View Full Version : Forced Induction
- Problem with starting up motor
- Pic Request: CRX Sohc Turbos(Engine bay shots)
- Can GE sleeved/o-ringed block be bored out without any issues?
- ic, whats too big, too small?
- EGT Importance
- max boost with btm/safc/450s/pump gas???
- oil return/feed flange
- How do I install blue top Eclipse injectors in my son's '95 Civic?
- Supercharger Service: Jackson or Magnusun
- b18b 3'' downpipe? where
- Any hondas here running Haltech
- fluxuating idle until car is ran for awhile?
- Spool on SC-61
- JRSC????
- cheapturbo.com
- Question about the temperature sensor and vacuum lines.
- tdo4 to small for an h22??
- A little OT but thought you'd get a kick out of it...
- building up the engine to handle the power
- Gauges Preferences
- Downpipe problem
- 5lb bottle
- Vortech supercharger.
- Does anyone know the specs on a the turbo that comes
- hondata interface issues
- what else to get?
- D15 Turbo questions...?
- Jackson Racing Thermostat..
- Eagle crank or B20 crank for F/I Dart block?
- has anyone upgraded their greddy 18g compressor wheels/housings
- I need the half of the V-band that goes on the DP. For my Precision turbo..
- question for turbo'ed folks: anti-lag system
- New Edlebrock Turbo Kit?
- Just ordered a new turbo =)
- need help on junkyard turbo
- Can you chip an OBD2 ecu?
- 35mm tial ?
- Catch can Question
- Why turbo a SI ?
- Very small T3?...Smaller than the super 60...options?
- Looking to run 9lbs on greddy kit, is 440cc good for the power im going to make?
- ECU layout for FCU
- quick dumb question
- Turbo and compression ratio
- From D to B
- got a used greddy kit where can I find gaskets?
- greddy blue box tunable?
- Does the SC61 Have 360 degree thrust bearings?
- what size shot?
- AEM FPR with a A1000 fuel pump?
- Apexi SAFC vs. Hondata
- Profec B opinions?
- 50 Shot Safe?
- updated turbo prelude pics
- quick opinions on my fuel problem?
- Wastegate Question
- Cometic or Bored OEM Headgasket?
- Oil restrictor for turbo???????
- NewB Trying to learn
- question on using gaskets...........?
- aluminum ic piping
- Hondata K Series Programmable ECU
- good kit...yes or no?
- turbo that can flow enough for 15 whp per psi???
- any1 here know of or know sum who has used ctr pistons and n20 ?? (did search)
- Turbo kit for new EP3 Civic Si
- Winter time! time to piece my turbo together for next summer! q's ?
- Part # for 3 bar pigtail
- dumb question but seen pics of both ways
- Quick question
- full race comments
- When to Micro-polish a crank?
- anyone have experience with IB Annihalator packages for b18c
- Turbo Setup SOHC
- Internal and external wastegate question
- proper sc61 size for 83mm b18b
- aem ems ez? what kind of laptop do
- Question on DMS injectors
- S-AFC and Remote Car Starter?
- Those who own ROM buners..
- IC charge pipe pictures.
- stock sleeve question (already searched)
- how do you know if the charger bearings are out????
- greddy sohc turbo kit Converted to greddy dohc turbo kit.
- Will Hondata fix check engine light?
- Engine Managment for a Boosted B16
- Anyone help me determine what these are worth?
- craziest downpipe ive EVAR !! made
- no charge pipe for 20 mins??
- Cold Spark Plugs
- oil catch can question
- stock ls head for turbo
- DSM sidemount guys, post your set-up
- connecting IC piping to this kinda compressor outlet?
- ***** WHP & performance differnce from a 60mm VS 64mm TB.
- LS turbo?
- How much power on what engine, boost, compression do you run?
- Fuel Pump....Is this normal
- coming soon! :)
- P28 with Hondata
- everyones thoughts on exedy clutch's??? please?
- turbo bearrings
- Lookin for a nice spooling tubro... What size for the B20?
- B20/Vtec engine with T70 single turbo (witch flywheel??)
- E-manage eliminates speed governer and rev limiter??????
- need an answer asap
- T3 Garret 48/42
- just installed moroso oil pan now smoke coming out of header where it meets head.
- jrsc b18b1 LS with hondata
- Anyone has some good site for purchasing custom piping for turbo?
- i need help with zdyne pin out
- Turbo GSR motor with bad compression worth tuning?
- Add a Knock Sensor to a B18B??
- a question about gsr turbo pistons and rods
- can someone walk me through setting my hondata settings? i can't seem to figure it out!!!
- did serch, new q's on egt placement.
- good and resonably priced place to replace turbo seals
- Found an intercooler: How good and worth how much, y0
- Anyone used VDO boost gauges?
- stop looking at anytopic you're looking at and help me... plz!
- Tial wastegate problem
- NOS jetting
- 2.5" exhaust or 3"?
- Greddy turbo kits..
- How do you read the Knock sensor on the SAFCII?
- should I buy
- Any one been sucessful
- Hondata cost is wild!
- greddy i/c question
- Critique my turbo setup. I need advice and opinions.
- s80 or y80 differences???
- who's right? edlebrock or RC?
- boost gage spike?
