View Full Version : Forced Induction
- IM looking for high qulified engine bulider to build my d16z6
- dsm and nippon denso injectors need help !!!
- Please Help Me Decide!
- What size thickness headgasket to get
- car wont boost over 6psi? wtf
- whats a good turbo cam for jdm d15b
- Changing Intercooler Require re-tune?
- Clutch?
- precision 6265/6765
- What turbo ??
- need help identifying my turbo please
- whats a good site to buy an exhaust sytem?
- Turbo help please!!!!
- How much boost can I run?
- Need Help!! Car will not go into boost, and is running very rich
- do i really need a wastegate?
- what pistons are these?
- Multilayer exhaust manifold gaskets?
- b18c supercharged
- LS/VTEC turbo trouble HHEELLPP
- MY CIVIC HAS CHOPPY/SKIPPY IDLE?
- B20 vtec turbo dyno problems
- need help on soleniod?
- exhaust diameter for jrsc poormans type R
- Help Needed: Daily Drivable Turbo S2K
- Good tuners in Austin and Houston TX?
- Opinions on Crome please!!
- Why does the integra type R make more power then the GSR with a supercharger
- new to turbo help plan build
- Noob Turbo Question...
- Are any of the CXracing and/or "ebay" turbos rebuildable?
- NEED HELP EBAY D16 TURBO KIT
- New to b-series! good for boosting?
- T3/T4 vs GT3071R for 450whp?
- Even more Tial MVS fakes on eGay
- Has This Happened To Anyone Before????????
- JRSC with FMU 6psiOK
- Can I run nos or small turbo
- RUNNING WAY TO LEAN
- C/R for boosted jdm gsr
- Recommendations on internals for boosting my b16A
- New car, shot intercooler, ebay replace? low hp/psi setup
- Which turbo is better!
- RC injectors shorter then factory?
- T3 K27 turbo good for lsvtec
- Golden eagle vs elderbrock vic X intake
- DSM turbos vs Garrett GT ball bearing turbos
- My B16 Turbo Build w/ Pics, Updates & Questions!!
- looking for some Turbo advice
- precision turbo smoke?
- Injector sizing...B20,JRSC,E85, and nitrous
- Corn-fed Stock K20A2, Full-Race, T67 (DYNO)
- B16A Turbo Setup - Max power on stock crank ?
- Best turbo for 450whp
- what turbos can replace a t3/t4 setup
- turbo d16z6 in a 96 civic ex VAFC build
- T3 50 trim Vitara build d16z6 dyno results
- Fuel Rail Bolt Thread Pattern
- intermittent very rich condition. unknown cause/trigger
- Built Turbo Car voltage problems
- Has anyone done any side by side testing on Mishimoto intercoolers?
- heat issue, some options please
- Your feelings on this turbo kit? (b18c1 stock)
- Custom Sidewinder Manifold, 6262SP Build S2000
- Can someone help me with ideas for a turbo setup?
- Please HELP! Injectors wont fit???
- turbo leaking oil
- Running Lean Past 10psi, Tuned for 14psi
- top mount with 6765
- Boost creep issues
- B16 turbo build suggestions...
- buddy club spec III cams on turbo?
- turbo gsr bore ?
- intercooler/head gasket question
- whats better 1000cc injectors peak and hold or saturated
- catch can
- where to buy a evolution wg valve seat.
- Hols in Florida and no boosted Honda's in sight.
- I need the third-gear 1.346 of ZC DOHC Trany!!
- I need help/info about clutches for turbo B16A.
- Blox B cams
- nitrous
- ACL's vs OEM Bearings
- 880cc injectors too little?
- Can I drive 20km without a downpipe?
- d16y8 turbo
- 2000 Si Turbo IAT Questions
- aem 2 hondata ?
- civic eg turbo help with 60ft times
- Boosting my friends DOHC ZC. advice/opinions wanted!
- Adding wastegate flange to non-wastegated manifold?
- E85 guys help me out
- Reading spool from a dyno chart
- Turbine housing selection
- V-tec engagement
- Need help! Compression on a b18c sleeved_bored to 2.0? (searched)
- got my car tuned
- Boosting a B18c
- Turbo D16y5 172whp-163tq
- Stock Turbo GSR what oil? (searched)
- which coolant hose i connect the feed and return?
- tuning d16 turbo with crome free
- Internal wastegate vacuum
- Race Gas and Pump in same tank?
- Best turbo for my setup
- help need turbo install socal
- where can i get a good turbo kit?
- homemade dumptube asap ...
- boost scramble?
- b16 head with skunk2 internals????
- Quick Question
- Moroso barb fitting?
- new to boost..is this temp reading normal?
- Misfire between 3-4 K tuners help!>!>!
- blown-itr...turbo?
- B series block plug
- injector question
- B18C4 turbo, Fast at night but slow in day?
- EK Kswap with Rotrex
- white smoke turbo d16 intermittent
- JRSC - HELP!
