View Full Version : Forced Induction
- can i use 460 rx7 injectors on honda?
- oil pressure light
- Custom Turbo help please
- Whats a good 3" inlet turbo muffler?
- Integra question
- How much is this setup worth? Ballpark figure.
- Who to send block off to? Searched*
- Whos using aem ems v.1.03
- simple turbo question ...
- What's missing in my setup
- Greddy oil filter adaptor plate - thread sizes?
- fittings for garret turbo
- why cant you run big cams with a turbo?
- Building a sohc turbo.. What are your combos/ dyno numbers?
- stock fuel press for 01 ls?
- Greddy E-Manage on a OBDO 90 Civic
- Which Spark Plug Wires? Stock or aftermarket?
- Turbo plugs part numbers?helppp
- Majestic Turbo
- Car studdering at higher rpms...
- EMS question
- Turbo Spec's Compressor/Turbine A/R's
- newbie help!!is anyone selling obd1 inj clips?
- Turbo/Motor "Dial In"
- TURBOcharged STOCK or STOCK sleeved motors! lend me your rears
- New Dyno In New England.
- off topic, how do I become a member and not a trial member?
- Search is down....help me with log mani choice
- ITR Sleeves Question
- Will I need to re-tune?
- When buying Hondata, wich options r a must?
- Buying a Greddy turbo kit for my jdm d15b
- Tilton single disk
- When going from 8psi to 12+ on the Drag turbo is it a huge Difference bc of efficiency?
- overheating problems..
- Piston Weight
- which fpr?
- cheap but reliable turbo kit for b16a CRX
- Crower Cams?
- can i see some side mount IC?
- Please Help ME?????? My spark plugs wires are Jumping.
- BLITZ DD BLOW OFF VALVE..
- Daily driven
- Specific questions on super chargers
- custom manifold in orlando?
- Largest turbo with Log manifold
- how can i clean greddy turbo air filter?
- Anyone port their compressor housing? results, theory, input.....
- Creating a Downpipe with Ecutout (Which Design is the BEST???)
- HELP TURBO'D BUT NO BOOST! HELP!
- Tuning experts i need some help...
- Flat spot in first
- EFI Fuel System....
- Turbo Bang Bus
- How much can I safely bore out my B16 to?
- How much power is this IC capable of supporting?
- An Uber-E-Turbo? Maybe...
- PSI?
- B16 Main bearing and rod bearings don't have a color anymore?
- vafc+680's?
- New Pics added to "the build"
- panda engine
- boost and vafc question
- Biggest Intercooler on an integra?
- can i safely turbo my itr?
- lovefab shorty vs. drag
- short video of tinker219 srt4, i hope?
- $30 Breather / Catch Can ---- Opinions
- cam gears on stock r cam shafts
- PLEASE HELP!!! CEL 1, 5, and 45 after turbo install
- tuning with hondata
- Talking about the "Hondata Intake Manifold"... I got a ?...
- motormatrix.com?
- Carbon Fiber charge pipe: Update
- The Ultimate Sleeper?
- oil feed with cooler setup ? >>
- lovefab vs full-race
- Any good Hondata tuners in the va/dc/md area???
- where can a buy just an act hd pressure plate? not the whole clutch kit.
- New to Boost, Teach me please - Wastegate Q's
- is this theory correct
- Quick Inline fuel pump question...
- Stupid ARP head stud question..
- Best Built and cost?
- what numbers? b16a
- Difference Honda NTK sensor and Bosch LSU Sensor?
- I wanna' get 200whp, what else do I need...
- A little help needed.
- Blown motor analysis
- AEM EMS tuners in alabama or southeast
- are eagle rods any good for turbos
- What size intercooler piping for my setup?
- T3/T4 60-1 HIFI IS ANYBODY USING ONE OR CAN U GIVE ME ANY INFO ON IT
- Switching Exhaust housings on two turbos??
- full race turbo kit on a b20
- HF manifold gasket substitue
- how would a MSD ignition improve my idle on a turbo honda (ZC)
- BOOST GAUGE READING?!?! 64.4?
- Physical difference between Honda and DSM injectors?
- Little nipple on wastegate actuator
- What do you think of this turbo?
- Best management for low boost 7lbs. ?
- Fuel Pumps.... in tank 255 walbro/holley.... should i ALSO use an inline?
- What mainfold???
- ls turbo motor pic....
- What do you guys think about this adapter plate?
- HONDA-TECH MEMBERS GET DSCOUNTS FOR EFI UNIVERSITY!
- Need advice on a possible setup
- WHY oh WHY!!!!
- Anyone heard/use ACL rod and main bearings?
- Helicoil or larger head bolts?
- Turbo questions regarding H22 5th gen Prelude...
- missing link Q's...???
- Lags in first
- JRSC and N02
- Water pump for Liquid to air - where?
- will this work?
- how long does precsion take?
- need advice: planning to turbo my B16 b ctr motor
- Stock Prelude H22A Tranny
- Turbo AUTO transmission HELP!!!!
- Setting V-AFC wit Turbo B16a
- Compression Drop!!!
- engine build up on an h22a1
- Oil Supply Line to Turbo
- ANY NEW DEALS FOR THE NEW YEAR?
- So many choices, not hardly enough money...
