View Full Version : Forced Induction
- tial wastegate
- precision billet gt35r question
- AIT Sensor
- why?? crower stg 3 exhast cam, unknow stg intake.....
- Got the car tuned, 6262, sleeved GSR, e85
- Need Help identifying Master Power turbo!
- Dual pumps
- Turbo that dont need oil? Comp Turbo.
- Front mount manifold
- calculation for peak cylinder pressure? maybe??
- E85 setup
- Pro1's or Tuner 1's
- Where are Small & Mid Frame Garrett GT's Made?
- Can you turbo a honda civic motor? - Cobra owner asking.
- d16 jrsc questions
- Who balances turbos? Recommended turbo balance places?
- New LS turbo problem
- head lifted AGAIN wtf help
- Kenne Bell Boost-A-Pump Options
- injectors for my turbo integra
- Thinking about buying this turbo
- zex wet kit with only meth input?
- Turbo Install (Oil Catch Can, Boost control)
- Precision PT6765 Billet manifold question ?
- b16 jrsc with meth injection
- oil catch can for d15b7 turbo setup...?
- GSR turbo- leaking oil into charge piping , have some questions.
- Bw S362 power potential
- can i use these pistons?
- gsr turbo!
- What turbo for a stock motor 99 SI?
- Serious Expertise Only
- New 'Home Brew' EBC multigauge
- sohc turbo build help
- ugh (precision issues)
- Wiseco 6542 Piston help
- 6265 Turbo
- decided to go lsvtec on stock shortblock. what needed?
- 98 honda civic ex turbo
- crank, rods and pistons
- Boost d16y7?
- How laggy is it going to be, .60trim +9:1 comp.
- inline pro mani, what bolts for wg and turbo?
- the end all greddy 18G downpipe dilemma thread.
- Building nitrous short block
- Stepping the block and O-ringing
- Who sleeved this block
- Code 16???
- GSR Block with Type R Head: 60-1 Turbo - E85 Dyno Tune
- JRSC silencer?
- jrsc h22sc on a f22b2 head
- How many of you balance the rotating assembly???
- Bosch ev14 O ring injector question
- OBX turbo manifold
- using an adapter flange hurt performance
- 97 dx coupe with b20 turbo questions about my 93 gsr head fitting it..and turbo quest
- I need help guys
- piston ring clocking
- BAD gas mileage LS TURBO
- Building motor for boost
- ID injectors over FIC ones?
- hondata ecu for turbo 94+ b20 integra
- Best way to go about the GSR manifold with boost
- SOHC TURBO BUILD
- My complete turbo EF build from start to finish
- quick AEM Tru Boost question
- so who is running a holset hx30
- reverse my chipped ECU?
- 81mm head gaskit on 83mm bore
- fuel pressure gauge in filter
- NGK BKr7E #6097 discontinued
- Jim Elkins Motor
- B&m fuel pressure gauge line split
- 2.5 inch exhaust housing to 3 inch downpipe restrictive?
- cracked turbo manifold...fixable?
- High HP setups, girdle or no girdle??
- too many miles?
- Best 70mm TB, what are you using???
- inline pro manifold and downpipe question
- Virgin 89 ef turbo build
- M62 bearings
- revhard or victor X???
- skunk2 or bc
- my integra build
- my log is better than your log
- Civic has turbo issues !
- Fuel lines mounting (an lines)
- need help installing turbo on b16a1 in a 97 civic ex
- Piston to wall Clearance
- What to expect with this D series?
- 4"
- Another satisfied STC customer; Reaper Results Thread
- Need help with a tune plz neptune rtp
- Turbo bearing clearance measurements
- Turbo F22B2 build "Maybe??"
- Precision Billet 5857 v-band flange size???
- Precision 780cc injectors / Resistor box +AEM EMS
- K24a2: AFI Turbo Kit - Pump Gas Dyno Tune
- how do skunk 2 stage 2 turbo camshafts perform with 20+ psi
- need a hy35 downpipe gasket
- b16 all motor nitrous. what pistons to go with?
- Rod bolt stretch guage
- Major issues. Car won't rev past 4800 under load. long list.
- Which sleeves
- New to jdm , What one?
- Why INNOVATE has such a bad name? ILL TELL YOU WHY!!!
- Daniel's Laskey build Church Tuned Daily Beater! 400whp
- From Bama to Denve.r Retune?
- quick answer needed asap! will this DP work?
- B18B1 5PSI Turbo Check Engine Light Issue
- h22 turbo build
- true 3 inch twin loop?
- how can i boost my single cam...
- Help. Turbonectics t3t4 spec
- d16 turbo oil leak
- ..which cams/cam gears to use? b18b1.
- Sleeved block... Two options... Need opinions
- P0108 code after cold start?
- need some newb info on turbos
- what size catch can???oil cooler??
