View Full Version : Forced Induction
- T3/GT35 "Blowzilla"
- HELP identify this turbo!!!!
- Am I over boosting? Whats the popping sound?
- in line Fuel Pump install
- FMU makes noise/sounds?
- Anyone know of any good MR2 Turbo boards?
- Uberdata
- missing link on a 91 teg 0bd0???please help
- not sure, jrsc question, please help
- anyone running the RM rods?
- need up close pics of turbo's d series
- ecu??????
- intake manifold and turbo questions. skunk2 sufficient? yes i searched
- Nitrous Users... Check this out!
- Need help tuning in Seattle
- Socketing p72 for Hondata
- Drag or RevHard
- NEED INFO GUYS!
- How do you connect the wire on a Warlboro Fuel Pump? that came with the Drag kit?
- Engine light came on! Help.
- b&m banjo fitting?
- can you anodize or powdercoat and intercooler??
- threaded oil return fitting for Greddy turbo? Stan the man?
- Turbo LS Owners: How many are using knock sensors on stock B18Bs?
- t3/t4 .63 a/r spooltimes
- im ready to build my block PLEASE HELP
- How tough to get 13s out of an sohc turbo in a crx?
- look at this
- drag gen 3 vs gen 4
- JRSC Map Controller Help!
- Wantin to see some ls turbo setups
- Nissan guys need your help.............Anyone deal with turbo-boost.com????
- My Turbo R
- -help making fuel maps with a vafc-
- already searched
- What is a crank scraper?
- Anybody have sound clips for the greddy type R BOV?
- Copper head gasket keeps blowing becuase it wont seal
- questions about turbos...
- drag ic
- bought a turbo and some numbers checked
- Building b18a turbo motor need advice...
- D series, test your knowledge!
- Golden eagle Oil adapter w/fittings for LS/vtec and turbo feed
- Exospeed Stage 4 Race Block for turbo?
- Where to buy a downpipe
- Missling Link Problem
- Wategate, and exhast return ?'s
- Wideband ?'s
- Few questions
- N20 PEOPLE
- Hondata hesitation?
- DRAG kit dump tube size?
- Blueprinting an engine
- pop off valves? anyone use one?
- vtec turbo??????????
- Turbo exhaust system, is bigger = better
- SMIC piping questions
- Motor experts... rod bearing failure question
- jackson racing supercharger!!
- Greddy upgrade
- should i hear spool efore i see boost?
- HP for 3 gears only?
- NOT boosting up to wastegate's spring, any ideas?
- oil pressure problem with LS/vtec turbo. no vtec
- Repost from tech section, maybe someone here knows.
- Help Overboosted!!!
- Resurfacing turbo manifold?
- Who has this civic? this is crazy~
- Some problems on initial start up. Please take a look. :)
- phantom CEL?
- Nissan 300ZX turbo question, i can't get the exhaust housing off!!
- Garrett or precision?
- boost problem
- Has anyone blown a dart motor?
- Searched... no definate answer... Help Please... Turbo question...
- Kamikaze Header, yes or no?
- Integra LS Turbo Advice
- which one should i get for the jrsc
- Celica all trac stock water over air intercooler (cheap liquid intercooler?)
- which FMU ratio to use with my greddy setup !
- Full Race kit w/ C&R Radiator?
- dsm injectors...really quick question!
- Debating on a intercooler, if i should keep the one i have or replace it...
- car over heating after golden eagle block guard install?
- Thinking of going TURBO but what first?
- garrett t3/t04e 57trim - what can i expect?
- Turbo D16Z6 dyno tuned w/uberdata ::PICS::
- Anyone running this gauge pod?
- question about 5 bolt downpipe
- question on wastegate fitment..
- CEL Code 3 MAP w/boost and FMU/injector/inline pump
- Pics of my daily driver :)
- trim & a/r questions
- Can't find an exhaust flange for this turbo! Help!!
- question for those who have installed a quaife!!
- Hondata - Romeditor ?
- turboxs boost controller Q
- where can I get rebuild kits for the these turbos?
- what kinda turbo on a WRX?
- 1990 SAAB 900 ALUMINUM TURBO INNERCOOLER
- FMU question
- Disco Potato
- Ls tranny vs b16 tranny
- 9.8 to 1 Wiseco
- How tunable are Crower 403's w/boost
- Difference in parts
- turbo list
- How much more boost with my new setup
- Durability issues of thicker head gaskets.
- Cheap beater on ebay with a swap(ends in 25 minutes)
- AFC HACK, injector problems.
- h22 Jackson racing supercharger prelude 97-01 jrsc
- quick cath can question
- help! broke bolt on the compressor.
- apexi vtec controller wiring diagrams?????
- Looking for a clutch recommendation!
- People with Manual boost controllers help!!
- qt mile and hp estimates for my ls (And what next tranny or bottom?)
- on my turbo, bought it new rebuilt and the nut on the metal wheel came off........
- AFC Hack install prior to boosting...
- ??? Compressor surge & Boost below 7psi on TiAL BOV during normal driving...????
- Inline Pro cast iron 4-bolt manifold
- Tranny & Head bolt thread pitch and size.
