View Full Version : Forced Induction
- f23 turbo application spark plug?
- F.S. Eip Fuel Pressure Regulator
- Apexi World Sport exhaust on a JRSC setup?
- Is my bearing clearence ok?
- New acura owner, turbo help.
- headgasket for 84.5mm turbo GSR
- help me find a good turbo manifold h22!
- Identify that turbo.
- hondata S100b question...
- Gsr swap not Boost
- tial 44mm and 38mm springs the same?
- full race downpipe ground clearance w/ first gen hasports *crx
- want some advice
- Single slam turbo build and pistons
- Standard Oil return line..........?
- waht kinda flanged turbo is this?
- Boost Leak 70mm Mustang Throttle Body
- what tool do you use......
- PRECISION T3 PTB 300-4432 BALL BEARINGPRECISION
- need some turbo definitions for me......LS VTEC Turbo(GSR HEAD)
- retune when switching to oem muffler?
- coolant loss
- D series torque?
- H22 with Garrett 60-1?
- exessive valve noise, help me out.
- BOV???
- Ls Crank in a b18c Dart
- Mercedes 300D T3 turbo question
- My car goes down at 1500rpm
- turbo b16 ignition ...
- Moroso pan...proper oil level?!?
- Spun Main bearing how to flush turbo??
- I am about to pull my hair out. Motorola 2.5 map sensor. wiring
- car died
- 90 crx turbo 1.5 blown head gasket
- best tuning for turbo cars
- zex programming problems
- what clutch for a dd with 450whp 300+tq
- how thick of a head gasket do i need?
- greddy profec b
- Sorry I know this a dumb question
- built b20 turbo...gt30r or gt35r???
- break in info
- jrsc probs
- What bov is this?
- RC injector installation help.
- help me identify my turbo!!!
- TURBO B16
- turbo price
- Precision Intercooler Mounting Question
- iddle question
- Hondata S300 not reading the same boost levels as guage!? Hondata Guru's please chime in!
- CC twin disk user's
- going from stock greddy DP to FULL 3".....input/help/info needed
- How much boost can a mini me handle
- s372 to big for 2.4l
- Engine idles wierd?
- Turbo Head
- where can i find longer spark plug wires
- need pics of wiring set up for type r swap in 1995 civic hatch
- Socal Tuning session with Mase in Late November
- moroso steel oil pan ?
- A/F Ratio
- Turbo does not spin at idle...
- Anyone ever tried doing a puller fan on the FRONT of the radiator?
- Spanish tuner
- Jrsc for Em1 (searched already)
- 600+ hp on none ported heads ?
- Quick OIL COOLER question!
- How do i identify CAMS?
- EVO style vent in the hood to reduce temps.. input plz
- Anyone Running Exhaust Crankcase Evacuation without a Catch Can?
- Ordering fuel system tomorrow NEED FINAL OPINIONS
- Thinking about boosting my CRX..
- Best bang for the buck turbo for 550-600hp
- turbo vaccum line setup problem
- Golden Eagle Intake Manifold "thoughts"/picture..
- jrsc thoughts
- my mini me's back firing!!! HELP!!!!!
- are these good for my set up?
- weird electrical problems..need help fast
- D15 vs D16 Vitara build. Yes I searched.
- Whats wrong with AEM 3 bolt cam gear?
- Dang Performance TX? anyone heard of it?
- peicing together my turbo kit reccomend me some guages/EMS plz.
- Is the Exedy oem replacement clutch boost worthy?
- what should i make?
- Need manifold for B18B with DSM flange
- Exhaust manifold flange in midwest?
- how to lower boost on deltagate
- vaccum setup ???
- idle fluctuation post F.I
- Tilton Flow Control Install PICS
- Need help identifying some Skunk cams.
- EBC boost levels vs wastegate spring rate
- How specific should i get?
- has nay1 heard of these kits or r running them?
- Apexi Power FC with commander
- where ot mount e-cut out?
- What size injectors are these... Pics inside
- fuel system issues.. dual walbros.
- S362 vs GT35R???
- oil restrictor
- do i need throttle body?
- Engine build
- best upgrade path after the fact
- Ls vtec, which pistons to use?
- Built z6 head - safe to put on y7 block for mini-me?
- Pic Request!! Full Race Twin Scroll-Wastegate/Dump setup!!
- turbo crank shaft
- turbo crx wont start with 750 cc injectors
- What exahust to use???
- are you high horsepower guys runing msd??
- Evap canister purge solenoid idle problems - can I remove it safely ??
- How long before i throw a code
- H22 OEM Intake Manifold for turbo?
- sc61 or garrett 57 trim?
- 84mm for daily driver ?
- do i need bigger injectors for a turbocharged stock motor?
- built GSR bottom end ?
- 400hp street car... A/C belt keeping ripping apart. any suggestions??
- where can i score autometer products for good prices?
- Injector help!!
- JDM H22a turbo question/ AZ emissions question...
- Blue smoke, cant figure it out, pix + video inside, lotta details.
- injector question
- Aluminum or Stainless steal IC piping?
