View Full Version : Forced Induction
- turbo doesnt seem to spin easily??
- D16z6: 50 trim t3/t4 - Built bottom end - Pump Gas Dyno Tune
- simple turbo ???? pls
- D15b7 turbo build
- H2B Nitrous?
- B16 turbo
- turbo oil return through dipstick?
- 2.0 fully built gsr break in
- vitara pistons
- Louder than normal skunk2 valvetrain
- Do all BB turbos sound like this
- vacuum pressure change with vacuum manifold
- POS ebay kit+z6=del slo
- Siemens Deka 750cc driveability?
- B16-T Questions.... Psi.... Slicks....
- What happened to my car?!
- 2000 ITR turbo???
- Can a catch can affect your tune?
- vitara turbo crx. clutch question?
- What pistons to use in my LS/Vtec Turbo?
- Turbo help plz!!!
- Just a test
- Good H22 turbo manifold with Holset H1E turbo?
- turbo timer wont count down :(
- Catch can!!!!!!!
- 3" exhaust
- eagle i beam rod bolts question. help help
- update on my endyn vs tk race head
- Problem keeping car temp down in traffic?
- Endyn vs LHT rebuild for JRSC
- piston ring material,
- V band flange for 6765
- HELP! anybody familiar with this turbo manifold??
- D16Z6 388hp @ 24lb boost, Good or Bad???
- GSR Shredding JRSC Belt under load...
- Looking for pictures of d16 turbo with a/c
- Injector question, with pics!
- turbo idea?
- Is my Ls/vtec turbo at the right hp?
- just installed a CC twin disc...
- 550WHP NEEDING ANOTHER WALBURO 255?
- identifying my turbo
- cutting jdm dc2 bumper for intercooler..
- Need Bov Help
- B16 turbo throwing out white smoke.
- Cams?
- TB0326 volvo turbo
- Good level to set boost at
- Educate me about turbo manifolds...
- Need info on draw thru turbo kits
- 84mm B16B, Peakboost 35r top mount, 28 psi, hondata- 636 whp
- EG Hatch gsr turbo overheating
- Value of t3/t4 that needs a new turbine wheel?
- injector wires for bigger injectors - quick question
- Quick stupid question on tial wastegate vacuum lines
- obd0 b16a boost build Questions & Help
- b16 bearing
- Trying to decide between performer x and victor x for my set up.
- help, stripped arp eagle rod bolts
- dual walbros..whats ur thoughts?
- What do you guys think of this temporary build...
- Is this Setup ok?
- IS fuel fitlter upgrade needed??
- Weak Idle then Shuts off
- Official Catch Can / Breather Setup V2.0
- 880cc Seimens/Deka injectors?
- outer diameter of DC2 type r Throttle body needed
- sohc+nitrous, 1st attempt(help wanted)
- Turbo Set up for 94 DC4
- Quickest spool time on a Z6?
- boostedEF91's 522whp Civic Hatch Progress Build
- rsx bogging at 4k n wont pass
- Oil return line
- BUILT MOTOR WONT SEEM TO SEAL PROPERLY
- Boosting?
- opinions lst or lsvt and why
- serious car won't start problems
- another stupid arp headstuds question...
- Need help with Vacuum lines
- serious car won't start porbs
- Non-Intercooled Turbo Setups - Pic thread
- Tial bov issue. Still getting compressor surge
- Fuel pump failure
- Greddy 18G on Fully built B16!
- GSR BOOST HELP
- HP guess-timates anyone
- More HORSEPOWER in my 91 crx si
- MY02 S2k 570whp Pump Gas
- is it safe to torque arp rod bolts to 50ft lbs??
- intercooler piping size
- twin turbo question
- going turbo help?
- What size wastegate and what manifold style is best?
- cx racing wastegate
- Feedback on my LS-T Dyno Graph
- Scat rods and rod bearing question. Help?
- Help me decide.. Going outlaw
- Headlifting?
- boosted gsr keeps blowing coolant hoses
- Building turbo Y8. Reccomendations on turbo size needed
- Vitara scat wristpin question
- Supercharging my EG with oil loss
- Diesel turbos on a honda ?!
- ok i've searched and found the answer to one of my 2 questions on oil catch cans...
- radiator cap explodes???
- Modifying a supercharger
- WATER METHANOL INJECTION E85?
- poor fitting hondata intake gasket? JRSC intake mani question
- Shit in my catchcan
- Question about supercharged k-series horsepower.
- Stock Fuel Pump On 10psi LS turbo safe
- B17A1
- My F2B CRX long term project
- Effect on tune by 1lb boost
- Turbo B16: Normal coolant and IAT temp?
- ZEX Wet kit converted to dry???
- gettin ready for boost!
- Head studs and main studs; At what power level is this actualy needed?
- H22 turbo Manifold
- AFI catch can install
- Turbo oil feed when using a thermostatic sandwich plate?
- Need Help Identifying Turbo
- TiAL Now is incorporating H2O Cooling.
