View Full Version : Forced Induction
- TD04-H Turbo on a D16Y7 Motor Automatic?
- I need suggestions, please!
- second 02 sensor hookup on a 19t greddy kit
- attn diy efi tuners, quick question about using spoon as basemap
- opinions on best guage to monitor stock turbo motor
- What about this turbo ??
- Nitrous internals question
- Exploded engine diagram
- JR Supercharger Belt Problems
- not boosting...weird problem
- Is this enough to meet my goals?
- Which pistons Je or srp are better??
- priming a turbo
- Rocker installation
- will the heat from a turbo cause damage
- ECU ?
- Website for DSM res. box and clips??
- Need a lil bit of info
- Umm I think I got a BIG problem.
- Pics of DRAG 3 manifold VS SFP Manifold
- where to find apexi turbocharger?
- What bearings shall i buy
- CEL 20 (Electrical Load) & CEL 41 after Dyno
- Turbo setup is finally on! Lots o pics.
- WTF? The DAMN cel light wont go off after hack install. Anyone else? can't get CEL #
- i need to upgrade my fuel system
- You guys seen this Supra street racing video? Or Highway roll race vids?
- Manifold Bolts OR Manifold Stud kit
- D15B7 forged rods?? who makes em?
- Turbo Help??
- Axles, which to use?
- WHATS EVERYONES OIL PRESSURE ON THEIR TURBO HONDA?
- started my crx turbo today and....
- T3/T04R Vs SC61 Vs T3/T67?
- oil filter adapter question
- Clean and SOLDERLESS Resistor Box Install (looks stock)
- Piston rings!
- H-T need some opinion on a good build
- PIX OF MY TURBO KIT
- check out this fully built block
- SC61 and Lovefab
- need help with turbocharged prelude
- AVC-R boost control valve placement
- ... minimum requirements for 'tuning laptop'...???
- Code 13-Baro after hondata install...
- ic efficiency question?
- what kinda time should i run?
- how did you set your cam gears boostin at 7psi
- 4*1000cc inj or 8*660cc
- wats ur gas mileage with 97up Prelude w/turbo?
- Motormatrix thumbs up!
- Can higher viscosity oil cause spool time to increase ?
- Wastegate Suggestions
- T25 A/R .49 EXH .89 Turbo Question.......
- turbo manifold and dip stick
- What Nitrous kit should i get?
- Import Racer !!
- stock radiator hp limit?
- vtec not engaging at boost....
- is it worth rebuilding??? 14b
- Selling your turbo honda, % of return
- compression ratio question
- catch can/oil separator
- rods, valvetrain, full race
- problem with vafc hack
- EGT guage in Full-Race manifold
- T3- b18c1
- walbro fuel pump install questions
- street tunning in cold weather
- amount of oil to use with turbo on...
- Greddy Kit pipes
- procharger supercharger
- heat shield for manifold
- Is this how you hook up a boost controller with an external wastegate?
- Denso spark plugs w/ greddy kit
- rc injectors
- post ur nx ntercooler setup pics plz
- Crank damage
- Price to make a warped flange flat?
- pic request
- SAFC Hack on my AE68?
- Quick spark plug question
- I need a TechEgde Wideband Log File from someone...please
- DEFI Heads Up Display Boost/TT
- how many psi can a drag turbo support?
- obx b-series turbo manifold?
- 2 beat a 2jz or not????
- better management than greddy fcu???
- New turbo exhaust for Integra's coming out!!
- Junkyard fuel pumps for a turbo sohc @7.5psi
- Turbo on auto tranny
- basic maintenace befrore turbo...
- tuning in toronto
- Stock rods, aftermarket pistons and sleeves. How built is built?
- Look at what UPS did to my Pistons
- Finally! I got my turbo setup!
- Power loss vs. compression reduction : Rule of thumb?
- Look what came home finally! Pics
- Rev Hard Stage 2?
- GT30, T04s, T66...........
- turbo heat under the hood
- At what point is a headgasket too thick?
- Aeromotive FPR (13116) and fuel pressure?
- New Member...Info about Greddy Turbo for DC5's
- downpipe and emissions question
- where to get z6 internals?
- Turbo B16A Setup? Help...
- Car Misfires When Starting Cold
- turbo with ac manni question?
- needle or bypass valve? in order to drop oil pressure...
- SFP manifold....
- Twin Turbo Charged chevy 302 need advice
- best gauge for the money?
- How Much Nitrous can a Stock B18a Hold?
- Mechanical difference between WG and BOV?
- Greddy turbo kit
- gsr turbo plug gap
- lets talk about some SERIOUS nitrous setups, dyno's and track numbers...
- What's my T28 good for?
- 99Hybrid_Hatch, please read and respond
- Decided on a Turbo... what else. BUDGET!
