View Full Version : Forced Induction
- JB Weld+ Freeze plug
- Ring-gear and pinion
- Throttle Body size what is to big?
- looking to turbo your h22?
- Greddy Oil Filter Sensor Attachment. What fitting to use?
- quick question about walbro fuel pumps....
- fuel pump
- Motor Mount Injection - What Do You Use? *to stiffen stock mounts*
- ls/vtec turbo questions
- Downpipe cutout idea *Feedback needed*
- B18C5 Turbo Build-Up Question
- How much Psi can my D15b2 handle.
- d series setups
- My DIY turbo project. 93civic hatch cx with Gsr swap coming along slowly..
- First time at track
- turbo rebuild questions...Garrett
- I need some setup input
- Need Some Hose Help!!!
- Greddy Turbo Timer / HKS Turbo Timer installs... neither work
- any way to re-calibrate a boost guage
- how much hp are stock b16 rods good too?
- i need some help on a quad stage boost controller from turboxs
- Going turbo. Running 9psi. 2.25 exhaust to small?
- Limit on Pressure Plate wear, ACT XTPP
- CP Ring Gap
- MAD GH3Y 3 bar issues, need help plz
- Think I Blew My Head Gasket
- No Cat....hmm..police?
- NINJA!! NINJA!! NINJA!! (almost)
- I'm stuck on what motor to put in....
- someone straighten this out for me
- AEM, boost control, tial 11.6psi spring.......
- Boost problem
- Anyone See the endyn fabricated manifolds
- Need A Part
- Still having CEL issues with Inline Pro Map Defender
- 2.1 gsr whats rev limit
- Dsm O2 housing on a 4g civic.
- I did a search, no results. Soaking a turbo in oil before install.
- z10 catch can source
- SSAutoch**me: T3 .42/.48 Turbo - how much HP?
- Low Comp #'s in #1 cylinger........ TECHS needed i have done all already!
- quick wastegate spring ?
- Where to place o2 sensor w/ cutout
- What's the difference between the different generation intercooler?
- help map bypass question
- Nitrous'ed B18C1
- expletive- replacing a headgasket and i have no idea what bore or thickness the current one is
- Crome or Uberdata? and what do i need
- opinions on my new setup
- a few pics of the progress
- any difference between 4 bolt and 5 bolt turbine
- Tuning Turbo after install - How much?
- D16A3 turbo
- something wrong with my missing link?
- Center section question
- Engine Builders... New Rings, Self Hone - What to use? 3 stone or dingleberry?
- MAP sensor reading for JRSC and other Uberdata questions
- vac lines
- lots of oil in my spark plug ???
- cat...yes or no....exhaust?
- High compression plus boost
- for you guys running pusher fans, what are you using?
- searched around: ACL bearings
- Exedy Twin Clutch Flywheel bolts for b-series????
- endyn intake manifold?
- AEM Help: Timing advances from 4,000RPM up
- coolant spraying from overflow tank?
- oil feed lines how long is too long??
- car boggin at low rpm, maybe skips tooth on timing belt?
- Installing Blitz Turbo Timer
- Anyone in South Florida know where i can get piston rings?
- 2 port sizes on Endyn Catch Can
- ic's on HT market place,
- gsr or ls/vtec
- Difference in I rods and H rods?
- boosting problems
- b16a3 turbo setup- switched turbos, now smoke from breather at idle
- I'm looking for some rough dimensions...T3/T4E
- blue box install ?s on a 93 dx coupe wit d16z6 swap PLEASE HELPPPPP
- Uberdata tuners in Wisconsin
- VAFC 2.5 bar map settings
- CarbonFiber H22 Manifold update
- B16A compression ratio recomendations
- anybody broke a sleeve with a block guard?
- buying weld on bung for valve cover breather, what material do I get?
- Turbo'ed Daily Driver?
- turbo efficincy maps
- Engine Choice - B16a2 or Busted B18c4
- hondata S300 who has it?
- How long has your motor lasted?
- What does ___ step colder actually mean?
- Question, regauding coolant/fittings.. Barb to AN (water cooling turbo)
- fixing to turbo my delsol have a ?
- turbo kit
- How tight (torque specs) should I tighten my 1/8 NPT fittings? -3an fittings?
- Is the higher cost really beneficiall?
- mitsubishi colt turbo kits?
- m22 on spray?
- Is this turbo set up a good deal?
- **GSR boost** *need help turbo prep install*
- shit happens
- how small of a FMIC do they sell?
- VAFC compatible with greddy kit?
- GE ls/vtec dowel pin location **PICS**
- Tial blow off valve
- 11.8sec del sol - daily driven - pump gas - open diff
- revving to 9500k on a b16 cable tranny...what will i end in the 1/4 ?
- input on fpr needed or not?
- Hey Please need some opinions
- T3T4 on an HF Mani?
- why does stainless rust anyways?
- Quick question...is the GSR crank timing belt gear, the same as the B16?
- Fast-turbo
- I'm a braggart. Pics inside. (GT42R)
- white smoke coming out from my new build
- lost motion assemblies question ?
- flywheel and boost
- D series boost?
- fuel pressure.....
- zex direct port jet question>
- some general,yet important questions..
- h22 direct port installation
- Main Head studs?
- 10 sec NOS setup?...
