View Full Version : Forced Induction
- GSR or Si cams ?
- piston slap
- Turbo Integra randomly dying...
- turbo setup?
- reliability of a b18b boosted
- MSD to OEM
- OBX turbo manifold?
- Rebuild or Buy New
- The Effects of E85: Parts Test
- 5 bolt downpipe with only 4 bolts
- **need help asap**deploying in 3 months**
- reguarding a manifold vs radiator
- Exhuast Sizing Question
- Turbo Cam Supporting Mods
- install help gt30/70
- compression b16a1 help.
- How do I Install Boost Gauge?
- aebs sleeved gsr. How far can i take it?
- D16 turbo.. killing Headgaskets... Backpressure..!?!?
- initial review: Tial SS housing, MVS wastegate, and Q BOV
- N/A B vs. F/I D
- What do u need for v-tec?
- 5857 or 6262 turbo
- Integra Turbo Question
- b16a vs b18b
- AFR'S Whack?!....
- Tires for DD Boosted Cars
- msd cap and rotor blowing up
- car smells like burning oil
- Ways to quiet exhaust???
- IM ABOUT TO GET A 372R WITH NO RACE COVER ,NEED INFO!
- jrsc mini me vafc2 need a little help
- Do i need these Prothane mounts
- E85 Fuel Pump sizing
- Bad Chip
- What size oil feed line for full t4 turbo
- Fuel Pressure Regulator Advice
- OEM Rings WITH Forged Pistons
- turbo doesnt spin at idle???plz help
- Hooking up boost solenoid
- high HP DA integras?
- stock b20 (searched)
- Need advice on cam choice
- Ignition timing, S300 compensation by gear, what is safe timing range?
- Wire tucked now where to mount soleniod?
- Overheating
- Ls/vtec turbo RPM peak horsepower?
- H1 Turbo on an LS Motor
- turbo power question
- ZEX DRY to WET CONVERSION?? POSSIBLE???
- E85 injector sizing
- MSD Injector Info NEEDED!!!
- basemap needed!!!!
- wastegate elbow clearance.
- Anybody have any experience with the BLOX billet throttle bodies?
- what numbers could i have with this setup???
- td05h water cooling help
- DID IT MYSELF pnp LS head.
- overboosting problem...
- WTB: turbo manifold
- Think this would fit?
- Blow by after I install air filter
- Intercooler Piping 2.5" or 3"????
- Garrett T3 60-1
- F22 problem
- Which Supertech valve springs (h100dr or h1002d) to use with CTR cams?
- Spark Plug question
- backfiring/sputtering
- What size rods and what compression ratio pistons ?
- What causes a PISTON Ring to Break?
- Calling E85 user's post your spark plug brand, part number, gap & pics of used plugs
- Ecu problem ? Ectune program
- Garrett 3071, anyone run this turbo?
- Turbo build started, couple questions
- turbo build help
- b18c with Skunk2 Pro 1 cams
- Cylinder PSI
- AEM Methonal Kit VS. Other Methonal Kits
- Complete intercooler piping kit for Integra
- b16, Gsr or LS tranny
- skunk2 high compression valves in boosted y8?
- The B16A1 build
- uprated cv joints
- turbo ek..how many still have a washer bottle?
- How much power? built b16
- Car won't go above 5K rpm
- Holset H2c
- Sound Performance Quick Spool Valve
- signal mounts with BIG intercooler ?help !!
- Walbro intank - 044 inline/ or Sump tank w/ single 044?
- SRT-4 injectors. have i missed somthing.
- Will this oil feed/return line kit work?
- Fuel Rail Banjo Adapter Fittings
- Lightest Rods for Non-Sleeved Block Build
- oil feed line B18 turbo
- T3/TO4E 57 trim Question
- h22 turbo manifold
- Ring gap question..
- curise control with new turbo setup
- Decent place to get a downpipe from?
- ideas on hom much hp my turbod ctr will make?
- Inline Pro injector driver HELP
- HYTECH side exit turbo manifold for b-series
- Precision 6262 Turbine too small ??
- top mount keeps cracking, get it ceramic coated?
- rod bearing question.
- rc750cc with stock fuel rail?
- Where does this Hose go????
- JRSC - PLS HELP!
- catch can question on turbo ls
- gsr cams make it run richer?
- questions about parts to a turbo set up
- Advice please. 2000 CivicTurbo
- Log/Cast Manifold
- boosted poor mans type r bulit!?
- Evo 7 intercooler in civic
- DIY for turbo build?
- Keep Messing up Turbos. on my 3rd one
- My stock sleeves B20 motor build.... trying to make the best out of it!
- Tuning d16 turbo
- Tuned my set up today. Results are in!
- Time for a new turbo. What's this old one?
- Where can I get a BOV like this?
- Turbo install, now LIMP MODE
- Cant find a straight answer about 60 trim for an LS
- FiveOmotorsports 2000cc vs. Bosch 1600cc injectors
- Just installed my JG manifold HELP!
- calling all honda-tech power guys
- Gotta New Manifold!
