View Full Version : Forced Induction
- SC34 vs. SC50 (GSR)
- So which LSD?
- will thse b18a pistons work in a b18b block aswell?
- 350 whp impossbile for d16y8
- code 3, 41, 43 after turbo kit install on DC integra
- Tach Jumping
- has anyone use the cheapturbo oil line kits
- Ok to helicoil where the headstuds go?
- Fuel economy in your Boosted B18C
- what is the best method for tracking down an ehaust leak
- turbo/civic question...help
- d16z6 turbo?
- Storing a Turbocharged car
- whats wron with a fmu
- unplugging the afc. converting back 2 NA w/o problems?
- JG/Edelbrock vs. JG Sheetmetal vs Endyn CF Intake Manifold
- Yay got my kit today what u think?
- Need some help with my buddy's Nissan turbos...internal wg probs
- Greddy 18G downpipe bolts????
- turbo ls help =XX
- PWR radiators & SOHC
- Differences between b-series heads.
- how do i clean my charge pipes and intercooler from oil.
- zex kit from civic on integra ?
- Eclipse stock turbos
- Eagle rods....need my block notched?
- HELP!!! Tial Wastgate 44mm V-BAND is not SEALING, anyone else experienced this.
- Well it happend!!
- supercharger stalling problem
- compression check after 200 miles of light break in ???
- wideband o2, AEM EMS, and GM 3 bar
- b16 low end tourqe question?
- My B16 Drag Dyno #'s
- How much does an Anti-surge/shrouded compressor housing affect the compressor caracteristics ?
- eclipse 450 cc injectors in a eF?
- sorry for doing this but i have to
- How can i mount an air filter on this turbo (garrett t3/t4)?
- B18C guys w/ DRAG genIII kits..
- Why isn't the supercharger boost kicking in??
- GSR Turbo What boost daily, on stock block?????? and on stock injectors?
- ImportBuilders Turbos ... good.... bad..???
- >>>>BOV POSITION <<<<<
- Tuning Questions! with VAFC2 and AEM wideband, is it worth it??
- Since turbo's create a lot of heat...
- uberdata on autos?
- Turbo tuning with you GBA?
- TurboD16 video for ya
- apache air filter for turbo
- Just turboed my gs-r
- Is anyone breaking OEM Cranks?!?
- has anyone ported a turbo?
- Which filter
- Rev Hard turbo kit boosting 20psi Why
- Does anyone have pics of the RSX Cybernation manifold?
- Anyone boosted with AEM EMS had experience at Turbo Trix in Edison NJ?
- compressor maps
- Tial Wastegate venting exhaust at idle?
- i think i blew up my aem ems.... lol
- Why no ignition??
- greddy boost controller
- 99 SI turbo Project part 2 , pics of install, battery box, ONE FAB A/C Manifold, MSD,
- Type-S BOV adjustment
- Turbo B17, is this strong enough for big boost?
- All you turbo guys who are running AC let me know how you ran your IC piping
- Who is making the most power with a Greddy 18G turbo?
- SHould i RUn the Sandwich for Oil or the T in back of the Block?
- MOD ADVICE?? i am looking to build up my motor w/ turbo but not sure what to get, already have many
- Big Turbo ProjecT
- Anyone have kteller exhaust pics modded to look like the n1 style angled exhaust?
- Anyone ever bought a used turbo from this company?
- Is vtec is irrelevant when boosting ???
- Some pics of my new Turbo, and Manifold... :)
- which would be smarter.
- Compression test turns out higher after 1 month of boost?
- Need source for small intercooler
- OBD1 P28 ECU - JDM or USDM?
- Who's using Water Injection?
- 18g a/r size?
- spark racing intercoolers
- Welding on dumtube straight to the wastegate outlet
- exhaust leak or not? *pics*
- how do sequetial turbos work?
- going to turbo a gsr
- Not sure how to fix Engine codes
- turbo ls 1/4 times look ok?
- replace pistons/rods with engine still in car?
- Mase tuning in south florida this week?
- GSR block, b16 head, moderate boost. should I sleeve it?
- piston ring staggering is this the correct way
- turbocharged D16 vs. Stock H22.... who would win???
- AR Fabrication for tuning
- Tial Wastegate settings
- b16a or b18c or b18b witch one hold boost the best all tell me!!!
- Who's running a b18b with a JRSC? Anyone doing so with an auto tranny?
- Stock Gsr Motor???
- Whats this about? anyone tried it?
- DYNAMIC MOTORSPORTS DILLSBURG,PA
- D series turbo ninja slain
- How is spool time measured? Which gear?
- uberdata tuning????
- Dyno results..... I am now addicted
- Hi-Temp paint on Turbo Manifold???
- high compression + turbo
- Tonight's fun: Turbo Rio gets a T3
- Do I need a restrictor for my feed line?
- Tire question....BFG's....
- Anyone in Seattle area wanna help with turbo install?
- internal to external wastegate how to
- New Exhaust Parts.....
- 3" turbo back exhaust and lots of moisture is that normal????
- Just boosted for the first time!
- nitrous ignition timing
- Blitz Super Sound BOV adjusting...already searched
- HKS SS BOV Questions, any help?
- Hondata problems...
- CEL #54
- Vacuum help
- spike when shifting... is that normal?
- New build but getting distracted
- Street legal setups for 94 GSR
- Turbo Suggestions?
- intercooler piping?
- Master Turbos
- OK, I WANT UBEDATA< WHAT DO I NEED! GIV EME A LIST AND WHERE TO GET IT!!!!!
