View Full Version : Forced Induction
- autometer air/fuel gauge
- bouncing idle
- Integra customize turbo
- Roll Cage for a 2nd gen Integra??
- modded b20 need a few suggestions on nitrous.
- going from air/fuel ratio gauge to a EGT
- I want to turbo my B18 any suggestions
- Can a stock LS engine do this...
- was wondering how to install dsm resistor box
- h22 turbo standalone
- bigger DP for d series greddy kit???
- need help on intercooler piping...
- fly wheels on boosted cars.
- intake air temp before and after intercooler
- fuel injector leaking from the injector, not the seals
- turbo 99 si ?? head gasket or not?
- Cleaning the Engine Bay With a Turbo
- Pipping for gsr or itr???
- PICS of my 3 week old setup
- help! turbo bog!!!??????????????????
- Any xtra problems/concerns/precautions w/ the coming heat?
- Help Liam! VAFC Hack with Jackson Racing Supercharger?
- what missing?
- what clucth to use?
- Stock honda wideband 02 and aem ems
- Did boost cause this? Scratches on cylinder wall.
- tBLOWBY....... HELP!!!
- turbo housing
- New motor, can it be saved??!! PLEASE HELP!!
- Who's ready for the Eagle rod clearance?
- Recovered..Integra found in silver spring, MD
- help with pricing: inlinepro t3 manifold, 70mm str tb, skunk2 gsr manifold.
- Engine has LOTS of blowby????
- smoking? could it be from the turbo?
- Help!!! Installing Drag Turbo Kit on ITR.
- A couple HOMEMADE turbo questions
- best intake manifold for FI?
- Fans kicking in too late. Water flow impediment?
- inline fuel pump reommendations?
- Junkyard Injector Question
- Drag Gen FMU/Fuel Pressure Regulator. Please Help !!
- Pic pof my melted piston
- Turbo 2000SI running RICH on Greddy blue box any options? No dyno for 800miles! HELP!!
- Chiping OBD2??????
- Guess what 4PSI on a non-intercooled B18B does (dynosheets inside)
- wastegate placement? pics, old skool DC sports mani! help.
- Converting to using a MAF sensor rather than a MAP sensor w/ the EMS
- how to recalibrate fmu?
- It hot today.. IAT running 120 F
- Which clutches chatter???
- how much boost on stock internals
- What WHP will a 2800lbs car need to go 12's?
- Is 20x8x14 Slicks a good size for a turbo car?
- Attn: H22a guys, re: sparkplugs...
- Coming to a sohc near you...
- Turbo or Supercharger???
- Pinpoint that sound........
- Drag kit question for d series
- New 1/4 mile times w/ turbo
- clutch on turboed civic
- About to order custom pistons - could someone double check me?
- Apex PowerFC. Any tuners here with experience with it.
- Oil light....
- What do you guys think of this turbo size?
- my jrsc setup...good? or no?
- Is an AVCR needed with AEM EMS? Do they work in conjunction?
- D15/16 hybrid questions
- for sale or trade
- Anyone know if this DIY fuel controller works?
- Pics of my Ghetto turbo!!!!
- Boost Spike with TiAL 35 mm wg and profec B
- Will an ls throttle body fit on my d16y8
- Do I need an FMU?
- Type R gear ratios and boost, will they mix.
- hondata tuning ? (need input)
- Where to get HKS wastegate flange gasket???
- injector resistance on DSM Blue tops ?
- Removing Blockguard
- field instuctions?
- GUYS check this out.
- D series timing belts
- can RC 550's from a b16 fit into a mr2 rail??
- How should i seal up this hole?
- i wanna put a turbo on my LS, what parts of my engine do i need to build up first?
- Is it possible to idle the car without IACV and stand alone?
- cheap turbo parts from my first gen eclipse..
- check engine code 43, and hesitation in no-boost???help!!!!
- Air/Fuel and Overheating
- Problems W/ my Oil Feed Line Fittings
- sohc turbo missing/cutting out ^5500rpm
- replacement Head gasket, to spray or not to spray:
- Eclipse non-Turbo injectors
- where can I get my turbo fixed?
- exhaust for supercharged engine
- Hondata Tuning Needed ASAP!!!
- jotech experience in an organized matter with all info
- Pics of my junkyard setup :)
- 90 degree drag inlet elbow.
- radiator...which to get?
- Tires.
- SOHC turbo gurus, Need help quick!!!
- What are the potentials of the D15B8??
- vouch for blazin
- anyone have dyno sheets after gsr cams over stock b16a cams
- MaxRev kit, do i have to remove fan?
- hondata maps in an uberteg chip?
- which turbo is better t3/t04e or t3/60-1
- Boost Bypass
- Help can;t find the link about Gsr cams in a b16A
- Does anyone have opinion's pic's or sound clips of a vortec bov
- Turbo Rebuild Kit (T3)?
- cam timing with N20...
- ... need eprom burner for hondata... ideas?... ((dont wanna spend $$$ for pocket programmer))
- how much timing retard w/80 shot.
- ... OT : how to UNCHIP ecu???
- how much HP are 370cc injectors good for??
- Arp head studs for d16z6 need help asap Need a pic of them installed
- Well, I don't think I'll be at the track this season.
- should i swap my dx tranny for a ex tranny
- quick fuel pump question
- car not boosting..why?
- Whats the best way to get mid 12's out of a boosted 5th Gen Civic EX Coupe?