- Fitmentwise, which johnnyracecar/ tyrus intercooler for 96-98 civic?
- daron iron ductile replacement sleeves?
- turbocharging stock ZC
- *repost* Intake manifolds - best for high boost applications?
- Intake manifolds - best for high boost applications?
- Turbo parts are on the way........ THANKS Ben @ Importparts !!!
- B18c5 + Full-race turbo kit, some Q's on driveability at low boost (60-1 or 60)
- How does this sound for a new setup?
- civic hb w/ a h22 turbo Specs and questions????
- TurboSmart Fuel Management System
- AEBS Head Stud Question
- How Much Nitrous Can the F23 take?
- lighten flywhee.....crank pulley issues
- flooding/not firing after walbro 255 install
- JRSC for 94-00 gsr's Safe boost Pressure opinions?
- How much power
- Turbo comparison- T3/60-1 vs. SC61, educate me!
- Boost on stock internals
- 4 bolt vs. 5 bolt dp?
- Looking for the most streetable clutch with good pedal feel for just 250 lb. torque
- b16a with sohc greddy kit, can i up the boost?
- surge tank idea?... (searched)
- What flywheel shall i buy
- What do I need to not get a check lite at 18psi??
- broke my 3 bar. help>>
- zex bottle heaters Good?
- Worth switching FMU
- check engine code?
- Tang/divided vs. Tang/undivided
- I NEED YALLS EXPERTICE
- Very weird problem, I have no idea what just happened!
- Question about Hondata and timing?
- Is this Turbo Manifold any good for D-Series??
- PLEASE HELP!! HONDATA W/ MAP SENSOR???
- Please Help! ECU Fuel Management System help! Hondata s200 vs Greddy Profec E-01
- How to read EGT gauge
- What fittings to get?
- crower econos vs. eagle 900hp rods
- electric super charger that work what do you think (no gay boat pump)
- anybody try this clutch disc?
- The build...........................
- Old pics I found...greddy SOHC turbo install, 97 Civic EX
- How much nitrous can i use on my new setup?
- wiring black box with dx harness
- plane head to raise compession????
- torqe specs on arp head studs b18c1
- newb to advanced car mechanics, compression question
- Carbon Intake manifold VS JG Edelbrock
- Pic request for SMIC's and Piping
- What did you like about YOUR first time boosting or feeling boost???
- Raver Motorsports
- DSM Injector and Fuel Management help needed
- need a precision sc61 compressor map
- Engine build up: 2nd gen crx, b16a, vortech SC.. would like suggestions..
- TurboXS RFL or Blitz Bov..
- white smoke when i come to a stop..sometimes
- blown zc from turbo.
- what does a missfire feel like?
- Not Honda: Cylinder Block Sleeving Experts
- greddy gauge questions????
- I think I blow'd up my motor....
- Anyone used a techedge 1.x? I think its a 1.1.
- check out what i made
- 3 bar open loop voltage??
- Noob booster.. custom kit, suitable?
- skunk 2 vs crower
- intercooler end tanks
- Can someone give me a run down of what Uberdata is and how it works?
- to4b vs. to4e
- nx new maximizer
- 2 dyno comparisons, need explanation.
- Noob question
- Mods plans for 04'?
- Garret T04
- happy new year
- MotorMatrix.com ..........
- how come nobody uses blitz bov's ??
- Found a motor?
- MSD Inline Fuel Pump Vs WALBRO 255 FUEL PUMP
- what do you'll do to provide a positive airflow throw your crankcase
- Got my Lovefab manifold!
- Best cam for turbo D16Z6?
- Engine stress question
- DO I NEED ENGINE MANAGMENT???TURBO CIVIC
- When installing forged pistons and rings quick question!
- What dsm injector can I use on my crx
- Anybody here run a solid read mount on G3 Teg??
- JRSC belt keeps jumping one tooth on SC pulley?!?!
- DELPHI INJECTORS?
- '04
- SPRING BOLTS V.S. FLEXPIPE
- Flamenco-T's oil line kits. Good price???
- MaxRev manifold with Tial wastegate.
- Quick couple of questions about turbo accessories........
- funny smell and white/gray smoke
- please analize my setup
- New toys....
- Hesitation/fluttering after walbro 255 install.
- Inventory of JRSC gsr kit
- Will lowering my fuel pressure make my POS start better?
- Coolant Lines??
- Need some help from the Love Fab guys.....
- new issues with turbo d17
- Rebuilding engine for Turbo
- 16g/SOHC
- Help me make a decision.......build my b16 block or build ls/vtec...both fully built..kind of long :
- Status pics of my ITR, shes almost ready to be fired up
- Happy New Year!!!
- question about AFC
- What modifications are needed to run DSM 450cc injectors in a 96 Civic?
- MSD with turbo?
- Car wont start...PGM-FI main relay fuse keeps blowing out????
- Here is a turbo we would all like to use!
- What could be causing overheating under normal driving and not at idle?
- is a 80 shot and 8 psi the same?
- Cheapturbo.com's newest 300hp club member... (sorry 56k...)
- tial BOV fit on DSM flange?
- HELP How to wire 4 WIRE universal o2 sensor
- Cams for turbo LS...?
- boost
- nitrous on a chipped ECU
- GSR 3rd and 4th gear in LS Tranny
- I dont know what model AEM EMS to buy