- Lst overheating
- Stock d16z6 boost build
- new kit will i hit my power goals?
- arp head bolts
- diff. boost pressure in 2nd than 3rd?? creep??? help!
- b16 oil pump
- valve train for 700+hp
- alcohol vs intercooler?
- Anyone use an aerocharger before
- Seeking to hit 500 whp. Input please!
- catch can question..
- D16z6: Bullseye 57trim Turbo & E85 Dyno Tune
- HELLO FROM UK BOOSTER!
- KIngs Performance S2King NEW DYNO Numbers!
- Gauges
- aem wideband help datalogging
- Ls turbo questions
- Precision Turbo?????
- poorman type r ...which headgasket and timing belt?
- so my car is tuned...how do i add to power?
- stock d series axle hp rating
- Need Help Please. 09 Civic SI With JR Charger Need Injectors
- new to honda modding want to build turbo crv
- water in charge pipes cause pinging sound?
- Turbio guys, need help with a TT
- tuner help on b16 turbo project?
- Passing emissions with a d16y8 turbo?
- looking to source centrifugal supercharger
- S2 Mani on stock gsr-t..choke my numbers?
- A/C friendly downpipe clearance
- 325 whp @ 9psi
- precision 39 mm?
- The Del Sol Build That Seems To Never End!!!!!
- Injector driver help (2sets of injectors)
- 300 Whp integra
- what boost are headstuds a necessity
- 300 WHP INTEGRA GSR
- 500whp b16
- gsr turbo question
- out with d16y7 in with d16z6
- curious about my ecu while trying to tune...
- need help fast!!!!
- Skunk2 Pro series 1 cams...vtec not right
- walbro 255lph good enough for 550 bhp?
- Dam these things are small
- 2.5" to 3" turbo outlet downpipe
- sorry Turbo nooob here.
- fuel cell with e85?
- godspeed topmount turbo kit..
- D16 Injectors
- Noob turbo question
- b16 500-600hp which cams
- A/C compatiable mini ram???
- TURBO TYPE R BACK TO LIFE
- 500hp Daily with 8.4:1???
- M&W Pro 10 Wiring....
- valvetrain setup
- need help, no spark, really wierd
- manifold with AC
- -3an line with restrictor
- injector size
- how will tightening/loosening hks ssqv affect sound/performance?
- B16A Turbo Build
- JRSC Fuel Enrichment Relay Q's?
- Anyone ever run into this with file fit rings....
- Will never deal with BullsEye Power
- p28 Hondata s300, can't pass 1psi boost..?
- Problem With turbo anybody else had this happen???????
- timing belt skip
- Boost + IAT question
- Turbo b18a1?
- Best Stations in cali to get e85??
- Opinions & suggestions needed for my homemade catchcan & crankcase vent.
- spooling a t70 turbo?
- Is there any sort of manifold comparison thread?
- H22 to H27 91mm Bore Turbo setup
- Shooting for 500whp
- PITA day + Blown Snail :( Recomendations
- got my car tuned..question about my boost controller.
- Full-race ramhorn vs neukin or spooling performance
- Top mount mani?
- intake manifold or ITR cams?
- Lebanon Valley NHSWAPS13203 track rental
- Check engine light is on HELP!
- Power increas from dx exhaust to type R or rsx
- Turbo setup, this is gonna take a while
- JRSC and Nitrous Questions
- How to keep a/c
- Turbo/exhaust sound muffling question
- obd1 o2 simulation settings
- Best sparkplugs for 320whp civic ls/vtec
- first time gsr turbo start up...problems
- video of a very nice turbo civic in the making
- Precision Turbo Problems
- my nitrous'd b20 build thread w/pics
- Turbo Info
- oil dipstick problem
- Anyone else having trouble getting ahold of JDL Auto Design?
- Compressor Surge or WG Flutter?
- Considering going turbo.
- turbo gsr keeps shutting off....Help please
- Nos jet chart...
- Installed Go Autoworks Turbo kit now overheating???
- stock head gasket?
- What spark plugs are you running?
- Smoke in air/bad for engine?
- Zdyne Software. Please help!
- is this good enough?
- Re-welding open manifold to divided
- B20 VTEC - Garrett 57 trim - E85 Dyno Tune
- Where can I find the 'newer' style of the Garrett intercoolers? (Pic Inside)
- Wants to build and turbo my d16z6
- T4 flange: whats my best turbo option
- b16 FI questions
- Injector Resistor Box
- Such thing as the "wrong" flexpipe?
- Wrong turbine housing? Need turbo experts
- WTF WITH MY R - HELP PLEASE
- 2003 Accord Questions, turbo? im lost
- Exhaust setup on a boosted LS-V
- dynojet setup...dyno operators chim in please
- Catch Can Question
- The "Best" Pump Gas?
- s300 question
- WTF WRONG MANIFOLD WHAT DO I DO NOW?
- Boosted GSR - New Member - Need help...
- changing chra from turbo?
- Mickey T Fender Modifications??????
- Help with gm 3bar map