- calling all daily drivers, how long have you had em?
- TT lambo
- Will my LS Setup make 350 plus? PLEASE HELP!!
- pte 6265
- Good quality manifolds and where to buy?
- sealed power valve springs
- D16z6 headgasket..but which size??
- Need intake advice on my d16 turbo
- Forged Pistons for Build
- spool up diffrences in precision .64 from.82
- Check engine light at high revs in 3rd
- darton flanged sleeves
- Helpp!! b20v turbo what pistons to run
- flipped my car back to na and am having an odd issue
- how boost really works
- Ef civic GS-R with jackson supercharger
- t3/t4 Rebuild questions
- Advice for LS turbo
- Will i make atleast 350hp?
- B18C1 Nitrous Build... Am I Forgetting Something?
- bosch. fuel pump
- Pistons
- Looking for advice...Turbo LS/VTEC
- Greddy EGT gauge probe
- I have H22 questions...
- Best supercharger for a 06+ civic si?
- Godspeed Ram horn luck?
- Duende's new build- The hunt for 600whp+/DC2
- oil from mani
- Bay Area CA: $150 to whoever helps me install my turbo kit!
- greddy 18G, screw this elbow and DP..HELP!
- Poorman R Block Setup Suggestions
- Need some advice...rhc7 LS/VTEC
- any options here? vband to t3
- Exhaust 3" to 2.5" to 3" need quick answer!
- Garrett 4" and 4.5" Int Core Question
- 90 civic gsr with jackson supercharger???
- B18C5 ITB's + Super Charger Combination
- b18a build help?
- Need help identifying turbo... Precision stamp
- injectors?
- starting prob
- wat oil on new turbo break-in
- boost gauge mounting 96-00 civic
- 95 civic turbo smokes ...HELP???
- stock itr with 50 trim, psi and whp
- Torco UL Accelerator
- boost creep fix
- 5 bolt flange question
- 7.5:1 to 10:1 compression noticable performance difference?
- difference of t3 and t4
- Turbocharging an H22a vs..
- what do u think about lsv boosted?
- LS Booste Intake Mani and Turbo Mani Sugg..
- Wideband problems Please help
- new turbo help
- Turbo EK wont pass smog
- Rods limit on LS motor? Can you change them without pulling motor?
- d16y8 turbo help
- intercooler sizing
- injectors and lsd
- New too jap
- Seals go out?
- Valvetrain - Spring Valve Cam Recommendation
- jackson racing SC question
- wtb turbo kit.
- turbo kit help?
- 3" muffler options?
- HELP huge boost problem
- custom turbo manifold
- LS vtec turbo
- free flow dual exhaust
- innovative mounts and boost
- My LS-T build questions. Advice welcomed
- Do I need another tune? B16 nitrous 75 wet shot
- Noob questions, OK a few questions, need help to ID this!
- E85+ 750cc injectors= ?
- Blown turbo help!?
- Nitrous with Turbo (Anyone??)
- hallman pro MBC
- 3" piping approriate for setup?
- Need Helping Identifying Kits. Need To Choice
- meth injection with nitrous
- map sensor b-series
- Please help
- Anybody had any experience with Outlaw Engineering's Thermal Spacers?
- DA9 ls turbo build
- advice on hooking up my catch can
- Finally pulled the trigger, Turbo build, advice is welcome
- Garrett T3/T4 rebuild questions
- breaking in rebuilt turbo d series
- GT3076R/.63 to GTX3071R/.82
- Boosted B18 - Wont Rev past 3-4k
- Tuning ??
- ARP Head Studs Torque
- Precision 5857 BB... Billet or not?
- will this jerry rig work
- What is better High or Low Fuel pressure?
- What Kind of injectors to get?
- Diesel Fuel
- heat wrap - yay or nay?
- Anyone ever use this guy Turbo O?
- built gsr 17psi 355hp/375tq
- T3/t4 down pipe bolts
- ARP flywheel and clutch hardware or OEM?
- Intercooler Pipe Routing Question
- wastegate dump tube length
- Evo 510cc injectors in d15b vtec...
- d16z6 boosted build. advice?. input?
- Ryguy's New Turbo Build
- 300 whp with full size radiator, PS , and AC
- Ek turbo Help please
- Return Line Size for SC61
- My first build! B18c1 Turbo!
- blew it up ... rebuild questions
- What can you tell me about CAT rods???
- Kinked return line+ light white smoke from exhaust after sitting on idle??
- Theoretical Build LS-Vtec
- Turbo Rotating Clamp. Turbonetics t3/t04e
- D16 Turbo???
- Question regarding 4032 pistons...
- b20 pistons
- 1000cc injectors vitara
- H22- Idles and then goes lean and dies..wtf?
- New Member here
- Outlaw/Sfwd 8 Cars Turbo?
- what flex pipe design should I use?
- Sleeving block