- Zex Wet VS Dry
- Turbo choice for HMT kit: 14b or Subaru turbo??
- Cleaned up my turbo a bit...what high temp paint to use for manifold?
- Crwoer StageII good for H22+Big NOS build?
- help me boost!
- What size piping will i need from the turbo to intercooler? (SC61)
- newbie needs your help on boosting
- Need a turbo install
- Is there any difference?
- Turbo rebuild - Majestic turbo or cheapturbo
- HKS SSQ?? SOUND CLIP?? Whats it sound like??
- Where to buy o-ring and seals from RC 550cc injectors?
- Evo 8 are fast from take off, had me 2 car ahead, suck.....
- speed pro install???
- BOOSTING A B18C1
- SC61 on LS
- Turbo Troubleshooting. For the beginner. (Need feedback)
- ebay's ssautochrome wastegates
- A couple of Questions for all Turbo 5th Generation Preludes
- H22 Turbo Race cams
- adjusting turboXS type H BOV?
- Tunning Issues..?
- non- mandrel bent ok????
- prs help!
- Nitrous on my lsvtec...what else do i need?
- Drag turbo FMU's what brand are they?
- turbo help!! afc hack
- Tial BOV Spring???
- what do you guys think of the sc61 turbo
- SSAUTOCHROME AGAIN
- couple of ..............
- Turbo Install Blues
- traction bar answers -- why brand X (i mean brand z) doesnt work
- Request: Oil Feed Line Pictures from block to turbo
- Which upper charge pipe fits a gsr with skunk2 IM?
- what plugs to use??
- AEM EMS Vs. Hondata s200b
- turbo d16y8 or b16a2?
- arp rod bolts. resize?
- eagle rod questions
- Low impedence injectors OK with JRSC B18/B20 setup?
- just started motor after rebuild have a question??
- revhard manifold and downpipe?
- So Im thinking about turbo'n the old HX Have some questions
- vortech supercharger on integra
- turbonetics 62-1/T3 full ballbearing turbo
- My new dyno numbers, sohc turbo
- Idle Issue
- i have a missing link q? yes i searched!!
- Still having boost problems(profec B)
- hks wastegate on ebay....
- 96-00 Civic b Series Drag Kit in a 92-95 B series hatch? How off will the piping be
- how can i make a sohc greddy kit fit my new b18c5?
- how can i make my type s louder? harder or softer???
- before tuning ?s
- Is this dsm 450 injector still usable?
- car bogs under boost - Please help!!
- Turbo Daily Driver? How many miles, How much Boost, Setup?
- Has anyone got main bearings from this guy. Hope this dont get locked
- ac fan on radiator thread?
- Tuning w/uberdata, few ?
- Titan rods?
- bay area turbo tuning
- garrett T3 downpipe to turbine bolt size?
- Where to get wastegate flange 35mm to merge with downpipe?
- New Honda owner, turbo set up...
- Can the valve adjustment be thrown off...
- B16 stroker turbo numbers
- Water in intercooler?
- Boost Gugae question ..
- Why do we even need headgaskets?!
- fuel managment, this sound good?
- In need of new pistons, but which ones?
- hard break in method.
- boost gauge sits a little above 0 when not hooked up?
- rc 440's plugs ?
- 94 gsr turbo ????????
- ECU GODS Can I add IABs to a p28 and any h22 or p13 experts please help!
- My Turbo Project Update
- This a good basic fuel setup?
- Turbo Questions
- How long should you go? before you change your oil.......
- Quick Type-S BOV Q
- blitz dual sbc spec s
- GReddy Rebic III Manual Availability?
- Stop turbo from free spinning at all....
- Anyone go to Secret Services in Tampa Florida?
- Turbo Gasket Question
- Ignition Timing problem with hondata Please help..
- stock gsr lsd and 300whp
- Fuel setup questions
- Intake manifold
- safe compression for B18b but good #'s
- have a question about this 62-1/t4 turbo
- what BOV's fit type-s flange?
- Maintance on full-race kit?
- My Project B18B Integra (with a few pictures)
- fuel pressure guage on stock fuel filter
- Greddy oil sandwich block
- Please aid me in choosing a turbo from CHEAPTURBO.com!
- XS turbo kit?
- redundant question #12
- This weekends project No 56k
- Turboing an EG?
- Keeping the oilpan cool?
- Where do you buy IC pipe couplers??
- Duty Cycle Question
- help..really really corny question
- Identify this injector ...
- ImportBuilders Block
- sc61 for my setup goals or stick with what I've got? OR something in between?
- Thoughts on using NITROUS on older engines
- Switched to AEM wideband 02 sensor need help
- Supercharger/Turbo problems?
- Just wanted to share my new lil project :)
- Jackson Racing FMU Question
- turbo oil filter ?
- *Blocks*
- Blitz BOV
- Junkyard Turbo Prices? Would I need an engine build up? 4g w/ Jdm Zc
- strange idle
- what company makes a 3inch exhaust
- Help with tracking a shipment...
- How much are u spraying on ur SOHC and what 1/4time u runing????
- How many of you run LSD's???
- Golden Eagle Sleeved copper rings. How to Remove / Replace
