View Full Version : Forced Induction
- FASTEST SPOOL ?
- Full-Race bushing style GT40 variant...?
- PT61?
- Exhaust manifold gasket leak?
- Compressor Maps 101:
- getting Integra built for spring, what is a good combo of parts/brands for rebuilding bottom end?
- dart block build up what else do i need
- need help to find manifold....
- sea foam on a turbo car?
- b20b turbo (not really a turbo guy)
- Driving 5 hours on a hondata basemap, bad idea?
- boring/porting out turbo outlet
- What trim is this? *dyno inside
- Inline Pro or Spoolin Performance turbo manifolds.....which one is more reliable????
- rev rods
- o2 sensors with race gas help!!!
- My list look good for my goal of 375-400 whp
- who does rebuilds in orlando?
- Break in new engine in winter?
- is my t3-60-1 water cooled
- precision BB turbos
- Boost Controller Solenoid Clicking!!!
- ECU already socketed, is it ready for datalogging???
- Help!!! GSR tranny code
- Is this too good to be true??
- how can u tell if ur turbo is a t4?
- Couple of questions regarding my setup
- O2 voltage dropping? am i going lean please help!
- Any one have a low boost turbo set up?
- turbo h22 del sol help please!!!
- slightly off topic.....best thing i have EVER seen though
- turboelements.com manifold
- What Daily driver manifold, did many hours of research still cant decide. Looking for owner experien
- need help? i wanna install turbo my self
- my video
- Best prices on Exedy twin disk?
- turbo ROUGH at cruising speed HELP!
- any reputable shops in shops in norcal
- LS vtec turbo build,custom valve train,need advice.
- westcoast-turbo.com & turbo elements.com feedback info
- rebuilding a b18a1
- What Turbo?
- Finally Ran the Car (video inside)
- ANY Tube manifold CRX
- SC61 or T3/T67 for a new turbo?
- Estimation of power please
- Running coolant lines on a gt40r / Where did you get the fittings???
- Tranny modifications for high HP FI
- Westcoast-turbo.com?
- Dynoed b18c w/ stock sleeves Saturday
- Have a few questions about my new motor!
- Shooting for 800whp...which fuel pump???
- clutch selection
- 99 Turbo GSR exhaust question.....
- throttle body on turbocharged car
- MASE touring the Gulf Coast...
- my down pipe
- My B20 Block has arrived!! Sleeving woes. Any help would be appreciated
- now that im turbo, i notice my oil becomes very thin and smells of gas after about 1000 miles
- Missing link on a LS Turbo
- d16 greddy kit question
- Anyone running a 3" downpipe on a Greddy kit?
- Could this be why iam getting to much oil int the turbo??
- Dare I ask? SS Autochrome!???
- NX Ntercooler worth it?
- Junking Emanage for Crome I finally woke up!!! questions inside
- has anybody used aluminum rods (bme) on a boosted b-series
- Full-Race manifold = ticked off dipstick/ Any suggestions on replacement?
- LS turbo what else do I need???? help.........
- B16A vs B18C1 vs B18B vs B20B vs D16Z6
- Does a 3" exhaust really make that much of a difference?
- anyone buy from west coast
- The project I’ve been work’n since Sep (56k get a book)
- Turbo LS need imput on turbo selection help pls.
- so im finally going turbo... pick the turbo thats best for me..
- Need a tip on how to remove rod caps..
- top speed off a b16a1 with +-350 pk??
- engine running wierd?
- ACT or Exedy for D-series Ninja...
- Dyno sheet GT35R 1.06 ar set-up
- question!
- Post up your big nitrous honda !!! Searched !!!
- sound from a greddy BOV Type R
- Where can I find plug for AEM 3.5 map sensor?
- rsx turbo
- Spec differences between Full-race GT35R and GT3567R
- can someone take some measurments for me on a spare head?
- help cant find any boost.
- how will my na cams do with turbo help !!!!!!
- Dyno Problem!!
- Do you turbo guys have this problem too?
- Rebuilt Turbos
- Newb Turbo Question
- EFI / Electrical Problem(s)
- Post pics of your Aeromotive FPR setup!
- Boost controller or wastegate?
- GT67/TO4R Compressor Wheel part number .
- Turbo mani, driver side cold? or hot?
- what clutch for my set up
- For turbo h22, block guard or sleeves??
- Good deal on turbo kit?
- help with 400hp turbo setup
- Valvetrain
- Question relating to JRSC?????????????????????????????????????????????? ??
- gt35r w/ a/c
- Is it possible to buy a new exhaust housing?
- tuners in RHODE ISLAND
- Boost Problem
- Exhaust manifold too hot to get painted?!
- dyno tuning problems...
- incase that i cand mod a TRANNY (b-serise) ??
- d16 turbo.. no boost
- Spool up compare
- Injector design and response time.
- 4000 integra
- T3/T67 Turbo acting funny...
- 3inch exhaust?
- how are my plugs?
- Need one set of Wiseco Piston Rings/ 81.5mm bore
- Black Annodizing intercoolers. Who is a good source for the money???
- Will this turbo support my goal of ~300whp??? Need to know soon....going to buy!!
- aftermarket block gridle
- B16A2 or B16A2 head and b20 block for boost ?
- Typical cost of turbo installation and tune?