- Best aftermarket B-series cams for Built Head on Forced Induction
- WTB stock del sol si
- b20b cam info
- Z6 oil pump question
- My New Setup
- Race gas or water/meth??
- two holset questions, please help!!!!
- Stock LS Intake Manifold Vs Skuck2 compared!
- compression raito junk
- problems with earl fuel filter??
- What would happen if I run the WasteGate with no spring in it?
- Evo TIAL 35R Kit
- Can someone lead me to a good turbo setup for d16 on my civic...
- 400whp pump gas + stock sleeves.. thoughts/comments
- engine rebuild for turbo set-up.
- pros/cons
- Head gasket thickness?
- Injector Pulse Noise
- Will this B16 set up work?Just need a little help..thnks
- H22 GT35r camgear adjustment?
- Couple B16A3 turbo questions.
- Who makes/sells the freeze plug threaded fittings with -10an ports..?
- Blitz SBC ID III plug broke...
- HAs anyone used the bosch widwband
- t3/t04e 60 trim on a 2.0L gsr
- UEGO sensor and impreza O2's are the same???
- Boosted b20
- new turbo setup!!
- Apex N1
- Turbo E-Manage Blue "tip-in" question
- Turbo or Supercharge
- God Speed Wastegates?
- how can i get my car threw state inspection??
- new engine + break in period
- This set up is good for turbo?
- Supra anyone?
- turbo lsvtec guys I need your input
- WTB B20=]
- Wastegate problem solved, now Motorola 2.5 bar map sensor question...
- which turbo
- Garrett experts, PLEASE HELP! GT28 questions
- Best turbo pistons
- Clutch slipping? while freeway driving in high gear VIDEO
- MSD Dist - Standalone wiring
- brake boost
- intercooler mounting question
- Thinking about installing turbo...just need to know a few things first.
- Is Inlinepro's SST4 manifold compatible with crx?
- The Quest in to the 10's
- cant turn the boost up past 15 lbs
- help figuring out what this is....APEXI boost?
- comparison of turbo's for my new setup
- what oil do you run?
- Offical Build Thread **540 whp Type R PUMP gas** w/ AC, PS, & ABS (56k no way!!)
- where is a Good Boost Source for my WG????
- Boost Situation?
- puff of white smoke when trying to start?
- ARE MY OIL CLEARANCES OKAY?
- Identifing Chrome or uberdata or what else is out there on a ecu
- what size injectors are best
- Uberdata CEL 3 motorolla 2.5 map
- Need some help one this problem...
- Car cuts out at 6k... has fuel and spark
- Prelude F22/H23 Boosted Built Plan
- b16a turbo tell me what you think?
- Recent work on the girl (56k take a nap)
- bottom end ?
- Wastegate help!!!! Please help!!!!
- Picking a turbo for e46 330i.
- Home Made Turbo FIRES and other disasters
- Turbo H22A - ACT Clutch suggestions ??
- What flywheel to get?
- my 92 civic turbo
- Stock B16 back from the dyno.
- Fuel Pumps Dual Walbros or A1000
- boostin my gsr soon had questions
- putting a turbo in the s2k, just some pics of the build!
- turbo?????
- can anyone tell me anything about this intake manifold?
- power FC on prelude PROBLEMS
- Turbo B16 - Quick oil question!
- How much weight can you take out of a DA
- turbo leaking oil from chra and into turbine.. blown ring?
- LS Turbo or Single V turbo
- BOOSTING 94 GSR have questions?
- TiAL Q BOV Help.
- Race resonators...
- Another installed my turbo & my car won't start thread
- BW users ???
- JDM GSR TURBO
- Turbo experts please look @@ need opinions on please.
- Fuel Pressure regulater and fuel rail
- supercharged highj compression???
- no cold idle whats wrong help no fitv
- Need help ASAP, turbo car is smoking.
- Milky oil from turbo return
- Victor X manifold and 76mm throttle body?
- Toda spec B cams and boost?
- questions about: innovative 42mm wg , and carbonetics lsd
- BOV opinion
- Wastegate question....searched to no avail (I also have A.D.D. =P)
- how to check your head??
- lm1 + p28ecu
- Boosting my 94 gsr, have questions
- need help with vacume controlled wastegate
- jrsc some quick questions
- Peakboost FTW on type r?
- looking to buy a GT1548
- Has anyone ever ordered from *VPFab* or member *ebydrc*?
- Need help with abit of missfire&code 41...
- Boost issues with BW S360...
- turbo USDM type R questions (Knowledgeable answers please)
- Show me your Turbo setups with Air Conditioning!
- Post your intercooler temperature drops.
- Chamfered Bearings
- Anyone ever have problems with a mech. boost controller goin to a bigger wastegate?
- Alternator problems?
- Just had to ask you guys. how much??....
- pic re!!!! turbo set-ups with full size radiator
- Jackson Supercharger question. *Searched*
- Greddy Emange (blue) or Hondata s100
- Where to buy MVM stepper pulley for JRSC *SEARCHED*PLEASe
- b18b block
