View Full Version : Forced Induction
- AC on = Car shuts off?
- Anyone know where to get ZEX 59300 cheapest?
- Oil Block adaptors
- what FPR to use with dual bosch pumps?
- Cheap gauges with warning light/beep ?
- quick question! help!
- OK guys heres my dyno run B16A2 that ended in disaster....
- TURBO HELP
- Hybrid Turbos?
- JRSC LS/VTEC - cam question
- really need the help...havent done this before
- hf manifold?
- Precision GT3251E
- intercooler sizing question
- Stock internals.
- hookup? or breakup?
- wastegate flange???
- oil not getting to turbo...please help!
- want to buy b16 turbo charger and manifold wit ac/ps
- HELP! failed emissions b18b turbo
- finding valve lift
- Power FC OBD2a or OBD2b
- I'm baffled, throwing a really strange CEL, need help ASAP.
- PeakBoost's latest addition!
- check this out
- Helping an injured Vet, Overhauling style.
- Vacuum wont go below -10
- Location of Wideband Sensor
- Air to Water INTERCOOLER setups / charge cooler setups please
- Problems?
- safe piston to wall clearence on an arias piston...81.5mm bore?
- FS: RC 550cc injectors, Greddy RS BOV
- Rod/Stroke Ratio and Boost Question...
- Is My Timing ok? Crome question
- boost creeping problem on gt28r
- GSR turbo set up questions
- 250whp stock sohcs any of these motors still running?
- 2.0 stroked b16 pump gas dyno chart
- can some one tell me
- Ok need some help..............
- Edelbrock 50 State street legal.... any good?
- Brand New GT35R Hybrid leaking oil...
- Rebuilding a GT28 Ball Bearing
- help : pully
- need someturbo help
- LS turbo.......Which Tranny is best? GSR or B16?
- D16Z6 boost setup. Won't start, weird noise :O
- Replacement for Greddy boost solenoid?
- b16 turbo or h2b
- moroso oil pan gasket???
- faulty wastegate?
- ecu tuner locally
- MSD Ignition vs OEM Ignition
- What type of oil are you guys using?
- Need help....just bought a JRSC on eBay
- Chipped Ecu For Ls Turbo
- NOOB Question about tuning...
- Rod Short Departs Precision Turbo
- soch turbo help
- turbo b16 low hp ?????
- Any ideas
- Turbo DOHC zc
- idling problem
- HP Goal possible?
- valve cover venting?
- will it hold
- Detonation
- RTV silicon instead of gaskets?
- How thick is your Koyo , Fluidyne, PWR radiator???
- MSD BLASTER QUESTION
- piston to wall clearance help
- re:
- Civic Vtec 1.6, can a turbo be fitted
- Carnage.......
- traps and et on an sc-61
- anyone with a ful race a/c ramhorn and moroso oil pan?? oil drain pics needed
- Intercooler question!
- looking to buy new pistons for build motor... 9:1 dish piston or 10:1 flat piston???
- arp head studs for 7psi?
- NPR Pstons Gap [HELP NEEDED]
- Using Prologger's Lean-Safe with NepTune RTP quad-stage boost control possible?
- my turbo build up
- top end vs. low & mid range?
- Egt readings
- y8 keeps stahling after tuning
- Help with head lift
- oil in my charge pipes
- GT4094R?
- Many clouds of smoke..........white that is
- Oversized valve clearance.....????
- BOOST/WATER TEMP gauge issues..
- Do I need to get bigger injectors and a fuel pump?
- gt28r on a d16y8 (97 civic ex coupe)
- Is this head fixable?!?
- Oil Bung... to low??
- slight overheating with greddy kit
- Need a new turbo...
- turbo build any suggestions
- How to free stuck piston rings? Make piston stew!!
- dyno #'s on 10 psi
- clocking a t25???
- MSD IGNITION QUESTION
- Full-Race topmount--->to backdoor intercooler, need pic
- NEED HELP
- Need help with turbo install
- turbo setup
- Need a quick answer, please
- Tapping oil return
- ****SOME TURBO QUESTIONS, d-series motors********
- Turbo Intake Manifold?
- Blow Off Valve Problems, HELP!
- Found a junkyard candidate but what is it?
- Fuel line fitting
- Wanting To Turbo My JDM B16A...HELP???
- is this head still ok to use? (gsr)
- head stud question PLEASE HELP***
- first time turbo, need advice.
- Big Clutch problem... need help FAST
- oil pressure psi
- V Band question..help please!!
- im a n00b with 1600 and counting .. greddy kit? .. or should i try and piece one together
- whats a nice turbo manifold for $250-$350??
- Clocking center section on a Garrett t3/t4 turbo?
- gt35r turbo
- KMS block Girdle ?
- turbo, oil leak on compressor side?
- JDM B18c turbo setup ???????????
- Which fan to use?
- D16y8 - JRSC / What flywheel to use for best performance? Lightweight or OEM?
