DRAG/ Tial WG users.......
- pics of my new car, just arrived from japan
- Specific {Q} about water cooled turbos
- Help - what turbo kit for CRX?
- my maxrev turbo install !! its half done.. with pics and what not ;)
- can someone post or email a pw0 hondata rom turbo or none turbo tuned plz
- RC 310s and 10:1
- piston compression ratio?*pix*
- <Q> Jaggies in dyno plot VS. fuel delivery...
- Found a place for cheaper fuel injector cleaning and blue printing!
- Ways of fighting detonation...???
- Nice looking manifold
- Good price on Radiator
- No VTEC engagement prob with hondata.... please help....
- Stalling with light flywheel?
- Anyone have Golden Eagles website address?
- Greddy Blue Box question...
- Kooks turbo header (for those that have it)
- Turbo my Teg?
- which walbro fuel pump do you guys run with hondata
- Cometic Head Gasket???
- Any of you turbo guys want to sell your STOCK OBDI style injectors
- T3/T4- B or E identification
- if u have bad ring/ringlands .......
- need a little help here.
- Im going crazy.....Check this out.....
- Well, the day has finally arrived!
- How much boost can my EX handle
- would this work with my custom turbo kit?
- Running too warm? Should I try to run cooler?
- **WHAT FAN WILL FIT LS TURBO REX??**
- DRAG Prototype Vehicles Needed!!!
- apexi dunk for turbo ????
- LS Turbo Automatic - HP Loss??
- Any Opions On JG Pro series turbo short blocks?
- Fuel pumps
- Anyone have???
- pics of my car
- Anyone know who stocks 84mm 9:1 Compression Pistons? HELP!
- QUIET 3" muffler? Suggestions? ->>
- Cost of an LS/VTEC kit
- 165HP turbo Honda PWC....
- Modifying Greddy for 3"
- Hey guys, I'm joining the darkside.
- NHRA Sport Compact Nationals, Gainesville FL. April 13-14 2002.
- Electric Oil Pressure Guage
- Turbo's from Exospeed
- b18b turbo or b18c1
- msd coil problem........... anyone?
- Another Problem
- Turbo + Twisties?
- Question about use of Hondata / Aeromotive FPR
- ANY MORE GROUP BUY ON A TURBO
- B16 VS GSR oil pump 4 LS/Vtec??
- Anyone racing or going to Gainesville this weekend(NHRA)
- Bulletproof LS motor?
- D16 turbo manifold - CAN"T find any in archived posts???
- OT: Sport Compact Car-- Street Car Challenge
- anyone?
- Used Greddy Kit ... Is it worth it ... ??
- Motor mounts??
- comment on proposed setup please!
- help on custom turbo
- Laptop - Hondata
- simple supercharger question ?
- electric supercharger with some #'s(yes i'm bringing it up again)
- Went to the track last night
- whoever ordered there prodrive gears
- J&S Ultra v.1 guestions
- Starion I/C size concern...
- Turbo Intercooler question
- eagle rod question
- My new babies ...... =)
- try to figure THIS out
- pistons - have them coated or not?
- Questions on fuel system.
- aluminum flywheel question?
- Boost Controller setup
- My new turbo, can someone identify this?
- Hondata???
- My sohc vtec greddy dyno at 5psi
- Blitz BOV with 6-7 psi...
- Anyone running a T3/60-1?
- GReddy Type 24 IC kit..need answers asap please
- Who sells valvetrain components for LS?
- honda iat and coolant temp with speed pro?
- 1/4 times for civic ex turbocharged
- Need advice on turbo
- daily driven turbo swap....which one?
- what kind of pistons and rods do you suggest?
- what valves and springs are +suitable for turbo?
- tuning shop for AEM
- can someone PLEASE answer this..................
- turbomanifold bolts!?!?
- REV HARD Stage 2C?
- launch rpm with drag radials
- Arturbo!!
- Where to get info?
- Plugs
- best choice for high HP axles?
- VAFC/SAFC/FIELDSFC...?
- Anyone ever ran a 63-1 on a street car??? t3/t4....only for BIG TURBO PEEPS
- turbo prelude questions???????
- The Legality of no Hood.??
- How much power can a T3/T04e support?
- LS and a t3/to4e
- B-Series Turbo Kit For Sale!
- Best place to buy turbos...not kits, just turbos?
- Accel DFI HELP NEEDED
- Mustang Dynos or Dyno jets.. which do u prefer and which is more accurate..?