- 3 Bar Map Sensor Help!!!! Give me some insight!
- Hondata or aem EMS?
- this is what happens when ur ride is slizzammed!! pics inside (56k warning)
- full-race vs in-line pro
- Where can I find a Greddy 92-95 Civic Si Turbo Oil Line?
- identify this compressor housing
- Dyno Day Results! 500whp!
- synthetic oil spill on timing belt ..Dangerous?
- WTF is up with my timing?...
- R.I.P Clutchmasters *pics of destruction*
- What would be the best size line to use for a oil distribution block
- thanks HT for all ur help...but i'm having problems
- ANOTHER AFC HACK QUESTION!
- uberdata and hp #
- Filter location from turbo... Any proven power gains?
- JB weld for o2 sensor bung?
- 500+ hp guys.....what clutch to get?/Is external coil needed?
- JRSC GSR Parts?
- Ghetto Turbo D! Setup done with pics.
- B16 w/ t3to4r
- Got torque?
- Just recieved my LM-1 wideband o2 sensor and was wondering....
- turbo coolent lines
- placing MAP sensor before turbo... any possible benefits?
- wich would run better with this setup? 390cc or 450cc
- garrett t3/60-1 turbo ?
- 85MM B18C BLOCK = A 2.0 ????
- question about dsm injectors
- civic si project first dyno session!
- Pics of my new FI induction
- How safe is this basemap? LS turbo/uberdata
- just blew transmission gsr boosted what tranny....itr or gsr
- any one with pics of a side mount smic
- 14b weird sound and no bov?
- uberdata or stand alone
- Ever taken your turbo'd civic on a road trip?
- Ls turbo guys. 15w-50 full sythetic too thick?
- why does Greddy's kit make so little power
- B16a-si VS. B18B LS
- 2 quick quest before install
- TurboKit Question
- where can i get a romulator for uberdata?
- Ever heard of AutoLab?
- Help WIth 3 Bar Map Sensor!?!?
- heres a good question for you honda pros...
- question about oil pressure sensor
- Couple questions before intsall
- Turbo y8 question...
- 7lbs on a stock b16a2
- Question about radiator and boost?
- REBUILT AND RUNNING PIG RICH
- TurboXS MBC Broken?
- Turbonetics Compressor Housing....
- Anybody have experience w/ GT30R?
- Is 4k on stage 4 sprung clutch bad?
- Junkyard turbo guys?
- where can i get a gm 3 bar map sensor with pigtail included??
- The NEW AFC Hack thread: Who's still running it? *Uberdata/others not allowed*
- Anyone know where to find a T fitting for oil pressure switch?
- ? about built engines
- My megasquirt works
- Just dynoed stock JDM GSR with SC61
- Check out the new Turbo Pro-Mod
- Greddy Kit on my car?
- I need a B16 exhaust flange drawing in CAD....
- Greddy 18G question- why does it squeak?
- Turbo in the rain...does your car act "funny"
- turbo rsx problems
- t3 rebuilt turbo burning oil after 1000 miles. help!!!!!
- Wideband question
- When do you need to sleeve the block?
- compression test results not good - need advice on next step...
- JRSC ITR! CRAP DYNO TIMES! ANGRY AND CONFUSED! HELP!
- gsr turbo a/f ratio
- Piping Size for HKS, Apexi, and Mugen Exhausts?
- turbo h22 eg
- what it is coming from the exhaust
- oil-spray cooling for pistons on VTEC but not for SOHC... ?
- SuperCharger or Turbo for b18
- Open Downpipe and Wastegate
- after cat turbo system
- has anyone done this...turbo manifold without turbo...yet
- What Aftermarket Exhaust system sells 3 inch full cat????
- dsm 450 cc how do i tell what i have
- Lsvtec 12.5:1 compression maybe 13.1 with 50shot?
- nitrous with boost?
- How build turbo on D16Z5?
- internal wastegate porting
- Any brands make gauges pods near the speed/tach/gas for 92 95 civics?
- if i were to build a home made turbo kit...
- Stock B16A with JRSC Kit and Boost Upgrade
- Jackson Racing Air/Fuel Ratio Gauge
- Anyone try using an S2000 throttle body?
- just about done with my turbo install
- Turbo gsr but with what turbo?
- good bov for 7psi?
- Im new to forced induction, stupid question
- What else might I find a decent turbo on?
- Help with clutch suggestion H22
- how many psi can a Ls Golden Eagle sleeve/bore/hone block with stock internal hold??????
- I WANT TO THANK H-T, BOOSTEDCOUPE, HELLA- JDM, UNDERPRESSURE02, ETC
- what size intercooler piping
- OT: Need some help here
- turbo cams for b18b?
- WHO'S RUNNING EMANAGE (NOT THE BLUE BOX BUT EMANAGE)
- Driving a turbo car....*questions*
- GT40?
- please help fmu or safc?
- Please help fellow FI member. Fair price for car?
- Evo injectors, do they fit?
- tuning e manage
- gt3000 injectors
- How did i stabalize my a/f ratio?!?
- Question about converting from JRSC to Turbo
- mvm pulley
- Greddy type S and type R flange
- specific brake swap help, (Ive searched already....)
- all mototr or turbo
- exhaust for turbo
- Finally fucked up the civic
- Newbie, couple of questions
- vafc and jr map controller
- Standalone
- Who's running this MBC (manual boost controller)? *link inside*
- street tune: how much open road does one need?
- AFC, 450's, not idling correctly