- bolt sizes
- Wondering what kind of HP I can get
- - Boosted JDM D15B - Mild, Reliable Build...
- injector dynamics 1000cc or 750cc??
- Greddy air/fuel warning meter issues!!!
- need help with Compresor map reading
- Help - where to buy nose driver for M62 JRSC
- boost by gear, ebc or mbc?
- hx 35 question
- b18 turbo manifold
- front facing h22 race exhaust manifold forsale
- Bubbles in coolant only when revving?
- is there something wrong with my car?
- GTX4272R NEW SHERIFF IN TOWN?
- Stock GSR + turbo - How much boost is safe?
- 450+whp Guys - Question about Camber, Toe, and Traction
- Oil leak around dipstick base????
- Boosting my zc dohc d16..only looking for about 5-7 psi...send me links???????
- JRSC Lower Tensioner Assembly Alternator Casting
- Fluidyne drain plug size
- Edelbrock Victor X Manifold vs JGE Custom Manifold
- tempting to build my LS, some questions.
- 97 civic d16 bad gas mileage new turbo
- bullseye s362?????
- jrsc pulley question need some info
- Precision turbos
- Little bit of rad fan help needed please
- B16a setup?
- 35R 1.06 exhaust housing too big or not?
- Turbo Build - What motor to choose - crx or hatch
- trying not to run lean
- EG JRSC using stock exhaust?
- Problems connecting ECU
- gsr-turbo expectation?
- stock gsr or ls/vtec built
- spoolin performance log manifold
- New Supertech piston ring gap too large-should I go oversize rings?
- Which Header ?
- gasket tickness
- Help 4" downpipe CRX WONT FITT!!!
- 10 sec. d16 Ej BUILD!!!
- CRX Turbo?
- temperature high ?
- b18c turbo help seriously
- Turbo building???? Help!!
- RCautoworks built b18c with precision 6262
- 392WHP stock head/stock block ls from Wrenches tuning
- recommended redline to tune turbo setup on?
- Need help with a turbo
- Anyone running stock K24 with a turbo?
- My dyno session, pics vids
- how to get a fuel pressure gauge on F23 motor?
- new guy to hondas, but not new to making horsepower. needing advice
- Holset VGT on a Honda?
- broken tail wastegate ?
- Need Answers Please!!
- Anyone here use Full Race traction bar and Inline Pro setup?
- 800hp billet 62/65 b-series
- Injector size to gain 350hp on stock turbo b18a1??
- Phormula KS-PRO on B/D/F/H series
- DSM 440'S on OBD1 del slow
- Milky white substance under valve cover
- How to build a reliable ls/vtec Turbo for 250-350whp
- How to tell if Turbo Is Bad?
- tunning help with Water/Meth Injection
- Breather can full of coolant!?!?! why?
- Sick of reading mixed reviews on vacuum lines for wastegate
- wtb: wastegate actuator for td05h turbo
- T3 vs. 14B
- help on turbo
- ARP head studs? F20b
- JRSC Fuel Integra
- rev limiter on LS-T???
- catch can fume traffic
- Eagle H-beam
- IACVs keep breaking on boost..
- t3-60 or similar
- Can you spot the wrongs LOL
- hard wiring fuel pump
- HOW TO DISTINGUISH A REAL GARRETT TURBO?
- b16 just a shout out on any one who has some info
- Crank Breather & Break booster Question
- What Kind Of Numbers Should I Expect?
- Wastegate setup
- OEM Vitara Piston Rings Or Aftermarket?
- quick question about new injectors fic fitting hondas
- this turbo mani a t3 or t4 cant tell
- Max Power on stock Sleeves w/ E85
- Need Help Overheating Ls Vtec Turbo
- boosting accord
- Main's bolts chatter while torquing.
- Lets talk spring rate set ups for DD high HP
- is 7:1 AFR's insanely rich?
- Cam Issue
- ls/vtec setup help
- Using a lsu4.2 on a aem wideband?
- booost is coming help h22
- i am boosting soon need help asap
- stock gsr new dyno numbers
- Turbo Fuel Rail Opinion
- crank case pressure/venting problem
- Analyzing a compressor map, did I do this right? (big 16g for an ls motor)
- my setup.. getting tuned in 7 days.. how much power do you think ill make??
- -8 fuel line
- type-r super charger pros and cons ??
- DA integra ic piping kit
- Coolan Overflow issue
- Single Cam turbo builds
- V Band Clamps
- (new to boost) setup
- td05h wastegate actuator issue/questions
- Whats the best way to build a B16a For turbo??
- Water/Meth Injection worthwhile on LHT Intercooled JRSC?
- Need help finding a TURBO for my Honda Build
- 3 inch exhaust for a hatch? help?
- Weird oil pressure , already searched.
- 500whp what clutch to hold the power?
- Planning to yank out b16 for??? B18 or B20?
- Turbonetics Raptor BOV issue
- TURBO B20VTEC HAS ANYONE DONE THIS SETUP AND MADE OVER 400
- Wanting to boost my d16. Help and advice.