- Wastegate dump tube open to the air or conected to the downpipe?
- Eagle rods do not work in a B17
- what oil to use with new turbo and fresh build up
- dumb question o2 sensor
- ill ask again
- intercooler sizing on EK Civic
- fuel vapor
- My goals
- turbo manifold
- MAP sensor bypass?
- LSD
- water lines for turbo
- No Friggn' SEARCH!!! Valve Cover Breather Setups....
- In-tank fuel pump coming loose???
- New pics and....
- Need help with remote FPR..
- Missing link?
- Best bang for the buck turbo timer & boost controller
- need b18c1 motor layout - questions about fmax install
- turbo to manifold gasket
- Last week was a sad day for my baby
- My weekend at the Spring Compact Natls at Moroso..
- GS-R vs. B16a cams
- Big Intercooler!
- Anyone here unsing a 2 step?I got questions
- Hondata Ver 3 ! Anyone beta testing this...
- weird whinning noise with jrsc...any ideas?
- TURBO PARTS NEEDED
- Where can I buy a missing link
- dsm side mount intercooler on a 93 civic?? (Need to find archived post)
- another slick question
- sorry guys no seach working need plug cap on bkr7es-11? thanks
- PROPS to all FI cars !!!!!!!!
- Where could I buy this part of a wastegate?
- dialing out overlap with cam gears... what are your settings?
- Installation of inline pump
- defi guages, looking for a post
- What else do I need?
- Golden Eagle
- HF or STD manifold for Turbo???
- opinions on boost controller
- pinging with hondata stage 2
- What's smallest spring for Deltagate?
- my GSR is idling and doin weird things
- OT , does anybody have the millermatic 135
- What brand injectors fit Honda's perfectly?
- fabricating a manifold
- Can someone double check my fuel line parts (based on the archives)?
- what cars did the garret t3 come on?
- Recalibrating FMU
- What all to do?
- How to find out what pressure to run at the rail with 550's --Dustin???--
- EGT temp in celcius
- Vortec SFMU setup, need to achieve around 6:1
- flooded my motor all to hell
- Darton sleeves
- help w/ manifold options for the h22?
- Stripped Flywheel Bolts
- BAD News : BLOWN MOTOR! need advice....
- pipe joints?
- Just finished my wet kit install, god help me.....
- b18c1 vs. b16a (si) transmission?
- Would you guys jump on this opportunity?
- If one was to go that one extra step....
- How do I get the !@%% exhaust housing bolts off?
- how necessary is...
- Anyone ever try Toluene in their fuel?
- Power to the fuel pump
- WTB stock 97 gsr injector
- Water injection system
- Recently Turbo Teg
- CRX Resistor box
- What size slicks for 14psi+ boost?
- Should I get a new WG spring or buy an MBC?
- general boosting question(CONTINUED)
- What size flange to fit end on 3" Thermal? (making my own flex)
- I need Vince's # at Golden Eagle.. (yeah i did a search)
- are b series and d series injectors interchangable?
- need help i just got a mil code 65, Secondary Heated O2 Sensor Circuit
- installin check valve on 98 civic?
- intercooler piping pic's - DSM custom made
- i am sorry guys but i got vent about tial products inc
- Hondata studder
- hondata + 440s installed - fuel pressure question
- to peeps with lots of power using slicks on DRAG tracks!
- anyone have drag gen3 kit on a b16a crx
- Simple Injector Question, Please read :)
- NEW! J&S Ultra SafeGuard now with AFC
- Where can i get intercooler piping and a downpipe at?
- Need Help On My SC'd JDM GS-R!
- Max Rev Oil feed.. from the Block to the turbo...Plus Update on my install !
- i got a code 23 on my GSR
- To those with Maxrev Downpipe: did you have this problem?
- I need a 3inch flex
- Fuel Problems with only 5 lbs of Boost
- Greddy blue box different for civic sohc, civic si, and integras?
- Cheapest price on Datalogging upgrade for Hondata?
- installing RC injectors
- intercooler piping>?
- Boosted....Finally
- hondata has new prices!
- 1 more question for the night.
- Turbo newbie questions!!!
- My engine Engine Started, Ran 15 Seconds, And now it wont start
- Fuel injector problem`!!
- plugs ????????
- can someone suggest a good wastegate to use?
- Time to Build the block
- stock tach too slow?!
- general boosting question???
