View Full Version : Forced Induction
- D16 / D15 TURBO HEADERS <~~~~~~~~~~~~~~~~~~~~~
- Rank1Racing Manifolds?
- How important is a oilcooler?
- Inline Fuel Pump: How to tell if it's working???
- Boost drops after hitting VTEC ------ why? Dyno plot
- What next?
- Twin Turbo?
- 2000 civic runnin rich pls help asap
- Help on building B20/Vtech for Turbo
- safc settings
- throttle body/charge pipe size vs. power
- need help in miami getting car running (shop or person)
- Wastegate rubbing
- Turbo problem
- Whats the Oil Pressure size of a Garret T25
- Boosting the LX motor (D15B7)
- BAD NIGHT FOR ME.... blew a rad hose... n im wondering??????
- AFC with 450's and Lean A/R Ratio
- buddy club cam and nitrous
- MSD Digital 7 Help!!!
- what cams are you running ?
- Still looking for Las Vegas Honda tuner!!
- retard timing vs. high octane
- Are all 92-95 civic turbos kits gonna fit?
- Blox or Skunk2 intake manifold?
- Las Vegas tuners????????
- this is what happens when you buy obx turbo manifold (56k beware)
- ACVR wiring help.
- T3-T4 Hybrid, V-AFC, B18C5...Which engine control unit???
- Missing link from RSX fit civic?
- HKS type-0 vs. Greddy full auto timers
- anybody have experience with cheapturbolines.com products?
- storker turbo motor b18/b20
- bad idle on turbo lude
- where to go in midwest for emanage tuning?
- 88-91 EF, Fluidyne rad and Full-race or Lovefab manifold???
- anyone using blowzilla turbo?
- Oil return line question
- Thread Sizing
- Interesting article about exhaust sizing
- Proper intercooler piping size
- supercharge a LS
- my mani
- who in NY chips ecus
- buying blaster coil and cap
- I NEED to know where the hoses on the back of this block (B18C) goes...
- upgrading turbo housing
- *Want to upgrade turbo... What do you guys recommend???*
- Manifold opinions
- new to boost
- does a turbo make your exhaust more quiet?
- 310 injectors with fmu @ 7lbs??
- BUILDING LONGBLOCK 4 BOOST !!!advice appreciated!!! GSR
- Pic/Diagram request. Coolant lines T to the turbo
- which kit will make more power for my ls apexi sohc kit or greddy 18g?
- Saturated vs. peak/hold injectors?
- RC 440's for JRSC with 10lbs?
- 2" diameter downpipe too small?
- high compression & Nitrous??????
- Tuning question
- Stock B16a Boosted???
- is this a good fmic please look
- exhaust gasket question
- new johnnyracecar.com intercoolers
- Internal VS External Wastegate which one and why?
- oil pump gear question??????
- Chipped JE pistons
- Help tuning my set-up!!
- rc 310 injectors enough for 8pounds on b18c1
- want to turbo..
- reading headgasket.
- Really high and climbing idle after turbo install, HELP PLZ
- Golden Eagle or Race Engineering Block Guard?
- question for people with AEBS blocks.
- What Turbo is Right for me? :)
- Question about sleeves?
- just bought aem ems and feel I've stepped in over my head
- anyone running a pusher "and" puller fan on your radiator?
- Need some help - These guys think they know about forced induction!
- places to buy bolt-ons?
- Tuning AVCR on a Turbo RSX
- Hondata install ?
- What intercooler to use??
- which injectors for JRSC GSR?
- Is there oil pressure when turning over a new engine?
- Sleeves flex under boost?
- injector question: can i run Ford specific injectors in my Honda?
- SSAutoChrome turbo manifolds/products any good?
- New to FI, D17 questions:
- Bone stock motor with FI?
- Clutch lovers!
- aem Uego o2 guys.. HELP
- Is a 3-puck exedy clutch a bad choice for my power…301whp and 255wtq?
- NX Mainline Kit?
- TurboXS RFL Flange...
- turbo and mani that will keep ac on del sol
- help finding the perfect turbo manifold
- AEM EMS?? Blowing Coil Drivers Common?
- SOHC t3/t04 what size trim???
- johhnyrace car intercooler pics?
- Nitrous Jet Question...
- Sorry for being a dick
- Inline Pump: REMOVE CHECK VALVE??
- What type of clutch?
- Where can I get a new T3 60 Trim?
- engine management
- opinion on srp pistons.
- What would make the more TQ?
- Searched Hard-core: SC61 Worries on stock LS
- How much bigger is the .70 A/R housing than the .60 A/R housing?
- No difference between 8lbs and 14lbs boost!
- Which Turbo Setup
- direct port nitrous Installation
- fluidyne problem overheating??
- SOHC OBX Turbo Manifold any good?
- FMU question + vacuum?
- T3 Turbo Compressor housing gasket
- hondata or aem??
- Loose Turbo?
- any great uber tuners around richmond va
- AFC-HACK <--How many of you are running it?
- Fuel Needed For 12psi?
- HELP!!! A little oil on head gasket while torquing down head...will it hurt my motor later on?
- Whats the Powerfullest three b16a turbo engine?