- avc-r installation
- Injector Size Debate
- So I thought I figured out my 4800-5000 RPM rev limiter problem! NOT!!!!!
- okay so a friend and i homemade boosted a d15 in a 93 dx...and we need help please
- should i rebuild or go bigger???
- drag 3 turbo kit installation
- VAFC hack sufficient for 8-9 PSI on 18G greddy kit?
- MY H22 turbo EG: just got back from the DYNO @ .9 BAR!!
- Where does my oil go?!
- Physics majors, think about this one...10PSI = 40+ PSI
- Block Guard
- hondata gasket
- f.m.u Problem
- vafc hack screwing with my timing?
- Hmm, kinda off topic. What do do with a new potential project.
- gsr crank in b16
- need help with hessitation in and out of boost its killing me!
- Just starting a Vouch Thread to keep my History!
- a big box arrived!!!
- which is better a t25 ball bearing turbo or a t3t4 hybrid
- Tranny oil leaking out of the passenger side
- Need new rings...where to buy?
- Blah, Blah same old questions on boosting.......
- What do I need?
- I searched... Lightweight 17" Black or Gunmetal Rim
- what ignition are you using?
- nitrous users- signs and symptoms
- What Size turbo comes standard on drag 3 kit for SOHC?
- How do you test a turbo?
- Smallest Turbo???
- Black Smoke when shifting
- **KINDA OT, BUT: A (hopefully) cool idea for an alarm system..need technical gurus input!**
- *BOOST* Problem! Need help~
- help with crower LS DUAL SPRING & TI RETAINERS with turbo 402T cams ..
- anybody running more then 400+ in a b18c1 with the maxrev kit?
- equal lenth vs shorty mani's
- Hey tuners.. how large a difference will this make?
- i REALLY Need a Downpipe
- Return fitting question
- Crower SOHC Turbo Cam Review? Opinions?
- GSR Motor
- Do I have everything? d16
- 90 degree bend off turbo?
- Can't work out whats wrong with my AFR!!
- check out this thermal exhaust if your looking to buy one..
- HELP:greddy oil block adapter
- turbonetics t3/t4 .57 trim ar63
- 3 bar map sensor
- Tuning question??
- Congrads to Cortney Green (Uglyasscivic) 10.37 @ 140!!
- Tial 35mm and Tial 35mmHP springs the same?
- OK to boost if car will be sitting unused for a while?
- Turbo!! HELP!!
- Max Rev Question...
- purging the fuel system
- should i buy a turboed r
- turbo mani not sealing against head....suggestions?
- b16 spool time
- joining darkside!
- oppinion on a turbo...
- MAP problem
- who has/had a t3/t4 on a d series?
- Can you use AEM's wb02 w/out the EMS?
- importparts.com Retail Store Grand Opening - November 22-23, 2003!!!
- Anyone who as ever installed the moroso oil pan
- who had/has t3/t4 on a d series?
- does those dyno wideband change readings with a CAT???
- Why do I always run into this bullshit...
- Front bumper doesn't fit too well over IC, had to chop it a LITTLE...*pics*
- b20vtec boost (good or bad)
- Daves way at SuperT
- Check Engine Light with Turbo Exhaust
- STREETRACING CHRONICLES!!!!! NUMBER 3!!!!!!!!!!!!!! lol
- Is this block any good?
- Obd 1 integra ls w/greddy turbo
- Tial Wastegate spring color?
- is this intercooler junk????
- Did a little facelift - pic intensive
- !!!!HELP!!!! turbo timer install
- Testpipe / High Flow Cat / or Gutted Cat
- My setup on my GSR.....thus far
- No Turbo Timer
- Back from the dyno.....JRSC B16A
- opinions on LS/VTEC Turbo Setup????
- How to boost 7 lbs on a DSM turbo?!?!?!?
- Few HMT Videos this Summer (Dyno/BBQs/Burnoff/Rally)
- DSM manifold?
- drag turbo specs?
- tranny/clutch troubles.....syncro?!
- opinion???????
- greddy turbo kit for 2000 gsr
- Building custom exhaust, 3inch and need to know where to get 3inch resonater and 3inch resonated tes
- custom manifold parts selection help.....
- ported stock manifold vs stock manifold
- A/C Line Relocation
- Vortech guys im in need of serious HELP!!!
- For the 1,000th DAMN time.... I own a Kiwi mani
- Just bought a Greddy Kit...have some questions.
- someone please explaint ot me what open loop and closed loop are exactly!!
- Anyone have this intake manifold?
- Rods/Pistons Installed.... Now the Run-In???
- OBD2 to OBD1=Power Fluctuation
- 13 psi only 278 whp on B18C1??
- I made a mistake....
- went to the track! tell me what you think
- Put a toggle on ECU fuse???????
- MSD Inline Fuel Pump - Fitting Sizes?
- gsr cams better for boost?
- Hack with VAFC and wide/low throttle settings
- Cleaning intercooler tips?
- what wastegate spring for about 30psi?
- Knock sensor on the Profec B spec2 question
- Keyway for exhaust cam cracked
- Motec Pros only
- Quik qoestion for anyone with v-afc
- JRSC Questions.
- CABLE SHIFTING B series transmission??