- how much boost on b16a
- how to hook up BLitz DSBC type S??
- question about dsm low impedance resistor box for injectors need help
- what turbo would you h-ter's recomend for 600whp???
- Koyo radiators
- How to install a greddy type S blowoff valve?
- just got my turbo... what a surprise...
- more afc hack help
- which injectors? b16 turbo
- Turbo Prelude VTEC
- spark racing intercooler any good?
- Hondata tuning in western Canada ?
- Hondata users, Ignition Advance under boost?
- Wheelie bar pics..
- DSM exhaust manifold on B18b
- Is this a TRUE statment about Profec B and TUning?!?!
- Crower Rod Question
- how to run 15 psi on SOHC??
- Hondata Base Map
- 14b trim...anyone know the comp and exh trim?
- which viscosity of motor oil?
- Difference between JRSC GSR and type R manifold
- drag intercoolers
- built h22/h23 guys with boost....
- NGK BCP heat range 8 anyone?!
- boosted del sol having problems
- What kinda numbers does an LS turbo put down?
- hondata tuning
- build up questions. . . more boost.
- Some questions on ecu chipping, cam shafts etc
- Bad piston slap, anyone else have this?????
- BEST turbo for d16z6
- tial or turbosmart
- need someone to socket my p-75 for hondata
- whtas the better car
- mixed information about reading plugs.
- Aftermarket Exhaust Manifold Gasket for H22 ???
- How hard with DSM 450's
- what manifold, turbo, and DP should i use to keep my AC and PS
- gsr with ctr intake cam good with boost or not?
- Sell me Acl bearings
- Has any one been in a car with propane?
- will a blitz BOV for a nissan 180/240 sx work on my honda
- top psi with blue box
- fuel controller w/ stock injectors?
- so long to the turbo DA
- few questions about my turboed D15
- I need some inspiration...How long did it take to complete your buildup?
- what turbo manifolds fits a b18c civic with a turbonetics t3/t4 60-1, 4in inlet/2.5 outlet
- Were to buy custom ic piping
- NOS Sneeky Pete Kit
- Debate, Prodrive Oil Pump Gear or Stock?
- t3/t4 gerret
- what kind of tires for the rear?
- Fuel injector clearance/positioning?
- Endyn pistons + 13k mi =
- Can this flywheel be slavaged??
- My Experience with Endyn
- Everyone read and give opinion
- water temp rising with A/C on
- EK's w/ stock bumper. what size intercoolers are you running?
- Well after struggling with it for a while, SNAP!!!
- camp1320.com injector blanks
- 439whp 312tq RSX 25psi Turbo street driven on 93 oct.
- Does Tire Size affect boost pressure?? Help I'm confused..
- Everyone welcome Damon to the team!!!
- Do I need a wedge shaped adapter plate?
- question about victor x intake mani
- SMC+ not working WTF!!!!!!!! HELP
- Best way to seal oil lines??
- Resistor Box on Civic
- Another Honda video ad. This is the coolest vid I ever saw I think!
- jrsc on a b18b1....can my motor handle 8psi
- How do i take off the oil pressure sender? (did a search)
- endyn piston ring gap
- Please tell me this is TRUE !!!
- Any differences between the sc34 and sc44 aside from trim?
- Venom 400 VS. FMU
- turbonetics boost controller
- Didn't make what I wanted on the dyno, need advice on BIGGER TURBO...B16 people!
- HOme made MBC, works booooooooombb diggy!!!!
- Installing my DRAG kit, What do I need to do? Long!!
- New gearset..... maybe
- Help - Technological paper on Turbochargers
- boost drop with bigger exhaust
- Irratic boost
- Hondata tunning in South East
- Greddy E-Manage / Profec E-01 Basic Tuning Question...Calling all users
- for turbo, why tune to 12-13 a/f ratio?
- Bar and plate or tube and fin intercooler
- 70% done (new pictures)
- 9.0-1 Compression questions...
- Cylinder rings
- Bf goodrich drag radials
- stock fuel pump
- sat. 310's, resistor box?
- for people with the maxrev mani and t3t4's and hydro trannies...
- auto tranny rebuild kit, opinions and questions
- Fuel pump flow rates
- 14B + AC + DA9 Help !
- Benson's - Need phone number
- If I want to get a Turbo kit for my SOHC and decide to swap to B18C1 later....
- Blitz DD Bov and Blitz SS Bov??
- some kick ass engine setup at Ebay
- SC gsr
- no boost after 5000 rpms
- 8x24x3 core big enough for 500 whp?
- polished compressor housing --> what benefits?
- Ennis: Got me some 12s
- open deck vs closed deck (searched)
- Boost limits on the Profec B??
- Just got my re-built motor in
- GSR Radiator in 00 Turbo Si......fitment problems?
- Efficiency Range of T3/T4 Hybrid
- d16y5 exhaust manifold - what fits?
- 7 psi isnt enough.....
- Questions on strengthening a motor for turbo
- My baseline dyno, before I got turbo. =)
- looking for maxrev dealers?
- B20 VTEC turbo tuning comments
- 390whp non-IC JRSC.... details inside
- Jotech tuned:298hp @ 15 pounds(please read and give input)
- SICK boost gauge(DIY)
- Compression Gone!!!! Please Help
- only 310???
- Pre-assembling parts of a Turbo kit?
- oil drain fitting really close to my downpipe,will it melt?
- What size injectors???
