View Full Version : Forced Induction
- anyone wanna take bets?
- stock gsr clutch on greddy turbo
- Build up for moderate boost
- Greddy 360cc and 660 cc injectors on groupbuycenter.com
- Turbo????
- pics of a few usernames are in!!!!
- Should i be getting any boost in 1st gear? I only get maybe 2-3psi.. Turbo LS
- Why have an oil pressure gauge?
- Interesting evening at Moroso last nite
- Cheapest place for a JRSC?
- LS Tranny = More turbo lag?
- someone wanted to see my t60-2
- JYT guys...IHI setup on b16a
- Anyone good at guessing the trim?
- so? I love my turbo :D
- 4 rib vs 5 rib crank pulley
- Custom kit or Aftermarket kit? Turbo experts need advice
- too much stress on rods?
- High Compression Turbo with stock sleeves Question
- Flex Pipe, where to get one for cheap?
- Max boost efficiency on drag3's IC
- ~~~~How much boost on stock fuel pump???~~~~
- Happy Thanksgiving!!!
- Help Turbo or Supercharger
- AVC-R and wastegate users... LOOK
- kit question
- Thermostat and Radiator Cap
- Is a KKK k26 turbo......
- hytech manifold
- Can't boost >5psi...
- Finally Boosting
- Max bore on a ZC?????????????
- Max HP with stock fuel lines on a 91 Civic Si...
- Any info on GReddy A/F gauge?
- Endyn Supercharger
- N-tercooler
- Copper head gasket after engine build?
- Lean/Rich Gauge
- Do these EGT's sound about right?....
- Coolant issues!
- all those w/ 3" downpipe/carsond cat/thermal exhaust setup
- STOCK VS. AFTERMARKET HEADER?
- Which GMs came with 2 BAR MAPs?
- J&S INSTALL Q. NEED RESPONSE ASAP!!
- who can find some end tanks....?
- NOS set-up: What do u guys think?
- Help me please!!!..
- Please take a look!
- Chat
- 99-00 civic si VS. 99-01 integra LS drag turbo kit/????
- Even more turbo problems...please help.
- Pissing me off...
- turbo position ?
- intake manifold suggestions please!!!
- J&S Safeguard install location Q
- RC 550cc?
- Thermal question
- for you guys getting the maxrev setup or customing your own kit...
- Gunna install GReddy boost gauge....which way?
- Is my Greddy Profec B defective?
- b18c5 and c1 rod question
- FS: Hondata 4b upgrade $400 obo
- what will...
- 15psi would yield what times and traps?
- what to boost???
- Anyone run an air/water IC daily driven?
- Problems!!! Has anyone on here shimmed up the oil pump spring on turbo cars?
- to vtec or not to vtec....
- b16a turbo crx
- What Pistons for LS motor???
- drag gen 3 + xs engineering intercooler core
- Glowing turbo
- please send me all of your turbo video clips(mpeg's etc..)
- Clutch install
- hitting rev limiter with a turbo - is it bad for your engine?
- Zex Nitrous Kit
- anyone running turbo ls crane cams?
- What can go wrong with me running off the downpipe for a day or two?
- PCV valve questions
- Which wastegate?!? Tial or HKS?
- SCE Copper Pro Headgaskets?
- GReddy E-Manage : Anyone actually *used* it?? !
- JB Weld
- Aftermarket radiator with turbo kit?
- What did you do with your old motor???
- What Turbo Should I Use???
- Should I buy an Autometer Air/Fuel gauge? Sway me either way.
- trying to get a IC, can't decide on the size...
- Test-pipe Simulators are here...
- Adjusting fuel delivery for turbo without electonics..
- Hearing whistling noise at WOT
- best motor to turbo
- I think almost Blown Motor After 2 Days!!!
- NA vs Blower
- What kind of fans to use w/ aftermarket radiator like Fluidyne...
- Why is lower gearing bad for turbo?
- Hood Clearance Problems with Wastegate..this time w/pic
- burnt pistons
- J&S install quesstions (1999 SI Drag3)
- Does anyone have a DC-2 JDM front end w/Drag kit...any intercooler problems
- Questions about BOOSTING 99 Civic Si - Greddy Kit
- Just ordered my new snail, what do you think???
- blockguard?
- For those running 12s & faster
- opinions from the experienced...
- ~~~~~ WHO CAN ANSWER THIS QUESTION? ~~~~~
- 10 sec daily driving Integ.....
- Video I took today of me boosting a little...
- B18C1 Head bolted onto a B16A2 Block, Direct Fit?
- How can I tell what trim my turbo is?
- running stock fuel pump and boosting...is this ok?
- Hood clearance problems with wastegate
- Turbo Problem After Install....
- Ball bearing upgrade?
- What weight flywheel do you prefer for Turbo?
- Coolant overflow bottle.....
- What 1/4 mile times to expect with my drag gen 3 Si?????
- Question for New Jersey F/I guys.
- Anyone have a problem with GReddy EGT's not working at all?
- Question for you F/I guys....