- How r u guys running firewall mounted Fpr?? Need help blocking off stock Fpr hole
- Oil Breather system
- Reliable Turbo DD? D16Z6
- Water/ Methonal Injection
- My Turbo b18c1 Build-fuel system help
- current dyno (engine brake-in)
- NOOB: on boosting single slammer
- LS/Vtec Turbo.. Confused??
- New Motor Build - Info Needed!
- Help! Trying to mount Aeroomotive Fpr on Str Rail w/Edelbrock Manifold
- No crank after turbo kit install!! need help
- which motor will....
- i've searched...just need a quick answer (aem fic on obd-1)
- Hondata vs. Crome
- b18 whit skunk2 pro2 cam and turbo?
- cp 7020 in sleeved b18c5 - CR ??
- new to boost and have a lot of questions
- My radiator and fan, pics inside
- Part Throttle Hesitation / Surging
- Bottom End Build Help
- Manifold for GT4094R?
- Head Gasket Head studs?????
- LS turbo, no rev past 3500 help!
- What Oil Should I Be Using?!?!
- Why go Eagles?
- b20 type r cel 8 help
- timing boosted b20...HELP PLEASE
- ***11:1 Pistons+LS Rods+Turbo***
- anyone runnig this manifold SPfab A-SPEC?
- crx turbo pistons
- JRSC cam questions
- SPA Topmount Clocking Flange Group Buy Thred !
- i am jw on this, an hf manifold for turbo build question...
- k20 turbos kits - which to buy
- Tuning timing at low rpm + boost
- Spark plugs and gap size E85...HELP NGK?!
- ***Built D16z6 Turbo question***
- A1000
- D16Y8 block with a Z6 head...
- Engine cuts out at full boost
- RevHard mani and radiator questions
- Question about my B18C block
- New dyno numbers
- Vitaras w/ 21 mm Wrist Pin?
- JRSC sensors ???
- 16g to t3 adapter plate any good?
- deg. on cams??
- Anyone know where i can get a flange for this turbo
- Waste gate question
- hondata/omni 4 bar map settings for motec ems
- turboing a b16a2
- Oil Pressure: Mobil1 15w50 vs. Valvoline VR1 20w50
- B16 turbo bogging need help!!!!!!
- 35mm/38mm Tial wastegate flange question
- LS Rods in D16 - Crower Bushing Pt#?
- Running super rich and power loss
- DSM injector seals
- Vaccum readings at idle (boosted setup)
- Victor X vs AEBS experience needed!
- Injectors
- Turbo Oil Drain below oil level on oil pan
- Any help, new to boost and scared..
- kkk
- Hi, might purchase a turbo D16Y8 car.
- DRAG cast mani boost spike?
- Help Me understand "Get a tune"
- Brand new turbo setup - do I need to pre-oil it?
- 60 trim on a d15b
- Single ot Twin piston BOV?
- Adventure to 500whp, suggestions please
- help. crankshaft clicks??
- 450 whp as my goal ?
- 450 whp possible??
- Which one of these Borg Warner Turbos are good for a 400whp-450whp D-series build?
- Charge piping question for tuning?
- what all comes with a JRSC for a b16a
- s372 overkill for stock gsr?
- Need some help figuring out my wideband sensor.
- HF Manifold?
- Tial 44mm to 38mm MVS adaptor flange?
- anybody using a hks ssqv 3 bov
- 3071R Oil Restrictor on a -3 AN Feed?
- help with my b16a2 build...
- mitsu resistor box on del sol...
- Broken Oil Fiting Back of Block what to do??
- Fitec Motorsports 3 bar map
- 2.0L GSR wont start after Re Ring
- fp hta turbo?
- full-race prostreet 11" tall backdoor intercooler mounted onto a DC2 with JDM front
- built b18 oil pressure
- d16z6 turbo - Final processes
- Excessive Blowby? Please advise *video* included
- should i retune
- Feed line size for 6765
- greddy b-series downpipes.. can i still buy one?
- having a fuel pressure problem any ideas?
- a2w intercooler, water feed lines.
- Oil on spark plug tip after rebuild
- A/C & PS Compatible Turbo Setup
- tuning around denver area
- aem uego wideband o2 "input"
- evaluate my current build d16-t please
- Oil pans
- carbon fiber compressor wheel
- turbo z6 not building boost
- PS-92 coil on stock dizzy
- S9B gearbox
- PeakBoost Customer Appreciation Day w/ FREE Tuning by Ken Peak
- b18b1 boost
- GT3071R Turbo
- Any dyno plots of a Precision 6776H?
- quick RC 440cc injector/ resister box question
- Very rich AFR & car misfires under boost..help!
- Injector size question
- Best Tranny
- high hp fuel set up ?
- upgrade t3 turbo?
- Turbo's built into manifold?
- vacuum source/line/fitting question
- ****Cam choice and gearbox choice****
- skunk2 tuner 1 cams for gsr turbo ????
- EVO8 16G Turbo / Another Sizing Question
- B16a Dyno??? 12psi? 211hp!?
- Stock Ls turbo build
- Erratic RPM at 3000
- D-series cam help
- 92 integra turbo set up