- electronic boost controller and tuning.
- apexi ihi oil feed compatible with greddy td04?
- turbo LS/Vtec WHP?
- Turbo Setup
- Help with a FI build
- blow off valve help
- Post that you are tired of seeing.
- which turbo
- GT turbos and blow by???
- b16b setup?
- welding oil return line fitting on oil pan
- full-race crx turbo manifold on EK :S
- I put this in the wrong forum I guess.... Saab T3 Garett?
- B16A STOCK MOTOR with backyard boogie turbo set-up...
- got this baby free. :)
- What would cause this? (Same psi, but car so much slower)
- T3/T04E with a .50 a/r cold side and a .63 a/r hot side. some questions
- Ideas on spool time
- how much boost
- Fuel setup; SARD FPR and AEM fuel rail
- 700HP injector question
- what base map
- oil line question
- I want pics of SOHC, AC COMPATIBLE, RAMHORN, or SHORTY Ram turbo manifolds.
- boost b16B
- 99 gsr turbo.......greddy.
- Those running from a factory turbo?
- should i turbo my 98 civic
- Dyno: Pump Gas,Peakboost AC Kit, T3/67
- Eagle Rods
- shorter final drive with small turbo?
- any sols on here running a JRSC?
- what % of the exhaust goes through the wastegate?
- Are E Cutouts rubbish in general??? People who've had them, come in!
- V Band Flange material for a Turbine Housing
- Turbo spinning hard
- anyone kno where i can download the emanage software????
- Turbo GSR low RPM misfire
- B20 stock sleeves
- Which cam ?
- aebs sleeves copper O-ringes
- turbo newbie..=(
- 160k on my motor
- ebay manifold
- hitting rev limit to soon??
- the d16 got some bling and a drop
- HOW TO: Construct a simple, cheap, and effective EF catch can.
- Is there any ramhorn manifold that retains p/s and a/c?
- where can i find a kamikaze header for a b16
- 315hp max..2.25in ic piping or 2.5?
- Noob on turbo have ?'s
- Need help finding flanges for my turbo(pics)
- Will this set up work??? b18c1,jrsc jackson racing supercharger.
- Fuel line/regulator question.
- What crank for my 84mm B18C?
- 94 AWD Mirage, 622whp, 567tq, 93 octane, alcohol injection...
- Sorry but...
- how to turbo my b18b?
- Check this....never seen it before
- Revenge Motorsports in El Cajon CA does nitrous oxide refills
- Plans for turbo setup.. Comments?
- J/R, hondata IM gasket issue
- Suggestions on caoting for manifold & exhaust housing
- New bigger/better setup = Less ET/MPH/Power?!?
- 10k+ rpm turbo setups?
- Turbo kits for H22a in EG...?
- building b16 block
- How much boost, on JG straight sleeves 84mm B20
- building turbo f20b
- turbo question
- White cloud of smoke while boosting...PLEASE HELP!
- rocket m22xx... boost
- Some boost questions from HOLLAND :)
- 5-600whp Competition Clutch question
- getting no oil from turbo feed line
- turbo stuff
- 14b turbo
- boost on a c5
- Using obd1 ecu on an auto obd2 civic
- stock bore versus scratch????
- H23 NO START
- all motor turbo cams
- Supercharged and turbocharged?
- Stripped head bolt....Switching to an accord M12x1.5 bolt????
- boost sohc turbo wont start?! searched, not your typical problem...
- Opinions please.
- Anyone interested in a 500+ WHP Supercharger Kit?
- Full race downpipe used for AFI ramhorn???
- HELP DA EXHAUST QUESTION
- What can I do to my stock 95 civic?
- What should I get for my b16 turbo setup.......??? Help me......!!!!
- Supercharged GSR ?'s
- Tial 44mm wastegates, What spring do they typically come with?
- Rev hard manifold screws. What size?
- Bore or Hone New Pistons?
- does bov blow off with boost leaking like crazy?
- wastegate springs, psi question
- Average cost for tune?
- This is why I always use loctite!
- Nitrous plug gap h22a4
- BIg throttle body question
- buildin a gsr block for boost need help!!
- will a 27*6*3 FMIC FIT?
- 421,7whp 20psi B18
- h22 diameter piping question
- which other spark plugs are good for turbo'd hondas other then bkr7'S?
- Using apexi power fc with forced induction
- used rods?
- JRSC + PW: JDM Intake??
- turbo or allmotor?????????????
- 02 Bung Close to the turbo..
- type s vs blitz bov
- Anyone Near Bloomington or Indianapolis that has tuning Equipment?
- Treadstone Performance Turbo Kit
- T3 turbo question...do i plug this?
- Heres my set-up..what you think?
- Need Diagram of JRSC
- jrsc'd da??
- Big turbo small bore
- Ring gap??? .030!!
- Got my Ls v Dynoed at DNR Performance