- Drag Gen 3 Turbo Kit Help!
- aemtuning
- how many hours does it take to tune...
- help piecing together 3" exhaust.
- any size difference between the sc61 and my turbo(drag2 kit)?
- Just turned the boost up to a max reading of 10.3psi....wow!
- a N20 build...
- painting intercooler black?
- ECU CHIP (good/bad)
- finally got my turbo installed and hondata tuned...
- Turbo Set UP! ECU Turbo CHIP help.. Opinnions
- What could cause VTEC not to work?
- hack with check valves?
- cheap dseries manifold
- Fuel pump ??????
- Hondata 3-step questions
- Downpipes
- turbo gsr cuts out when MAP reads 3.1 volts w/ missing link
- Turbo Oil for 100K miles car?
- rh stage 2 kit,is any engine management needed?
- Turbo too big??
- O.K., turbo timer w/factory 99civic si keyless/alarm???!!!!
- Anyone have experience with GenX's Performer X kit?
- what is needed?
- HOLLA if U NO a good tuning shop in Orange county
- Cam combo?
- intial turbo start-up...
- well here it is, what do ya think?
- Turbo question
- power don't peak with drag turbo
- Is this intercooler efficient?
- OEM headgasket can I use it safely... vs Cometic ???? please give me your IMO ...
- hack question
- anyone have a spare tial 35mm wastegate ring
- Need Help ASAP. Non Universal BOV work for an integra?
- vband
- How much total timming are you running under boost ????????
- Its almost time!! 11504
- Best cat-back system?
- t3/t4 identification
- intake size for turbo
- Tuning in SC or GA
- ECM Engineering.......
- need help with turbo tech
- Where do I mount my i/c
- Stock SI exhaust
- Tial wg spring
- All boosted EG Hatch's post brake setups!!
- TurboXS DSBC and Tial WG hookup
- Dyno Day.......Free Dyno Pull
- skunk2 manifold on ls motor...have a problem..need help
- Searching for sc50 flow charts
- B18c1 Users: What Turbo, and spool times?
- Anyone elses retainer nuts fall off?
- divided exhaust housing ?
- Greddy EGT gauge is fubarred...
- Displacement on 1.6L with 9:1 pistons?
- Stock valvetrain with 15 psi?
- For the JRSC guys
- Visit from the UPS Man
- safc...
- Engine management system
- Rate this combo
- Now.. tuning Hondata...
- Help the newbie... Hondata?
- Drag 3 turbo's
- Spark Plug gap NGK BKR7E-11
- can i keep the cat?
- Mechanical Oil Pressure gauge OK in cabin??
- Where can I get piping for my dump tube?
- turbo instalation experts can you tell me where i'm messing up?
- Cast Sidewinder on B18B Integra
- Integra o2 sensor code
- can't find a post...need some help
- Admin's can you make a sticky with compressor maps for all Turbo's
- Turbo code thingies?
- does someone have a compressor map for sc34
- Dump Tube Question
- turbod zc
- Is this a good price for D series turbo install??
- guages similar to blitz blm guages
- injectors 550 big enough? saturated or not?
- fuel pressure question?
- how to test PSI on a turbo?
- Good price on inlet manifold...
- Anyone seen Motor matrix.com!!!!!
- B16 clutch into D16 --- anybody ever done it?
- greddy kit??? need help asap
- Machine shop experience?
- Making intercooler piping for dc2
- To all drag owners with ls/vtec???
- Opinions....
- Is this a upgraded radiator??
- A New Oil Feed for all B Series, Opinions Please
- Best place to buy DEFI
- boosting a k series?
- SC61 Owners/Sellers - Please Read
- Haltech Tuned Civic
- $600 to spend at a machineshop
- Quick t25 setup question
- air in ic pipes?
- AT boost Level should the Valve springs needed to be upgraded
- greddy kit need tuning??
- FEEDBACK! WHICH IS BETTER!
- Funniest shit I've read this year.
- Went to teh track last week. **13.9 @ 109**
- NOS NosZle O-rings
- YO!!!! JRSC Prices
- Clocking the turbo questions.
- Drag manifold power ability?
- Another Victim of MOTORMATIX
- Help me pick out some I/C piping
- Car shuts down everytime I go and do a complete stop>>
- Silicone Vacuum hose
- why wont my intercooler fit?
- is it me or do all turbo kits kinda suck without tuning?
- almost through with my new manifold
- best turbo for a b16?
- GSR Turbo VAFC Settingsw
- FI Related Video! Street racing kinda cool.
- head?
- RAVERS NITROUS
- turbo ls looking for 430-450
- equal lenght manifold.....
- why is the stock O2 sensor is not accurate?
- wideband display
- injector problem. please help
- turbo coolant lines