- video inside
- What do you think about my turbo build up
- There is no induction in the force of production in boost sensation.
- is overheating normal after installing turbo?
- FMIC piping question...DC into EK
- Will a forced induction civic pass emissions?
- Custom downpipe and exhaust questions...
- Searched like hell: Stock LS/VTEC Turbo
- Is a SC61 compressor housing bigger then a SC50?
- Injector size needed for 500whp
- D-SERIES NINJA's!! SC34 .48 vs .63 help me choose!!
- NGK 3330 spark plugs
- best tranny 4 boost?
- Modified EG 2/3dr front bumper to show top of intercooler - any pics?
- FMU disc size?
- whick manual boost controller to use?
- Diagnosing What The Problem Is...Turbo, Headgasket, Boost Controller?????
- GT30R vs SC34 vs GT32E
- manifold kits
- wierd clutch issues...
- how much hp will the honda ignition take before it starts to break up?
- which willem??
- DP Question
- Can everyone with a turbo LS post their Dyno and Or Turbo Setup here!
- Need input, buying tomorrow
- injectors
- Turbo install hardware...
- zc turbo-setup
- First Trip to the Drag Strip
- Greddy Kit on a 94 dx
- Supercharged H22A project, what mods preclude this
- Crack a liner. Now what
- Which turbo?
- Oh freaking great...bolts are missing from my turbo
- where is the full line on the oil pan?
- Haltech plugin' play for OBDII honda
- oil between DP and turbo
- KKK turbo on d16z6
- Running some problems
- Emissions legal turbo?? heck yeah! check out these results!
- T25 turbo.........parts interchangeable?????
- hack setting
- Oil Return line question
- questions about my new garret t3
- is it bad to have my BOV vacuum hooked to my compressor nipple!
- IHI RHB5
- want to build motor to run 12-14 psi rods and pistons good enough?
- headgasket question????
- Questions regarding a replacement motor in my hatch? Turbo ls/vtech blown
- Uberdata help
- TURBO KIT FOR CRX ZC DOCH
- Track Numbers on Turbo GSR Hatch, w/twist....
- Lsvtec with 95mm scat crankshaft?
- Bad idle - could it be a bad O2 sensor?
- stutter box...
- Looking at a used JRSC, what should i look out for?
- hondata question
- nitrous... is this worth it?
- Is my oil return line safe?
- tunning help
- Weird overboosting problem
- FS: Turbonetics T3 60-1
- Got questions installing an inline fuel pump
- Legit?
- b16 + t3/t4?
- darton mid sleeve question?
- whats easier to tune? vtec or non vtec engines?
- Inline pro manifold fit ALL B-Series heads??
- SAFC or VAFC or BOTH????
- D series turbo, better than b series??
- how many of u turbo-d's run stock fuel pump w/dsm 450s
- ONE Offical way to setup up your Alarm+Turbo Timer
- Anyone strip threads on exhaust housing?
- Side Effects from using Full Throttle Launch / Two Step Limiter?
- My sweet azz INTERCOOLER !!!
- 9:9:1 comp D and ihi rhb5?
- Maifold?
- CTR cams on GSR Turbo
- Anybody Reached 300whp on the 18G greddy Turbo?
- Problem with JRSC?
- D15Z1 Compatibility
- flywheels flywheels , what the hell to get.
- cylinder head swap
- JACKSON RACING FMU INSTALL (WHICH IS INLET AND WHICH IS OUTLET)?
- The Two LS heads... (tried search)
- 17psi on stock block F23 w/ a t3/t4b
- Dreamin' of turbo
- AVCR
- Oil in Compressor of Turbo. Help. Suggestions?
- does anybody cam there turbo hondas?
- well just as i thought ...
- Still confused about the PCV catchcan thing
- WTF? Spark Plug Help!
- How much boost can i run on a stock h22 block?
- Turbo GSR CRX
- I searched...What kinda numbers are you making with ur t3/t04e?
- turbo install: coolant resivoir in the way
- blew up my ls turbo,time for ls vtec turbo
- red top rx7 injectors....who is using them.
- Uberdata experts, read here, j1 jumper questoin
- finally made it to the track, time slips inside!!!!!!
- IS IT POSSIBLE? keep ac with sc50
- Hotrex's SOHC-T dyno sheets
- Cant get my boost to hold 14psi???
- Uberdata Website? Down?
- 310cc injectors fine? Or get some 440cc?
- please help, no compression in cyl 3 or 4, what do i do?
- Forcing/Maintaining Open Loop Operation
- Does anyone use thier tilton twin disk for daily driving? 1st day of driving w/ it feed back.
- manifold performance??
- ls boost/ what turbo
- Most efficient SMIC?
- supercharger lube question(jrsc specifically)
- anyone running srp pistons in their FI setup?
- Quality Manifolds?
- K&N filter best price???
- whats good...forced induction gurus please help
- Seafoamed a turbo car and.................
- b20 turbo
- will the HKS B series T25 manifold work with eclipse turbo??
- Ntrous Express NXL questions?
- Better Turbo for b18C1?
- turbo kit for LS vs. GSR?
- which fmu for d16z6
- Turbine positioning
- Greddy 60mm EGT install problem.....