- b18c5 turbo greedy
- Updated Pics of my li'l Sleeper...
- remove inline fue pump, upgrade intank fuel pump, which one to get?
- Oh crap! leaking oil from head gasket!!
- oil restrictor--where do I get one?
- question about the turbo.
- Plugs and Gap????????
- Drive without fuel managment???
- Personal Experience with turbo reliability?
- Got a dumb question about building motors.
- Oil return...again
- Good turns in to CRAP!
- ANYONE KNOW ABOUT T04X TURBO???
- Anyone running with the HKS EVC IV????
- exedy clutch
- Curious, about the DRAG piping
- to those with oil catch can....
- how do u know if..blown
- What kind of E.T.'s can I expect with a Drag kit?
- What kind of E.T.
- Car Weight
- size trubo for 2001 ITR?
- quick question on Greddy turbo timer...
- Gauges: Is there a difference between a Pyrometer gauge and EGT?
- greedy fmu question
- V-AFC or S-AFC???
- ohhhhhhhhhhhhh what a day!
- What next?
- Who makes Huge turbo setup???
- ETOWN!!!!!!!!!!!!!!!
- quick question about boring
- who installed their own turbo.
- Supercharger
- huahuahuahuahauahua 256 hp 181ft torque....
- anyone know this?
- Does the Drag Gen III have an atmospheric wastegate?
- Greddy turbo kit or drag III kit for a daily driven realible car
- Someone educate me....
- greddy turbo kit questions
- HKS C.A.M.P.
- anybody have a dyno plot of greddy turbo on B18C?
- Whats good EGT Guarge with PEAK HOLD???
- B20 crvtec good for FI or not?
- I think I'm screwed...any kind of permanent fix?
- wat turbo exhuast are you running
- zdyne or hondata? any big differences?
- Who is turbo and higher compression (or was)
- my downpipe broke...
- anyone have the AVCR?
- what do i need for high boost?
- JE high comp pistons
- NEED TO BUILT UP ENGINE... again.
- turbo manifolds designs
- where to find 1/2 mild steel plates ?
- outlet diamter of compressor ?
- Would tuning be possible with a V-AFC?
- Hooking up GM MAP and hav a question...
- Fuel/computer setup
- Going turbo but still want headwork, what cams to get?
- want to rebuild my 94 ls teg with 120k miles for a turbo
- JE pistons on GBC.....safe?
- i want to rebuild my 94ls with 120k miles for a turbo
- a number to AXZ tuning?
- i fixed my BOV no more annoying compressor surge
- turbo timers with peak and hold boost gauge?
- do any of you guys mees with nitromethane....
- Budget Turbo Q's
- can you guys recommend an EGT gauge/probe to me?
- Crower cams?
- plugs or gsr
- Whatcha think?
- TURBOED HONDAS IN THE RAIN
- Need quick response, no time for a search
- oil burning...next question....
- burning oil--Diagnostic Question.
- Probably another easy question...
- Best deal on Greddy Products?
- EGT TEMP
- pre-oiling/lubing new motor
- NJ SHOPS
- anyone running electric water pump on the street?
- 99-00 Civic SI DRAG 3 kit dyno
- blitz timer with boost gauge
- IDRC Finals in Palmdale CA is now going at a SPECIAL rate for Socal racers!!
- is a to4(T4) pretty big?
- anyone wanna trade blowoff valves?
- What is the best turbo to use with zc
- F/S Brand New Greddy TypeS BOV w/flange
- Jackson People???
- NGK BKR7E or NGK BCPR7ES11?
- FI Newbie: What things are included in a COMPLETE turbo kit?
- Boost with high compression....who's tried it?
- fuel line for wet nitrous kit
- Cant hold boost...boost leak????
- Eagle Specialty Forged Rods - Introductory Special!!!
- 190lt holley fuel pump anny good
- Finally, pics of my cars!
- Which manifold coatings?
- Need some quick 411
- Anyone interested?
- FuelPressure guage is acting up... what to do?
- anyone running bigger then a t3/t4?
- Where to dyno in NJ and NJ area?
- The Blue Box Unvailed!
- hondata questions
- boost level vs. different turbos
- OT: painted my block???
- need a hondata for my turbo gsr
- Need downpipe
- Another A/R Question
- nos install
- Running turbo with NO intercooler.
- CR with B20 vs B20vtec
- Overboost
- attn B18bturbo(viren) or anyone else who may know
- attn dallas people.. dyno day saturday!
- Kinda new to forced induction and probably a stupid/easy question...
- which turbo setup would be faster on a 98 civic ex coupe?
- Just look...Should I buy 310's, or no?
- problem with code 13..help
- Loss of boost. What happened? And BOV too tight?
- The difference between the Greddy GSR and LS kit??!
- F*cked up ringlands, cracked cyl sleeve #4...
- People w/ GReddy turbo timer...
- What other ways are there to up the HP w/o upping the boost?
- cruise control dont work after connecting BOV
- Did I get the right plugs?
- Used turbochargers?
- GReddy instructions online?
- what injectors?