- ATTN: ALL WHO ARE BOOSTED... NEED YOUR OPINIONS
- WRX 440cc injectors.....what clips??
- Apexi boost kit install
- whats a decent priced clutch for about 300-350 whp turbo b18c??? (search fuction aint workin!)
- people running 750cc's.....
- What turbo do I need?
- Apexi AFC signals - AFC gurus, please read ;)
- Building 10 second FI engine.
- Is it worth it
- B Series plugs in a D series Q?
- ATTENTION ALL TURBO LOVERS !!!!! FAKE APEXI TURBO TIMERS !!!! BEWARE!!!
- Intake manifold for turbo
- jackson racing pulley upgrade b16
- Oil for Integra Turbo?
- Size? Greddy TDO4H-15G vs Garrett T25
- Peice together my on oil lines or buy a kit?
- gt30r .82 a/r pump gas?
- Trouble with DA downpipe how did u do it??
- Throwing random code 68...sound like my ecu is messed up
- cat flange
- Trying to find one of those wastegate actuator exhaust cutouts...
- v-afc hack,need to know more???????
- anyone have 3" complete muffler piping for sale with a cat?
- F22 boost?
- suicide?
- Need Turbo Question for a friend!!!
- SOHC 374 wheel power@23lbs of boost
- Is Intercooler piping 92-95 Civic same as +96???
- not seeing boost...
- 24psi + GT35e + stock sleeves =....... (sleevable?)
- obd2a -> obd1 diy conversion question
- SOHC Numbers on stock sleeves?
- Finally started new motor - PROBLEMS!!!!!!
- i've searched, turbo setup question
- Downpipe issues resolved
- MSD Wondow Switch 4 Nitrous - which one?
- When do you 18G guys hit full boost
- Question: If I got a Chipped P28 and Got My hondata s200B do i need to swap anything out of the ecu?
- first time in to do fi need help!
- 16g on gsr
- Custom Fabbing 3inch downpipe Help
- Finally Blew up!!!!!!! YesSS~!!
- How did you DC owners do your FMIC with AC? Fans, AC lines, etc.
- Running gas/c16
- Turbo covered in oil? PCV problems..
- Is this a safe nitrous setup?
- HELP!!! boost to no boost after parking it!
- headgasket leak?
- Turbo Size?
- Blowing out spark @26 psi and .023 gap???
- Mandrel Benders in CT HELP
- turbo zy?
- ???Thinking of spraying my car , along with BigBoost???
- broken SOHC intake manifold, whats my best bet?
- need to know if this is a good deal
- ls vtec turbo exhaust question
- WHICH INTERCOOLER?
- compression
- D16A6 with Z6 head and Apexi AX53B60-P18.
- need diagrams on traneee
- how much power can a greddy typeS bov hold?
- Rad fan CFM questions
- Which turbo for my setup?
- intercooler piping diameter matter ?
- UD vs. Crome
- tdo5 or t25??
- Maximum power output for gt35?
- Head Lifting Under Boost- Coolant overflow- how bad is it to drive like this?
- grade my sparkplugs
- Full-Race Stage II (non-AC) High/Low plots, pics [Update]
- moroso oil pan leak??
- sweet so my newly turboed car is fucked up help me diagnose the problem....
- noob... I admit it.
- info on timing for b18b turbo fully built
- d16y8 turbo ACT clutch 6 spuck?
- Question about piston
- keep the revhard manifold or trash it?
- ngk bkr7e question..
- Boosting 2000 integra...want to keep air conditioning
- Dseries Turbo Help
- Turbo Effeciency question.
- what turbo should I go with?
- oil in compressor?
- anybody running neptune have this problem?
- What turbo is this? Evans Tuning Vid
- HKS SSQV VAVLE STAYING OPEN ON LOW THROTTLE?!???!? HELP
- arp headstud problem
- drag turbo manifolds
- car runs crappy while in open loop
- Ovalization and clearances, please, need help. b16 @ 350whp.
- better pump then a walbro
- GT42R dyno..not so good but very happy.
- adjusting Map Scalars in Uberdata
- too much overlap? cammed LS
- For all the XSPower turbo haters =P
- oil return line ok?
- sleeved gsr
- build motor first starting problems
- Turbo Cams
- good clutches for a 400whp street gsr set up?
- getting tuned!
- Help me identify why my fresh turbo blew.
- day dreaming
- Turbo H23's with good numbers?
- few questions about engine rebuilding.
- which heat range(spark plugs) are you guys using... for a gsr with about 10-12 psi boost
- greddy turbo question
- Garrett T4 Turbo? opinions
- head lifting underboost, question about putting headstuds on one at time
- Hondata with p28 ecu
- Uberdata Tuners In CT
- Need help ID'ing this TURBOCHARGER T3/???????
- complete kit for $800...good buy?
- Blow Off Valve Question
- Why can't any mechanic fix my idle problem?????
- What size piping and turbo?
- What turbo Is this Help Please (pics Inside)
- wtb t3t4
- my new turbo 4/power street car
- turboing a h22
- Boosted Motors and road trips...dangerous?
- PLX R-300 now released
- Cleaning/Maintaining a Blow Off Valve? Tips?
- what do I not need (or need), And who is the best AEM tuner in DFW