- Newbie Turbo D-series questions :D
- 2000 SI valve adjustment
- W-O-W! Just got pics of my custom Mani/DP from Silly Sohc - and DANG!
- HELP i cant decide
- ITR CAMS w/Turbo..Good HP#s or Not.??
- What size Wastegate for turbo integra GSR??
- Exedy Stg1 organic clutch for boosted D series?
- Turbo B16 Not Making Power
- Would you trade a JRSC for a almost complete turbo DIY kit?
- where to get good gasket?!
- S2000 injectors...
- Injector Help
- Stone Racing Wastegate.......anyone using it??
- Dyno: Boosted B16
- AEM Peak & Hold Injector Drive
- anyone runing skunk stage 2 na cams??
- JE pistons and boost?
- Rebuilding for F/I
- Boosted B20vtec-Dsm Injectors, cars chokin runing stock ecu??
- turbo build help??????? 10 questions
- injector experts please enter-injectors sizing for HP goals and fuel pressure and how they are relat
- Intercooler size for 350 whp...
- Newbie Question I have Searched GT28RS?
- What BOV is this...
- Wastegate placment
- b18c1 nos setup
- really cold weather and boost pressure or drastic weather change affecting boost?
- ***Video*** JRSC 95 GSR compilation
- NEED help with d16 NOS
- $1020 for a rebuilt t4 garett turbo, good deal or no?
- what are your opinions on this kit???
- for those who have not seen this
- 3inch Flex Pipe??
- head gasket??????
- can a turbo honda road race?
- turbo VS turbo
- vtec problem
- Turbo LS/Vtec * Oil cooler, or no ???
- Studs instead of bolts on the exhaust housing to hold downpipe on. Anyone did this before?
- OBD II Tuning options
- OBD-2 to OBD-1
- help please
- The Ultimate B-series Intake Manifold (ENDYN)
- is this a good deal?
- smoke from valve cover breather hole..
- are my bearing to loose
- Where to get Cometic H.G. local to Ga?
- What part did you give the most thought to before purchasing...
- Are precision turbo injectors direct replacement
- Stock oil cooling
- my integra build
- turbo burnin oil, white smoke
- How easy is it to run the piping in this topmount setup.
- Need help moddding a B16 JR supercharger for my B20
- anyone making homemade top mount manifolds?
- 155lph pump
- what injectors need a resistor box
- Opinons???
- boost on highway question
- Best D-series tranny?
- ***DC Intercooler options...
- EG Hatch...H22 on Boost
- For Green Tops vs Precision injectors. Same dimensions?
- Clutch & Flywheel set-up for my hatch?????
- Any actually have any emperical evidence showing a sheet metal intake actually making power on a tur
- Precision turbo with vband
- sknuk 2 turbo grind camshaft?
- eagle rods recal?
- Mass Coolent in Oil - New Headstuds/gasket - 185compression??? help!
- new engine, headgasket blown already ?? please help ...
- GSR GREDDY kit on my EG
- sc44 vs sc61... Which is better for me?
- Question is should i turbo an LS- V-TEC
- turbo problem...
- need help asap
- Just wanted to see what You 400WHP gsr guys are running
- custom turbo set up
- Anyone know where I could pick up a VAFC 1?
- B-series mitsu manifold
- What is the best all in one boost control, fuel management system?
- 550 WHP Goal with 2.1
- How many people are using a restricter valve??
- cel code 45 after fuel pump install???
- Ignitor Bypass with msd
- 1600cc injectors on a daily driver? Bad Idea?
- intercooler sucking up water
- Port match exhaust housing to manifold flange?
- @ 150mph gauge lights come/car dies
- which crank is better for boost?
- How to make MAP sensor see boost with JRSC and Hondata
- Multiple oil line T's
- RC Injectors in Greddy Turbo Kit Alternatives
- greddy td04-h
- stock jdm itr turbo
- 94 teg getting built have some ???????s
- skunk 2 intake manifold worth it?
- REV HARD KIT owners....What are you guys doin for dump tubes???
- got the car now need advice for my ls/vtec engine.
- need help please wastegate trouble
- Turbocharged b16a1 engine with Nitrous Yes or No?
- can i really get a turbo setup for under 2500 ?
- Bigger Fuel rail yes or no?
- JDM d15b7 and Vitaras?
- KMS Pistons for 300-325 whp F22
- help with boost level
- Dual Forced Induction Question. Supercharger and Nitrous.
- Anybody wrap their exhaust housing?
- 1.6 vs. 1.8 spool time
- B20vtec Turbo> idles funny!!! please help!!
- t4 exhaust flange pattern?
- JRSC D15Mini-me on stock boost
- New Motor Issues...
- BOV - TURBO XS RFL KnockOff, Does This Horn Look Right? WIll It Work? Loud?
- Update on my old school fuel management project.....eeek!!
- How much oil is coming out of the oil feed line and how fast? and if my return is the same size as t
- turbo help
- Having a problem with my Hondata s300
- GT35R vs GT3567R .
- power differance between cat vs no cat
- LS/Vtec with Forged Pistons... help
- How much boost on stock sleeves?
- Rod bearing clearance measuring question
- Exhaust Header Wrap - How Do You Secure It? Hose Clamps Alright?
- 180* Bend After Compressor Housing, EFECIENT?
- turbo problems
- Oil Breather Box (Black box on back of block)
